- HP estimate pretty please
- Compressor Killer! Beware... kinda funny!
- 1966 mustang v6 PS BRACKETS
- Rebuilt my carb today...
- Is this part supposed to be straight?
- 1967 Brake line diagram
- Almost ready
- ***New rear end gear - Pics inside***
- Help Needed! Interior vert 1/4 recovering
- Radiator Question
- c-4 trans in my 66 whinning in park
- 67 Interior Lighting
- Heater hose question
- Need Help Decoding Rear End Tag
- FLEX-PLATE QUESTION! PLEASE HELP!!!!!
- Brake Swap
- Fan Blower motor problem
- Mission Accomplished!
- what i did today
- Found photos of my 69 from 1972
- HID's
- Antenna
- post your mustang interior
- 427 "Cammer"
- I need carb and cam suggestions for a stock 65 289
- 67 Fog Lights Switch Location
- How long have you owned your Mustang.
- switching trannys
- i have Video!, Does it sound / look alright
- Which oil to use???
- hey! i just realized it was by cars B- day yesterday! cool
- DELETE THIS THREAD
- Wiring for a '66 GT Coupe
- Wheels for my 67 Mustang Question
- Heater box seal kit for a 73
- Gas Mileage
- Carpet?
- electric fan
- Strange recall
- A new sig.
- flexwheel trouble
- Got the 347 Kit!!! HP estimate???
- cracked head?????????
- Mustang stopped in its tracks
- still having speedo gear troubles
- Attended the annual Mustang show here in Pensacola...
- My new Ride(PROJECT) From Unique Performance
- Stock 289 new Cam concern?
- still running lean
- 1968 Mustang Convertible
- OK. I blew a head gasket when water pump belt flew off
- has anyone ever used liquid gasket to seal their sending unit?
- I've got the top end off of my 289 and thinking about
- Smoke out of Exhaust
- regulator swaps
- A little experiment I am trying
- Transmission - This can't be good.
- Need some encouragement
- vent frame window
- delete this
- 351W power expectations
- Paint materials process
- 66 mustang question help please
- 1966 Not shifting
- MSD 6A, lots of questions
- different colors
- Wheelwell chrome
- Questions about gauges
- What rim and tire?
- my mustang is titled as a '64!! hokie smokes!
- Oil looks milky
- Starter Grinding Question
- Fenders - need help quick
- Roller Rocker Arms, are they worth it?
- New Leaf Spring. Got luckie!!
- Internally or externally balanced flywheel?
- 69 rear seat ?
- Reverse not working... (69 C4)
- spindles?
- Muffler Tips/Help, Flows
- quarter windows....
- whats the difference
- front end rebuild question
- Speedo is Now Way Off
- Maryland Mustang
- summit k6301 cam
- T5 Swap parts help
- Mirror Mirror on the Door....
- HELP!!! 69 Radiator swap 20in to 24in
- Reinforced Shock Tower and UCA pics
- help a friend
- April 19, 2008 - Mustang Mania 4 MD Cruise
- Brakes
- smoke questions
- Silent exhaust......don't laugh
- 351c Brass Coolant Restrictor - JEGS Substitute?
- what is the manual three speed called??
- quick flywheel question?
- New Update on Project 66 Mustang / SVO 2.3 Turbo Bolt-in 4-Link Suspension kit
- Disk Brakes
- valve adjustment
- 66 I6 Distributor Rotor
- Any suggestions...
- 460 Big Block
- 65 convert inside pillar molding
- Rear Gear ratio?
- Lots of play!!!...between pitman arm and control valve
- Installing a engine bay brace
- Symptoms of a bad fuel pump?
- Flaring Brake Lines.... Need a little help please...
- C6 or FMX
- Dual piston vs single piston disc brakes
- tell me what you think
- Aluminum heads and cast iron block?
- Starting problem - Am I on the right track?
- havent been on in awhile
- planning ahead on 1969-70 mustang
- 289 hipo/289 differences
- One More "What's it worth"
- strange electrical fan problem
- Convertible Top Installation SNAFU
- a little more hp
- Hood scoop location
- 1966 6cylinder engine to 302 V8?
- Looking for answers on 428 cobra jet
- Stearter problem---HELP!!!
