View Full Version : Classic Mustangs
  1. efficent build?
  2. door handle loose
  3. suspension upgrade help
  4. Door Window Weatherstriping
  5. Help with 1965 convertable mustang
  6. Ca Smog Law changes
  7. Well I new something didnt look right!
  8. Grant Wheel Install
  9. Need help choosing new tires for new rims
  10. Hood Latch
  11. Alternator upgrades
  12. License Plate Lamp Assembly
  13. C4 Pan and Filter Torque?
  14. Whats this for
  15. My 65 is dead on the side of the road! What happened?!
  16. Air conditioning upgrade
  17. Fuel pressure, 5psi?
  18. To Fake and Urban all you that helped.
  19. trunk lid spring
  20. Complete Ford Vehicle Line Information
  21. Vacuum Routing Diagrams
  22. 71 seats in a 70
  23. Bearings.
  24. Utilizing Pistons...
  25. Exhaust question
  26. can you send me pics of your non stock mount alternator
  27. put it on now or wait?
  28. New Eliminator Style Fiberglass 69 Hood..
  29. Opinions on Upgrades
  30. Blinking lights
  31. Upper control arm question...
  32. Is the engine built right?
  33. New Twist on a Shaker
  34. Speaker and Package tray ?'s
  35. Gas Tank Filler Pipe
  36. teardrop hood
  37. 1967 mustang with 4.6l cobra engine
  38. Installing AC in my 66?
  39. Hi-po Heads for 289
  40. Great new Opentracker Suspension Installed!
  41. Tires & Flat Spots
  42. Pics and Ideas for a new shifter
  43. anti theft stuff
  44. 1965 mustang Disk brakes
  45. ember that 68 convertible I was looking at?
  46. Mike's new wheels from OE
  47. Anyone know what these brackets are for?
  48. Install AM Radio
  49. When did 1965 production end?
  50. Cheaper option?
  51. measurments for a 9" rear
  52. vinyl repair?
  53. any one have a 351 block they want to get rid of?
  54. Door handle confusion
  55. 73 coupe, mirror remote placement question
  56. 65 Gt Burning LOTS of Oil
  57. 70 mustang INstrument cluster bulb descriptions
  58. 70 Mach 351C Rebuild - Help Anyone?
  59. Mysterious wire on my 1966
  60. Repro Headlight bucket...any good?
  61. Wind Noise (lots of wind noise)
  62. Different Exhaust
  63. What rear end is this?
  64. Update on project 66 Mustang/SVO 2.3 Turbo (pony door panel installation)
  65. 68 Fog lights install ?????
  66. Sway Bar Bushings - Will this fit??
  67. T5 Clutch Cable & Headers
  68. Why use painless wiring???
  69. 6x9 speakers in a 73 coupe problem solved
  70. Pics & Status Of My Mustang
  71. 1967 Mustang Convertible - should I buy it?
  72. bumpsteer kits
  73. Ford, Chevy, GMC, 302
  74. Ford 8.8 rear end
  75. Hood Mounted Tach
  76. Spindle Question
  77. Panel Bond Floor Repair
  78. Going to look at a '66 Convertible
  79. not quite there yet
  80. Door skin replcement
  81. 70 Fastback quarter skin pics
  82. LED's are really great!
  83. question about removing radio knobs
  84. What size wheel studs for Bullit rims on a '66 Mustang?
  85. 14x1.5 studs?
  86. '68 Mustang update
  87. Difference between 302 engine gasket kits
  88. well crap - tranny
  89. WTF oil pan gasket?
  90. Valve Adjusting? Needed or Not?
  91. Coil Spring Cutting?
  92. How to Clean before reassembling engine..
  93. ENGINE PAINT QUESTION
  94. Simple paint question.
  95. What Is It & What Does It Do?
  96. Head Question....
  97. 302 Distributor
  98. 1967 V8 Idling starting issues after couples months, 600 holly dual pump
  99. Got a price for a new 9"
  100. Wheel Adapter Pricing and Questions
  101. Mustangs in Junkyard
  102. 66 Steering Box and Shaft
  103. 4 speed transmission
  104. need pictures of 351w vbelts
  105. help id mufflers
  106. PCV hooked to intake + breather = plain stupid?
  107. New tail lights installed, issues...
  108. Aod cross member and looking for v8 rearend
  109. 351 geaders for a 68
  110. Valve Guides
  111. What the heck? Removing UCA & LCA
  112. Engine RPM at idle and drive
  113. Just finished the trunk (well almost), custom, pics
  114. wheel width in 66
  115. Help with painting!
  116. Does anyone know???
  117. Float Level Adjustment: Holley 570 Street Avenger
  118. Up-date on Project GT140T (66 Mustang/SVO 2.3 turbo swap)
  119. Retractable 3 point seat belt installation
  120. Quarter skin replacement questions
  121. Is my cam shot?
  122. Info on Sacramento-Mustang H.I.D. kit
  123. all wheel drive mustang
  124. 5.0 motor build
  125. Best way to repair cut radio hole?
  126. Winter Wonders
  127. High Country Special
  128. 8.8 under 66 coupe
  129. Good trustworthy mechanic for 66 fastback in Southern California
  130. First day of mustang production?
  131. 1966 2 Speed Wiper Motor trouble...
