View Full Version : Classic Mustangs
  1. suspension problems
  2. difference in 289 + 302?
  3. Sandblasting?
  4. Stupid question--- c4 auto
  5. Engine rebuild or Crate motor?
  6. Almost finished narrowing my 9" rear end
  7. paint question - exterior
  8. 66 engine mounts
  9. 351 Windsor
  10. having a couple of major issues
  11. how much tire on a tt2?
  12. Suspension Kits $$
  13. 351c or 351w?
  14. anybody use these subframe connects?
  15. front springs *Daze*
  16. rims
  17. installed hood pins
  18. new distributor question
  19. Thermostat
  20. Floor Board Cancer
  21. Does any one know where I can buy drill bits wholesale?
  22. hood pins
  23. Looking for this
  24. aftermarket hoods for 66 coupes
  25. Fastback and Coupe, interchangeable?
  26. Optima Battery Solutions for a '65
  27. pros and cons of rod length
  28. rough idle
  29. Been busy
  30. Scat 9000 cranks
  31. New motor mounts will not line up.
  32. best rear window seals for a 67 fback?
  33. T and L engines
  34. Speedo problems
  35. 2 colors 1 choice
  36. Wiper Switch Removal
  37. Car Troubles
  38. Buying '66 coupe. Recommendations
  39. Inboard axle seals?
  40. 1965 Fastback and Coupe frame/body
  41. southwestspeed granada spindle kits?
  42. What causes sloppy handling??
  43. Carb size for turbo's
  44. hello everyone..
  45. How I adapted my new Carb
  46. old mustang commercial lol
  47. need help
  48. Header install questions
  49. how to remove the cowl
  50. t-5 countershaft bearing retainer
  51. Rear GT Valance
  52. Think someone knew? problem areas?
  53. 67 Fastback and 68 parts car on craigslist...
  54. better brakes..
  55. I "restored" a pony steering wheel for my 62 Galaxie
  56. '66 Mustang - trouble starting in cold weather
  57. I need a bellhousing.
  58. my passenger door lock is broken, i can't open it
  59. ignition timing-numbers ?
  60. cost to paint engine bay?
  61. frame off question
  62. These good seats?
  63. 2nd hand body jack
  64. Paintwork
  65. Post pics of your ride....need some wheels ideas
  66. Cam,lifters,roller rockers....
  67. disk brake
  68. 70 Mach 1 door panels
  69. Torq thrust
  70. Gas Tank - Undercoat?
  71. installing aftermarket tach
  72. resto parts
  73. same problems 3 months later
  74. stock rear end
  75. Left Hand Drill Bits
  76. Can You Help Me Find It?
  77. Question about leaking fluid when warming up...
  78. Lower Radiator Hose
  79. Who thinks a 650 is too big?
  80. 66' steering wheel
  81. 289 Rear Seal ID and OD
  82. What's it for?
  83. pony instrument panel vs. non pony?
  84. mirror questions
  85. 66 Tear Down
  86. Here it is my Custom Linkage
  87. Paint code needed not sure on it.
  88. 66 coupe questions
  89. turn signal switch
  90. Color questions
  91. Strut Tower Brace?
  92. Flat cam??
  93. Blower decision
  94. rear end paint
  95. Nokia N95 for sale $300us Dollars, Playstation 3 60GB for sale $180us Dollars.
  96. need part names...pics inside
  97. Chrome Bumpers
  98. Value of '65 or '66 Convertibles?
  99. Mustang
  100. 1965 6 cyl. (4-lugs) wheel/tire help
  101. Tightening flex plate
  102. headers for 65 289
  103. Intakes
  104. Is my temp gage showing too hot?
  105. Flexplate ID?
  106. heater motor squeek
  107. power steering leak/rebuild help
  108. Does anyone know how to...
  109. Ok guys... what the heck (sound deadener)
  110. Restoration question
  111. Newbie with 1965 disc brake questions...
  112. rebuilding my suspension
  113. A few new pics, took the 67 out today!
  114. Moving to Chattanooga TN. Maybe?
  115. INNER DOOR MECHANISMS
  116. helping a friend out!
  117. Shelby Drop
  118. wire wheel covers
  119. new suspension loud as heck!!
