View Full Version : Classic Mustangs
  1. AJE Racing front end...
  2. Couple of Questions on my 69
  3. heater control valve
  4. i6 to v8
  5. undercoating help
  6. new car!
  7. Winshield Rubber Installation
  8. paint and body guys--need help
  9. what engine is this
  10. How difficult is it to find seats for a '68 mustang?
  11. V6 transplant
  12. help me plan my build.
  13. How many RPMS at 60 or 70 mph?
  14. Can I keep my Factory AC in 1967 Mustang 289?
  15. 1967 Mustang Factory Air Help
  16. Bellhousing that clears headman headers?
  17. 66 under dash wiring help
  18. Mustang Restoration Help
  19. difference 302 and 302HO
  20. Where can i find a workshop manual online?
  21. 302 not firing on one cylinder
  22. Frustrating Day
  23. Why would it rust here, of all places
  24. Help!! 351 Cleveland Flooding at idle
  25. any tricks for removing bumper?
  26. Dim Taillights on '66 Coupe
  27. What engines fit a 1970 that came w/ a 302?
  28. 73 mach 1, almost finished...
  29. saying goodbye to the mustang
  30. 1970 302 engine blew rod, new engine? help
  31. Starting Issues...
  32. Water Leak
  33. do I have an A or C code ?
  34. wheel & tires for 73 coupe
  35. Mustangforums T Shirt Design Ideas
  36. front end rattle
  37. good deal or not?
  38. RPM MAnifold
  39. what cars are 4 lug 4 1/2" bolt circle ?
  40. switching from 4 lug wheels to 5 lug front end wheels.....
  41. Made my Onw T5 cross Member
  42. strange trim package
  43. +12V for Electric Choke?
  44. transmission input shaft problems
  45. Am I right??
  46. 1972 Mustang Convertible rear power window motor removal
  47. 1972 Mustang Convertible rear power window motor removal
  48. Good Price on Granada Brake System?
  49. bad brakes in the mornings
  50. i need to convince my parents...
  51. never messed with suspension before........
  52. Aerosol Extention Wand
  53. Pinion angle?
  54. Shaking problem!
  55. For those of you who didn't see, I have all kinds of...
  56. I'm driving!!! I'm driving !!! I'm driving !!!
  57. Suspension Design - Use of 1 1/8 Sway Bar
  58. 1967 Shelby conversion?
  59. SLP exhaust on a 65
  60. New Addition to the Stable
  61. yay my exhaust is done. but not street worthy yet
  62. Best Engine Paint Color?
  63. 67 fastback wants an improved suspension
  64. Problems Starting '69 302
  65. Cheap Overflow Tank
  66. Grant Wheel - Sparking
  67. 4.11's and posi
  68. New neighbors
  69. Some nice things about the new forum
  70. 1965 headers advice
  71. email
  72. Timing Gear Help
  73. 1966 Mustang- remove pushrod from master cylinder?
  74. 72 mustang AOD conversion Question
  75. After market shifter
  76. info on 1967 carpet colors-ivy gold interior
  77. 69 r-code should i resto rod it?!
  78. Need some help on my c4
  79. bracing before welding
  80. Spark at Engine - All dead?
  81. charging system
  82. 70 Mustang .. Smoking Battery Cable
  83. New Legs for the 66
  84. My headlights/dash lights blink...
  85. Holley carb. what do those parts do (pics incl)
  86. 1965 mustang-tranny problems
  87. 93 mini starter issue
  88. Ram Air
  89. How to prepare my rear end for more horsepower?
  90. 1966 Mustang convertible- shoe size
  91. If you are on IE6 this may help speed up the forum
  92. Question on sound deadener material
  93. C_4
  94. Need Help to ID 7.5" rear end
  95. Problems with the Forum...For the Powers That Be
  96. C-4 to 4 speed
  97. Wiring for Voltage Regulator 1969
  98. Tire Troubles
  99. spark plug clearance
  100. Custom sheetmetal and chassis pics
  101. Frank Pompilio's TT 67
  102. Machine shop question?
  103. '66 E-Brake conversion?
  104. Custom Trunk and Stereo FINISHED! *pics*
  105. smog pump in a 66?
  106. I have to ask
  107. Semi-rare 66?
  108. bolt patterns?
