- cheaper blower idea
- water
- What's your answer to when people ask "When's your car going to be done?"
- Please critique this overall engine build...
- Which shocks should I get?
- which intake to choose?
- tie rod, spindle, rotor ??'s
- 64 1/2 Mustang
- Trip from Oklahoma to California
- what can i do?
- Quick, [stupid] question
- 1" drop in front of I-6 '66
- locating swap meets
- reverse flow water pump - lower radiator hose
- I need to find used 71-73 parts. How can I use Forums to find them?
- Transmission lines
- Help with valve clearance
- Is This A Ok Intake And Carb?
- mechanical to electric fuel pump
- I actually puuled an engine!
- Replacing oil pan on 67 mustang
- Need photo please, of dash to a-pillar
- Timing chain cover gasket set question
- maier racing sale
- Transmission Question
- intake and cam 95 5.0 carb engine
- Underbody Dimensions '66 Coupe
- Original owner 1964
- 66 mustang radiator support how to?
- What is your Classic related New Year's Resolution?
- I6 owners
- fuel and temp gauge go wrong??? help
- howd i do for $30?
- anyone from southern california?
- How does it sound?
- Blowout sale
- Firing Order for a Classic Mustang
- electrical / fuse panel issue on a '68
- Choke Thermostat/ fix
- cocky ricer
- Wrong cam, Cam or roller tip ratio rockers?
- 351 Cleveland 4V ideas
- quick wheel quesiton
- leaf springs
- oops...car wont steer....
- Data Plate Restoration
- brake conversions
- what do i look for in a car?
- LUGNUTS
- Heat Riser Placement
- cool video
- moving the leaf springs in
- headlight issue
- 6 cyl compression
- agressive cams
- 4 lug or 5 lug for my '65
- Problem removing my front seats..
- Tires for 67 Mustang
- Huge question!
- restomod steering wheels
- My horn button doesnt work. Pics.
- Removing Pedal Assembly
- Axle and transmission fluid levels
- BAD vibration!
- Cam Bearings 351c
- Mustang oil paitings
- Need opinions on how something looks, steering wheel
- tranny question
- ford 9 in.
- Rad Size?
- tow dolly question
- Remove Export Brace when pulling engine?
- Intake & Carb Installation ?
- Project progress over the holiday...
- Does my engine need a rebuild
- Lift installed with only one tall problem
- 68 mustang gt brake question
- worn out cam?
- just bought a 66 coupe
- 9mm wires too big?
- Shock tower brackets
- Torque Box & Toe Extension Repair
- What a great xmas!! NOT!!!Motor cought on fire
- Help design my 1965 Fastback suspension and drivetrain
- Shock Tower Clearance
- can i fit a 18x7 in the rear of my 66 vert?
- will these fit together? (tire question)
- MSD Ignition questions
- Any online walkthroughs for a Pertronix Ignitor and Flamethrower
- fine tuning issues need help!
- sme quick help....
- what color is this...
- Headers/Exhaust H.P gain???
- carb
- Where to start in purchasing?
- Need Help, battery or Alternator problem
- i dont think im going to repaint anymore
- Christmas Eve
- 650dp flooding
- Engine Swap
- Fender Flare ?Question?
- 302 Motor Mount
- (help) 1970 mustang starter upgrade
- Transmission fluid check
- bad brakes?
- Suspension - Grab-A-Trak Kit ~$500
- front suspension toss up
- stupid question
- Headliner Install for fastback... Help!!
- head cover
- Fuel Injected....
- Production Numbers
- new motor questions
- Happy Christmas everybody!
- pop open gas cap?
- 67 CS / GT - shelby scoops?
- 3rd gear stop bolt adjustment?
- performance brake fluid/pads.
- Treating hard to reach rust behind bumper trim
- Fixing warning lights
- Best way to cut off bolt heads?
- rim bolt pattern ?'s
- Does a C3 tranny exist?
