View Full Version : Classic Mustangs
  1. Whats this engine part?
  2. Adding a brake booster to a 65
  3. 302 into my 66 convertible 289
  4. Low enough?
  5. Granada front and rear swap
  6. 1968 mustang alignment specs
  7. What kind of 302 should I be looking for?
  8. Best sounding muffler?
  9. Restoration Reference books
  10. idle
  11. Fender removal
  12. C4 Tranny Leak
  13. engine swap
  14. Cam question
  15. Odometer roll-back question
  16. 66 Gastank question
  17. official build up 289
  18. Emblem Question
  19. MD cruise / show info ??
  20. What ignition coil goes best with a petronix ignitor?
  21. Handling N 64 - 73 Mustangs
  22. Question on tire pressure
  23. Who emailed me?
  24. gt350 and shelby 500kr
  25. 351 emblems
  26. Windsor Jr / Roush 180
  27. will these fit?
  28. *** Barn Find**** WHAT IS IT ??
  29. Tranny issues....
  30. Fluctuating amp meter ?
  31. question - steering play
  32. Couple of suspension questions
  33. flaming river tilt steering column?
  34. Help! convt rocker panels
  35. Does any one know what rate coil springs the...
  36. And the good news? on the cowl is...
  37. Overheating problems still.
  38. 1971 coupe to fastback
  39. hoods?
  40. setting timing
  41. Column / floor shift 1971 Mach 1
  42. Newbie Questions
  43. Ignition Coil Failure
  44. Body shops and floors
  45. Small block vs big block Toploader 4 speed?
  46. stripped thread
  47. underside painting
  48. Supercharged 351
  49. fiberglass!?!?!?!
  50. " Sprint B " How to Prove it ?
  51. too good to be true?
  52. Made a mess - need electrical help!!!
  53. Wake up my 289?
  54. cowl problems and leakage
  55. car model contradistinguish to the xenon bulb
  56. why wont my 67 mustang start??? please help.
  57. taking the stang out for its first long trip in awhile
  58. HP Question
  59. backspace with 18" on 67
  60. What is this?
  61. Few Questions.
  62. carbon buildup and cleaning
  63. Overcarburetion FTL!
  64. Too Tall Jones can't drive my car!
  65. oops my C4 has only reverse...sometimes
  66. Brake master cylinders
  67. what do you think?
  68. Afr heads on 351 windsor
  69. Wheel well pics
  70. HEI question
  71. any way to polish a doorhandle that looks like this ? (pic)
  72. Torino Shaker on a 1968 Mustang
  73. Vintage question
  74. Street dominator intake questions
  75. Strengthening Weak Points
  76. Door questions
  77. Help!!! 1970 parking brake question
  78. new picts
  79. Newbie tinkering with '65
  80. 9" rear from a '66 Galaxy?
  81. She wants the Shelby front end look...
  82. I Hate Winter!
  83. She wants the Shelby front end look...
  84. Body Work?!
  85. what floor pans?
  86. Look good to you guys?
  87. Cam and Valvetrain
  88. 3 Point belts ?'s
  89. another interesting mustang
  90. I LOVE reengineering original Ford parts!!!!!! As allways all comments incouraged.
  91. cable and hydraulic clutchs?
  92. No Fuel Pump
  93. 351 cleve
  94. Heidt's Products
  95. Newbie wants to learn
  96. whats been going on guys?
  97. Bit of a shock
  98. cam bearing
  99. Torque box protection
  100. I have a new compressor YIPPEE!!!!
  101. What headers would work best in a 70 engine bay with a 351w
  102. You hoodlums been behavin'?
  103. 72 mustang questions
  104. 65 Fastback-Strong gas smell!!
  105. Bad news...
  106. hand bending brake lines
  107. Lucky me.. car could've caught fire!
  108. A News Flash About Unique Performance!
  109. 69' stang
  110. mechanical advance
  111. Paint ideas
  112. Crate Motor
  113. 289 w/ a 268 cam - stock springs?
  114. radio in a 70
  115. 65 mustang fastback tires
  116. how much is my 65 worth
  117. Header Gaskets
  118. blinker wiring 68 fb
  119. timing markings?
  120. which (hard) brakelines ... ?
