View Full Version : 5.0 Mustang
  1. difficulty level pro 5.0 install
  2. fuel pump
  3. 4cyl t5 and 4:10 gears?
  4. Finally Installed!
  5. Potentially looking at getting a fox body, coming from DSM's...
  6. Help with guage question ???
  7. auto trans question
  8. AOD tranny
  9. exhuast help
  10. fuel pump
  11. Angcobra 5.0 Block Broke?
  12. override transmission
  13. running rich question
  14. spark rattle???? this is weired
  15. O2 sensors
  16. Convertible top..??
  17. Rear End QuesTion..??
  18. Exhaust Question
  19. C-6 trans question
  20. Intake manifold?
  21. GT40 INTAKE OR TRICKFLOW
  22. gasket help!
  23. exhaust project going well
  24. The never ending Head thread
  25. Rear seat removal
  26. ignition question for dummy's
  27. Fuel pressure setting
  28. line lock?
  29. oil pump change while engine in car
  30. 4cyl springs ???
  31. prochamber or upr x w/cats
  32. got my motormounts, now how do I put them on? with pics
  33. where can i get a chp kit or a scat 306 kit
  34. clutch cable installation problems.. *QUICK HELP*
  35. Fuel pump location
  36. a little belt info
  37. Cooling problems, it's never ending with this car! Need help asap
  38. auto 302-stick351 carbed?
  39. quick gasket question
  40. Your thoughts
  41. Getting Ready For Inspection. Quick Questions!
  42. Ok, I really need help with this..
  43. knock problem
  44. Help me identify my weird rev squeal please???
  45. VALVE NOISE? OH NO
  46. new dyno numbers Update
  47. stock timing?
  48. Starter grinding
  49. repainting my taillight housing. what paint
  50. Lifters
  51. New Starter and Silenoid - Still hangin up
  52. HCI Finished - Car doesn't want to idle stalling out*Updated Pg2*
  53. Fuel pressure/ PCV ?
  54. what tire pressure to run?
  55. Stock splash gaurds on an LX (removal?)
  56. dss ?? to buy or not to buy
  57. any auto guys run this shifter?
  58. fried clutch?
  59. Besides the battery, where else can I hook up the horn for B+?
  60. exhaust decesions..
  61. Distributor from a 351? Also, camshaft?
  62. Alternator pulley diameter.
  63. is there a diagram for this?
  64. MOVED: cj pony parts car show??
  65. Throttle Body EGR Spacer
  66. Tranny???
  67. 1990 Mustang trans question
  68. centerforce clutch opinons
  69. alternator issues
  70. Neil Erickson Midwest Induction GT40p
  71. stubborn speedo cable
  72. air conditioning removal
  73. 5.0 88 VERT TO 93 NOTCH TECH HELP
  74. factory tach
  75. fuel starvation ????
  76. Will '87 up taillights work on an '85??
  77. weighed my car today
  78. Ongoing issues, car keeps dying
  79. New Clutch
  80. Question on offroad x or h pipe?
  81. quick clutch question??
  82. cleaning injectors
  83. MAF Question
  84. Would this cause my massive loss of power?
  85. rocker arm?
  86. NEED HELP!!!
  87. Small cap HEI dizzy
  88. still got issues
  89. Digital Dash - Fast & Furious style - UPDATE
  90. Where do they go?????
  91. over heating
  92. Does Anyone Know???
  93. puffin
  94. what is this thing?
  95. quick clutch question
  96. New N/A 331 dyno plot inside
  97. 93 gt rear disc brakes
  98. What to do next?
  99. rear end rebuild
  100. Looking for a smoother ride
  101. 4 lug rims
  102. Cars getting hot, no overflow?
  103. MAF Meter question and timing
  104. Weld draglite question
  105. Changing Dash lights to colored LEDs
  106. Tuning Your 5.0l
  107. What Torque converter?
  108. help with completing h/c/i
  109. CARB. ISSUE
  110. Max. Rear Tire Size
  111. Need help with wiring
  112. Installation Kit Required?
  113. Terminator Radiator In Fox
  114. Brake Calipers, 93 rear disc caliper piston!
  115. 75 amp bosch relay
  116. 351w Flywheel Question
  117. hesitates only with a/c on
  118. ECU problems
  119. Throttle response is a bit laggy...
  120. 94 timing
  121. huge miss until 3000 rpm
  122. Does this seem right? Temp question
  123. Nitrous problem fixed!
  124. MOVED: Salvage 89 gt 5 speed
  125. no compression
  126. painting my 88 lx hatch?
