View Full Version : Classic Mustangs
  1. mustang line drawings or clip art?
  2. Cobra Brake Conversion Question
  3. '65 woodgrain console
  4. may have to sell
  5. Carb Diagnosis Help Please
  6. Which distributor gear to use? (for Crane 449561)
  7. 68 Transmission Swap for Clifford Build 200ci
  8. 68 mustang powersteering bracket help!!!
  9. windshield gasket for 69 fastback
  10. '67 200ci wont start
  11. Oil smells of gas
  12. 65' Rear Suspension?
  13. 400M engine // what heads to get?
  14. 390 fix up ideas?
  15. Where to get quality window weatherstriping?
  16. Book recomendations
  17. Heat question
  18. home made coil over conversion
  19. roof rail weatherstrip
  20. Anyone try the AJE suspension on a 67 mustang?
  21. Why use phosphoric acid?!
  22. car wont shut off?!?!?!?!?!?!
  23. Doin' a u-turn
  24. Car Not charging correctly & pics from this morning.
  25. Are these 1964/1967 Vintage Mustang Wheel/Rims?
  26. How much can a stock bottom end 390 take?
  27. 65 mustang suspension set up!!!!
  28. Dynomax Mufflers
  29. Clutch
  30. Interior question
  31. 65 Mustang Convertible Pump rubber mounts
  32. Shelby drop??
  33. '64 1/2 Powertrain options
  34. 69 gt scoop on a 66
  35. wuheee! car is moving as it should now :-)
  36. Mustang Mechanic in Charlotte, NC
  37. registration
  38. suspension opinions?
  39. 302 for 1965
  40. Starter smoked
  41. Oil leak and headlight?
  42. Hey guys i need help, 67 gta wiring trouble.
  43. tuff dawg engines?
  44. I need help
  45. High torq starters
  46. 64 drum brake rebuild
  47. Shocks - KYB Gas-A-Just vs. GR2
  48. Not another tire/wheel fit question?
  49. Interior?
  50. 1969 Brake System Fail Light
  51. which comes first body filler or primer?
  52. new to restoration and classic mustangs
  53. getting hot at idle ..
  54. Glass Restoration kit? (Eastwood's Rhodite)
  55. need some allignment help?
  56. Shelby GT 350 question.
  57. lucky me ... :-) will get my hands on a 650 speed demon
  58. Gauge Question
  59. Rims and tire size
  60. 289 a code a/c equipped?
  61. Where to buy suspension parts? + lots of questions
  62. 351w flywheel question
  63. *** Is this 67 Mustang worth is? ***
  64. Painting stripes
  65. '65 Instrument panel question
  66. Brake lights
  67. Just shoot me now!!! (window trim)
  68. Hooker Mufflers
  69. Thoughts On Oil
  70. clutch cable and tranny problems
  71. Im thinking about a 40-60 shot of NOS
  72. 05-09 Mustang Seats in a 1965-66 Mustang
  73. need more heat; stang runs cool
  74. clean out body filler in driprails?
  75. Questions on Cobra brake swap
  76. Steers TOO easy?
  77. hood hinge problem
  78. Springs for Comp XE256H cam???
  79. AOD
  80. Tires...
  81. Just bought a 69 fastback, time to learn how to fix and care for it
  82. 66 mustang starting issues, no power
  83. removing carpet and insulation
  84. ScottH. your 8.8 swap? i have questions
  85. help with the differences in 9inch rears
  86. dash pad or dash pad cap?
  87. 289 smog heads???
  88. Electric issues with 68
  89. Weiand 8124 and 4100 carb
  90. Swaping disc brakes from a 70 to a 65
  91. Hood Hinge questions
  92. 64 windshield wiper arm removal?
  93. More Power
  94. 64.5 sleeper mod
  95. Drip rails. Keep 'em or get rid of 'em?
  96. Rear Differential Yoke
  97. where could my oil leak be coming from
  98. new, and in need of alittle help
  99. removing distrib wont come out???
  100. 1966 Single Resv. Master Cylinder
  101. Rear axle seals leaking!
  102. 65 Convertible Deck (Trunk) Torsion Bars
  103. Turning over on it's own???
  104. Question about an old fender for sale
  105. need some cleanin'
  106. Can you stroke a 289 in its original block?
  107. trunk weatherstrip
  108. need brake help fast
  109. Cam ?
  110. Wheels causing car to jump all over
  111. Car Died Mysteriously
  112. Exploder 8.8 stock width in a 65? Doable?
  113. Ford Racing 11" rear disc brake kit
  114. Dust cap size?
  115. axle retainer bolt size
  116. Donor Car for 65 Mustang Coupe (engine, tranny, rear end...)?
  117. 67 mustang coupe e-brake
  118. Finally back on the road!!!
  119. Lots of Questions! I need input!
  120. 1969 Coupe door glass trim
  121. Did some upgrades to my 67 turbo'd stang
  122. How much power will this combo make
  123. Help with new everything!
  124. more c4 questions!
