View Full Version : Classic Mustangs
  1. Paint color?
  2. Rear end seals
  3. Failed Brake Lights?
  4. New Baer rear brake kits
  5. Interior kit mach 1 1969
  6. Rain leak + fender removal HELP!
  7. PCV question
  8. Brake rotors
  9. Gauges not working
  10. Search Build Sheet Decoder
  11. Where to buy a 16bolt Intake Manifold For A 351W
  12. The other side is done
  13. Edelbrock 600cfm carb
  14. difference in 3o2s
  15. Interesting listing for 1965 coupe?
  16. 65 blinker problems
  17. melting plug wires
  18. Chrome Interior Trim
  19. Elctric ignition and point eliminator
  20. r&p
  21. its fixed
  22. 6cyl-V8 trans difference
  23. 70 Mach 1 metal dash
  24. Suspension.
  25. 71 M CODE NEED FRAME
  26. Sound deadening *update*
  27. what's wrong with this picture?
  28. 87 351 minsor to a 65
  29. Oil in intake
  30. Man I have issues!!!!!!
  31. Original sticker and invoice
  32. what should it idle at?
  33. what would you guys like to see?
  34. 67 aod TV Cable
  35. where to get parts for my transmission
  36. 3 to 4 speed conversion
  37. 66 Mustang needs advice
  38. Bouncing Alternator needle
  39. turbocharger
  40. 1970 Trans Am Wheels
  41. Oil pan question...
  42. '68 Shelby GT500KR - first ride
  43. age of motor
  44. Plating
  45. what is this wire for?
  46. heater hose intake location ?
  47. opinion for my 289
  48. '66 side mirrors
  49. 1 wire alternator question
  50. Radiator size
  51. Home Made Axle Seal Puller
  52. Behind the front bumper - recommendations?
  53. Original rims
  54. FINISHED!!!!
  55. Shorty Headers?
  56. Where can I get a replacement title?
  57. 429 Ques.
  58. Odd driveshaft
  59. rain leak
  60. 1969 351 Carburetor
  61. Aluminum Driveshaft
  62. Electic fuel pump in a 1967 coupe??
  63. 4-wheel disk brake setup...
  64. California Black Plates
  65. Spark Plug Wires
  66. Ultimate Suspension?
  67. Power Door Lock Remote and Alarm
  68. Heres some help Decoding you'r vin guys!!
  69. Converting to electronic ignition
  70. 6cyl vs V8 rearend
  71. Power brake booster for 4 wheel disc brakes
  72. 302 compression question
  73. upper control arm hitting tire?...pics
  74. Changing out rear
  75. heads and pistons
  76. The '69 Mach 1 - The way to go!
  77. Engine Trouble
  78. General question about Eleanor worth?
  79. TRUCK ENGINE
  80. gt40p headers
  81. electric fan. for sale also.
  82. speedo help
  83. Wheel Spacing Question
  84. Camera Case finish
  85. Clutch question
  86. Will a 15x8 w/3in b/s fit under my rear end?
  87. Alarm, remote locks, remote start
  88. help please
  89. Wiring harness
  90. Quarters 67 to 68?
  91. Out with the old, in with the new.
  92. would it really be worth it
  93. another new efi on the block
  94. rear axle assembly...
  95. Header Probelm?
  96. Is a 289 really that repectable?
  97. Valance
  98. 1970 Mustang Gift Car Cover
  99. EGR removal
  100. Harmonic Balancer
  101. small block v8's
  102. 1970 power steering reservoir paint color
  103. It arrived
  104. anyone around southern california that...
  105. lower radiator hose for serpentine setup
  106. I can't decide if I want to buy a 68 or not
  107. power locks
  108. Weights
  109. Need Help With 250
  110. compression question?
  111. Need some build up advice
  112. 1965 Coupe block question
  113. Little confused on the wiring, need some help
  114. 5.0 build
  115. Convert to 5-lug
  116. Posi vs Non Posi
  117. Convertible Top Fit
  118. Got to sell 2 out of 3 - what would you do?
  119. suspension help?
  120. 5.0
  121. power steering
  122. From 289cid to a 5.0
  123. 4 link
  124. pros and cons
  125. rack and pinion question
  126. 351w intakes
  127. direct fit brakes?
