View Full Version : Classic Mustangs
  1. T5 NWC case vs WC case
  2. 73 Mach 1 Rear End
  3. Edelbrock Manifold
  4. 66 Coupe Rear Window Seal
  5. Newbie buying a 66 vert...questions
  6. Bill Cosby on the Shelby Cobra
  7. may be getting a 67 coupe
  8. Block clearancing for 347.
  9. ibanez guitar for sale
  10. Belt routing question
  11. What year is this 302
  12. leaks
  13. Electric Motor Conversion
  14. Advice on Repair
  15. 331 stroker build, Advice wanted.
  16. GAUGES
  17. converting from auto to manual steering?
  18. interior
  19. 64.5 Steering
  20. power steering and engine pulleys
  21. Labor charges for floorpan or frame rail replacement?
  22. 68 power steering
  23. body and frame issues-what to do?
  24. Backspacing for '72
  25. 69 Fastback Speaker Location?
  26. Firewall grommets?
  27. C4/AOD Transmission Crossmember Question
  28. Help with car history!
  29. original 289???
  30. Mustangs Plus
  31. instrument lights
  32. How much horsepower can 302 take?
  33. 1968 Leaf Spring
  34. egine build gone WRONG, what would you do
  35. C4 modulator
  36. 71-73 Stock Hood
  37. electric fuel pump ?
  38. New to classic 'stangs - help!!!!!!!
  39. C4 Tran what gears to use ?
  40. What to do with my 3k?
  41. Oil problem
  42. 1970 mustang advice
  43. Speedo Gear Question
  44. help with 66 289 heads
  45. highest compression on pump gas?
  46. Monte carlo bar installation
  47. Leaf Springs and Rubbers.. lol
  48. Backup lights installation on a 1065 C-4
  49. PVC help
  50. Help, ticking sound
  51. Feedback from the mechanic: engine is worn out
  52. wrecking my head .... what do you lads think about this
  53. Cost of labor when installing a crate engine?
  54. 1969 Mustang 302 upgrades
  55. Glove Box Emblem
  56. Finally Started!!!!
  57. What seam sealer to use
  58. Should I modify my 66 engine.
  59. fuel pump
  60. Used Vs repop
  61. Am I misreading tire numbers??
  62. Windshield
  63. Just starting resto: book suggestions?
  64. Just bought my 1/4
  65. thermostat orientation
  66. PST suspension
  67. 1968 shelby gt500 hood pins
  68. 289 Mileage
  69. preparing my garage for a new stang
  70. badge stencil, guide, emblem placement etc.. ?
  71. Need Help!!
  72. Well, is this too good to be true?
  73. help?
  74. ADVICE PLEASE!!
  75. waterpump question
  76. Complete 66' coupe restoration need some tips
  77. Maybe I found one?
  78. Rear Gears Question
  79. What year is this?
  80. Console question
  81. close ratio toploader?
  82. Do not order from superiormustangparts.com
  83. 66 coupe carpet kit
  84. headers for a 289
  85. '67 Shelby Style Hood for 1967-68 Mustang
  86. Mustang 1965 - 168 with best mileage?
  87. Seat belt options?
  88. R134a
  89. Pertronix Igniter II Adjustments
  90. electric choke carb ?
  91. *New Member-- 1977 Cobra II
  92. which one?
  93. Wheels for my 72 Mustang
  94. going p/s and r&p
  95. CSRP brake question
  96. dont think im goin turbo no more
  97. rims and wheels for a 1966
  98. a noisey P/S pump
  99. a little help please.
  100. I miss this site!! Ordered my suspension..
  101. opinion on 65 A code vert
  102. Engine questions for builders
  103. Long distance comfort and MPGs
  104. 302 clutch?
  105. Which one should I buy?
  106. power valve questions
  107. first year of the 302
  108. 1971-1973 What needs some upgrading???
  109. First time prepping for paint..
  110. Proportioning valve, mounting locations?
  111. Help with Battery size
  112. Any Body Running New Ford Racing 342?
  113. painting ideas??????
  114. 351W - What woudl I need?
  115. 351W - deal or not
  116. Getting closer to paint
  117. New Skins for patches
  118. Introducing my Mustangs - Loads of pics
  119. Random questions
  120. decoding engine hp
  121. How do you KNOW it's a 66 GT?
  122. why i love a shaker hood
  123. spark plug color help
  124. Tranny experts..
  125. Loud noise coming from right front wheel
  126. Rear end dimensions
  127. Carb
  128. anyone need an exhaust system?