  109. carrier bearing preload
  110. Easiest way to remove H pipe clamp bolts from exhaust manifold?
  111. What if
  112. 4 speed toploader questions
  113. DA sanders
  114. buying an old mustang
  115. Question on location of identification tag 71 car
  116. HELP!! '69 Mustang GT info...
  117. Timing help
  118. Newbie Question (429 in a 1969)
  119. Newbie Question (429 in a 1969)
  120. ok classic guys and gals help me out
  121. Recessing turbos on the 65 ***photos***
  122. Idiot lites to gauges 1964 1/2
  123. Fiberglass info and/or sites?
  124. T5 - driveshaft 3/4" distance yoke to gearbox
  125. Stangfix
  126. H/X Pipe or no?
  127. 72 mach I rear end
  128. pony int
  129. Maybe I'm Rusty??? Timing help and other ??'s
  130. Wheels help needed
  131. How does this sound???
  132. widest tires without tubbing
  133. 6cyl to 8cyl ??
  134. windows not lining up
  135. Had a question about paint cost.
  136. the pony is getting new skin!
  137. Disc Brakes
  138. Yay! we have our site back!
  139. whooo hooo
  140. Good buy?
  141. neutral safety switch
  142. What Could it Be Worth???
  143. valve lash again
  144. Won't start - any ideas?
  145. Base/Clear vs. Enamel Paint
  146. borg warner T10
  147. I had trouble believing this one
  148. Pics of VA and CAA A/C wanted
  149. 65 Mustang disc brakes
  150. Ford 9" rear end
  151. Radio Delete For 67 Mustang
  152. rims
  153. hot august nights
  154. 67 Wiring Harness Pics
  155. What's your guess?? Just for fun :)
  156. rust in the fuel tank
  157. new olympic game
  158. Done Before?
  159. Happy to say... ?? about cut outs
  160. 1967 Steering Questions?
  161. Does anyone collect Mustang collectibles?
  162. 1970 shocks
  163. 64.5 clutch wear issue
  164. Suggestions on minor rust repair?
  165. ring and pinon, and posi unit
  166. will this look stupid?
  167. Harmonic balancer rebuild??
  168. 2008 Mustang Memories Car Show In Livonia, MI. 56k, BEWARE
  169. Steel "Shelby type" side scoops made today
  170. Drip Rails on 65
  171. 68 fuse box
  172. 1966 Alternator not Charging
  173. SmartStang?
  174. 3 wiring problems to finish - (cont.)
  175. Dim lighting in gauges -'65 Mustang
  176. 3 wiring problems to finish
  177. Advice on painting my 68
  178. parking brake
  179. Bad Ignition switch?
  180. Is something wrong with this mustang back lights
  181. kinda mad
  182. Ever have water on your floor after it rains??
  183. some finished work.
  184. 1966-67 mustang questions
  185. Heater core installation
  186. Drilled Drums
  187. shifter linkage problems
  188. ride height
  189. Vinyl roof
  190. converting from rear drum to disc on a 65 mustang
  191. 69 side scoop
  192. 8 inch grenaded!! need some parts!!
  193. signals
  194. Stupid question 1,001
  195. Roadster?
  196. bearings
  197. File too large!
  198. 68 scoop ornament installation
  199. Boosted Drums or Discs
  200. emergency flasher switch local
  201. Air Cond help
  202. 65 vapor lock
  203. upper control arms... original or not?
  204. What should be top speed of 1968 mustang 390 GT (325 HP)?
  205. 289 Bolt on Upgrades?
  206. Help with bcool radiator!
  207. Rear end swap question
  208. Insulation
  209. Resistor Spark Plugs- Which ones?
  210. Top Replacement
  211. Not underglow but inner glow..
  212. Need Opinions on Upholstery/Seats - I know polls dont work.
  213. No Idle?
  214. Windshield washer pump
  215. Big Show (MCA) in Qakville Ont.Canada
  216. Carburetor Hose Closing and making Noise?
  217. Running after 11 years
  218. 68' window regulator
  219. brakes for 67 GTA
  220. c4 kickdown
  221. gaugesssssssssss!
  222. What is this worth?
  223. Front glass removal
  224. Power booster for 1966
  225. My new -73 Mach 1
  226. '73 Mach 1 tire question
  227. T10 4spd Tranny question
  228. || Favorite Auto Parts Store ||
  229. Tach
  230. 9" 3rd Member Installation
  231. Dash Lights Product #
  232. update on my car new floor & firewall
  233. Grant steering wheel clicking noise when turned??
  234. omgzzzzz who wants to die now?
  235. Looking at 65 Mustang
  236. advice plz
  237. 351w reverse water pump part#
  238. New Sending Unit..? 1968 coupe
  239. Starts but then immediately stops...fixed!
  240. New bullitt rims on a classic?
  241. reverse manual valve body
  242. 67 Mustang Bumpers NOS....IN THE WRAPPER
  243. What is the Best Handbook or Guide
  244. brake hoses ..
  245. voltage
  246. Installing a New *&%#@ Ignition Switch
  247. Door assembly
  248. looking for a nice project car
  249. What panels are these?
  250. 1966 ford hood
