View Full Version : Classic Mustangs
  1. Looking for underdash wiring harness
  2. Where in the World is the Date Code on the Engine Block?
  3. 68 mustang rear end conversion
  4. The Date Code
  5. engine in - won't start with key
  6. Figuring out my 351c
  7. How to Determine if My Mustang's Numbers Match
  8. 73 Rear suspension advice needed
  9. Wood console replacement
  10. Retrofit seats and harness
  11. Woodgrain on Console
  12. stroker build questions
  13. **BENCH TEST**
  14. Tools
  15. Fixed the Bumper Bracket retainers on the frame rail
  16. Not a ford but can anyone help
  17. Classic Mustang specialist near New York city?
  18. Optimal 289 upgrade specs?
  19. How to identify an unknown paint color
  20. explorer rear end
  21. Just itching to cut something apart
  22. lots of ?'s
  23. T5, drive shaft shortening.
  24. 289 HIPO heads on a 302
  25. 65-66 Rear Fender Measurements
  26. s
  27. Need a opinion!
  28. 66 M/T Back-up switch wiring
  29. 8" rear end, HELP {{{limited slip}}}
  30. 302 to 351???
  31. SHOCK TOWER SPREAD
  32. need help on electricals
  33. adjustable strut rod/lower control arm question
  34. Another new guy
  35. piston question
  36. summer time coming
  37. 2 groove pulleys for 66 power steering?
  38. New guy!
  39. Engine to transmission plate
  40. Carb/Throttle Rod Hook Up
  41. 5.0 Into a 1970
  42. rims for sale
  43. Right starter motor for a 1981 fly wheel
  44. Boss 302 w/ Paxton Super Charger - ?s on my build
  45. silly new cars
  46. Cragar SS type wheels
  47. Valvetrain Help (Strike Force Heads)
  48. what size motor mount bolt?
  49. Engine feed harness
  50. Primer and Rust Question. PLEASE HELP!
  51. thinking about a T5
  52. gauges
  53. instrument bezel
  54. wheels for our truck
  55. Will These Work On My Engine
  56. automatic to stick help!!!
  57. Which Oil Pan/Sump
  58. Intake Casting Number
  59. need help finding some stuff
  60. And it starts........The 65 Fastback Build
  61. It's In!!
  62. Bullit wheel questions
  63. quarter pannel patch
  64. mustang truck?
  65. 302 engine to offroad.
  66. 66' Wont Start!
  67. Rubber drain plug tip
  68. I think I might own a Mustang!
  69. Cylinder Heads Questions
  70. headlight switch?
  71. Electric fuel pump, questions....
  72. Wiring Question
  73. Anybody know of a shop in Northern NJ
  74. Got a new rearend...now what?
  75. Best tool for cutting sheet metal
  76. Two Transmission Questions
  77. Help, I need a dimension from a 67 or 68.
  78. Rearend sheetmetal work
  79. 1967 Resto Mod
  80. do I need my engine rebuilt?
  81. need opinions on this 67
  82. Power Loss On Acceleration and Carb Backfire
  83. Power seat retrofit
  84. headlight switch
  85. wet sanding help
  86. New member- IRS ideas?
  87. Getting ready for the Swap
  88. 65 ignition switch
  89. help :)
  90. 66 trans question
  91. DSS Racing
  92. New carpet...
  93. Coil Placement on a 289 1966
  94. Axel Removal
  95. Carter AFB id numbers
  96. cylinder bore question
  97. distributor for 70 stang
  98. 289 build
  99. Trans Am
  100. 351W motor mount ??
  101. The good the bad the ugly
  102. good welder?
  103. stick shift trans
  104. ? for those who have built one scratch...
  105. torque box
  106. is it hard to install cam bearings?
  107. Parking Brake cable at the firewall
  108. Long Term Storage?
  109. Should I replace the top on my 1964 1/2 convertible myself?
  110. torsion bars?
  111. 66 gauge cluster
  112. CPR Street Machine = Excellent Service
  113. Any way I can tell if steering box
  114. can turning radius be improved?
  115. Got the bondo off
  116. Whats on your coffee table?
  117. steering box
  118. Got the rear end assembled
  119. she wont start
  120. bigger axle, will the car go up or down ?
  121. winternationals
  122. Clutch roller bearings
  123. Under drive pulleys
  124. New tire sizes
  125. Stock Manifold+Steering Box Problems
  126. Interior on '65 GT coupe?
  127. Gauges
  128. torque box removal
  129. Steering box
  130. One side down - one to go
  131. Gauges Opinion
  132. What size tires to run on 17X8 and 17X10's?
  133. summit exhaust system
  134. argue with my dad, is this 67 vert worth 6k? is this one worth 5.5 million?