- 4 Point Seat Belts - Will these work
- How do you restore old seatbelts?
- How do you keep white interior clean?
- Some test drive questions
- Rear End
- almost done
- 65 tail panel help
- Restoration Project, In What Order? - 1965 Coupe
- just got a 65 mustang
- Insurance..
- Clutch equalizer bar?!?
- I love Ron Morris!
- x-mas present but i need help
- Got a question for ya.
- turbocharged 302...
- Fuzzies First?
- What is the largest size rim to fit a 67 coupe
- Axles
- custom console
- changing to 3.55s
- brake pads
- Radiator Hoses - need help
- 4 lug to 5 lug conversion
- what tires to use?
- Heads too big?
- 1965 with 5speed
- Replacing heater cables
- 400 hp what to upgrade tranny and rearend wise
- Has anybody repaired a cracked steering wheel
- C4 Stuck in forward gear?
- Kite Runner (Movie)
- any mass-flo efi users out there?
- mini tub help
- Has the vast aftermarket stifled the DIY spirit?
- Bare Metal?
- defogger
- Got my car back from paint!! **PICS**
- floor pan replacement done correctly?
- Who's car is this?
- 1966 restoration/build up Houston
- Crate motor for 66 vert
- So here it is...13 months later....
- timing chain...
- replacing rear window
- What did I do wrong?
- HELP DONT KNOW EXAUST PIPE DIAMETER
- Engine and Transmission not connecting!?
- 3 speed to 4 speed conversion
- 4 speed shifter
- Blinkers....
- 1970 Mach 1 gauge cluster
- wiring question for HEI
- 1965 Fastback Parts and Diagrams
- Ticking 351W
- crate or build
- Intake manifold/Carb question
- Electrical problem
- running rich? or lean
- some advise on timing chain cover removal
- Rusty Scratches
- 3 Speed to T-5
- 69 Mach Quarter Emblems
- What will Santa bring for your Classic this year?
- rear suspension
- Cherry Bombs Comming Soon!
- My new heart...
- To the Paint Shop...
- donor cars?
- Why doesn't my engine start?---I need a car.
- Front Spring Woes
- Where to start?
- new pictures
- removing gas tank 65
- Goodmark sheet metal
- Selling my II!!
- 67 axle in 64
- stance questions
- best parts catalog
- How's my exhaust sound
- (more help) rack and pinion
- (help) 1970 mustang shocks
- Tunnel Ram Air
- What is the most gas efficient motor?
- Reference recommendations (books, etc)
- Which axle retainer seal?
- Parts arrived! '69 is getting new floor and frame.
- 65 mustang
- URGH- 351C HEADER PROBLEM NEED HELP
- Engine going back in question
- Full body cart
- Almost ready
- Merry Christmas and Happy New Year
- WTF? I have Posi?
- Made in China- is it worth it?
- Rear Main Seal
- auto to manual
- noobest of noob questions
- Bay Area, CA Paint Shops?
- Engine Bay and Wheel Wells
- 87 8.8 in my 67
- FMX linkage question
- newbie question - fuel line
- Questions for the Racer Guys
- $400 to blast my "65
- 1" drop or more?
- s/c places to buy
- What parts should I use?
- 1973 Convertible Gauge Cluster
- How to tell engine is original?
- Please Educate Me!!!
- HELP PLZ!
- Water pump, Aluminum or Iron?
- Rough idle on 66 coupe
- Leak in water pump/timing cover
- second gen. parts on older models
- Edelbrock Performer RPM vs Weiand Steath- Which do you prefer?
- which shifter??
- performance parts?
- Rim and backspacing question for '67
- 64 1/2 coupe
- advice on mounting fuel pump
- After researching,,,,,keeping the I-6
- suspension problems
- difference in 289 + 302?
- Sandblasting?
- Stupid question--- c4 auto
- Engine rebuild or Crate motor?
