View Full Version : Classic Mustangs
  1. Auto_mad_ic
  2. speedo help!!
  3. Torque on Shelby fiberglass hood bolts?
  4. -------->2006 Mustang GT Transformed into 70' Mach 1 "Must see"<----------
  5. Selling My '68
  6. car detailing
  7. Newbie Carb Question (Fuel)
  8. soaring
  9. Rally Pac Clock
  10. last Minute advice
  11. REAR 5 LUG CONVERSION HELP
  12. Have a Million Dollars?
  13. Will My Hookers Be Okay with New Engine
  14. 4 to 5 lug adapter
  15. gears finally came!
  16. radio bench test
  17. Here It Is....(Must Check This Out)
  18. Heater Box Removal
  19. Rally Pac internals
  20. tire size
  21. cool toys
  22. Carpet Question
  23. dreary
  24. Rear Suspension
  25. ADVICE NEEDED
  26. I'd like more top-end power on my auto. Any upgrades from a C4??
  27. Tune up and what else???
  28. What Size Tire Is This?
  29. 68 Mustang 6cyl to V8
  30. Update on my project!
  31. Rear end decoding
  32. efi to carb
  33. Great 67 Shelby ad and more!!
  34. floor pans
  35. gt 50%
  36. Where to get the Best Deal Nickel Plated Tri-Y's
  37. 67 front valance
  38. YEAR ONE MUSTANG
  39. Found a good article on Ackerman angle
  40. I hope some Pics
  41. Colorado area engine rebuild
  42. Cold air intake system?
  43. Has anyone used "Direct Fit Brakes" kits
  44. where can i get some 17" x 8" bullitt rims?
  45. Boyd Rebel Wheels on a 65
  46. electrical or mechanical?
  47. circut board good?
  48. 67 or 68 Battery Hold Down
  49. Scary Install
  50. 69 to 70 bolt in glass adjust
  51. Help Needed!!
  52. Edelbrock's new heads
  53. 67 Mustang???? Setup????
  54. do these bolt right up?
  55. 351C and 351W roller rockers
  56. 1968 Mustang Coupe for sale
  57. 65 coupe
  58. Its really that hard old man?
  59. Where can I buy Ospho
  60. Wow these spolers really do work
  61. 351c heads on 351w?
  62. 66 blue interior carpet questions
  63. radio
  64. torque converter questions
  65. stroker kits
  66. C4 Tranny Wires
  67. pulsing headlights/engine
  68. Bolt Pattern
  69. Hello. I'm Rob. Got a question about a 66, and
  70. Body Work 101
  71. wiring harness
  72. Ever do something stupid?
  73. Rotten Door Jams!
  74. power steering pump pulley
  75. 67stang w/ 351 windsor looking for cheap peformance
  76. 67 engine compartment
  77. Ignition options
  78. DOHC in 66
  79. 1/23/08 Project 66 Mustang /SVO 2.3 Turbo progress up date
  80. New Guy...want a fastback
  81. Specs on brake master cylinder
  82. Just to clear up backspacing and offset
  83. 65 Instrument bezel
  84. old school race or toque 2s
  85. How To Set Ignition Timing?
  86. All Ford Swap Ohio
  87. How much valve movement - 351C
  88. 66' coupe- too much play in the steering
  89. Surface Rust (photo)
  90. Mustang will be in April Popular Hot Rodding Magazine!
  91. shes alive
  92. 429 SCJ
  93. 65 aftermarket help.
  94. Suspension upgrade for 66
  95. rebuilding 289
  96. Can this be adjusted?
  97. you guys have flowmasters?
  98. 289 Head- Valve specs
  99. Autolite 4100 carb for sale
  100. Anybody know the stock weight of a 73 Mustang Grande?
  101. Electronic Ignition upgrade for 72 mustang W/302
  102. Transmission leaks... needs a fix
  103. Guidance Please
  104. please help
  105. Wiring Problem... Help...
  106. V8 swap - 302 or 289?
  107. cable clutches, cant decide what to do
  108. what part is this,...engine pics
  109. Recommended Upgrades?
  110. Closing the gap.. Shelby Endcaps/stock taillight panel
  111. 1967 engine swap
  112. 1967 engine swap
  113. Need advice to replace antenna on 65 Conv.
  114. Dash trim for a 65
  115. CJ Pony Parts 10% off sale/ Carpet Question
  116. headers!!
  117. how the hell do you take off the door lock thing????
