View Full Version : Classic Mustangs
  1. 1966 radio question.
  2. 1989 302 - Harmonic Balancer - Help
  3. 68 accelerator pedal removal how?
  4. advice on changing fuel tank
  5. primer question
  6. 1966 manual > Power steering
  7. Gas Leak at Fuel Filter
  8. 66 coupe - center console
  9. 351w in a 66 coupe
  10. fender bolts
  11. carbs and fuel pumps
  12. Water Pump '68 FB Issue
  13. Good bye Circuit City, hello new speakers!
  14. Screwed up my rearend!
  15. Looking at a rebuild kit
  16. Carroll Shelby signed glove box door
  17. wheels
  18. Reverse Lights Not Working
  19. original tooling?
  20. How do you find 89 Block Number?
  21. roller perches?
  22. 66 Mustang Value
  23. rust
  24. Traction Bars
  25. Which wheel center cap?
  26. Picture help
  27. which carpet kit do you have?
  28. Fixing Cowl - Would this work (cheating)?
  29. carb question - freakin holley!
  30. Front Tires
  31. T5 questions
  32. what do u guys think?
  33. New parts on the way!!!!!!!!!
  34. 302 Torque Settings...
  35. msd distributor?
  36. Re-Upholstering Tommorow
  37. Hard to Start Cold
  38. Trying to figure out a distributor
  39. my most expensive mod yet,....(non car related)..sorry
  40. why? persistent problem
  41. 15" Sticky Tires ?
  42. Big Block or small
  43. guages dont work!!!help
  44. torque converter
  45. swap to manual
  46. 15 Years in the Making
  47. 68 shelby console????
  48. new steering wheels sparks
  49. Not Firing
  50. modify shock towers
  51. Please help!!!!
  52. Coil Spring sugestions?
  53. sting fiberglass
  54. 67-68 Hood Louvers
  55. Heads, Last Question.....
  56. 65 valve body ?'s
  57. FMX Rebuild Help
  58. Rear calipers
  59. European Photo Shoot in MIAMI w/CLASSIC MUSTANG
  60. '69 Grande spoiler suggestions
  61. intake/air cleaner advice
  62. HELP!!!!! FIX MY MESSED UP FAMILY!!!!!
  63. gap between axle end and differential pin
  64. headlight switch wiring help
  65. Engine Paint
  66. Differences between Blocks of different years.
  67. New MetalWork Video
  68. Original 1966 Side Glass Question
  69. Sorry. But whats this
  70. Hood Clearance?
  71. 68 4 speed shifter rebuild kit help needed
  72. I asked before and got no response
  73. cleaning oil pan/ gasket?
  74. 69 coupe w/air, cruise, PB
  75. grab-a-trak suspension?
  76. anyone know where i can get a disc brake set up?
  77. 71-73 Bumper Inserts
  78. c4 questions
  79. 289HP or 5.0 what should i use?
  80. thinking about these wheels
  81. '68 GT500 what color to paint?
  82. New Suspension
  83. since I had my heads off ...
  84. Cleveland VS. Windsor
  85. First Post - 65 Mustang
  86. speedometer cable
  87. Help - Tips for Painting the interior
  88. t-5 swap..have you done it? how long?
  89. Super CoupeR
  90. 40+ year old trunk gasket
  91. Good Morning! Dash pad interchangeable?
  92. GT 40 HEADS
  93. 289 to built 302 Progress w/pics
  94. EFI swap wiring
  95. Buyer's remorse
  96. Finally finished fabing up my tranny mount
  97. 65 quarter windows and regulator installation
  98. Stripes
  99. Is this a real shelby?
  100. saganaw 4 speed transmission questions
  101. Engine coolant leak
  102. Finding the "Build Date" for a 65' 66' from warranty number
  103. Picture for anyone new to working on cars
  104. Stinkin' speedometer cable!
  105. New carb cuts out, why?
  106. Pictures of my '68 fastback...
  107. the official build thread of my fastback......
  108. IFS Suspension Help Needed
  109. My choke is messin with me
  110. flaming river vs. unisteer?
  111. 5.0 upgrade...need some info
  112. Door lock rods vibrate like crazy
  113. Export brace and monte carlo bar install
  114. How will I sit?
  115. Reassembly pic just for moonweasel
  116. '68 Fastback Electrical Issue??!!
  117. Gas hood struts?
  118. Disc brakes...4 piston vs. single...dumb question?
  119. Electrical Problem
  120. Help with Hoodscoop install
  121. Is this a stupid idea?
  122. roof progress
  123. Behind the fender - Just paint it or what?
  124. 1966 rally pac
  125. Rear End Question
  126. "Data Tag" Location 65'-66'
  127. 67 Fuel pump?
