View Full Version : 5.0 Mustang
  1. thermostat housing problem
  2. multi-function switch
  3. Peeling front bumper
  4. Overheating??
  5. Hooking up A Wideband
  6. Thanks to adderMK2, dizzy is in but....
  7. 1.7 VS. 1.72????
  8. Just wondering
  9. 1986 - 1993 vs 1994-95 h pipe Q
  10. 1984 5.0 mustang exhaust and cam decision
  11. electrical short in dash gauges??
  12. TIMING PROBLEMS?! HELP!!!
  13. Flushing Coolant
  14. GT Headlight Switch
  15. no fuel pressure at carb
  16. Doing a 1990 LX 4 cyl to carb 302 swap...
  17. X pipe w/ cats question
  18. Electrical problems...
  19. stock motor?? Will it run on 90mm mass air?
  20. weird smoke issue
  21. Why do they say not to run synthetic in new engine?
  22. 347 burning oil HELP!
  23. Water pump/Bolts
  24. 91 gt very strange wont start
  25. Problems Shifting
  26. 94 GT BBK LT's how much lower will they sit
  27. 92 Stang Don't want to Kick over?
  28. Car don't want to kick over/ No spark
  29. ERV Is messed up. Help!
  30. smokin exaust in 2nd gear
  31. ignition break-up?
  32. PCV valve/crankcase issue
  33. tire size abilities?
  34. 89 gt,need help,spark plug gap?
  35. 4 bank SCT chip....problem
  36. Engine won't turn over sometimes...
  37. Clutch Fork Issue
  38. intake manifold question
  39. Piston rings or valve seats? Got an oil eater here.
  40. Looking for a body kit
  41. What to run for internals
  42. Help passing emissions...just failed
  43. thinking im going to pushrod
  44. electronics problem?
  45. Electric Fan Install Question
  46. running nitrous line
  47. emmisions
  48. hmmmmmmmmmmmm cant get the cable out
  49. Options for new engine
  50. Mechanical or Electrical Guage?
  51. Windsor Jr. Heads and Which Headers?
  52. 82 gt flywheel?
  53. Pulling the vavles, help
  54. Stall When Hot
  55. Freaky Tach
  56. 5.0 vs. 5.0 HO
  57. which maf?
  58. NEED HELP
  59. bent core support
  60. Oil Pickup
  61. molding????
  62. speedo not working
  63. Oil Level Sensor
  64. lock lug nuts
  65. tv cable..help me
  66. Drive Shaft bolt what size socket?
  67. Clutch/Trans problems
  68. C-4 SHIFTER
  69. Studdering when turning left ONLY
  70. cleaning headlights/tailights?
  71. Is this worth doing????
  72. Dizzy question
  73. SuperCharger
  74. Guys Really Need Some Help 4 Days on this
  75. tansmission help?
  76. egr tube
  77. Belt size?
  78. Losing Coolant from behind the water pump.
  79. My car has NGK plugs
  80. UPR products
  81. Overheating
  82. car dieing dont know why....
  83. Parking brake adjustment
  84. what size
  85. OVERHEATING!!!!!
  86. Question about head size.
  87. replacement radiator
  88. Installing rear axle bearings
  89. Supercharger Help
  90. stock intake flow
  91. Front Cover/Timing chain...
  92. Front suspension ?s
  93. throw out bearing?
  94. Plug Gapping?
  95. Best place for manuals and...
  96. a/c delete....
  97. Maybe an Exhaust leak?
  98. Somewhat stock exhaust help
  99. New to cars, looking for advice!
  100. overheating
  101. alternator fire
  102. holley systemax 2 intake
  103. HELP WITH EBRAKE
  104. Head choice and porting stages?
  105. Steering Rack ??
  106. New Clutch
  107. just got fuel pump quick question
  108. question about 351 heads
  109. 89 Mustang AOD Spline Count?
  110. BBK Shortys and bolts
  111. map sensor
  112. burnout
  113. Replacing my Steering - help me
  114. Best Performance Upgrade For The $$$
  115. My '95 Crapped Out Today!!! Help???
  116. T-5 to Tremec t-5 swap
  117. speedo gear
  118. quick help please!!!!
