View Full Version : Classic Mustangs
  1. would you drive it
  2. Insulation & Weatherstrip Question
  3. new clutch for t5 swap
  4. a different tire question
  5. 66 pony interior
  6. Lead Substitute for Gas ???
  7. Is this a good RO sander for paint removal?
  8. A Cringing moment
  9. grille emblems
  10. AOD update
  11. NEW update for Mach 1! lots of pics
  12. New gas tank leaks at sending unit
  13. quick engine questions
  14. How much for cosmetic repair?
  15. 1967 289 engine dies in drive
  16. Start up problem
  17. start my mustang for a last time for a while...
  18. Changing Timing - Can't Turn Distributor
  19. Checking Vacuum on My New 289
  20. Buying Parts
  21. i need a 2.8 litter bellhousing
  22. Always having to jump-start car - please help!
  23. Concours ivy gold with gold standard interior
  24. 64, 65, and 66 Mustangs are NOT Hot Rods,
  25. Recurving the dizzy
  26. Wheels and Tires are Done!
  27. 69/70 FB Dynacorn trunk and wheelwell fit problems
  28. rear end removal - questions
  29. Next step restomod 66
  30. Hello, NorcalTroy
  31. I got a cpuple questions ive been thinking..
  32. Ignition or not???
  33. Manual Transmission Capacity
  34. How do I lower my car?
  35. At what point is SELL
  36. Symptoms of a Bad Battery
  37. Oil Question
  38. Project 66 Mustang / SVO 2.3 turbo update
  39. anyone know stock torque numbers for A-code 65 289?
  40. Best Headers for T5
  41. Quick! what's the dimensions of...
  42. cheap fun...
  43. A few questions about front coil springs/suspension....
  44. WTB 66 Mustang LH door
  45. Electrical Problems with Starter/Ignition
  46. where do i get?
  47. header clearance
  48. Head Install went Great, 1st try w/ pics
  49. What a great day!
  50. disc brake spindle???
  51. Sometimes you gotta love eBay!
  52. Odd stance after being up on stands?
  53. Car won't start
  54. My mustang lives(short sound vid)
  55. where can i get these?
  56. new wheels!
  57. door hinge / door alignment help needed bad
  58. Screw the EPA, WE NEED ZINC!!!!!
  59. Shelby or not
  60. LOOKED CLOSER at CABLE CLUTCH_have another ???
  61. t5 reverse lights
  62. what intake and carb to use
  63. BLACK
  64. eng. price
  65. Issue with my hazard lights...
  66. console difference?
  67. happy bday
  68. need little information 71 mustang
  69. Need help!! with 65 steering bad!
  70. Prices from '64 to present
  71. 65 parts on a 66
  72. What would you buy?
  73. Brake line question 68 disk front end
  74. Just getting some Visual Feed back
  75. blower kit
  76. Will any GT40 head bolt-on to stock 65 289? Or,
  77. Bad Shutter off the line..help?
  78. Help with decoding FE motor
  79. '65/'66 fairlane spindles....fit mustangs too?
  80. Flex-A-Lite
  81. PAINT choices
  82. Quarter panel drain plug valves?
  83. 427 from a galaxy-Good-Bad???
  84. backup lights staying on! help
  85. T-5 WONT FIT!!!
  86. 65 Block how large can it be overbored?
  87. car show
  88. Usefulness of Factory Assembly Manuals
  89. look waht i foudn in my oilpan
  90. BROKEN CABLE CLUTCH CABLE!!
  91. 67 Conv Back Quarter Windows Come Off Track
  92. Fitting quarter patch
  93. 302 engine overhaul
  94. Front End Please Help!
  95. Sound Deadening ?????????
  96. horses in the barn
  97. Floorpan replacement questions
  98. Floorpan/Trunk Restoration
  99. might be getting a mustang what am i getting into
  100. Window Mech Grease Question
  101. How to reskin a door?
  102. Manual steering upgrade on a 65 T code
  103. what should i do?????
  104. Removing Door Panels
  105. Ever seen a real 1966 GT350 Convertible?
  106. Spot welds :(
  107. 73 MACH 1 stripes
  108. No Brake Lights or Turn Signals
  109. Holley 4412 questions
  110. RUST PROOFING NEW COWL ASY
  111. key door cylinder issue
  112. 351c intake manifold
  113. need opinions on pro-comp vs patriot aluminum heads.
  114. 302 build
  115. Where is the Manifold Vac Port?
  116. 331 stroker project begining! finally =]
  117. Upgrade to 428
  118. Vynl Removing
  119. my '66 coupe
  120. hoses for 66 coupe ( 6 cy) w/o ac
  121. Red River Showdown
  122. remove paint on hood
  123. Does the 65GT Bezel fit a 66 Dash Cluster
  124. Putting the rear end back together
  125. Need Help 65 Fastback
  126. Paint?
  127. 64 1/2 turn signal Flasher Location
  128. fan thermostat
  129. ID'ing 65/6 door and a 67/8
  130. dashboard removal
  131. Repainting Rear End!
  132. 1965 front seat upholstery. Where is a GOOD 'how to' article?