  121. Can anyone recommend a shop in NJ?
  122. One odd mustang
  123. Escrow Services
  124. fiberglass shelby side scoops
  125. Pulleys
  126. Old bolts
  127. Pull-A-Part?
  128. removing light switch
  129. Neutral safety switch
  130. I need a ps pump pulley for my 67
  131. gano filter
  132. axle u- bolts
  133. lifter ticking /adjustment?
  134. replace drum brakes with disc
  135. 1965 Mustang 289
  136. Engine Bay Painting
  137. cost of manual conversion
  138. Windsor or Cleveland
  139. Stalling while putting in gear
  140. '66 with inline 6
  141. Paint and body!!!!
  142. Question on starting up
  143. '67 or '68 measurements
  144. 9" Third Member
  145. MOVED: New Hybrid/Electric Car... 300mpg!
  146. What kind of glasspacks would you recommend?
  147. Dumbest thing ever
  148. Flowmaster 44s
  149. Anyone have experience with repop '67 tailight panel?
  150. clutches
  151. 1967
  152. 351 W in 67 Mustang
  153. Back to my brakes
  154. Valve Covers
  155. Mandatory parts
  156. Mustang Restorers - MD/VA area
  157. Which Body filer?
  158. wheel question
  159. Flow Super 44's
  160. Auto Restorers Magazine?
  161. steering wheel restoration
  162. MOVED: Farmers Branch Exotic Car Company Raided
  163. Gas smell
  164. Fulcrum spacer?
  165. Speed question
  166. pics of the 67
  167. starter stang
  168. wiring up my fan and fuel pump
  169. Maximum Backspacing???
  170. power brakes from from 94 1/2 ton
  171. Anyone sporting minilites 8 spokes?
  172. bad, bad mpg problem...
  173. Where to Start in 65 to 70
  174. New '68 Mustang - transport companies...
  175. This sounds too good to be true
  176. 66 starter issue
  177. Mustang Dream Last night..
  178. My 302 65 Dyno Results!!
  179. Pulley Question - Overheating Related
  180. Autometer Gauges into a '69 Cluster...
  181. im in love
  182. pony doors
  183. tick tick ticking noise after starting car
  184. Suggestions on breather tube?
  185. chrome GaLoRee!!!
  186. Viny dye - How durable??
  187. 1968 GT X Code info needed...
  188. 66 coupe on craiglist
  189. Open headers or flowmaster 40's
  190. M head vs 4v
  191. South Jersey Buyer
  192. 68 Console
  193. Blower?
  194. keep or ditch the wing?
  195. Bad Wheel hop..
  196. Stock Wheels
  197. got a wierd question....
  198. I finally get a new heart!!!
  199. were to get?
  200. best parts?
  201. engine bay,fender measurements?
  202. distributor question and wiring
  203. Brake bleeding!!!
  204. More head questions
  205. Battery Relocation for 65 Fastback
  206. replacing inner fender wells :(
  207. 1970 Cowl question
  208. Rack and pinion for the 1971-1973 Mustangs?
  209. New Engine Config for my Blower 66
  210. Engine compartment smoothing questions
  211. Classic Mustangs from 4walls.com - Peel & Stick, more.
  212. My '67 GT350
  213. Shock absorbers
  214. search function problems
  215. Average Entrance Fees at Shows, how much?
  216. lowering 1971 mustang coupe
  217. Remove the EDP Primer??
  218. how much to rebuild a carb
  219. what to do with a rusty classic
  220. is it worth it ? what will I need ? (6to8cyl, axle, wheels ...)
  221. whos looking for an engine build or parts?
  222. valve caps?
  223. V8 swap
  224. gt 40 casting numbers
  225. 289 engine build up - raise compression?
  226. Mustang ll rebadged as what?
  227. 4R70W Tranny problem....
  228. Posi rear gear carrier
  229. Heater Control Plate
  230. My Waterpump Pulley
  231. Rear end leak
  232. 9 inch splines
  233. Pics finally....
  234. good kit?
  235. Brake and Fuel Lines for '69
  236. size 40 tires
  237. help
  238. Where do I find this part?
  239. headers?
  240. TMI Sport Seats
  241. 5.0 in my 67-wanting advice
  242. Headliner Question
  243. Seatbelts: 4Pt vs 2Pt
  244. rough idle
  245. 1965 production qnty
  246. What edelbrock intake do you recommend for a 351w?
  247. heater resistor
  248. Anything I'm missing? One big push on body work...
  249. Wheel tyre combo for 66 Convertible
  250. Instrument Cluster??
