View Full Version : Classic Mustangs
  1. Variation on the standard cowl leak test
  2. !974 302 in a 67 mustang
  3. Hydraulic Linkage,Modern Driveline
  4. Starting Over
  5. Edelbrock intake gasket question!
  6. MSD Ignition box
  7. 6-71 supercharged small block Ford !!!
  8. fuel injection swap
  9. Bye Bye FMX
  10. Clutch Kits
  11. Body Work
  12. Antenna Alternatives, Stub?
  13. '07 wheels on a '66
  14. Which gauges should I go with?
  15. first time HAMMERING the 69
  16. Beefing Up A Toploader
  17. How to Find My Mustangs History
  18. degreeing camshaft?
  19. Has anyone installed an Autometer Speedometer?
  20. are these stock '67 tail lights?
  21. need encouragment!
  22. exhaust question
  23. thermostat recomendation/overheating
  24. speedometer cable
  25. question for AUTOMATIC racers..
  26. A NEW GAME called, "put the crack pipe down"
  27. Dizzy Details
  28. Push Button Help
  29. 67 coupe daily drive, OPINIONS appreciated.
  30. Finally got a good stance on the stang
  31. May be the dumbest thing I have done thus far!!
  32. Cleaning kick panels
  33. Question for any professional body men
  34. Painted Grill Pony
  35. Wiring Diagram
  36. Gluing quarter skins
  37. 1500cfm 10" Zirgo HP Radiator Fan
  38. Carb question
  39. Blinking lights
  40. Which style?
  41. 70 spindel on a 65???
  42. late model rims or classic mustang
  43. 200CI Cam
  44. how do you replace a speedometer cable
  45. 66 gauges in a 65
  46. Trunk Lock cylinder.
  47. rims?
  48. What do you think I should pay for this car?? 65 Coupe/347 Stroker
  49. TRIBUTE --- TO THE CLASSIC STANG !!!
  50. How much will body work cost?
  51. Combustion Chamber
  52. z bar bushings
  53. 71 mustang instrument wiring
  54. gear swap for a 69
  55. anyone dealt w/ pony carbs? seem kinda stuck up
  56. Tuning advise please! 429 stumbling
  57. Mustangs Plus 4.5 leaf/Edelbrock IAS review
  58. Just made the switch
  59. Tranny Leak
  60. Hurst Comp Plus Shifter help
  61. Carpet for doors???
  62. Weight difference between manifold and headers?
  63. Adhesive Letters
  64. Old school body work
  65. How to throttle an auto
  66. Peoples reactions when the see you in your stang
  67. Ford Pater number information
  68. 65 instrument cluster ground
  69. front blinker issues
  70. What Alternator should I buy
  71. Carb replacement
  72. What are the best Shocks?
  73. Good Carburetor Source
  74. rim question for 1967 Mustang
  75. Grundy Insurance
  76. whats a good carb/ intake combo
  77. Custom gauges?
  78. Vintage TV commercial of the beautiful 1964 Mustang!
  79. How to choose a distributor?
  80. Brake Master Cylinder
  81. Billet Dizzy Gear
  82. Horn help
  83. Old Spot
  84. A LOT of questions for my '65
  85. Wandering Dwell
  86. This 3G alternator deal
  87. Will a Roush 327R fit under the hood of a 1966
  88. Will an Edelbrock Victor Jr fit inside a 1966 hood
  89. Intake Setup Question
  90. Posi or Not?
  91. paint color. whats the code/name?
  92. Replaced Fuel Pump, now won't run help please.
  93. another new time ( broke rear end??) need input
  94. I've just run the break in cycle on new heads, cam etc. and am trying to tune it in and need help.
  95. cam types. please fill me in.
  96. Do i have original engine on my 65?
  97. what cam do i get?
  98. 1965 Mustang streetrod?
  99. 289 Numbers Matching
  100. pictures of the '65
  101. BF Goodrich Radial TA's
  102. Chrome Wheel Well Moldings?
  103. Headlight panels?
  104. Questions!!!!
  105. Hi, About Me
  106. T-5 swap
  107. Really Vauge Question - Why Wont It Start?
  108. 1968 Curb Height
  109. 6or8?
  110. Engine bay almost done!
  111. check it out. update.
  112. hood help
  113. what's a kid to do with a 289
  114. 1972 mach 1 emblems
  115. Clutch adjustments
  116. 66' painless wiring/wiper motor problem...
  117. aftermarket shaker
  118. trick flows - pushrods..