  132. gasket sealer on Fel-pro perma-dry gasket???
  133. Doug's D669Y headers and cable clutch?
  134. Light problem
  135. New to this section.....I have a question
  136. Classic security...
  137. Pilot Bearing, how much tolerance?
  138. STRIPES ELEANOR
  139. Autolite 1100
  140. Another "Cash for Clunkers" bill.
  141. PS pump needs to go! cheap ways of making it disapear?
  142. lemans stripes from factory?
  143. Cam - Question
  144. rear glass window
  145. 67 stock tire size?
  146. Which Convertible Boot Color?????
  147. 5 lug conversion question
  148. Need engine rebuild in Lawrenceville, GA.
  149. Mustang Club of America
  150. Rebuild
  151. Pistons and Wrist Pins
  152. Another proud owner of a 65 Mustang
  153. Loose steering
  154. 1965 ORIGINAL FENDER?
  155. Re worked the drum brakes today!
  156. heads question
  157. Anyone installed a Rack and Pinion for 1971-1973 mustang or smaller steering box
  158. Best replacement for 1966 GT dual exhaust muffler?
  159. Speedo cable drive gear fell off...
  160. Exhaust Tone - 289
  161. Fender & Door Bumper rails
  162. 1970 Mach 1 Shaker Hood
  163. painting in pieces.
  164. Which Oil Would You Use?
  165. rear disc brakes for a 65
  166. Heater reostat???
  167. New noise after trans rebuild.
  168. Tail light bulb and wiring questions.
  169. Seat belt question
  170. which 66 mustangs came with factory 9''?
  171. rear brakes
  172. Will 17x9 wheels clear on my '68 fastback???
  173. Changes to my 67 80mm, EFI, A/W
  174. Transmission question
  175. 67 Rocker Panel Moulding
  176. disappointed with laurel mountain mustang...
  177. Alum vs Steel wheel spacers... Thoughts?
  178. Looking to start a T5 conversion
  179. Supercharger a '65 Mustang with a '68 302
  180. HIGH COMPRESSION ENGINE: BURNING OUT PLUGS
  181. leaf spring question
  182. very odd problem with 351 cleveland
  183. changed headgaskets now I'm burning oil
  184. Replacing heads (and only heads)
  185. I need to lower my stang.... but i dont know where to start!
  186. fuel pump pressure to high
  187. STP to prime bearings and engine
  188. how to increase heater fan speed
  189. need new suspension
  190. Roller Cam Bearings versus Tapplet
  191. 351 swap
  192. Just saw a '65 fastback crash into a house...
  193. new waterpump
  194. Continuation of my rocker/stud issue
  195. 3 shoe'd pony
  196. Thinking of a Shelby style "roll" bar
  197. heater vacuum motors
  198. Rust Question
  199. The 66 Project Mustang for my Wife
  200. MT Sportsman S/R Tires
  201. Looking for a recommendation
  202. Mustang Bellhousing Dilemma
  203. Side Window installation question
  204. 1965 Mustang Coupe, need advice
  205. 72 Mach MSD Tach Adapter 8920
  206. Transmission question
  207. 69 tilt away steering specs
  208. Any ideas?
  209. just ordered brakes
  210. E brake problem
  211. Back up lights
  212. N00B-Suspension question... HELP!
  213. OK Another Problem
  214. How to re-install 1965 instrument cluster?
  215. 1969 Mustang Coupe Bodywork Help
  216. 1969 Mustang Coupe, Side Window help.
  217. axle housing breather/ brake distribution
  218. Back from body shop - trim options
  219. Honest opinion regarding '87-'93 5.0 EFI Swap
  220. Scaly Water Jackets and Radiator - How to Cure?
  221. Recommend me a welder
  222. 66 Mustang value question
  223. c4 question
  224. Cobra brake swap
  225. Trumpets
  226. Failed emissions test
  227. Old Mustang, New Wheels???
  228. Engine hesitation
  229. panel gap specifications
  230. Matching Numbers??
  231. Urban, FakeSnake or Anyone, Help
  232. 69 TACH HELP NEEDED!
  233. coil spring installation safety question
  234. Grant Steering Wheel Constant Click while Turning
  235. SEND HELP OR BEER!!!!
  236. Chrome Polishing, Best way?
  237. Manufacture Numbers?
  238. Is this a limited slip?
  239. convertible top install
  240. Small Water Leak
  241. 1971 mustang project help please.
  242. Engine Decoding
  243. 5.0 Worth It?
  244. Lighted Mustang Corral
  245. Spring Help
  246. New Blood for the '65
  247. Best Year 302?
  248. Rear 65 Fastback vent windows
  249. .....uhhhhh.... OPPS!
  250. Interior Paint
