View Full Version : Classic Mustangs
  1. Progress... finally (56K warning Pictures!)
  2. Can Someone Please Help? '73 Mach One
  3. Need rack suggestions
  4. New aluminum Northern radiator not cooling
  5. 70' turned into a 69'
  6. Best book to buy?
  7. information overload!!! - body prep
  8. Engine Setback in 69 Stang
  9. I guess that's what i get...
  10. Here's how I cleaned out my cowl
  11. Blast.... Before or After Major Body Work?
  12. Brake Light Not Working - Diagnose?
  13. new seat belts
  14. good cleveland sites?
  15. Deluxe Door Panels
  16. Desktop Dyno
  17. Carports?
  18. Properly Sealing Frame Rail to New Floor Pans
  19. Fatmat and Arizona Heat
  20. Interior Quarter Trim Vinly
  21. Frequently Asked Questions - Redux
  22. forged pistons for clevor?
  23. Trunk lid repair progress
  24. How do I diagnose turn signals not working?
  25. 5.0 Conversion into a 73
  26. Project Update, 65 Fastback
  27. Stripping, Etching, Primer, Ect..
  28. Can anyone ID these mystery 66 parts
  29. crazy pushrod lifter cam question
  30. steering help?
  31. Which muffler to get?!?!?
  32. GT-40 non-P heads good for 400hp?
  33. Compression Test With Engine Out of Car
  34. 1967 GT Coupe Leaf Springs
  35. Need a design of an Engine support stand to transport in a truck
  36. tranny goes BOOM!
  37. power steering pump
  38. parts
  39. Parts
  40. Parts
  41. Removing AC compressor....almost
  42. How do I maximize the profit on a 68 coupe resto?
  43. Most challenging body repair so far
  44. nottt goood
  45. Finished Hood
  46. Choosing A Harmonic Balancer!?!
  47. Trunk Lid repair questions
  48. The noob has a quick question
  49. Wiring Question: Starter Solenoid and Ignition Switch
  50. how to adjust my valves?
  51. repro hood question
  52. 69 pulls to the left
  53. What is this tag called? Where to help?
  54. New daily driver.
  55. help finding and pricing T-10?
  56. Floor pans
  57. What was he thinking
  58. Mpg
  59. Parking brake cable question
  60. Mustang "Codes"
  61. Original Air Conditioner
  62. Bad Tie Rod?
  63. 302 lower radiator hose constricting
  64. color...to change or not?
  65. Pony Carb Rebuild Installed, Fuel Boiling From Feul Vent
  66. cleve heads?
  67. Poly bushing question?
  68. c-4 transmission problem
  69. 68 emblems question
  70. 65 Spare Tire Assembly?
  71. Got my 71 back from paint!
  72. conversion u joint vs cut and weld
  73. Classic Mustang Stereo
  74. Chemistry Class
  75. shelby interior question
  76. Fast idle at start
  77. Solid 70 Mach with Shaker in Detroit. $7500...
  78. replacing frame rails- need help
  79. Trunk resto?
  80. What is this worth?
  81. A/T to M/T swap
  82. I need photos of Eaton pump installed.
  83. 289 not running 100%
  84. Good deal???
  85. 1966 6 cylinder gear ratio
  86. Cobra Jet Headers
  87. which engine is best for my 67 coupe?
  88. Filler Tube Upgrade
  89. 289 to 302 finally... almost
  90. 64 Merc Comet K code
  91. Coupe to Convert?
  92. 1967 Steering?
  93. AODE Transmission in 1969 Mustang
  94. damn california!!!
  95. power brake upgrade
  96. Can I get a reality check?
  97. power brakes.
  98. AT to MT swap
  99. dual quad setup
  100. Motor Mounts
  101. 70 coupe for sale in San Diego - Craigslist
  102. Mr B's '73 Custom Deluxe Convertible
  103. My next Project 1966 vert with pictures...
  104. Body Filler?
  105. clutch linkage
  106. Winter Storage
  107. Disk Brake Swap
  108. Need advice on a '66 Mustang!
  109. 1964 power steering fluid
  110. 1966 Mustang convertible- brake questions
  111. 1966 Mustang convertible- brake questions
  112. wont stop running
  113. brake/turn signal
  114. More problems.
  115. 66 mustang project v6 to v8 fuel injection
  116. 429 on Craigslist
  117. New Rear Frame Rails
  118. Irish Mustang Clubs????
  119. 351C Carb choice
  120. package tray
  121. 66 mustang project changing from straight 6 to 5.0
  122. Edelbrock IAS rear shocks
  123. 1965 overheating
  124. 428CJ Rusted Shell Worth?
  125. 1967+ merkur= ...
