View Full Version : Classic Mustangs
  1. stalling
  2. Power drum or disc brakes?
  3. 351m/400 mounts for 67 tang
  4. 1970 Mach 1 up for auction
  5. best flowmaster
  6. The latest addition to my car stable
  7. What Exhaust Should Tell Me
  8. Pitman Arm hitting new Headers ?
  9. 1979 302 Noob to the V-8 world- suggestions?
  10. Looking for my first Mustang - 8F02T153050
  11. new Pertronix Ignitor II HEI distributor problem and how it was solved
  12. Best Car Cover?
  13. aluminum radiator seal
  14. Just Bought it
  15. Power steering bracket is stuck to the cylinder shaft.. Need some help..
  16. 68 Cougar 302.
  17. Disc Brake Donor
  18. the vac line off the back of the trans
  19. Which distributor is best?
  20. Replacing RS lower door hinge on 68 Coupe....
  21. t5 to 347
  22. Drum brake rebuild springs correct?
  23. 69 Mustang with a 390 engine?
  24. sharp looking 1973 mustang........
  25. Value of a 66 convertible???
  26. new interior questions
  27. I BOUGHT MY CAR TOO!!!
  28. electronic ignition?
  29. toploader problem
  30. edelbrock top end kits?
  31. I BOUGHT MY CAR!
  32. 68 coupe questions
  33. what order to get this stuff?
  34. 4300 D? Carb
  35. 302 Intake Question
  36. tons of info need for a 351 C Mach 1
  37. Lake George NY HUGE CAR SHOW Sept 7-9th
  38. Cutouts
  39. York, England.
  40. rebuilding diff & rear axle
  41. My Car selling Story.. it was worth it..
  42. R&R 289 Engine Advice
  43. washing my engine
  44. A different Rim question ...
  45. Hurdles to run bigger wheels?
  46. Hmm.... I was wondering .
  47. 347 stroker
  48. Car covers
  49. Radiator/Fan Configuration
  50. New engine temp question
  51. Good Deal?????
  52. She's off the jacks and on the road!!!
  53. paint colors for 66
  54. Question re: '65 6cyl Carbs
  55. rim help
  56. when is hot to hot?
  57. ford racing valve covers
  58. 2 questions.
  59. Is it a big deal ?
  60. piston ?
  61. Help ID these clips
  62. 351C 2V Enhancements
  63. To Power Rack or Not to Power Rack...steering that is
  64. 68 opinions
  65. What exhaust sounds good. 351C
  66. GT-500
  67. new to mustangs, need info 1971...
  68. I NEED RUBBERS!
  69. What kind of heads?
  70. ENGINE IS IN THE SHOP!!!!!!!!!!!!!!!!!!!
  71. idle changes
  72. new pics of my car (wheels, drop, and engine)
  73. One thing after another..
  74. Troublshooting Oil Pressure Gauge
  75. Decal Placement for '65 Mustang Convertible
  76. exhaust opinions
  77. Rim Question
  78. Poll! Which Valve Covers? Pics...
  79. Roush Small Block Crate Motor
  80. Need some opinions...
  81. Sprint 250
  82. Clutch Question 4speed Toploader
  83. The Ad that was placed a while back , And my Version
  84. What is the shipping Time???
  85. How rare is a '67 bench seat
  86. 65 Motor Mount bolts..what size??
  87. turn signal/parking brake light connections
  88. Elite Marti Report
  89. New Springs = Disappointing
  90. TOE BOARD,TORQUE BOX INSTALLATION
  91. '68 parking lights
  92. ignition
  93. msd on a 351
  94. help with holley fuel pump
  95. Right Balance for Sweet Looking Engine
  96. New to this.... any suggestions
  97. i want more power
  98. improper weather strip, roof rail
  99. oil on head
  100. Mustang under tarp
  101. cam question
  102. First Roadtrip
  103. Build Question
  104. Help with rocker lubrication in the 200c.i.
  105. Opinion-Who is best Part Supplier
  106. grounds
  107. Rear Main Seal leaking
  108. No Stangs In Baghdad
  109. Regristration question
  110. Undercarriage Paint
  111. Instument panel voltage regulator.
  112. 67 Disc brake conversion
  113. new springs = awesome.
  114. More Horse Power?
  115. 1971 convertible with 250...
  116. mustang shops
  117. 351w brakets and pulleys
  118. engine questions for cleveland 351
  119. Good Cylinder heads
  120. solid 350
  121. HOW MUCH POWER
  122. Drip rail chrome
  123. will tires rub?
