- To choke or not to choke
- AC Drain port broken off
- automatic shifter assembly
- T5 WC rebuild
- how much for an original 68 coupe?
- 66 mustang for sale.
- lots of questions!!!
- Dizzy Question
- 1965 Mustang GT Coupe value?
- Anyone From San Diego area going to the Coranado Speed Fest?
- 1969 Mustang Coupe
- Torque Converter !!!
- help with dash thingy....
- Carpet - 1964 1/2 or 1965 ???
- A Newb question....
- AFR - Wow!!
- Headers for a 67
- rotisserie i built
- TRANNY SWAP
- crank pulley swap
- Power steering
- front leaf spring bolts rusted in place ...
- t5 or 4 speed
- Front Frame Rail Woes
- Automatic to Standard Conversion - Drive Shaft?
- Disc brake kit - what ch'all think?
- Rivets for the door data plate
- 302, 351 or a 390 engine ?
- new interior
- its a stretch to make it connect...
- Update on my tranny
- Dash paint
- Found a $75 4bbl carb
- is it possible
- motor vibration
- Private Collection
- OEM website
- 1968 Restoration - What to expect to pay?
- rear disk brake swap????
- steering wheel bushing
- Engine Weight?
- Problem removing spark plugs
- Horsepower question
- 68 Radio Question
- Do i need a rebuild?
- 67 coupe headlight issue
- More on EGR
- mechanic says my 65 Stang's frame is cracked, what do I do?
- export brace
- 351 or 302 for my 69 fastback
- power steering problem
- I bought my first mustang!! WOOHOO! ( pics inside)
- Advice please x
- Buying a Mustang
- Headers???????
- What sparkplug do you run??
- DYNO TUNING ADVICE?
- brake system identify
- 289 Hi-Po Specs?
- Rear sway bars?
- New Clutch HELP
- New timing seal in.. Buttoned up
- engine work
- BRG Racing in Concord, CA
- Seats/ Upholstery Question
- AOD Crossmember
- ok im really stupid
- Early vs Later Engines..
- 1969 302 V-belt questions
- pick a part sun valley
- Desktop Dyno?
- Nube to ford specific repair and have a few q's
- 200 to 302 Engine Swap Question
- Help!! What should I do first on my 67 coupe
- Strange sound when shutting off engine...
- I think i found the mustang I want
- Fiberglass Hood Tips
- 4v header fit a 2v head?
- cc4 to aod conversion
- 68 mustang fog lights
- Sluggish Engine Doesn't Seem to be Getting Gas
- what kinda spark plugs and carb do you recommend?
- Horrible front end squeaks
- 1967-68 eleanor coupe???
- Headers 351c
- Any kind of cam, manifold, carb kit?
- stupid question number one...
- what would i need to change with this setup?
- 351c Good deal ?
- 351 questions..
- 302 Build up
- Working together..
- This look right?
- all the info you'll need 65-70!
- Trading a Porsche for 68 mustang ...help
- Mustang Horror Stories for Halloween
- The nightmare
- a shimmy and a shake
- ATTENTION: HUNT FOR STOLEN 03 COBRA
- whats your best combo?
- Weatherstrip without Reveal Molding?
- 68 mustang horn
- adjusting the control valvegot from checker whit
- strange tapping from engine near transmission
- which 351m/400 or 351 cleveland??
- Omfg ... slap my friend
- Engine Runs, but leaks oil from the timing cover seal
- horn doesn't work?
- Brake problem questions...
- Well. **** on a Shingle
- My car featured in "Mustang Life" magazine......
- c4 vs c6 tailshaft
- what tire pressure?
- Disc brake swap
- Things that don't work...
- 1965-1970 mustang info
- 67 MUSTANG BRAKES
- 160 tooth flywheel
- 67 Shelby GT 350 - clone or not?
- ls2 int a 65?
- will this rear end fit a 67?
- Stupid Question about Plastic Cowl Cover
- 1969 Mustang - 390 FE Big Block Questions -
- wheres glen?
- carpet??? for 66
- Sad news for NHRA fans
- Most common things to go wrong?
- Timing Problem - Just Beginning
- need help with rearview mirror arm...