  128. T5 Snaps!!
  129. Value of 67 S-Code Fastback-Urgent
  130. 9" Posi Question
  131. Couple of questions
  132. Side stripes
  133. 69 Mach 1 Trunk Spoiler
  134. craigs list score
  135. Why I love my old school mustang
  136. Newbie Header w/ PS Hose problem
  137. Spring Perch location on 69
  138. Crown Vic rear brakes
  139. Ignition switch wiring help
  140. Transmission seals
  141. Drop ten and punt
  142. Can anyone help?
  143. fit problems
  144. air tool problems
  145. Shifter
  146. The engine is in, but...
  147. New Paint
  148. 66 paint question
  149. Are these axle splines normal?
  150. Are these the same
  151. What color to paint?
  152. '65 Interior resto Suggestions!!
  153. Electro Rust Removal
  154. spindle and tie rod questions
  155. firewall
  156. Mods drop value of classics
  157. putting the cart before the horse?
  158. putting standard black interior in 69 coupe.
  159. 69 Suspension for a Noob !!
  160. Shelby Drop?
  161. should i? i need your guys's oppinions..
  162. Sanding my 67' Mustang Coupe
  163. 67 coupe for sale on eBay looking familiar
  164. Where can i get used 69 mustang axles?
  165. Paint and Body.. I think Im getting Screwed,, need suggestions.
  166. autolite carb gurus...think ya can help?
  167. help with bushings...
  168. 67 disc brake swap question
  169. a seat belt question, but no factory seats
  170. A few quick questions for someone who knows nothing.
  171. pinion angle or driveline?
  172. Engine color
  173. Ignition Assembly, PITA
  174. heluva start to 2009
  175. Hood Prop Rod
  176. Sway Bar Fitment With Versailles Rear End
  177. Will these work?
  178. Norther twin Spal fan wiring?
  179. 73 coupe door belt weatherstrip installation
  180. Header help
  181. Tragedy Strikes!
  182. Help Picking Torque Converter
  183. Distributor for 1969 351W
  184. Quarter Window Help anyone???
  185. Helpful hint on reinstalling window trim
  186. Clear sealant on window trim?
  187. Oops, broke something on reassembly
  188. Alternate radio placements
  189. Tint window 1969 Mustang Video
  190. compression
  191. Charlene
  192. Will these brakes work?
  193. ABS Plastic Sheet
  194. bad news / good timing
  195. Power Brake Push Rod adjustment
  196. Breaking promise :) , one last wheel question.
  197. 69 Mach1 Help
  198. 351W ignition
  199. Installing rear speakers on a 64'-66' Convertible
  200. 1966 VIN location(s)
  201. 65 seat track restoration
  202. cowl repair from the inside?
  203. Steering Wheel or Alignment?
  204. Toploader Hurst Adjustment
  205. Valve cover ?
  206. Who has 17s on their 69-70?
  207. Door Striker screws
  208. EFI Swap/conversion Help!
  209. Update on '66 Restoration
  210. tranny slipping
  211. What are the lengths of the axles in a 69 mustang?
  212. Vibration Problem
  213. more progress door pillar
  214. Problem
  215. intake thermostat issue
  216. V8 brakes on a I6?
  217. Painters advice needed
  218. patch repair
  219. Parking lamp to body seal ?
  220. Video buffing 1966 candy apple red mustang
  221. 67 bench seat... help with seat tracks
  222. Another reassembly pic - door
  223. fill in the blank...
  224. Getting closer, front end pics.
  225. Can someone tell me what this means?
  226. Wheel width, how much would it really matter?
  227. Seat Foam Info: CJPP v/s Mustangs Unlimited
  228. Hood Pins
  229. Carb for a new beast
  230. Ford SVO Heads and Edelbrock intake-no fit!
  231. whats missing from this headlight?
  232. Electric Choke wiring
  233. v6 in a 1970 coupe
  234. Quick question about air compressors
  235. Installed a couple parts today...
  236. rebuilding T5 (3&4) slider question
  237. my mustang. tell me what you think
  238. Why do my header bolts keep coming lose?
  239. Fender Rolling
  240. Can brakes sit?
  241. 351W intake question
  242. Interesting - never a dull moment
  243. 2 Wheel Sets
  244. Edelbrock Performer Intake Spacer problem. HELP!!!
  245. Picking up new car
  246. New intake and carb but now she won't shift?
  247. Drum Brake Rebuild
  248. Nationwide Scrappage Legislation alert!
  249. Ooo, look what I found..
  250. Floor pans