  119. Need opinion on my new wheels
  120. Dash pads
  121. Instrument Pannel not Lighting Up
  122. New Member
  123. valve body torque
  124. Vacation Time!
  125. Custom Trunk- Progress
  126. Best $1200 spent?
  127. t-5 to engine combo's?
  128. exhaust pop
  129. Bittersweet Hello - Stolen Parts - VIN 140116
  130. Hard starts
  131. rear valence advice
  132. Headlight bezels...Help
  133. Trouble Starting: The Saga Continues...
  134. will newer rims fit?
  135. paint job and rims
  136. Kids
  137. RACING BELTS ON ORIGINAL SEATS
  138. What fuel Pump? and track time>
  139. comments?
  140. anyone else have a hard time
  141. dyno results today
  142. 66 Convertible Pillar Seal
  143. tire clearance
  144. zoom clutches
  145. need some help
  146. how do i
  147. choosing a block
  148. '66 Exhaust
  149. hey all radiator issues
  150. Pony vs Muscle Car
  151. autolite carb dismatle
  152. Quarter mile estimate
  153. Front anti sway bar
  154. Finally got paint on the Mustang
  155. FORD parts????
  156. new
  157. i need pics of alt bracket
  158. 302 buildup questions
  159. rear axle offcenter
  160. My discbrakeswap.com Experience
  161. Will this be a waste of time??
  162. Edelbrock Valve Covers on a 289?
  163. post # 1000
  164. 1967 289 going to manual steering
  165. Brake power booster or whatever
  166. My 65 resto tag along
  167. trade rims?? :|
  168. T5 conversion - jerky ride
  169. EVERYTHING BUT THE RADIO!
  170. Brakes...Dreaded brakes.
  171. Headers: black or ceramic?
  172. Taurus electric fan & alternator question
  173. pertronix gap
  174. Bench Seat Trim
  175. slave cylinder
  176. New tachometer: 6000 or 8000 rpm?
  177. Headers for a 65
  178. is the 260 worth much?
  179. Automatic shifter indicator
  180. Electrical problem
  181. Rear Defoster
  182. Which is better?
  183. 68-69 gt wheels but in 4 lug?
  184. Reproduction Bumpers
  185. procomp parts
  186. 351w 1978 2V upgrade to 1969 4V
  187. Exhaust manifolds
  188. 66 c4 transmission breather ?
  189. Hidden Radio antenna ?
  190. battery recommendations
  191. 1970 mach 1 *testing*
  192. stock aluminum heads
  193. ??? push rod bolts
  194. explain kickdown cable to me please
  195. Throttle came for 351C fit a 460?
  196. Looking for a mustang II pumpkin
  197. speedometer drive gear
  198. Header Clearance Issue?
  199. Electric Fan
  200. Dead Gauges
  201. embarrassing
  202. Painted Alloy Wheel Maint.?
  203. Oil Slinger?????
  204. cfm??
  205. anyone with a grant wheel?
  206. Overcharging battery, Volt Reg not working?
  207. Ground cable location
  208. emberglow interior
  209. Front Suspension Question
  210. Out of Nowhere- Sh*#ty Idle
  211. need 1970 hood w/ 429 scoop....
  212. '66 coil springs on a '67
  213. Seat Lean back chrome
  214. Help with TURBO's
  215. Powertrax lock-right lockers?
  216. 1973 Mustang Convertible Restoration
  217. Stiffer Leaf Springs?
  218. transmission brace
  219. Yet another gas gauge problem...
  220. could a stock rebuilt T10 tranny be able to handle lots of power?
  221. body work
  222. Buyer's guide?
  223. Gears, gears gears
  224. Steering Wheel size..1966 Pony/GT Wheel
  225. Complete Ebrake setup?
  226. brake system sitting up a while ?
  227. Torque vs. Horsepower
  228. cutting out on top end
  229. Rear suspension - Questions/Opinions
  230. It can't really be this hard, right?
  231. how do i know if my engine is orginal?
  232. car runs for 5 min and stops
  233. late model tranny in a 68 ?
  234. another "what to paint my car" poll
  235. Bonded Lower Quarter Patch
  236. broke transmission
  237. 1965 mustang front suspension and steering rebuild help!
  238. Smooth Start, Great Idle, but Horrible When Shutting Down
  239. removing fenders
  240. 65 mustang front end
  241. I have a good trick to make putting in a T5 easier.
  242. Cig lighter wiring
  243. oil leak
  244. Horn Blew Out
  245. 1966 - 9" rear end, what are my options?
  246. The right compressor for the job?
  247. HELP! please.
  248. 289 Rebuild - Final Cam Choice
  249. Anyone know where i can find these?
  250. Firewall pad fasters