  119. Broken door handle
  120. CAM & CAM GEAR INSTALL
  121. AC is only coming out of defroster vents Need to figure out why.
  122. Lakewood Bellhousing woes
  123. Need Help With Long Tube Headers
  124. Exhaust ideas plz help.
  125. fuel pump issue
  126. Best suspension.. eibach pro kit..
  127. 02 GT Rear ---> 85 Fox
  128. Spark Plug wires arking?
  129. intake manifold decision
  130. need help on intake manifold decision
  131. 94 dizzy in a fox
  132. BBK fuel pressure regulator leaking through vaccum port
  133. 24 lb injectors
  134. shocks and struts
  135. HOW HARD IS IT THE PUT MANUAL TRANNY IN AUTOMATIC CAR?
  136. temp sensor
  137. o2 harness extensions
  138. Any thoughts on using MLS head gaskets with
  139. Is this too hot?
  140. reinstalled my dizzy
  141. Need help on GT40 Heads?
  142. Oil pan questions
  143. Got a problem, what did i break now?
  144. Water temp problem
  145. JBA headers and JBA exhaust - comments?
  146. Differential may be blown?
  147. t-5 to 3550 swap
  148. My buddy may have fried his computer
  149. koeo results not right?
  150. Transmission Issue?
  151. Need help asap on Harmonic balancer
  152. best heads
  153. newbie with questions
  154. why dont i have fuel pressure above 4k
  155. Steeda adjustable clutch ???'s
  156. 3G Alt Upgrade - Do I need these parts?
  157. LCA Question for Everyone
  158. Loss of Power etc... 1991 LX
  159. Installed rack bushings - steering shaft too short
  160. Turning Signals Dont Flash?
  161. check engine lite
  162. bent torque boxes?
  163. quick question
  164. demon carb ?
  165. injector+ tb
  166. tb+ injector question
  167. rotating assembly
  168. 7.5 to 8.8 rear swap
  169. converting to maf How???
  170. Bad overheating problem *need some help*
  171. 94 GT Dies Randomly when at operating temp
  172. My hood came up while i was driving
  173. BOltons on speed density?..
  174. Speedometer hookup on t5?
  175. Mini Starter Problem!
  176. loud bang from the right rear side
  177. fuel problem
  178. stock rockers
  179. 275/45/17 tire question
  180. top end kit
  181. rough idle
  182. Porting Stock Heads
  183. Head question
  184. piston/rod question
  185. stall problem
  186. high idel 92 lx
  187. 86 gt....not reaching full power/rpm
  188. Horrible Gear Grinding When Reverse
  189. Question about stamping on ring gear
  190. 10 or 10.5 wheels with 46mm offset?
  191. a9l computer
  192. I pulled four engine light codes... not good?
  193. Clutch Issue?
  194. 93 cobra questions
  195. 5.0 help needed!
  196. Lean Code -172
  197. Cfi to carb questions
  198. cars first start fuel problem
  199. Trouble In Paradise
  200. Got another cooling problem
  201. mustang has a jerk at lower rpm's
  202. Now i'm tired of Sti's help me.... plz
  203. 88 lx window trim
  204. how to fix the cowl panel
  205. looking for first gear and slider
  206. engine squeal
  207. inconsistent fuel pressure
  208. Lots of smoke
  209. Heating Issues on new motor?
  210. Proper 5.0 emblem location
  211. Professional Electrical Help PLEASE
  212. 87 5.0, couple of questions! help
  213. will this work
  214. More disk brake conversion questions
  215. battery dies
  216. KOEO/KOER results/help
  217. Mass Air Flow Calibrator help
  218. by passing air pump
  219. 351 heads ?
  220. intake
  221. rim/tire on a sn95 rear in a fox.
  222. Convertible top problems
  223. Random little gray plug near upper right of motor.....?? hlp?
  224. 89 GT Lack of power, Help!!
  225. Why do I change the timing?
  226. Clutch cable let me down on the way home
  227. swapping t5 for a 3550
  228. Drive shaft removal
  229. EGR question
  230. Oil Pump Drive Shaft
  231. Oil Seperator
  232. 1995 Alignment problem
  233. smoke
  234. Herky jerky
  235. anybody tried this
  236. Help With First 5.0 Rebuild
  237. Throttle Body ???'s
  238. XE258HR-12 with stock pistons?
  239. bad regulator?
  240. 351 vs 347
  241. 84 SVO front rotor and hub assembly on 1980
  242. In Search of 4 lug wheel spacers
  243. Clutch removal: Please help
  244. ac
  245. Whos running underdrive pulleys??
  246. Transmission Cross member question
  247. t45 or t5
  248. will this cam work?
  249. couple of 351w ?s
  250. Supercharger