  129. crazy question..anyone in Cherry Hill NJ area?
  130. T5 SWAP PARTS QUESTION
  131. Gas Fumes
  132. Wiring - Petronix Igniter II
  133. cigar lighter
  134. *[FRONT]* From a 1970 to a 1969
  135. *[LOWERING]* Need photos
  136. need a hand with alternator brackets
  137. 400 cubic inches of potential
  138. rear drum brake help
  139. another opinion request
  140. crankshaft rod journal chewed up
  141. need measurement
  142. Side Scoops
  143. pics
  144. Dead turn signals
  145. Parts?
  146. t5 price and help on numbers NWC vs WC
  147. 347 progress
  148. cleaning
  149. General questions, carb related, etc
  150. Metal sale...
  151. Correct location
  152. How to "break-in proceedure" of new engine
  153. HELP: boost application
  154. I have a clutch question.
  155. home paint job
  156. O2 sensor?
  157. Sheet metal - Cowl
  158. Sheet metal - front fenders
  159. Rear Seat Belt Installation Help
  160. need some trunk pieces
  161. Been awhile...
  162. Windshield Wiper Leak
  163. New 9" rear end for my 66 fastback?
  164. Can't wait to get my car back
  165. FLAT BLACK
  166. 71 mustang roof
  167. 351C swap from 302 questions
  168. connectng rod question
  169. doing my brakes over
  170. the mustang moves...
  171. Head Gasket Questions
  172. vinyl color question
  173. 67 shelby fiberglass nose ???
  174. ........
  175. TIMING CHAIN Question????
  176. Maryland meet - PICS
  177. Coil Wiring?
  178. Found out what screwed my engine!
  179. Clutches, return spring.....
  180. suspension swap
  181. Stolen '90GT
  182. building a boost motor need help ;]
  183. gonna make a rotiserie
  184. timing and full or ported vac
  185. 08 shelby motor in a 68?
  186. 66 Coupe Complete Resto
  187. Original Invoice... Don't Understand what Some of the Listed Additions to Car Were
  188. 1973 mach 1 info wanted
  189. Long Progress Report - 65 coupe
  190. Custom Engine Paints
  191. pics of your tach location?
  192. Po' mans rotisserie
  193. Help with headers? - I need the run down...
  194. Getting ready to buy carb/manifold-last minute questions
  195. Could this be a good deal?
  196. alternate grounding points
  197. spark plug gap
  198. 408 / holley program
  199. Got my April Popular Hot Rodding!
  200. coolant for aluminum radiator
  201. Tires
  202. spark plugs need replacement?
  203. Camshafts
  204. bellhousing ID chart -- please add to FAQ
  205. Frost turquoise
  206. How Loud is the car?
  207. Electric Fan CFM
  208. Mustang Couch!
  209. power steering help
  210. The amazing exploding lock washer
  211. New Spark Plug Wires
  212. Screw holes to big-sill plates
  213. carburator help
  214. interior ?
  215. squeeking
  216. check out my 67 fastback
  217. 3.73's?
  218. '69 body/frame assembly info needed.
  219. FIRE
  220. Interior questions
  221. Performance rebuild of my 289
  222. value question, for restorations...........
  223. '66 coupe turn signal switch
  224. Need some opinions please - again
  225. 1971 Mustang
  226. weird alternator noise
  227. Would 351C 2v heads bolt to a 289 block?
  228. Tremec TKO600 Help!
  229. Help with wheels
  230. 72 floor pan
  231. Mild Suspension upgrade for your Classic!
  232. Replacing gas line in a '66.
  233. Need Help identifying motor
  234. How do I determine the originality of my 1965 mustang's engine and transmission?
  235. video of my 67 running
  236. More done on the 65, found some rust....
  237. Never Seen Headers tuck-up so Good!!!!
  238. Kickdown
  239. Kickdown
  240. 69' horsepower help
  241. In a 1965 200 cid mustang does the air cleaner and valve cover need to be the same color?
  242. Rear Drums Before/After and a Question
  243. color vote
  244. Stock 8 in rear end
  245. some questions
  246. Need Ideas!!
  247. 70 Mach 1 rack and pinion question...
  248. Decoding Problem
  249. ralley stripes
  250. Axle positioning for 67 Coupe