  125. clutch
  126. no compression?
  127. Interior Quarter Panel Snaps
  128. pe-bent brake lines don't fit?
  129. trim chrome or stainless?
  130. What Mustang to take from the available line-up? Need some advice
  131. Fender roller for people on forum
  132. 1965 with Hedman headers hits PS ram
  133. upgrading the disc brakes on my 69
  134. 64 or 5 with 260
  135. Unbent Fuel Line
  136. Painting
  137. Is it hard to change a sterring wheel on a 65?
  138. 3g alternator upgrade question
  139. Terrible Turning Radius
  140. How to bleed Jelly Jar MC?
  141. Anyone use Fatmaat - Any Tips?
  142. Headlight bucket repair?
  143. Tail Light Bulbs/Blinker Bulbs
  144. ABS Power Brake
  145. Engine Compartment Mach 1 1969
  146. Cam Help
  147. First time i took my stang over 5k
  148. Monte carlo bar won't clear comprssor.
  149. auto trans dipstick length
  150. Engine choice dilema...
  151. Will these rims/tires work?
  152. New carb driving me crazy
  153. Tips and Ideas for building a 390
  154. Still priming
  155. Mysterious Ticking Noise
  156. any tips on getting a c4 in?
  157. I have a UAC drop available
  158. Shaky/Rough Start
  159. 1970 power steering
  160. Sand blasters and media questions
  161. Engine removal - how hard?
  162. Engine help/advise for a non-engine mind
  163. 71 ford mustang loading up after idle and dying HELP
  164. Own a 60's Mustang - here is your chance to destroy a Camaro
  165. 1966 289 4bbl stall converter....which one?!
  166. Dammit!
  167. Spot Weld (post 2: Supporting the car + a little more info on my situation)
  168. Okay, so, it's dead (for now)
  169. headers too small?
  170. RRS Front Suspension?
  171. Question about Concours judging
  172. possible fuel leak
  173. pcv question
  174. Spring Compressor?
  175. 68 rear quarter window removal
  176. Looking for some decent courtesy...
  177. Surging help needed
  178. 65 front seat back installation
  179. near rear end part in phoenix
  180. Generator to Alternator switch
  181. MSD Dist. question
  182. Help locate brake bracket
  183. crankshaft rebuild trouble
  184. 1969 coupe build
  185. 1 Year 2 Months Later it's Back!
  186. Progress
  187. The project 1967 restoration in pics begins
  188. Cougar/Mustang seats interchangeable?
  189. NO Epoxy Primers allowed! What to use?
  190. gap size?
  191. repainting gt wheels
  192. Restoring 1966 Mustang Coupe~ glass question
  193. Acid dipping and E-coating
  194. Anyone bought from Laurel Mountain Mustang?
  195. 302 roller motor with 289 radiator?
  196. lowering kit preferences
  197. hello new here!
  198. 67 Auto Pedal Assembly Question
  199. order of operations: floor pans, rear torque boxes, and rear frame rails.
  200. 8" or 9" rearend
  201. Looking for 67FB parts
  202. spot weld?
  203. replacement regulators ?
  204. new headlights?
  205. Why the 351W firing order?
  206. Will these heads fit?
  207. Anyone use this brake booster?
  208. Help with hp goal
  209. Shifter bezel cover....
  210. Heater box resistor help
  211. Changing the oil for storage
  212. let me get this right.. lol torque converters
  213. 1966 Convertible frame picture
  214. ignition wires are toast....need to upgrade, need advice..
  215. Deadener, insulation,... what did you use?
  216. Help me identify a Cobra T-5
  217. brake master cylinder
  218. Off topic: Painted Garage Floor
  219. Value of my car?
  220. Sway Bar?
  221. Brake Star Wheel Adjustor
  222. another quick q on ignition box
  223. Disc Brake Help
  224. T5 transmission
  225. powerjection III EFI?
  226. wheel alignment question?
  227. 1965 mustang 289 or 302
  228. Front & rear window leak
  229. Toploader 4 Speed 390 GT
  230. crane HI-6 ... magical !
  231. 67 with 351c
  232. GT500 Progress!
  233. I AM SO PISSED AT BOOST
  234. Remove FR Wheel bearing race?
  235. Cotter Pin?
  236. floor pans & rear frame rails: the parts and the welding
  237. Door Handles R&R 66 Mustang
  238. Summit discount
  239. Dimmer switch - need help
  240. heater re & re
  241. Worn rear-end?
  242. what clutch kit did you use
  243. what clutch kit did you use
  244. rpm limiting with a ignition box
  245. Intake porting
  246. '73 shorting out when door is open
  247. Excessive Brake Pedal Travel?
  248. suspension/brake upgrades
  249. 1964.5 Mustang... Good Purchase???
  250. Wiring mess