  126. panel name?
  127. sun distributor dial
  128. Spare wheel??
  129. Carpet colors
  130. manual swap or leave it auto?
  131. export brace install
  132. Started Yesterday, Not Today. Appreciate Some Help, Details Inside.
  133. Power disc conversion
  134. Air compressor
  135. Dang Odd Grande Couipe
  136. Work in progress...
  137. 65 Fastback update
  138. 71 heater box
  139. rear wheel studs
  140. Custom Alpine Headunit Enclousure (Yes I'm proud of myself)***PICS***
  141. Highest octane fuel?
  142. I Got Owned
  143. Mint Classics
  144. So I took a Recip saw to the front end of my '69...
  145. Bodywork progress
  146. sparkly paint?
  147. Central California Mustangs
  148. Noob w/Parchment Interior Question
  149. Exhaust Question
  150. I6 200 1966 engine Running Rough - Valves
  151. Boost and transbrake=FUN !!
  152. '65 Mustang progress
  153. 302 5.0L timing indicator
  154. FR500 Wheels, anyone?
  155. I6 aod
  156. I have a very horrible problem
  157. Gas Tank Filler Neck Anti-Siphon Mod
  158. 72 mach-1. intake ????
  159. power steering
  160. 15" steelies
  161. door actuator
  162. Bondo slinger
  163. 302 build up with many questions?
  164. Gauges
  165. mustang buff to check out a car in dallas texas
  166. Bloody good day working on the stang!
  167. Questions I bet you get alot but I can't find anwsers
  168. 67 289 valve lash
  169. 1980 200 I6 In A 65
  170. I finished the trunk finally!
  171. coolant question
  172. Strange popping noise from engine when accelerating quickly or going up steep hill
  173. DIY Paint...
  174. Which Master Cylinder?
  175. 65 Mustang 2+2 front suspension update
  176. Can anyone use a free 289 stock cam or alternator
  177. Can anyone ID an original trunk mat?
  178. Finally starting the resto
  179. Ride of the month retry!
  180. 72 w/Ram Air distributor question
  181. T5 Tricks and Tips
  182. Repairing rear window frame
  183. Should I do the shelby drop?
  184. miles per gallon
  185. car covers??
  186. port matching
  187. A little Video for yall!
  188. It Breaks My Heart
  189. Junkyard console II (a better way)
  190. Carb to Gas Pedal Linkage
  191. what is the timing supposed to be set on?
  192. Interior, New Strut rods, and outside pictures! The phunk!
  193. 1/4 tank
  194. You gotta watch this video!
  195. Time to Get Engine Smart
  196. Rocker arm help
  197. replacing my rear quarter panels
  198. Install Help - Cowl Seal
  199. motor mounts
  200. Worth checking out?
  201. caliper paint?
  202. good upgrades for I6
  203. Exhaust
  204. fuel gauge
  205. im almost done with this car.
  206. Eaton PS pump install 1965 V8
  207. Using new body parts instead of old ones...
  208. Carpet Underlayment
  209. water pump pulley hits crank pulley?? WTF
  210. CPRstreetmachines Billet aluminum E-brake handle...
  211. Sweet sounds
  212. Mustang *Pics*
  213. engine problem?
  214. 1" Lowering Springs did not lower my car
  215. drip rail chrome how-to
  216. 1939 Ford Front Suspension!
  217. Local car show pics
  218. 302 engine a 351 heads or gt-40
  219. 1960's Tilt-A-Way option
  220. 289 Engine Problem
  221. Alternator question
  222. Junkyard Console
  223. Engine Acting Weird
  224. emergency switch location 66 coupe
  225. Rear end for Project 66 Mustang / SVO 2.3 turbo
  226. Chat times?
  227. high flow water pump vs.
  228. items for power steering and power disc brakes.
  229. what was that site
  230. Anyone seen these?
  231. Body Shops
  232. 3 point harnesses
  233. Paint and Body Quote
  234. I6 200 1966 engine Running Rough
  235. fatmat liquid??
  236. Help needed re-installing 289 in a '65. Troubleshooting question
  237. Mechanic in New Orleans
  238. steering wheel play...
  239. where is the fuel screw on the 1bb carb?
  240. 68 mustangs manifold is blowing hair out through a hole.
  241. 289 engine bolts
  242. 50 ft fat mat
  243. 92 w/ 351w & c4 1/4 mile time?
  244. Edelbrock top end kit
  245. 68 MUstang and Unleaded petrol? Do I need a lead additive?
  246. Clutch pedal spring - the one under the dash
  247. Hubcap Protection
  248. 1/4 mile time?
  249. Universal Taylor Wire Kit
  250. need some help, 69 mustang cleveland