  120. some progress today
  121. RPM Calculator I found online...
  122. Hawk Racing?
  123. exhaust leak somewhere
  124. Basics of auxiliary fuse box
  125. Wondering about value.
  126. Auto Shifter question
  127. Thanks JMD
  128. stupid brake question
  129. t5 question
  130. Factory console
  131. deep dish
  132. 28spline
  133. Dress Kit
  134. '67 Console Install questions
  135. 1966 Pro-Touring Convertible
  136. What Do You Think of Our New Project?
  137. SPARK PLUG WIRES?
  138. C-4 Linkage ?s
  139. Transmission issue - HELP???
  140. 429 stock intake
  141. still cant find a vacuum tree
  142. new steering wheel too stiff
  143. Valve seat grinding
  144. One Slick Mustang!
  145. Stroker or not
  146. metal cowl induction hoods
  147. Heater Box for 65/66
  148. do your seats hurt your back?
  149. Electrical issues part 2
  150. export brace and carlo bar going in!!!! sorta
  151. Flywheel and drivetrain
  152. 4 speed just about in
  153. brake and fuel lines??
  154. Hey Colostang
  155. Coupes
  156. The House All lit up!!
  157. new to fords so I need mechanical help
  158. tire and rim size question
  159. weird electrical issue
  160. Idle stop solenoid 351 4v
  161. i need some coupe pictures
  162. built trannys
  163. Valve Sizes
  164. dust caps
  165. center caps?
  166. Strut Rod Discussion
  167. backspacing
  168. Stock Seat belt re-install?
  169. Does any one else have a Christmas tree as cool as mine?????
  170. Instrument Lights Don't Work?
  171. Local Xmas parade - Vintage Mach I
  172. Exterior Color Options
  173. 1967 Mustang Schematics?
  174. GT stripes
  175. euro car guy
  176. vacuum advance question
  177. Special Paint - Marti doesn't know
  178. pulled the motor, now i need to spiffy up the bay
  179. Brake Booster help!!!
  180. Rearend work
  181. electrical question
  182. Alternator Diagram '65 Mustang
  183. dead battery?
  184. Coolant leak pt II (replaced wtr pmp)
  185. New MD area Stang-Ford club, check it out!
  186. missing nuts/bolts?
  187. Shaking Engine Upon Cold Start
  188. Bang for the buck on a 302?
  189. Christmas, the day for performance parts :)
  190. valve length?
  191. 66 vert...pulling engine,...need tips / advice
  192. Front Springs
  193. Coolant leak near fan
  194. visited chip foose's shop *pics*
  195. New Pony In The Family
  196. I think my FAN SHROUD sucks too much
  197. carborator and kickdown rod
  198. storing car for winter
  199. fuse or voltage regulator?
  200. Lambo Doors for 64 1-2 to 66 Mustangs
  201. 289 junk heads needed!!!
  202. mustang colors?
  203. "Shelby Sacks SAAC"
  204. Battery Recommendations
  205. Car looses power when accelerating!
  206. Heater Fan Help
  207. To change the pan gasket in car?
  208. Stud or Pedestal?
  209. how to clean up your engine bay
  210. Radio in a 1969
  211. Another ? about Valance
  212. Transplant issues
  213. rear seat foam for a 66
  214. Removing rear side window
  215. Unisteer rack and pinion installation
  216. Another lincoln 5.0 question...
  217. New 65/66 Cowl assemblies
  218. WARNING TO ELEANOR BUYERS!!!
  219. New plugs, now car is dead
  220. Ball Stud Control Valve Removal
  221. christmas ideas for you man ladies
  222. 1977 mustang cobra fuse panel
  223. Body Dimensions
  224. New Guy Here! Need your opinions....
  225. Help me decode a '68 fastback
  226. The other side this time
  227. Title for 1967 Mustang
  228. Front End Alignment and Shims
  229. Axle deminisions anyone?
  230. 67 side ornaments
  231. aluminum expansion tanks
  232. Looking for builders guide for my '69
  233. 1967 Ford 9" Rear End
  234. Rear Wheelhouse replacement
  235. Why solid lifters?
  236. boxed in truck
  237. 65 stang, worth it?
  238. birthday gift
  239. Engine tuning,, Problems..
  240. Pressure hose installation problem
  241. RPM's
  242. where to buy a 302 short block
  243. The Super'Stang
  244. c-6 trans leak
  245. The RMP "ETI Shock Kit"
  246. '68 emblem locations?
  247. bent valve/compression
  248. Higher RPM horsepower loss
  249. mechanical oil gauge parts?
  250. rear sway bar
