View Full Version : Classic Mustangs
  1. Modern Suspension
  2. t-5 in a 65
  3. 1966/1967 mustanf
  4. Power steering re-revisited
  5. Control arms, what brand?
  6. Gonna buy a Hump Hugger, but which color???
  7. Noise coming from the rear of car
  8. How are these seat belts?
  9. stock CFM of mechanical fan?
  10. What and Where is a Vaccum Advance?
  11. I got some new burnout videos!
  12. Automatic Tran Shifter
  13. Roller Idler
  14. Standard shift vs auto?
  15. Drums to Disc '67
  16. how can i push my shock towers back apart
  17. Build date questioin
  18. What paint to use on gold iridum oil pan
  19. 68 died while driving... No spark, replacing coil...
  20. !973 Grande Project
  21. Question for those with 65 disc brakes
  22. Why does my rocker arms need tighten so much
  23. Subframe Connectors - are bolt-in good enough?
  24. horrible mpg, gears + cam the issue?
  25. FMX help
  26. White smoke and bucking?
  27. Overheating problems... need advice
  28. Sigh... Just one of those...
  29. Intermittent problem firing in morning only
  30. timing or carb
  31. T-5 problem
  32. fuel tank sump for efi
  33. 1967 I-6 Ford Mustang
  34. Is this a U Joint problem
  35. Another fine product from Krud Kutter
  36. chrome fuel pump
  37. ignition coil blew
  38. How do I determine the size of my rear end?
  39. Fixing up my steering... what parts?
  40. went to the track today...
  41. Resistor wire and fried Electronics.
  42. Header issues
  43. Iffy Gears in 1969 Mustang Coupe
  44. Carb problems after switching to 4 barrell
  45. 351 M bellhousing for c4
  46. Cleaning the underside of the hood
  47. C4 Transmission Oil Pump Assembly Removal
  48. t5 help!!!!!!!
  49. 65 Mustang 6cyl tran not shifting - Is this a Fordomatic?
  50. Is this any good?
  51. Power Steering Unit Rebuild on 67
  52. Starting the car after its been driven awhile
  53. Upper and lower control arms
  54. Weird early 289 heads?
  55. Gauges
  56. Trans swap
  57. Knocking Noise
  58. C4 No third gear and speedometer not working
  59. clunker bill b.s.
  60. Help and advice: 66 Electrical
  61. new rear end questions....
  62. which head gasket for 289?
  63. dropping in
  64. 8" rear end brake line setup
  65. Recommended Engine Swap for Classic Mach 1
  66. Subframe connectors
  67. What is a good transmission?
  68. soon to be grandfather has built 351 is it worth 2k
  69. Bad Solenoid?
  70. A pillar drip rail repair (how to)???
  71. install side dip rails
  72. Electric choke placement
  73. For the MSD owners....IGNITION WIRES?
  74. 68 Shelby brake pressure valve problem
  75. Carbon Cleaning Machine??
  76. AAAAAARRRRRRGGGGHHHHH...Never easy, is it?
  77. underlayment
  78. where can I get a gt350 stripe?
  79. Where to buy a auto transmission for 65 6cyl?
  80. electric water pumps
  81. PCV hose is sucking oil
  82. Suggestions for 64.5 dual exhaust conversion
  83. 1969 FORD MUSTANG
  84. Brake Light Switch Question.
  85. swapping front signals w/ driving lights
  86. How much rust is too much
  87. 70 boss 302 on ebay
  88. Can use a 95T5 in a 85
  89. Adding Hazard Lights
  90. Replacing heater hoses
  91. PLEASE HELP..my 1973 Mustanng mach1 429 Cj starts at wrong time
  92. Starter Solenoid relay
  93. Back up lights...
  94. 1967 Mustang engine swap Q's
  95. 5.0 vs. 4.6 3v Modular
  96. Name (Type) of Ford Wiring Terminal
  97. help! car died on me going down the freeway
  98. Front End suspension Questions
  99. 351C 2v to 4v
  100. Distributor cap question
  101. Finally Got the Oil Leak Stopped..
  102. Using Loktite
  103. Larger carb on my I6
  104. LED Tail/Brake/Signal Lights for a 1968
  105. What did i do to my mustang
  106. 620 springs too much!?
  107. Checking Ignition Wiring
  108. Difference in transmissions??
  109. Ugh, very slow leak from water pump area.
  110. Flowmaster questions
  111. is there a diagram to put the front together?
  112. All but done outside (pics)
  113. B.S. or Not - What Machine Could Diagnose a 1969 Mustang
  114. New here
  115. on vacation
  116. Wheels
  117. Car is getting painted today!! And I still dont know what color!!
  118. Vacuum Lines
  119. LED Headlight Poll
  120. better front end suspension for 65 mustang coupe
  121. Car Won't Start After Fuel Pump Installation
  122. Generator + modern electronics connections?
  123. what size fuel line?
