- Restoration of my 66
- 31spline axles?
- Which engine should i buy
- do i need a particular valve cover to clear roller tip rockers and also
- 66 Ammeter
- '71 Mustang Axle Help!
- is it legal in all states to.....
- Help replacing U-bolts on rear leaf springs.
- widest tire?
- 65 Tranny Clunk
- 1966 Build date (VIN vs. Body Tag)
- pulleys
- flywheel help?
- Where to buy a good T-5
- What to do with my 351W
- Holes in my windshield channel??
- Early 65 price?
- BLUE or RED or BRAIDED plug wires?
- tilt column kit
- harmonic balancer torque
- classic with new headlights?
- 351W Oil Pans
- out with old - in with new...Maybe?
- starter relay wires,..pics,..where do they go?
- Some water pumps don't have the bypass ports drilled?
- You can never be to careful when a car is up on jack stands!!!!
- 1 Thread 2 Questions!!
- Restoration Specialists ???????????
- New Plug Wires for a 289
- ? about 65 eleanor trunk lid
- Will this Oval Air Cleaner fit?
- transmission rebuild
- Distributor/ spark problem
- dumb ques,...rotating engine for torque convertor bolts
- Oil Pressure Sending Unit
- Preceived tire width
- Going to Test Fit some Bullets today!
- will comp magnum roller tip rockers fit under original valve covers
- Strange Unknown DSO 54 6048
- OK to fire up without valve covers on?
- C4 tranny leak
- Exhaust Manifold Bolts
- power to manual steering question
- Question - Your engine and Gas
- cam journal lube
- Another Unidentified Parts
- radio upgrade and dashpad questions
- Need parts
- different factories=worth more?
- Looking for info on the 65-66 front turn signals.
- Decode Question
- Finally donee my front end
- 64.5 master cylinder and pushrod size
- 66' carb spacer gasket - cannot find! (6 cyl)
- 65 Interior lights on! lol no key and head light turned off
- Engine Ping
- CRAZY question,...67 front on 66? would it work
- Fiberglass and Sheet Metal Opinions
- Fun times at the track
- PAINT
- Curiosity is getting the better of me
- fastback seats
- I have a stock 289 and want some advice
- 1971 429 mustang
- h\Help with a Shelby Scoop
- Open header- Exhaust clip
- awww i thought i had a 67 FB
- Rear Bumper Question
- 1970 Kick Panel Vents
- 66 cowl repair
- T5 and no power steering : the real deal!
- Another Insurance question
- Advice on taking ownership of 66' Mustang
- Single DIN stereo with a 67/68 console
- 1967 Deluxe Upholstery question?
- 351w headers
- Locking rear?
- I just wanna cry... or beat the sh!t out of something! Posted Paypal address.
- Tranny leaking
- 68 Drivers Seat View
- I have the front end off of my 289. Is it possible to squeeze the oil pump
- someone posted a nice link by comp to determine push rod length
- rear shock access
- pomona, ca
- Anything wrong with lowering blocks?
- 8 weeks
- In need of that perfect shifter stick
- Mach 1
- wheel help
- developing a game plan.
- Change from Manual Steering to Power Steering for a 66 Mustang
- Make Lights Brighter
- rockers?
- driveshaft
- valve rockers too tight?
- Weld/assembly manual question
- Heat riser tube 351w -69
- Best Lopey cam 4 a Bolt on 302-????
- My car is 40 TODAY!!! Happy Birthday!!!
- need fuse box help
- Help out a soldiers dream.
- won't fire...about to give up...
- Anybody?
- Custom Headers- DONT FIT
- speedo cable
- Aluminum racing dashboard
- what the heck is wrong with my ignition coil!?!? AND NEW QUESTION
- c 4 trans question
- New project- some questions
- Should I rebuild steering box while I'm at it?
- one-wire voltage regulator from falconparts?
- one piece oil gasket
- 4r70w slection help
- burn out
- First time through a Drive through..
- '68 new disc/drum brakes = spongy brakes
- wheel and tires
- good machine shop in so-cal
- Hair Line crack in Timing chain cover
- Should I sandblast a pulley?