  124. parking lamps
  125. trying to gety opinions on wheel and tire setup see inside
  126. stripers
  127. Your tires and opinions...
  128. 5.0 spark plug gap
  129. Silly 1969 Mach 1 Question
  130. DASHLIGHT SWITCH.
  131. 69 windsor head question
  132. 289/302 dipstick location?
  133. why
  134. Front Inner Fender Replacement?
  135. PLEASE REPLY ASAP! Dashlights!
  136. Dad's new ride...67 coupe
  137. glass price
  138. Opinions Please!! (Interior)
  139. It has arrived!
  140. Rebuild carb myself or go pro?
  141. Why are there so many Autos?!
  142. Opinions
  143. Door Jams
  144. dual exhuast kits
  145. Toploaders?
  146. shift kit?
  147. power question
  148. 351 RPM Air Gap, Under Hood in 66
  149. V-8 Cruise!!
  150. 69 Cowl?
  151. Open Headers??
  152. Help finding a part please. (ignition Switch)
  153. I didn't just strip it, I broke it off...
  154. Wrong parts
  155. who makes some good floorpans
  156. 1968 Mustang Radiator Support Rust Problem
  157. 68 coupe window part
  158. 302 vs 351w vs EFI ?
  159. junkyard fords
  160. 1965 200cid transmission
  161. Torgue Box Installation Help Please !
  162. MEDIA BLASTING
  163. Rally Stripes ?
  164. modifying stock seats
  165. another thing about 67
  166. Bent Push Rods
  167. Kickdown linkage
  168. Vacuum Advance VS Mechanical Advance
  169. anyone have a 71-73 parts car?
  170. 67 Window Problem
  171. HELP
  172. Jacking up a Classic Mustang...
  173. HELP! Bad vibrations!
  174. What is your Mustang restoration strength and weekness?
  175. Sig Photo, Please choose which one
  176. Seat platform question
  177. 67 Droptop!!!
  178. How blue are you??
  179. Evaporust - safestrustremover experience?
  180. Shelby fastback look on the coupe.
  181. So my new tires are rubbing already
  182. Power Steering pump.
  183. 67 basket case
  184. 66 spoiler
  185. Mustang Body Dimensions ??
  186. 66 shelby gt 350 hoods
  187. Help with decoding a casting number please!
  188. Outer wheel house removal
  189. What wheel is this?
  190. Fiberglass front end?
  191. Stupid question about fuel filter
  192. speedometer goes nuts
  193. '72 Mach 1 Question or two
  194. need feedback on my engine compartment
  195. I need a new dash VIN tag.
  196. seat question
  197. wandering gauges
  198. Buying sheet metal from a major vendor sight unseen.
  199. cowl vent leaks
  200. COWL VENT LEAKS
  201. 1968 Shelby parts info needed
  202. New alternator ?
  203. 4 blade fan vs. 6 blade fan
  204. Electric issue with LED tail lights.... (Mustang Project) Help, please?
  205. taillight connectors - wiring??
  206. 1971 Eleanor
  207. EFI Mods ?
  208. my new TFS heads
  209. valve covers.
  210. Ok, So there was kind of a miscommunication And I need some help!
  211. 67 mustang
  212. left rear brake light out but right ok...
  213. Are all cylinders firing?
  214. freez plugs and oil gallery plugs....
  215. Hey A While Back A Kid Posted Some Ad. Do you know where it is ?
  216. need help finding these parts
  217. Who's Running a 302 Ford Racing Crate
  218. FMX Rebuild
  219. Well its REAL
  220. How much horsepower?
  221. $250 Transmission rebuild
  222. 1965 Fasback value
  223. unique front brake conversion question
  224. What happened to the Soap Opera?
  225. My sig picture
  226. Front Disc Brakes for 68 Coupe
  227. exhaust question
  228. rear diff.
  229. Rear end gears
  230. So .. how are ya'll doing?
  231. Rerouting Header Tubes
  232. overheating
  233. Correct Stripes
  234. 8" or 9" rear end on 68?
  235. What next for my 66?
  236. wheels and tires for 68 coupe
  237. Question about Black Plates
  238. 302 Timing question
  239. Registration question.
  240. My first ticket, questions
  241. will a c6 bolt up to my 302
  242. Fuel Readings
  243. heads
  244. 67 mustang vs. 68 camaro
  245. First questions
  246. suspension and steering
  247. Greetings
  248. daily driver '67 questions
  249. 1966 i6 starting price?
  250. steering and brake problems