  124. Close to inspection time & Hi-beams n/a
  125. 1971-1973 hood pins
  126. Winter Preparations!
  127. '69 Mustang Clutch and Brake Pedal Question
  128. Funky six problem, occaisional missfire or backfire?
  129. Twin Turbo???
  130. Bizzare starter issues! Need help.
  131. Front Bumper
  132. How wide of a tire?
  133. 429 Casting number s location?
  134. Leaf spring snag
  135. Edelbrock or Weiand
  136. Heater Core Replacement
  137. Turn signal switch
  138. Car value
  139. Motor and Trans, To Buy or Not to Buy
  140. Compatable rear ends
  141. 1966 exhaust manifolds
  142. Disc Brake Conversion 1970 Stang
  143. 8.8 Rear End Swap into 67 Coupe
  144. How do I know when my engine was made?
  145. Kid in a candy store! junkyard visit.
  146. *Might get a 65 mustang but the title is lost
  147. 289 electronic ignition problem ? help !
  148. 67 undercarriage
  149. what gears should i use for my 69 stang 302 rear end?
  150. Anyone have a pic/schematic of 68 200 I6 vacum advance?
  151. 68 Sending Unit
  152. 65 automatic floor shifter question
  153. 1966 exhaust manifold
  154. Need help with transmission question.
  155. 1966 Mustang 6 Cylinder Rear End
  156. Looking for a speed shop in NJ
  157. Picture Request: 69-73 3 speed auto floor shifter
  158. Made a "back seat driver" speaker box
  159. 68 stang
  160. metal prep and primer
  161. reverse slow to engage
  162. Wich transmission ?
  163. Another engine question, 351w H.O!!!
  164. a brake upgrade for a 65?
  165. Un-Wise But Exciting
  166. New guy intro
  167. c 4 swap
  168. Batt =12.3 volts but wont start unless I jump it...
  169. Flush mount windshield?
  170. Did alittle work with wiring
  171. '66 Having trouble at high speeds
  172. Loud Bang
  173. Phosphoric acid (paint) question.
  174. 1969 351w to 390 swap help
  175. Axle ratio
  176. What is this called?
  177. trans issues; please help!
  178. Thoughts on coolant additives?
  179. first set of problems with my 65 coupe I6
  180. AOD tv cable adjustment
  181. Planning a stroker for my 66
  182. 67 coupe a/c and rear end
  183. Carb issues?
  184. Fuel Pump Location
  185. question about cobra break conversions
  186. Rim for Spare Tire
  187. engine help please
  188. Power Steering problem, 1966 289
  189. 1969 mach 1 390?
  190. Strut Rod Bushings, Whats the deal?
  191. Differences in Late Model Mustang Wheel Backspacing
  192. Replacing Valve Stem Seals
  193. Progress PICS from Paint!!
  194. 69 Mach 1 Wheel Question - I want to go big
  195. Replace Fuel Filter 1969 Coupe
  196. 351w, wiring, paint, r&p and even a tea pot!
  197. where is residual pressur valve in M/C ?
  198. Car Sputtering/Stalling When Warm
  199. Help with 71 Stang chassis hard parts.......
  200. best body repair book
  201. Newbie lighting question
  202. 64.5 brake light switch after dual bowl conversion
  203. 64.5 brake light switch after dual bowl conversion
  204. Front seats newly upholstered
  205. fluctuations in oil pressure, pulling the pan tomorrow
  206. carb help
  207. Seat re-assembly.. I feel foolish
  208. New Exhaust - you mod guys will hate this
  209. Convertible top best brand and inst. cost?
  210. Choke tube
  211. Cheap radio replacement
  212. Tell Me What You've Found
  213. 390 F.E.
  214. Speedomoter Doesn't Work
  215. What's This Bracket For???
  216. Quarter Panel Extension Molding question
  217. Guys w/T5
  218. Thorley headers for a 289?
  219. My 1970 coupe project. Very very long opening!!!
  220. New Motor Overheating
  221. Correct engine detailing/paint procedures? Dents & Rust?
  222. Pulsation / Vibration only when turning right
  223. Need Photos of 68 I-6 Engine Bay
  224. Value of Car Decreased???
  225. poor man's mini-tubs
  226. mustang appraisal...
  227. New Guy
  228. Anybody here have these American Racing wheels on their car?
  229. Brakes
  230. Pulld my plugs today...
  231. 67 Heater Delete Question
  232. After engine warms up, ignition system acts up
  233. Quarter Panel
  234. Steering issues / what may be the cause??
  235. Oil-Fouled Sparkplugs, Premium Grade Gas
  236. Cowl assembly help
  237. few new pictures
  238. 68 10" rear drum parts
  239. T-5 shifter question
  240. Rear Axel-Shaft
  241. 1973 Sportsroof questions (429 SCJ engine?)
  242. Marti Report
  243. tri-y header clearance issues
  244. Headliner replacement
  245. Gas leak. Grrrrrrr
  246. Which Header?
  247. tire/wheel combo
  248. Whatta you think about this header?
  249. dash speaker wiring question
  250. Valve Cover Gasket Installation