  135. Got the Boss running- finally. What do you think?
  136. shopping list ... any comments ?
  137. Brain storming,new race car,need your opinions
  138. MUSCLE CAR NEEDED FOR COMMERCIAL SHOOTING IN LOS ANGELES IN LATE FEB.!!
  139. Headlight Issues
  140. MUSCLE CAR NEEDED FOR COMMERCIAL SHOOTING IN LOS ANGELES IN LATE FEB.!!
  141. 15" wheels without spacers
  142. Mustang II front end?
  143. 1970 mustang suspension and shocks advice
  144. boosting an I6
  145. Ipod
  146. Even a home built coil over front suspension can look SWEET!!!!
  147. Proof positive that this idiot can put things back together :) T5
  148. The 64.5-66 9" housing I built is back from the powder coater!!
  149. pvc valve
  150. Looking to buy, what should I check for?
  151. Engine pic ( AND A DUMB, DUMB question)
  152. Alignment Problem?
  153. C3 / C4 / T5, I am getting confused!
  154. Forgive My Stupidity!!!! Tri-y's do fit!!!
  155. 1968 fastback
  156. 1968 Mustang Fog lights
  157. There's a car man for every woman
  158. new cam...which heads to buy?
  159. Distributor ???
  160. kids and mustangs
  161. cold starts
  162. discbrakeswap kit and new rear axle. what brakelines will I need ?
  163. cigerette lighter kills the dash lits and radio
  164. wimped out on the 408
  165. distributor help.....
  166. hood scoops
  167. One piece glass - door window
  168. Sandblasting - What to Expect?
  169. oil & alt lights always red when lights turned on???
  170. Wood Grain - shinning up?
  171. OPINIONS:Boss-Pro 429 Scoop
  172. BUMMER!!! Tri-y's didnt fit!!!
  173. Engine rebuild kit question!
  174. How did our southern members fare last night?
  175. bleeding the lines
  176. just got a '65 mustang coupe.
  177. oh no!!!this cant be good
  178. FMX Transmission
  179. Sweet '67 Mustang at KC Boat Show
  180. can i use this clutch kit on my 289?
  181. 65 Convertible
  182. Improving the power steering?
  183. 351C engine build questions
  184. 351w Stock Cam Specs
  185. Parts for sale category?
  186. restomod AOD
  187. Disc brake conundrum
  188. adjusting/setting rockers...NEED HELP!
  189. just a reminder
  190. 64.5 help needed
  191. Interior Black Paint
  192. FMX tranny
  193. hahaha
  194. pullin' it all
  195. speedometer wont work
  196. One-wire alternator conversion
  197. help 66 mustang clutch linkage??
  198. What does it take to convert an I6 to a V8?
  199. Suspension Upgrade
  200. rack and pinion ?'s
  201. 65 mustang worth 3K ?
  202. 66 coupe replacement ????
  203. Will any 9" rear end fit?
  204. simple +- ?
  205. would you rebuild my C4?
  206. starting engine with NO transmission
  207. deck speakers
  208. wHAT to do with ,what is under 72 stang floor
  209. dim lights
  210. tranny and motor problems!! please look ;]
  211. would this fit?
  212. Ignition Switch Removal
  213. New Mustang Conversion
  214. taking steering apart help
  215. Distributor and intake manifold removel Question!!!
  216. trans question
  217. Two problems with my 1967, noise expert needed :)
  218. Exhaust size
  219. Looking for tool name!
  220. really getting pi**ed at ford parts
  221. Project Organization Opinions
  222. C-4 Pan Question
  223. Supercharged crate angine, where
  224. 351 cobra jet intake
  225. Free Dynamat!
  226. 1967 Mustang Coupe Wheel Fitment Question
  227. 67 GTA or Shelby?
  228. spindle to brake gasket help
  229. How much do I need to worry about rust?
  230. Late model seats
  231. 351W & Heads Heads Heads!
  232. Edelbrock Performer Cam
  233. makes me want to cry
  234. Thanks whoever cleaned up the FAQ
  235. Cost for floor replacement?
  236. 6 Cylinder Gas Mileage??
  237. Installing new carpet--any tips?
  238. Inner fender apron 1966 help
  239. C4 or C6
  240. Seat Identification?
  241. Sound Proofing mats
  242. Custom Auto Sound
  243. Corrosion protection
  244. Dashboard lights to LEDs
  245. painting headers
  246. need help with 65 mustang door locks
  247. I envy whipper snappers
  248. The value of occasional painting
  249. rear end
  250. afr head question