  127. k member help!!!
  128. 347 stroker question?
  129. carb ideas for a 400m...
  130. clutch adjustment???
  131. HIGH volume oil pump question
  132. Heads/cam/intake
  133. 1993 5.0 Detonation after 3000 rpm
  134. rocker arm fell off
  135. idling problems
  136. lacking oil pressure
  137. pinion shaft retainer bolt?
  138. i need colder plugs what which do i need
  139. 400m into a 86 lx hatch
  140. Front Struts
  141. Stupid Question on 50 shifters
  142. Cobra grill insert
  143. Acceleration problems..
  144. When it rains it pours
  145. rich/lean issue
  146. 5 lug questions...
  147. clutch quadrent
  148. 95 mustang cobra Q
  149. manual steering rack
  150. any1 know if a '96 cobra exhaust fits a fox?
  151. White saleens in 4 lug?
  152. Anyone running gear drive? Any sound clips?
  153. Clean hatch?
  154. Help w/part #
  155. what are these
  156. SN95 Suspension Upgrades
  157. which would look better
  158. neutral safety switch need help
  159. quick dumb easy question.
  160. Starting to build up my 93 LX
  161. what could cause this
  162. removal of E-brake
  163. 5 lug aftermarket axles
  164. Front Oil Leak
  165. 86 mustang inexpensive performance mods
  166. Water temperature
  167. loss of power after h pipe???
  168. What rear end is it?
  169. anyone running a 7.5?
  170. I'm down to BBK or Cobra Intake....
  171. Bracket for rear speakers
  172. BBK equal length headers
  173. Heater tubes can they be removed?
  174. help!!!!
  175. rims???engine?
  176. Turn Signal Problem! HELP!
  177. tuning fuel pressure regulator
  178. $650...what suspension should i buy
  179. How much vacuum should I pull at idle?
  180. gauges
  181. rear main seal... replaced and finised
  182. codes?
  183. Questions about the 5.0, some problems.
  184. driveshaft
  185. cranecam coil fire ball ?s
  186. which would be better for the steet?
  187. moving radio to new position
  188. this might sound dumb but
  189. 94-95 maf
  190. police interceptor?
  191. pulling a fender off
  192. finally got the car tuned
  193. Is it time for some new tires?
  194. SLP Loudmouths
  195. damn vacumm leaks
  196. 5lug conversion/brake ques..
  197. Air works! But speedo doesn't...
  198. difference between modules
  199. What's this for?
  200. What's your thoughts on springs?????
  201. 351C fox
  202. Help! Noise coming from clutch?
  203. 96-98 taillight harness
  204. Mass Air Sensor ???
  205. What is this Mustang Worth?
  206. egr
  207. Locking Header Bolts
  208. Which intake?
  209. 1992 power window problem
  210. pulling codes
  211. TPS voltage
  212. thumper e7's
  213. Drag Radial NT555R Help
  214. Head swap with Kenny bell s/c
  215. question regarding air bag..
  216. WHAT ELSE CAN I DO
  217. 82-85 saleen wheels?!?
  218. upper and lower arms ????
  219. gaskets for hci swap
  220. timing chain
  221. Another Gear Question....
  222. Md Cruise Sat Aug 25th
  223. power upgrades
  224. HCI 99% Complete - Help with last line! *NEED HELP!*UPDATED**
  225. 3G vs 6G alternator
  226. Where does this ground wire attach?
  227. 1992 turn signal flasher unit
  228. 347 parts list
  229. My new ride!
  230. Got a Problem...
  231. 95 5.0 spindles, rear end (5 lug) to fox body?
  232. Turbo Questions
  233. pulled codes, now what?
  234. BBK fuel pump noisy
  235. what is this?
  236. need help with my 88 5.0
  237. p/s
  238. Question, 83 'stang
  239. rear end gears
  240. NEED some help here
  241. To the Mustang gods
  242. gear and tire question.
  243. Next Mods
  244. speedo stopped working
  245. Hatch vs. Notch
  246. going to carb!!
  247. More blower and vacuum questions **one vent is working!
  248. turbo kit
  249. Fuel pressure is the same with vacum on and wiht it off???
  250. hook up low oil pressure light? using shift light
