View Full Version : Classic Mustangs
  1. Fuel Gauge
  2. FB quarter window upper pivots
  3. new wheels before new brakes??
  4. drum to disc
  5. 65 wont go into park
  6. good deal?
  7. WHAT EXHAUST IS THIS? IMCO?
  8. Important News for all Classic Mustang Owners
  9. How did the rearend go again?
  10. Fuel Cut Off
  11. How many square feet of sound deadener?
  12. rear disc for 8.8"
  13. which power brake booster should I get?
  14. Shelby-Style Side Exhaust?
  15. Rear leaf springs
  16. fuel pump or fuel line
  17. Progressive rate front coils
  18. Anyone purchased any parts from Sacramento Mustang Parts?
  19. Rear disc options?
  20. rear end gearing
  21. What Cam in a 68 Mustang 289ci
  22. need to removeremove speedometer needle?
  23. ANother HP question
  24. c4 tailhousing
  25. Monetery this weekend 8/16/07
  26. Tranny question
  27. Plastic Windshield Res w/pump
  28. Plastic Radiator Overflow?
  29. 69 firewall
  30. 1970 mustang value
  31. Fan Shroud Temp Difference
  32. how long are shackles supposed to be on 66 rear?
  33. paint colors for my 1969 mach 1
  34. temp sending will not fit
  35. where to buy rocker nuts
  36. Pretty sneaky Ebay listing
  37. 428 ford engine
  38. Help with noise (it can't be good)
  39. irish mustang owners
  40. X-pipe or H-pipe after headers?
  41. HP EST.
  42. What color?
  43. hp estimate and questions. Please read
  44. 351?
  45. *URGENT*Difference between 'concourse' and std. export brace??
  46. Console for a 67 coupe
  47. 1972 mustang
  48. What should I expect?????
  49. Just out of curiosity..
  50. Anyone live in/near Hoffman Estates, IL
  51. Stance
  52. brake question
  53. missing you guys
  54. 68 fastback mustang
  55. 70 Mustang Clearance For Wheels Question
  56. Granda 4 speed transmission
  57. Heater hoses
  58. new member... with turbo 67 66 stang pics
  59. harmonic balancer
  60. Bullet Rims on a 1970 Coupe Question?
  61. Expensive lunch
  62. Morning Engine Starting
  63. "Might as Well"
  64. '66 Stang
  65. Rear view relocated... how would you repair?
  66. crossmember: which way does it go!
  67. Traction Bars ...Override/underide
  68. Productive Weekend..
  69. Rear shackle questions
  70. Jaguar IRS in my classic Mustang project, feedback requested
  71. engine part # and specs
  72. need help identifing unknown big block
  73. Ol Yeller is lonely
  74. another name that part post
  75. running stock fan with a electric fan
  76. Someone explain the Shelby drop to me...
  77. 65/66 grille moulding clips?
  78. codes
  79. Need help identifing genuine '68 GT
  80. Seat track measurements?
  81. 1965 mustang 350 - for sale, needs resto.
  82. Lots of parts to install...(PICS)
  83. fitment?
  84. Speedometer question
  85. Engine trouble under load: low power, surging\bogging
  86. C6 tranny
  87. Choppy Drive Update
  88. shipping carriers??
  89. Is this a good deal?
  90. oil
  91. epoxy primer
  92. rust converter vs. rust remover
  93. 289>352
  94. Tied down.
  95. 4speed manual tran. in '71
  96. 68 vert - replace pwr top lift cylinders?
  97. 1969 Mustang
  98. Sturgis Mustang Rally
  99. New Member
  100. 1965 top cowl
  101. Wheel Covers
  102. Looking at 68' 289 Questions
  103. Temporary Vaccum Loss
  104. body filler
  105. Slightly OT Ford 360 question
  106. It started!!! However.....
  107. Tachometer addition?
  108. gears clicking when downshifting
  109. painted my 66,water in air compressor-SPOTS!
  110. Need help with flexplate 28 or 50 oz
  111. Q's for those of you that went from 14 to 16 inch
  112. 1967 Seat Belts
  113. For those who think it is more valuable stock ...
  114. Sway bar question
  115. been awhile
  116. mini spool?
  117. Need help IDing a Harmonic Balancer 28 or 50 oz
  118. 65-66 timing pointer
  119. T5 Conversion
  120. How to calculate Revolutions per mile
  121. Choppy Drive
  122. I6 header / exhaust upgrade?
  123. 289 heads
  124. 1965 A-code valve cover/air cleaner paint?
  125. another leaf spring question, what is original?
  126. Ebay's crowded
  127. 600CFM vs. 750CFM...how much does it matter?
