View Full Version : Classic Mustangs
  1. wheel help ideas
  2. I6 V8 Swap
  3. 1967 power steering problem...
  4. wiring harness
  5. Monte Carlo bar
  6. Edelbrock intake and carb question
  7. saggy coil springs
  8. Y E S ! ! ! ! ! !
  9. Battery cables
  10. Need Strut Rod Brace
  11. Powder Coating ?
  12. NEED EXPERT ADVICE, WHOS A PROEFESSIONAL....
  13. UCA drop pics
  14. New Heater Blower Motor Question
  15. Stroker Fuel System
  16. what are the dimentions of front coil springs in a 66 mustang?
  17. reasonings for choosing an alum rad over brass?
  18. Alignment Shop
  19. how do you remove brazing
  20. MSD 6AL trouble
  21. Gas Pedal Height
  22. Whistling sound from my carb
  23. Holley 4160 Fuel leak
  24. Carb Troubles? Mustang randomly runs like crap.
  25. Novice Mistake - retrofit vintage radio in '65
  26. 289 with exhaust cut outs
  27. Tranmission Leak
  28. Fuel Line for my 351w' 65
  29. Porting 351w heads worth it?
  30. Rich burning Carb
  31. explorer 302
  32. I had my car aligned
  33. cut and buff
  34. Turn signals
  35. Ignition System
  36. PCV valve
  37. Drums To Disc
  38. Pertronix Ignitor ?
  39. patriot heads
  40. from c4 to 5 speed
  41. Fixing an old a/c compressor???
  42. valves
  43. Jack Stands
  44. Opinions on these wheels.....
  45. what should buy/upgrade
  46. emergency brakes stoped working
  47. Brake Push Rod???
  48. 69 Mustang fuel tank in a 65-8 Mustang
  49. traction bars
  50. 1971 Coupe, Brakes Question
  51. Currie 9" Rearend
  52. Global West Adjustable Strut Rods
  53. 3.250"
  54. Carb Help!
  55. DIY new interior and cost
  56. 67 Mustang rear end 8" or 9"?
  57. Rack and Pinion swap from a 74 mustang II
  58. New to the forum... seeking carb advice (long).
  59. 79 351w a 6 bolt?
  60. Factory Performance Parts
  61. Found a Craigslist rearend
  62. I asked about rear main before but im not clear
  63. date code correct?
  64. Carb too big? Have engine spec list
  65. Aftermarket parts aren't the same.
  66. Header help with 69 Grande
  67. Sway Bar and End Link Question
  68. I need a flywheel.
  69. converting to a T5
  70. engine flooded or .....
  71. Wheels With Tires
  72. should I buy it?
  73. brake question - any suggestions?
  74. C4 Tranny Question
  75. Repairing/ Remplacing a Radio
  76. 66 Coupe with a 7 3/4 in ring gear
  77. 5.0 vs 289/302
  78. thinking about doing a 8.8 swap to my 68
  79. Differnce with speedo between...
  80. 65' canister fuel pump question
  81. cannot decide on the color?!?!
  82. grill
  83. voltage regulater vs new alternator
  84. radio
  85. Lucas oil - For prelub of rebuiling an engine
  86. Paint shop - IS THIS NORMAL???
  87. engine/trans change for 69
  88. 8 inch rear end question
  89. 1966 horn problem
  90. cigarette lighter and radio '67
  91. Reproduction Stereo
  92. whats this part for?
  93. torque boxes
  94. 1966 Shelby Brake Duct Pictures
  95. when is a good time to install subframe connectors?
  96. B-day Money
  97. Need rearend upgrade suggestions
  98. 390 gearbox,gearbox,tremec tko,4 speed
  99. 17x8 or 17x7 fronts?
  100. leaf spring U-Bolt strength.
  101. Heater Hose Bracket on Carb
  102. Newbie Buying advise please!
  103. Official Build/Rebuild Thread of my 69FB
  104. alternator problems
  105. Ground up '67
  106. Restoring a 66 Coupe!!!
  107. 1969 Window Diagram
  108. No reverse lights on my 67?
  109. restoration questions
  110. heads fried ...
  111. How do I know if my voltage regulator is mechanical or electric?
  112. Loud Irritating Front End Creak/Squeak
  113. Red Fluid Leak.
  114. Oil Confusion
  115. starting problems!!
  116. Trim
  117. Performance Upgrade- 66 coupe 289
  118. shocks
  119. POR 15 , your thoughts
  120. 65 mustang coupe roof channel rails
  121. hello from florida have question ref 65 stang
  122. Help with AC removal
  123. Mufflers
  124. Distributor resistor??
  125. Tie Rod Stud Size???
  126. 68 ignition problem!