- Driveshaft
- Quarter panel fitment a little off
- 1973 mach 1 question
- Mustang 66' Feedback
- Ooo, my back!
- All opinions wanted on engineering and functionality
- Tire size and back spacing chart
- Car Cover for Winter
- MOVED: I Want To Sell My 1967 289 coupe
- NEEED HELP ON OIL LEAK
- selling 67 i6 engine,tranny drive shaft,axle
- Stock vs Custom
- how to cut sheet metal
- tire size
- im starting new project for the classic guys
- Help!
- 72 Mach1: Need digitized logos and stripes
- Good news!!!!
- "period correct" 4-bolt wheels for a '66 coupe
- What do you think about this Mach 1?
- 67 mustang glove box light
- What to buy
- Help with 69'
- FLuid Damper for 289
- Just pulled the engine on the 1969 Mach1
- Where can I dyno my car?
- Deluxe interior colors
- How to find the DATE (MM/DD/YY) your classic rolled off the line?
- which is better
- Need help what is this car worth
- Window trim removal... how?
- poly strut rod bushing
- Kaboom
- Need springs, have questions?????
- which stroker should i go with on my 302 rebuild?
- help--what is my 66 mustang worth in kbb?
- Swapmeet Englishtown, NJ
- Pics of the Engine bay,, Still a mess
- Pitman Arm ?
- explorer gt 40 heads
- Pitman Arm nut size?
- 69 Tire Size? 15x7 and 15x8 Magnums
- 1970 Mustang
- Engine Swapping I6 to 289
- worth it?
- 50oz flywheel and toploader
- what is this called?
- mae racing - bad deal
- the vid
- Justification for replacing oil pump drive shaft
- help me with color
- Opinions wanted on my new suspension prototype (tubular UCA)
- LED lights?
- Posi, yay or nay?
- 1 WIRE ALTERNATOR
- Question for v8 swappers
- what color is this?
- Need your opinion ...
- Pictures of Rosalita, 1966 289
- Pictures of Rosalita - 1966 289
- ford crate engine questions..
- Im Kinda excited! (1968-Fastback)
- Found!
- Timing!
- Since we're playing name that part .......
- Final pictures of ยด68 Bullitt clone
- neeed your help on leak...
- Flushing Cooling system
- Trying to find 9" rear
- 351w stroker fans READ
- Engine still backfiring
- Almost "done"
- mag wheel polish question
- What 50 oz flexplate for a 5.0 mated to a C4 Automatic
- door locks.
- Fool proof ways to tune carb by sound/smell/taste?
- Santa came today in a big brown truck!
- Stupid question - 68 Electrical issue - Non working Fuel gauge
- once again, another name that part
- How much would you pay for my Mustang?
- another rear end question
- magnum 500 rims
- just some pics of 69 coupe.. well almost there
- Instrument panel problems still?????
- 8-trak player
- MOVED: Anyone need parts?
- control valve adjustment
- suspension help please.
- car attitude
- More Brake ???'s
- 5 lug conversion on a 67 I6
- Control Arm Zerk question
- Scarebird Bracket for Front Disc Brake Conversion
- (a few) pictures of my new car!
- vibration in steering wheel and dash
- GT-40 Heads or Port my Stock 289 Heads
- What type of sealant?????
- need yals help
- Cold starting problem 1966/289 automatic
- leaf springs
- Engine Swap ?
- c-4
- Bullitt Replicas up front and Deep Dish's out back
- main caps actually on the block
- Am I just working out air pockets?
- suspension, disk brakes rims and steering questions
- Long Term Storage
- Can a C4 leak from speedo cable input?
- Rear End Oil?
- Valve Stem Seals - I'm Going in - Last Minute ?s/Tips
- new power steering problem
- Is there an alternative to replacing entire dash wiring harness?
- Cost ??
- WHAT KIND OF TRANNY DO YOU HAVE ?
- my updated pics
- Fly-Ford Suspension
- what is EGR?
- valve-adjust ? compression ?
- Windsor 351 into a '66??
- Shock tower cap bolts
- Basic Question here... Car is stalling on me.
