- oringinal styled wheels?
- Power steering control valve
- 69 Power Brake Booster Changeout
- Radiator question
- Timing.. Joy
- 3 point seat belt installation for coupe
- Instrument Cluster Voltage Regulator
- Replacing 66 289 Water Pump
- 1970 INTAKE MANIFOLD BIG BLOCK - BUT WHAT WAS IT MADE FOR
- Identifying a 50 vs 28 oz flywheel
- Help! Wheels!
- X / H pipes
- 28 Spline Axle?
- Baffled valve covers?
- firewall to engine ground
- 351w w/ electric parts
- 68 351 header HELP!!
- new steering wheel install
- Crimping AC Lines & Hoses
- Intermediate Exhaust Pipe
- Temperature Gauge Reads High After New 302
- Finding a driveshaft??
- 302 C4 Flexplate questions...
- 68 bumper problem - and anyone else ever feel stupid on this stuff??
- new member in of help!!!!!!!
- Rear fender extensions
- Light battery + radiator?
- SSBC Brake System
- 4 speed swap info
- Hubcap Question
- Fuel Tanks.
- starting problem
- Has anyone used HALLS RESTORATIONS?
- Edelbrock vs Weiand Intake
- How much trouble would this have caused?
- Engine Pull
- Tachometer
- Carb Rebuild Help, Autolite 2100
- just wondering..
- did cougars have 9inches?
- Are all FastBacks automatic?
- Who is using shorty headers?
- on 66 should the tail light panel be strait
- Harmonic Balancer Replacement
- new here with a problem
- Cragar G/T's...Do you like these wheels.
- courtesy light
- Timing Problem
- Locked my keys in the trunk
- Difficulty Mounting Rally Pack
- D/FW Paint job!!
- Another 68 power steering question
- 69 Mach I...the car would not start.
- 289 will not start - first time post
- New guy with suspension question?
- New member with an old problem...
- Distributors
- Is this too close?
- Can anyone diagnose this problem?
- Looking for my dads old mustang
- Msd Ignition System?
- eletrical problem
- Rear axle swap???
- 1971 Mustang
- which aod crossmember is better
- 302 roller block bored .030 over
- Disc Brake Conversion?
- EXHAUST FUMES KILLING ME......
- Posts and Locations (Topics)
- Speedometer gear
- Pitman Arm
- Sorry guys, I still have vacuum questions.
- 1971 fastback uni-body
- Couple problems, need some expert opinions!
- My turn to ask...69/70 owners
- Power steering box with manual steering?
- New wheels and tires, now front right wheel grinds??
- Headlight Bucket Question
- wow! now it's officially a horse :-)
- Heidt sub-frame connectors are installed, and
- Sneak Peek *PAINT*
- I'm looking for a '67 Tachometer
- New Edelbrock E-Street Heads.
- 650fm /nascar performance intake manifold
- Priming. Which one, when and what isn't needed?
- moving the stick?
- rad fan which w ay around ?
- Which leaf springs?
- Tuning issues - 302
- shock recommendations
- Vacuum line
- 68 Shelby front valance.. w/license plate?
- 67 mustang coupe w/ 66 gt valance
- 66 coupe roof
- How do I measure my rear end?
- making a coil spring compressor
- clutch problems
- 1967 Electrical Problem?
- leaf springs...what are these?
- transmission fluid
- Hi-Po Manifolds
- Back with a 3.55 ratio - Feedback
- Powder coating a my carb
- efi swap questions
- Is it possible?
- anybody go to the birmingham show and take pics
- fuel gauge wiring
- Distribution Block & Proportioning Valve
- 2v carb flow?
- K-code Headers and Dual Exhaust
- fired her off today
- Paint Shops
- Electric fan not coming on
- block choices
- Is there a manual for a 65 6 cyl?
- Brake lines/hose 6 cyl or V8?
- Which rear springs???
- Carb rebuild
- 69/70 owners - Measurement please
- Question about 1965 turn-signal indicator
- distributor
- Heater plenum relacing?