  127. Rear Drum Rework Checklist -- Leave anything out?
  128. First Day Back Out (w/ pics)
  129. Car ROTISSERIE
  130. Best street tire for traction
  131. 69-70 rear window molding
  132. Biggest 15" Rear Tire for a 67 Coupe!?
  133. Modernizing Mustand
  134. Rear Spring Choice - Help
  135. Headlamp problems, install! Help....
  136. Installing Fog Lights
  137. this really sucks... :(
  138. Wheels and Tires For 66 Fastback
  139. Shackles or no shackles??
  140. new paint blistering (help)
  141. Rear License Plate Lamp
  142. How hard is a rear main seal to repair.
  143. Classic Mustang Article
  144. new wheels are in!
  145. Cleaning Intake Manifold
  146. Wheels and Tires 66 Fastback
  147. HIPO Camshaft.
  148. Honestly how bad?
  149. Suugestions on my Build?
  150. Speedometer is 30-mph off??
  151. Emergency flasher
  152. 70 boss 429 hood scoop fit 70 mustang hood
  153. which is the positive side of my alternator
  154. new floor pan... before and afters
  155. Tire Pressure
  156. Best headlight kits
  157. NO electricity
  158. Pertronix question
  159. Removing Front Seat
  160. March Pulleys
  161. door wont open.
  162. Your Choice for Suspension Kits?
  163. Blast Media
  164. ARGH!@#%$ Fastback = Broken (rant)
  165. valve cover gaskets and RTV
  166. Can someone list how to spot a trac-loc
  167. storage?
  168. Tire fitment issues?
  169. Looking for a 67 Shelby front end
  170. what gear to use
  171. what gear to use
  172. Updated on Exhaust, H-Pipe and Tips installed (W/Pics)
  173. My 67 convertible arrived at it's new home
  174. What Blast Media to Use
  175. Front Spindle Bearing Failure
  176. Electronic Ignition Conversions
  177. c4 filter change
  178. Home from Paint
  179. Replacement Cowl Panel Assembly
  180. 9 inch Rear-end Length
  181. 64' mustang - Measurements
  182. 64' mustang - Measurements
  183. compression ratio 1966 289
  184. Glass question
  185. setting idle with automatic transmission without getting run over
  186. clear coat question
  187. Nylon Fuel Lines
  188. ABS and Traction Control for my 68
  189. good buy?
  190. Need some help please, clerify?
  191. 8.8 rearend
  192. How do you hog ring the seat bun to the frame?
  193. Paint Job questions?
  194. Setting dwell on 66 289 2V
  195. Picture request: coupe with 17" bullitts
  196. Tuning Question (Gurus)
  197. Head question
  198. 289 and/or 302 block prices?
  199. starter solenoid sparking
  200. Transmission ID
  201. What's lurking behind this radiator support?
  202. Manual transmission swap.
  203. What's lurking behind this radiator support?
  204. SSBC or discbrakeswap.com and brake line question
  205. 06 Bullet Rims on a 67 Coupe!?
  206. Help 289 = 302
  207. Paint code and prices?
  208. What is a milder sounding cam 251/251 or 230
  209. Engine Swap Advice
  210. 5.0 swap from EFI to carb
  211. C4 Kickdown linkage--Cable or Rod?
  212. power steering problem
  213. 1966 Convertible Fog Light Switch placement
  214. located a 9in diff
  215. Suspension Rebuild parts and prices suggestions
  216. Front bumper brackets & Shelby fiberglass
  217. tiger striping
  218. 65 windshield moulding clip studs
  219. Tightening the steering box
  220. Renewed the wheels!
  221. Sprint Package B Question
  222. Need a carburator for my '68
  223. ITS HOME!!!
  224. What is a good compression # ?
  225. flushing windshields
  226. '68 Mustang---No High Beams ??????
  227. 289 Block for a 347?
  228. Engine Progress!
  229. 66 mustang hardtop - good buy?
  230. dull seats
  231. Sway Bar
  232. WHAT thE F_CK aRe these?????
  233. Chamber issues, help...
  234. replacement seats 67, and 3 point seat belt in convertible?
  235. T5 Conversion - Slip Yoke Question
  236. 5.0 and 5.8 Intakes?
  237. Anyone know of offset spindles?
  238. its been a while since ive been on here
  239. cable clutch question
  240. Most affordable way to do Shelby drop?
  241. Idler Arm Help
  242. New mobile device interface
  243. 14 or 15 inch wheels??
  244. Car is Done!
  245. Help selecting Front Disc brake kit
  246. Where have all the 9"s gone?
  247. Do I need an aftermarket bezel for aftermarket gauges?
  248. Back up light switch on my 65
  249. Valve Cover Gaskets
  250. What type of Shops do Fender Rolling?
