- Highbeam shuts off lights
- NPD front disc conversion ?'s
- c4 to t5 conversion kit
- Idle speed
- air conditioning ideas
- Emberglo
- Top Speed?
- '65 fuse panel
- Rear end question
- To start or not to start....
- 8 inch differential Mods
- Radiator to hot
- who said Germans were not funny.
- motor mounts
- Want a free 999 (build sheet) from Ford??
- Mustang CHRISTMAS! "Pics of the Tree on the Car"
- lights shut off un expectedly, anyone else have this issue?
- Would you buy an extinguisher for your stang? How many lbs?
- installing z bar
- need help with parts
- front coils
- Thanks DAZE, front-end aligned!
- Front Valance
- Coil Perch Movement
- A code ...K code questions
- couple of small revs
- almost ready!
- where to decode a c4?
- Front Suspension (Height)
- Rust through - what 65 fender part is this?
- Tri Y problems
- Decoding issue
- Mounting an electric fuel pump
- 1969 mercury cougar
- which rocker nuts should i use
- Cam bearings
- rear sway bar mod on 66
- Stuttering Sh*tbox Sally, The Tale of the II
- What should under the back seat look like
- solenoid
- Merry Flippin...
- Best place to get New Fenders?
- No more Flash errors
- Windows?
- gotta custom plate?
- brake backing plate
- oil slinger
- 1968 Shelby GT 350
- WOW!
- 67 p/s fitting help!
- Rebuild it or get a new one?
- is it worth it?
- cam/heads/intanke combo
- wheel size and raising
- A few problems I need help with..
- So... which way should I go with this engine build?
- Who is near DALLAS that can....
- exhaust differences?
- OIL LEAK
- Cutting body panels - how? And 3M panel adhesive
- Replacing Parking Lights with Fog Lamps
- You think 71 to 73's will go up in value?
- Weird Horn
- Rear Locker?
- im about to go crazy
- Power Steering Pump?
- funny story
- Will Edelbrock performer 3723 fit 65 289
- candy apple red
- Is a Holley 6oo 4bl to big for a stock 289
- fuse problem
- 1997 351w Questions
- The Sound of my Car!
- classic licence plate
- How do these look?
- I LLLLLOOOOOVVVVVVEEEEE Christmas!!!!!
- radiator hoses
- Anyone have fuel gauge trouble when it rains?
- Gauges
- Switchblade Key Conversion
- Paint supplies in Houston????
- Carb
- How do you think these would look??
- 67 Drip Molding Question???
- Coil Springs
- 66 battery cable routing
- Dropped her off for EXHAUST!!!
- rust proof?
- oil pressure
- 1968 Mustang
- 351 w
- harmonic balancer torque
- Modern Stereo in a 65-66
- 67 gt500 steering wheel
- fuel pump
- New Rims! Before and after
- oil cooler
- Deals on Wheels
- 70 Mustang, blew rod, New Engine? Ideas
- Main windows weather stripping help
- 18 mins on this 69 fastback
- Stock 351 C intake Manifold
- One bolt shaft still stuck - need help
- Defroster Hose
- Frame Rail, Rad Support info
- '69 Flywheel for 428CJ
- NEW CAR
- Windshield wipers..
- 2005-2008 seats in a classic
- interior panels/trim for 65 fastback?
- What does a D.S.O. really mean?
- Who has extra Holley's laying around?
- Anyone rebuilt their own PS Valve Body?
- Boss 351 Rotating Assembly
- Vacation Pics: Buffed the Pony
- Classic or not?
- Looking for recommended auto/paint for 68 stang in Northern NJ
- shaker 1000
- Injection Molded Valance?
- I need stuff for a 73 Mach 1
- New member introduction and have a question.
- reading spark plugs - one is different?
- Can anyone post a vid?
- steering wheel diameter
- throwing around ideas on a '69
- Transmission Type?
- Cooler Line Adapter?
- Rusted fuel tank?
- Lock Right locker
- Decision Time - Rears and Fronts
- '65 paint on inside of door
- weiand vs. edelbrock
- Defroster Hose attachment
- MR Amp onewire mod?
- custom 67 coupe
- Surging Power?
- convertible back seat brace in a coupe?
- No wing windows?
- scam?
- Paint Removal
- anything else?
- rear shocks mounting point
- Magnum 500's...
- show me your 'stang!
- Trunk Shocks
- Weather Stripping
- Decoding a block number
- Recommended Motor Oil?
- '66 coupe wheel & tire upgrade ??
- Alarm Install
- Best Manual
- timing markings question
- Either I really love modifying things OR I am a glutton for punishment 65 9" housing
- Inline 6 Drivetrain Tuning
- Electric choke question
- ALTERNATOR BRACKET BOLT BROKEN!! HELP!!
- UPDATED W/PICS I have a chance to buy a 66 fastback and 67
- Tire size? with Stock 73 Mustang Rims
- PROBLEM WITH 1ST GEAR...LEAF SPRING?
- Transmission Fluid Questions
- I want to supercharge my Cleveland, Can you help?
- It Keeps Dying when i put it in gear.
- Diffrential
- Electrical issue..
- 65 shifter
- Electric choke
- How to remove Chrome on 66
- Towing my 68 Coupe
- t-5 driveshaft size
- rear break swap ?
- wiring harness for efi motors
- Aluminum Flywheel - How much hp will it add
- 67 front blinkers
- noise when i get on it
- FMX or C6
- What tool(s) would you recommend???
- Drove the 65 today
- Anonomous Plugs and Wires (Lighter?)
- Help! Coolant leak from down under
- Running too cold?!
- Manifold for Fastback
- C-4 Linkage ?s
- Trans C4 auto ???
- Route 81N in Upstate NY - Was that you?
- 65 tranny sawp
- C4 Automatic Transmission problems
- The birth of the mustang
- What company is your favorite parts supplier?
- 67 Coupe with Coys C-67's and 429 Scoop?
- Classic Door Hinge (Latch) Fix
- 1967 Mustang Exhaust and headers
- Manual transmission brake pedal
- when to weld frame rails?
- HP estimates..again
- streetrodstuff
- bulb type
- My Valve Cover
- Hey conner
- i've been had, or have i?
- starter problems
- What are the odds?
- HELP!! Heavy clutch chatter, need ideas
- EFI setup
- saggin A$$
- Just Got A New Project
- Where to find oversize Rear Main Seal?
- 1/4 or 5/16 PS hose fitting - How to tell??
- Thread size?
- Repainting Interior
- how to lose weight
- Will a 428 fit in a 1965-67 Mustang?
- Rear quarter done finally
- problem with MF website and flash9d.ocx error?
- 69 mustang vin help!!!!!!
- Wiring Question
- carb calculator really works
- DIY Jig or something while replacing sheet metal
- Now this is nice
- What color looks best to you?
- Where to place jackstands on a 65
- 289 Ho worth $1000
- Headers
- is this Mach 1 worth it?
- carb repair
- car wont start (sometimes)
- Parking brake release Handle on 68 FB
- taking out the guage cluster
- dash
- building 351w
- 4 speed
- is there a palomino package
- Hit
- which trans is best?
- afr heads and cam?
- 67 mustang t-5
- earlyer carb power valve issue may be solved
- Engine Cleaning For a 67 with a 289
- Rat tat tat?
- Front Suspension
- too much pressure in the cooling system?
- welsh plugs for carbs
- Granada/Versallies swap worth?
- What Intake And Carb For My Cleveland?
- New cd deck in 66
- roller cam
- doh!!!
- Fiberglass Body Parts
- should i put a 351 in a 65?
- cool
- Oil Leak