- Wheels/Tires to pick?
- 65 GT-350 Colors
- Air Conditioning question
- Console light stuck
- installing a timing chain cover
- 65 Mustang Air Conditioning
- Where does the torque box go??
- what else can I do to add more performance?
- where to get roller idler arm?
- classic rentals?
- 65 mustang transmission ?
- Shelby Drop - 17/32"?
- dimensions
- Grille Paint
- posi gear additive?
- Taiwan body panels
- 408 running hot (sometimes)
- Found an unusual mark.
- block prep
- shelby dropped
- repro radios any good?
- 289 to 302 H.O. yes? no?
- Finally found a 4-speed toploader... now what?
- stock 289 block strenght?
- interior gauges
- 67 5 lug rear end
- rear speaker shelf thing rattling
- Project for 2008
- heads / cam combo
- thermostat temperature
- Headers on a 289
- could my fuel filter be clogged?
- Is there a market for 67-68 9" housings??
- 1966 289 fuses
- Does anyone sell the 1/4 window scoops for '67 Shelby?
- auxiliary starter
- with 289 heads and block with comp cams magnum roller tip rockers
- Broken valve rocker
- New spark plug wires
- Resto-mod
- Glasspacks
- 14 classic stangs, all in one place all owned by one person (lots of pics)
- T5 Swap and performance
- new time :|
- need motor decoded
- roofrail
- starter selenoid problem
- Does anybody make these panels
- What transmission is this??
- Diagrsm for Heater/Air Vacuum Hoses?
- line clogged?
- Chin Spoiler on a 66
- Electrical Issues
- headlight switch replacement on a 66
- fuel line clips?!
- Voltage Regulator testing....
- might be lookin for a classic
- Data Plate
- 67 Alternator question....
- bought a comp cam degree kit
- Justice for the spammer
- Heads??? Patriot? AFR? GT40's?
- 1966 Mustang console "map" door light
- 1971 cluster gauge help!
- Master Cylinder install question
- PINK PONY
- Brake line treatment?
- Identifying parts on my car
- Power steering pump line question.
- 71 mach 1 ram air?
- stall converter????
- A fastback opinion
- 1971 Cuda
- Body Work
- New Wheels!!!
- price help
- help decode rearend tag
- new engine is overheating
- What type of spotwelder???
- Free: 1971-3 radiator, frt spoiler, pick up in Cleveland, OH
- C4 problem! Help needed!!!
- Vent bolt?
- Sitting with no coolant - OK or bad ?
- Where does the hose...
- C4 Flexplate to engine torque specs....needed
- LOOK AT THIS SH%T!!!!
- Newbie help with Carb selection / intake -- Thanks!
- carb = pos - reccomend damnit
- Fuse Question
- History of my Coupe
- Nokia N95 8gb = $250, Apple iPod nTouch 16GB = $205
- Interior ?????? Question
- Post your Wheel/Tire Size/Suspension w/pics
- Rear frame rail removal/install question
- Ivy gold interior questions
- whats better for my car?
- Why not much interest in 1972 Sprints?
- Carb TV linkage to AOD and Holley carb
- idea for the workshop guys
- alternator,,how do I know what I got
- welder input
- upholstery kit or upholstery shop
- Intake Manifold bolt length?
- new england swap meets
- crankshaft
- C4 Front pump seal...
- I6 to V8 Upgrade - Price?
- head bolt sealant
- anyong order from HOT RODS USA!...
- grille
- Help with my sloppy automatic transmission
- 302 engine replacement
- Starting Question
- Smoke from behind steering wheel?
- Fuel Pump Question
- Custom Trunk- Work in Progress
- Crate motor
- Front End/firewall/Cowl replacement questions
- im stuck. need help..again
- AJE racing front suspension install on a 67 mustang
- Radiator Petcock
- Steering Column Support Bracket?
- Tempature Senser Installation
- started my floorboard project
- Heater Hoses
- Need some advise
- Electrical connectors
- Got the 347 in today!!!
- tire size
- DANGIT!