  118. need gas tank for 77 Cobra II
  119. 1966 Mustang
  120. need gas tank for 77 Cobra II
  121. You got to see this
  122. 67 Coupe, Almost a Daily Driver
  123. C4 (auto) not shifting at all
  124. 66' 302- want more power
  125. Transmission weight?
  126. Manifold Code Help
  127. 302 or 289?
  128. Diff Question
  129. Cable Linkage Or Mechanical linkage?????
  130. 2 grand to spend
  131. valve cover gasket
  132. what to look for- 1971 Mustang
  133. steering help plz with instructions and to pictures,
  134. Instrument panel lights
  135. Wiring Diagram - Help (updated)
  136. How to put the ignition cylinder together
  137. 347 stroker
  138. NEED HELP!!!
  139. power-steering hose routing ?
  140. pics of new gas tank sending unit installation
  141. '65 Mustang paint update
  142. How do i get this (bearing) off?
  143. seat covering tips/advice
  144. Sat for a few months, now won't start - where to begin?
  145. show me your 65-66 front valance,...shelby style w/ and w/o bumper
  146. Which spindles for a 65 disc brake swap?
  147. 65' 289 into 88'
  148. 67 power steering diagram need
  149. Cleaning up engine
  150. alternator ?
  151. steering question???
  152. getting the car back up 1/2 in the front
  153. Exhaust
  154. WHEELS AND TIRES
  155. the 67 as of now
  156. Brake system advice...
  157. steering box rebuild
  158. 300ci Inline 6
  159. part cleaning help
  160. installing cylinderheads bolts/sealer?
  161. 4 speed shifter question!
  162. Show me the springs!
  163. 1971 Staggered Shocks
  164. 4 to 5 lug conversion adaptors
  165. 1969 Mach 1 428 CJ
  166. some cheap headers
  167. not to bad for 6 hrs and $250
  168. Hotrod and Muscle show - pics
  169. 5-spd conversion ?????
  170. pics of front suspension work
  171. Need opinions
  172. Electrical Problems?
  173. Any BLACK 67 or 68?
  174. color
  175. 302 rebuilding
  176. connectors
  177. Connect my Kick Down Rod to Car
  178. What rims should mustang have
  179. Please delete this post
  180. $200 aluminum radiator
  181. How am i doing?
  182. FMX Reverse Issues
  183. Ford Traction Lock
  184. '67 Derluxe Seatbacks
  185. Licence plate light Mach 1 1969
  186. cowl cost
  187. Finally Got My Cowl Off my '70 - Now the Fun Begins
  188. Carb Help
  189. Dome light mach 1 1969
  190. shes got hips!!!
  191. 73 driver side door anyone?
  192. window sticker
  193. everyones carbs
  194. Shop in Indiana
  195. Carb adjust?
  196. Carb and intake recommendation
  197. Accessory Drive Belt Question
  198. Starter Cable Question
  199. 6 to 8
  200. Head Identity
  201. Mounting Rear Spoiler on Mach 1 -69
  202. Paint code for Black Jade 1969
  203. Where do I Begin???
  204. Opinions on this welder
  205. Getting her straight 4 paint
  206. 1/8 mile times from racing last night
  207. 64.5 D code (very rusty) Fastback roof converson???
  208. gotta love it
  209. Teak or Walnut Woodgrain Mach 1 1969
  210. 289 redline
  211. 3 sp ****er
  212. Suspension question
  213. hood hinge bolt locations?
  214. Vacuum Lines
  215. good deal?
  216. heater core test
  217. Cast Iron Water Pump On Aluminium Timing Cover
  218. 71-73 Coupe Rear Spoiler Idea
  219. will these rims fit?
  220. shelby hood scoop position
  221. machine shop costs
  222. Purshasing a 65 Mustang Conv
  223. i need help with fitting my body parts
  224. New Look
  225. how do i take the trim off the windshield?
  226. light bulb
  227. 65-66 black interior
  228. CONVERTING 96 TO 66 QUESTIONS
  229. Delema-to low front tires wont fit
  230. 66 Restomod Questions
  231. Parking Brake
  232. Water Pump,Cast or Aluminum?
  233. Things your PO's have done...
  234. Isn't this one of the prettiest things you have ever seen!?!?!?!?!?!
  235. 1bbl carb 65 6cyl
  236. 65 shelby-R fibreglass nose help
  237. dash pad
  238. eleanor
  239. anyone know someone who is selling a fastback thats needs restoring... rust is no problemo...
  240. why you need a radiator filter
  241. engine problems
  242. chrome engine trim.
  243. This Really Sucks
  244. Anyone seen this in the for sale section?
  245. It came it came
  246. Positraction
  247. Things to do while underdash?
  248. bench seat mustang
  249. Spoiler
  250. Price for body work?