- 67 Fastback Trap Door Trim Piece
- JBA Headers Fitment Issue
- side windows,
- what are the right heads
- Manual to electric choke carburator
- Won't Roll Backward in Neutral (Rolls Forward)
- done it now...no turning back
- 67 mustang shakes while trying to start off
- How to remove middle brake line clips
- should the cam have any fore/aft movement once installed.
- Is my C4 about to go?
- getting hot in idle
- Harder to start after rebuild
- eleanor front end body kit
- Hazard Lights 67
- 1967 Mustang shakes when I go
- transmission problem
- AM radio upgrade for Ipod & CD player; REDIRAD?
- belt slip.
- overheating?
- Solved the ticking, now why did it start?
- Help with a decision. 5.0 efi or carb in a 65?
- '65 Blinkers Stopped Working?
- I went and got the parts today. Holy crap is my wife pissed!
- Did it again...
- What do I got here and what is it worth on ebay?
- Mustangs Plus Lifetime Warranty???
- Are my shocks blown???
- ROCKER/PUSHROD PROBLEMS
- Alternator bracket question
- Type of fuel to be used for a 65 Mustang
- New bushings!
- 351 question
- Finish on the New Currie 9+
- a little off topic
- belt change help
- Edelbrock 1406 Carb adjusting - idle issues
- hub removal
- Anyone Running a FRP 392?
- what kind of tips?
- Stupid battery died again
- Brakes wont bleed. What gives?
- Pertronix Problem!!
- Does anyone have 65-67 5 lug drum hubs?
- Trailer Hitch for a 65' FB, is it possible?
- Furious at body shop
- Frame rail replacement
- serious rust repair advice appreciated
- what is a good drag racing coil? 68 mustang
- Gear Vendors Overdrive
- Data plate!
- Car shakes between 30-35 mph
- Pics pics and more pics :)
- Front Shocks
- 302 tuning
- Help! with my car
- 289 Rebuild NEED HELP!
- Power Steering Fluid
- Holley 600 CFM running rich.
- windshield cleaning
- another bleeding problem
- Removing ball joint from Pitman Arm
- What should my carb vaccum be at idle?
- How to replace Rear shocks
- Installing Custom seats buckets
- Mutant Engine!?!?!? What the hell have I got here?
- valve seal replacement- I6 200
- Cant get new clutch adjusted right. Help!
- mustang II front in 68?
- mixing different brands of tranny fluid?
- ATF Question
- Needing duraspark help on 67 mustang
- How much oil to fill the tranny?
- Smoking headers
- New Wheels w/ pics
- good 289 rebuilt engine source
- HiPo Motor Mount Suggestions
- Squeaky noise coming from passenger front tire
- How much is my '68 worth?
- seats for a 65
- 72 mach 1 wiring diagram for a 351 cleveland
- 1967 Mustang for sale
- Help Identify Carb
- I think I have carb Problems. help?
- Seat Dimensions
- 66 mustang shelby hertz paint
- will this fit?
- Rubber perch pads?
- Cam gear failure, what could have caused it?
- 331 stroker build cam and head options
- 1968 mustang rear reflector position
- Power brakes and the 5.0 EFI
- Scratch
- Just wanted to let everyone know.
- accelerator linkage bracket
- what to buy??? 2 options...
- spring perch width for 68?
- Chrysler\Plymouth Mangum 500s
- GT 350 Stripes
- Classic Air vs. Vintage Air kits
- Door hinge pin likes to come out....pics
- Options?
- Replacing Speedometer Driven Gear.
- Big difference..
- well its time..........
- Need Advice about buying a 289 HIPO
- A/C Evaporator Drain Location
- Steering Wheel Recommendations?
- Could i?
- 66 speedometer gear question
- Should I buy this engine?
- Door Glass Rattles like Crazy!!
- Fuel gauge
- Help me pick a color for the Pit of Despair?
- TRANNY LEAK.....pics, need answers..
- I'm back! (w/ more questions..lol)
- all my gauges read full...help
- Intake Manifold Problem
- goig for my first roadtrip with that 302
- Water pulley 302 or 289
- 1969 disc brakes ???
- how belts go 65 289
- rear quarter replacement
- Is this price fair????
- how can i tell if i have standard or deluxe interior
- 351 w throttle lag???
- Easter Car Show/Parade: Garden City, New York