  128. undercoating question
  129. brake lights stay on
  130. steering stuck need HELP now please
  131. Clutch release lever bracket install??
  132. engine gauge feed harness
  133. Nice
  134. proper length seat belts (front & rear)
  135. Door Latch Issues
  136. gt 350 question?
  137. Wheels and tires for Mach1 -69
  138. MOVED: French Emission Label?
  139. 4 speed ?
  140. Rack and pinion from YearOne
  141. I knew it was bad but not this bad
  142. Finally got the car on the road and boom!
  143. Help! Oil leak towards back of oil pan on a '66 289.
  144. Wiring Harness Burnt up, need help getting started
  145. door hinge repair question
  146. It doesn't get any better than this...
  147. Need help decoding casting#
  148. Suspension work pics
  149. Engine bay / inner fender painting
  150. Will my car sit level with Grab-a-trak?
  151. 65 Dash pad trim clips
  152. First Time Working on a classic......and I
  153. Roll Barz!
  154. Wing window vent rivet tool
  155. shifter heat
  156. solvent.
  157. I need help from anyone who lives in Tampa!
  158. 351w rebuild
  159. Carb vacuum ports ... what do you use to plug them
  160. need help finding a radiator filter
  161. AC Condensor and dryer.... help
  162. what carb?
  163. Put new gears in today
  164. Help!
  165. CFL MUSTANG WEEKEND BLOWOUT @ DAYTONA - *RESERVE SPOT HERE* - [8.25.07 & 8.26.07] - EVENT!
  166. Undercoating ... what have you used
  167. Right hand drive mustangs
  168. automatic to stick
  169. Instrument Panel Problems????
  170. how to remove seatbelts
  171. tuning problems
  172. help wheel cylinder ears
  173. MOVED: Way off topic political poll
  174. 1969 Mach 1 stripe question
  175. Hi All
  176. Spring insulator help?
  177. WIRING FOR BACKUP LIGHTS
  178. new to mustangs speedometer probem
  179. New memeber question on console
  180. Weatherstripping
  181. 65/66 Quarter panels drains
  182. Turn Signal Cam repair
  183. '66 Pro Touring Convertible Update
  184. Wood Grain Dash Restore
  185. Dim Lights
  186. '69 Dash Idiot Lights
  187. speedometer needle remove
  188. 1970 boss 302
  189. Giving our daughter a 69 Mustang
  190. Disc Brake Help
  191. Oil smell
  192. Got my car taken away
  193. what air filter with Holley/BG carb that has HEI dist
  194. 65 mustang ignition wire
  195. Collapsed Lifter?
  196. San Jose plant status ....
  197. Help Checking Part at Prestige Mustang in GA
  198. '69 Interior redone & steering wheel ??'s
  199. what braket is this
  200. 68 mustang gt
  201. low oil pressure reading
  202. Holy Forum Outage
  203. hardened ex. seats
  204. 289 roller lifter/cam mod question
  205. A/C&Heater Controls
  206. Flexplate has a small weight attached..
  207. Front suspension question!!!
  208. 289 heads on a new 302 block?
  209. 351c
  210. squealing fan belt
  211. Keeping the rain out
  212. Does anyone have a saddle color interior?
  213. Interior Correctness Question
  214. Bullitt............Not that impressed.
  215. Quick (& prob'ly stupid) question(s)
  216. Locked out of my trunk please help!
  217. Where Are You MF'n From ?
  218. race team / car club
  219. GOING DISC!!
  220. goodbye '68 mustang... hello '66 mustang
  221. steering column removal
  222. Dual res master
  223. 302.. A/C and power steering setup
  224. Removal of 'Moto Lita' steering wheel?
  225. CSRP
  226. finding bulitt rims
  227. ospho vs. eastwood rust dissolver
  228. Hydro-boost
  229. Safe way to work under the car?
  230. Manual steering box with PS
  231. Straight 6 problem
  232. Catalogs Etc. - From Unsolicited E-mail
  233. bucket seats in the back
  234. couple of questions
  235. 289 rebuild...
  236. Tell me who's right...
  237. 302 clicking sound when warming up
  238. My 67 Coupe
  239. Custom fuel lines?
  240. Need help with a VIN tag
  241. power steering box on '68 coupe
  242. ok how do i make it fit?!?!?!?!
  243. engine hoist rental
  244. Parking Brake Woes
  245. Resetting Speedometer???
  246. So Now Im Confused If I dont Have GT....
  247. Help me choose an Exhaust
  248. Starter Probs Figured Out - Maybe
  249. Brake fluid change?
  250. Brake Line Thread