- before i look into buying new wheels...
- how important is underlayment
- Gearbox question
- Who had it first?
- What do you think that is worth?
- cjpony parts interior kit
- Headers and Exhaust
- Converting 66 mustang to Right hand drive
- My 66 Fastback Pic Finally!!!!!
- I need a 351C Power Steering bracket
- Question
- question
- Installing 2008 GT front disc brakes on my 1968 Coupe UPDATE W/ PICS
- Pics of the car after grab a track mid eyes..
- PS Control Valve
- Can a WC T5 handle a beefy 351W
- She's 40, and still got it.
- 65/66 Convertible
- Another AOD swap question
- Got some new wheels
- For Sell Brand New Pioneer DJM-800 Mixer……$500
- Starter problems
- Found the casting info...now moreso confused
- Roots style blower for 351w ??
- Can I have one...Please Mom
- CFR Performance Air Cleaners?
- spring rates?
- maybe roller block?
- what should i do first?
- Timing Issues
- How many 71-3 owners are here?
- oh no...not again
- photos
- Battery size for a straight 6
- how screwed am i
- Rocker arms on 302 1968 mustang, making noise
- 289 Timing cover's interchangeable ?
- heads
- Brake line install....
- i think i have an HP289! help!
- Excessive RPM's- 66 Coupe
- 67/68 Drum spindles - Disc brake upgrade
- lokar center e-brake install
- So confused about my motor???
- backup light switch on '66 coupe?
- Insulation pads
- installing early mustang convertible tops,....difficult, or easy??
- 6 cylinder vs v8 radiators,...early mustang, interchangeable??
- I HATE Thiefs
- Rearend and Rebuilt 351c!
- Paint question - orange peel
- Reaplacing Master Brake Cylinder... any suggestions?
- Nice Suprise - found my build sheet!
- 66 Fastback
- cowl repair
- What year small blocks?
- Finally got my center..
- Lug centric?
- I think I broke something
- painting my tail light panel
- 66 autolite 1100 question
- i have some major leaks
- floater problems
- Blue Suede Cruise in Tupelo MS, Birthplace of Elvis Presley
- 200 six or 289
- i just won on ebay!!!
- Engine mounting on engine stand
- Valley Pan needed? FE 390
- 5.0 distributor... PLEASE HELP
- symtoms of bad coil? fuel pump?
- HEI distributor for 289?
- whats a 351 cleveland worth
- What Kind Of Carb Is This?
- WANTED: cylinder heads for a 302 1969 mustang!
- A few more front disc swap questions...
- help decipher engine code
- 65 Fuel Sending unit and float
- front disk brakes
- Zero Oil Pressure At Idle When Warm
- Signal Light Problem
- Polishing The Horse
- Any members in or near Mckinney TX
- T-5 identafication!!
- Good mechanic near Laguna Beach, CA
- Water Pump installation ?
- Disc Brake install ROADBLOCKS... Rusted hub... please help.... Thanks!!!
- 5 bolt bell housing? engine and car pictures!
- 302 engine problem please help!!!
- how do you guys add pictures?
- Replace or bondo over?
- '69 Rocker panel replacement
- alternator wiring question...
- Edelbrock Carb owners,..i need pics,..
- Do you think this is misguided???
- 351c cam at distributer gear
- First mustang..first project..HELP
- April Kool Nites?
- headlight extension part number
- Starting Front Disc Conversion tomorrow... Wish me luck!
- What are the shift points on C4 transmission?
- Cut the oil filters to examine
- 69 and 70 fenders
- Pay the bills tomorrow
- timing retards itself
- First DRIVE with T5
- Stolen 37 years ago...
- Shaving handles
- need help w/engine casting dates!
- Vent bolt?
- 66 I6 Flowmaster
- I updated my "between the seats" e-brake handle web page
- Exhaust system mods - need advice
- 4 jack stands - ok to do with engine still in?
- Mustang Restoration
- Anyone have some old 15x7 wheels to get rid of?
- Dash removal
- Will 2001 Mustang wheels fit my 1967 Mustang?
- Strange starting
- Before I apply the paint...undercoat?
- speedo gear
- New to the Stangs!
- cable clutch w/ T5 pics anyone?
- Battery/Alt problem???