  128. Tire Roast... Do you have any videos or pictures?
  129. Custom console final pics
  130. 2 speed shifter needed (hone-o-drive)
  131. Project Car
  132. Power Steering Help!!!
  133. would this fit?
  134. 5.0 v.s. 351 in a '69 mach 1
  135. went to the junkyard today...
  136. control arms
  137. rockers
  138. Bill of Sale - New Jersey.. Out of luck!
  139. custom autosound rear speaker system
  140. Brake squeak help
  141. Oil or PS leak?
  142. will these work???
  143. Did my headlights really go out?
  144. engine dies with acceleration
  145. cross boss manifold with carb
  146. Heater Plenum Help
  147. Repainting my valve covers
  148. 1970 Mustang
  149. head gasket thickness?
  150. Officially calling it done!! Finally!
  151. engine question
  152. affordable center consoles???
  153. Redline???
  154. repair manuels?
  155. need some basic engine help please
  156. original mustang blue air cleaner and valve covers?
  157. 68 center console?
  158. New Member - Price Question
  159. any wilwood users,...i need lots of answers
  160. Sound deadening photos
  161. Valve cover Replacement
  162. electric fan
  163. Can I repaint my alternator?
  164. steering column help
  165. steering box any good
  166. New & Improved Stance
  167. how to attach the spring?
  168. 200 to 250 6 cyl swap
  169. What Month in 2008 will Soaring's post count be surpassed?
  170. Need a valve job
  171. Torque setting question
  172. changed timing chain, now water pump pulley touches crank pulley
  173. Original style seatbelts
  174. 70 indash ac/heater in a 66 FB
  175. Classic 69 on TV show
  176. 289 build up Could use help
  177. hood hinges
  178. Covertable Questions
  179. strut rod bushing
  180. 1966 Hi Po Manifolds question
  181. Edelbrock F4B question
  182. Been gone a while.
  183. When is restoration to much?
  184. 1965 Fastback & Coupe Doors
  185. Remove axle shafts without a slide hammer tip
  186. Will this turbo kit fit on a '68?
  187. How much of a drop?
  188. Oil in coolant?
  189. Front suspension rebuild
  190. Fuel Line Illustration
  191. MF decals
  192. Can't decide what heads to wear!
  193. Coolant filter
  194. need some ideas
  195. what the hell?!?!?!
  196. Still having dash gauge problems
  197. MOVED: HOT GIRL AND A HOT MUSTANG
  198. 2 quick questions-Painting the engine-vinyl top question
  199. '67 Stang
  200. Water/Vapor from Tail Pipe
  201. Front/Rear Tires Pressure
  202. Shock Tower reinfocement necessary - 400 HP+
  203. the 67 update - 56k go make a sandwich
  204. Custom Gauges???
  205. update on my car. no 56k
  206. Parking Brake Cable Removal Tip
  207. D-day is almost here *65 fastback*
  208. distributor question
  209. 2 new anoying little problems
  210. Black, oily plugs
  211. How many colors did the classic mustang come in?
  212. Gear
  213. Hydraulic or solid lifters - How to tell|?
  214. jme gauge cluster
  215. PB Blaster worked - Thanks JamesW
  216. Leaks and lots of them.
  217. Pro touring vert gets pipes
  218. Which clutch?
  219. How far gone is too far gone?
  220. Paint question
  221. Door Glass Removal and Steering Rebuild
  222. arnt shorties supposed to work with a stick shift?
  223. True Story
  224. 460
  225. how many acessories can you hook up ...
  226. Vacuum/Tuning
  227. what sealer should i use?
  228. MSD Digital 6 plus ignition control
  229. Drum brakes locked up...
  230. Replacing carbs
  231. Vacuum Modulator line
  232. Rear gears installed
  233. Starting Issue
  234. cheaper blower idea
  235. water
  236. What's your answer to when people ask "When's your car going to be done?"
  237. Please critique this overall engine build...
  238. Which shocks should I get?
  239. which intake to choose?
  240. tie rod, spindle, rotor ??'s
  241. 64 1/2 Mustang
  242. Trip from Oklahoma to California
  243. what can i do?
  244. Quick, [stupid] question
  245. 1" drop in front of I-6 '66
  246. locating swap meets
  247. reverse flow water pump - lower radiator hose
  248. I need to find used 71-73 parts. How can I use Forums to find them?
  249. Transmission lines
  250. Help with valve clearance