  133. 71-73 Tire and Alignment Questions
  134. 351w deck height?
  135. Can you tell me where this engine tag goes
  136. some q's on stroker motors
  137. Spring project list?
  138. Speedometer / Cable Problem
  139. What is the Value of a Solid Boss 302 engine with no car?
  140. H-2-O IN THE O-I-L
  141. oil pan hitting center link...pics
  142. Unique Perfomance assets on the block.
  143. Belts...
  144. Speedometer Cable Tips?
  145. 66 spedometer question
  146. Rims for 1970 Stang, Fenders
  147. Paint / restoration ? 67 GTA
  148. Heater Box Removal
  149. Just bought another one ('66 Conv. $1,500)
  150. Heater case door
  151. 1966 mustang 302 to 351W swap... questions??
  152. 351w/400/340 =416cid??
  153. Who else can't wait for spring to arrive?
  154. Clutch Fork Issue
  155. POR 15
  156. Can you name this block?
  157. New Stang...
  158. Paint shops in the (916)
  159. any dif
  160. Installing aftermarket front sway bar in my 68 coupe...
  161. pitman arm, and control valve help
  162. loctite on flywheel bolts?
  163. Sound DEADNER
  164. radiator hoses
  165. Charcoal vapor canister tubing
  166. Gauges
  167. which shocks to order
  168. 68 Rear quarter panel question
  169. Accel, Pertronix, Mallory, Crane, etc.
  170. Carburetor spacer
  171. Need to Paint!
  172. whats this part called...distributor part
  173. what tooth flex plate,...
  174. NEED HELP WITH '73 RADIATOR HOSE REPLACEMENT!
  175. Show me your stance!
  176. What is a 289 block worth
  177. Best Order to Perform Restoration
  178. Tremic-5spd Question
  179. High revolutions at idle
  180. yes im a noob, but please help! milshake, not oil!?
  181. How much is this worth?
  182. Manual Novice
  183. New DazeCars web page on building a 9" rear end
  184. To Blur or not to blur?
  185. xcelerator?
  186. Shop Manual
  187. Cable Clutch Question!!!!
  188. Two Toploader 3-Speeds For Sale
  189. Dart Pro1, header question
  190. Window Tinting
  191. Found Cowl Leak, What's next?
  192. Can you order the spacer?
  193. Front frame rail extensions
  194. should I or shouldn't I?
  195. ? for the ignition experts
  196. Check out this sweet 65 coupe.
  197. T-10 shift lever question
  198. pertronix II coild and distri -- tuneing the timing
  199. What TEMP is your car running at? How 'bout Oil Pressure?
  200. radiator
  201. Fire Wall Insulation Pad
  202. T-5 swap... Half Way Home
  203. compression test and #'s ?
  204. Sick Paintjob IDEAS!
  205. Water pump pulley bolts
  206. Why is it hard to find a fan shroud for 6 cy
  207. Weather Stripping on Vent Window
  208. Questions about Suspension - Squeaks and noises... WD-40?
  209. Welding and Torque Boxes
  210. Mstg007 - 65 Stang
  211. crazy lights
  212. Stripe kits
  213. Rubber Spacers
  214. More numbers
  215. Warming up an Engine
  216. Rear Valance woes
  217. alive!!!! knock on wood
  218. flooding
  219. Wood or black grant steering wheel in my 67?
  220. Advise on Patching Shock Tower - Thinking I made it Worst
  221. Woodgrain Steering wheel assembly
  222. Challenger
  223. Recommendations for lowering the stance of my 65 FB?
  224. Random Question (Wire Tape)
  225. 69 Quarter Panel Question
  226. GT40 Heads and Intake on a 289
  227. anyone know anything about rebuilding third members?
  228. Pictures of the TKO and Questions
  229. Q1. Will this fit? Q2. fuel pump?
  230. recovering back seat of 66
  231. cant decide on a shifter...
  232. FLOORPAN REPLACEMENT ADVISE
  233. 66 with 65 mustang instrument panel
  234. Spiffy bolts for engine bay - **PICS**
  235. Went to pepboys today (pointless story)
  236. Rear Tires
  237. wtf
  238. Can't wait till I quit taking apart and start putting back together
  239. Open Track Day: First Timer
  240. Modern Driveline...
  241. ignition on 1968 coupe
  242. Fuel Pump Question? Stock or Holley?
  243. Have a 73 front valance ?
  244. 69 mach 1 stripes
  245. color code
  246. Question
  247. Best way to organize wires while prepping engine bay
  248. Blown head gasket or valve seals, I think
  249. A question or two
  250. Seat mounts...
