View Full Version : Classic Mustangs
  1. Starter Probs Figured Out - Maybe
  2. Brake fluid change?
  3. Brake Line Thread
  4. flywheel balanced
  5. Package Tray
  6. Pics From Tonight
  7. 4 Link in a 65
  8. New seats
  9. engine rebuilding book
  10. My F#!*ing hood!!
  11. 289 any one
  12. Someone Please End my Headache...
  13. 66 Horn Issue
  14. Dwell meter Basics...
  15. 302 with a/c pic
  16. '70 Wiring Harness
  17. Spring compressor
  18. Pics plz?!
  19. Ebay Shelby ?
  20. 68 Mustang engine question
  21. Engine rebuild DVD
  22. I just had my car judged
  23. backspace
  24. Wheel Opinion
  25. Please read!! Gas mileage & some other stuff
  26. augusta mca show
  27. Tranny Gear after rear end swap
  28. where is a good place to check a vacuum?
  29. MOVED: Full tilt night ride
  30. radiator size
  31. Cooling question*ADDED PICS OF OIL LEAK
  32. Newer 302 Vs Older 351w
  33. 68 convertible-should i buy
  34. 66 Heater resistor question
  35. Temp Sending Unit
  36. Carb Recommendation, '66 5spd, Streetrod
  37. engine swap
  38. Steering Wheel installation
  39. Where is the Dome light wire
  40. Muffler?
  41. I6 to 351w EFI question???
  42. cowl hood
  43. quick (and hopefully easy) questions for 66
  44. cowl ?
  45. Thought it'd be easier...
  46. 69 heater core
  47. Time.................
  48. Something fun! Pick your brain
  49. 65 Mustang with 302, want to add an AC Unit
  50. 3 speed Transmission compatability
  51. engine gaskets!
  52. Clicking on the 302 Engine
  53. 68 stang dash light problem - new switch
  54. Bit the Bullit today, looking for some reassurance....
  55. Pushrods
  56. Clutch linkage
  57. 68 Power steering
  58. Not a pony but looky what I bought today .......
  59. Mechanical oil gauge
  60. Brake Problem on 66 ...
  61. GTA clone or not
  62. engine block
  63. What trans can you put on a 67 L6?
  64. Drop!!
  65. Sweet deal!
  66. No Juice
  67. MOCA4
  68. MOCA3
  69. MOCA2
  70. MOCA show pictures
  71. Heater core leaking
  72. Need some old vs. new measurements, please.
  73. Engine vibration question
  74. Great Show!
  75. Does this count as a "Barn Find"?
  76. Thanks
  77. Duraspark or Pertronix
  78. 5800 '72 vert
  79. old parts
  80. iS THIS A GOOD DEAL?
  81. draining a t5
  82. KYB gas adjust or... else?
  83. Power steering ram boot
  84. question about pulleys
  85. hood clearance question
  86. 67' Coupe 289 - 69 Mach 1 351w 2bbl Swap Questions
  87. Rear disc brakes from ranger
  88. Which would you choose- 65 stang vert vs 70 mach 1?
  89. Selling a classic
  90. Engine Install Websites..Tips/Tricks? Help!
  91. 66 Title
  92. abs headliner
  93. Washer Res 70 mach 1
  94. oil pressure, is it normal?
  95. Hot August Nights-Rock n' Roll and Classic cars
  96. C4 trans install
  97. Classic reading
  98. Brakes - Phase 1 nearly complete
  99. 2005 rims on a 1967 Coupe
  100. 351-2V to 4V Conversion
  101. loud exahust
  102. Rear Explorer discs?
  103. Knock Knock and shavings figured out
  104. Where does reverse go?
  105. Forums
  106. engine wont start
  107. MOVED: mods that should be done?
  108. some junk i found
  109. 5.0L engine swap
  110. Silica sand clean up
  111. fan shrould for a 66 200ci 6 popper
  112. Correct yellow for Black License Plate
  113. Headliner costs
  114. Needle orange paint
  115. I get $700-$1000 for my birthday, what should I fix?
  116. fixin to paint,anyrecommendations on kind of paint?
  117. What mild cam lifter kit would you recommend for a 351w?
  118. ready for new headliner
  119. dash wiring question
  120. minitubs???
  121. more horsepower
  122. Anyone 100% leak free?
  123. What 4bbl intake would you recommend for a 351W? will a weiand stealth for a 289 work?
  124. A/C Idler Pulley
  125. Really Fun Adventure..After buying a 1968 stang
  126. tci c4
  127. Can you hear my stumble too or is it just me?
  128. speedo
  129. fuel mixture
  130. Project 67 RUSTang *new pics
  131. Anybody ever had a ticking fuel pump
  132. Oil pressure for the 408W...
  133. suspension uprades
  134. tachometer
  135. 71 seat tracks...
  136. 66 Mustang won't start...Newb to this Forum...
  137. distributor
  138. Best paint for engine bay/compartment?
  139. Quarter door Gap
  140. A/C
  141. Windshield restoration
  142. The beast breathes again, gauage issues
  143. Emberglow Interior Color
  144. What Friggin' Next...The Starter?
  145. Coil location?
  146. Anyone have a Holley 2bbl or 4bbl for sale?
  147. Clutch Pedal Squeak
  148. 69 louvers
  149. racing stripes for 66 stang
  150. Starter issue
  151. 3-point seat belts?
  152. frame dimensions? major reconstruction
  153. 1966 1 barrel carb
  154. FINALLY!!! Got my car back today!!! (8 months!)
  155. Trimming console for A/C
  156. 302 from Boat?
  157. HELP!!! Water leak
  158. Fuel gauge
  159. Torque box problems/questions
  160. Putting Independent Rear Suspension (IRS) in a 65 coupe
  161. 65-67 fastback availability
  162. Fuel Bowl (carb) orientation
  163. 351 M
  164. Pict of wheels and tires on 65 65
  165. Good Price for 1966-1972 fastbacks
  166. How do I clean this rust/junk on the Engine??
  167. 72 351 w ----------------------> Semi-Good Engine!
  168. !!!!!!!!!pros, cons, and why!!!!!!!
  169. Shifter Kludge
  170. Engine dies while turning
  171. 1966 heater/defrost fan speed question
  172. stupid or just out of my mind!?!?!?!?!?!
  173. Painting Advice
  174. Transmission question
  175. jack point on a convertable
  176. Big Shroud, Check er out! 64-67
  177. 9" ford rearend
  178. my project fastback progress... PICS**
  179. Squealing Tires
  180. Vacuum Advance Affects Dwell?
  181. engine assemb. problem
  182. AOD and headers
  183. 66 Oil Gauge...
  184. heater/ac box removal
  185. I think this guy is trying to scam me... What do you think..
  186. Coil Spring Removal Tool
  187. Hydraulic Lifter/rocker adjustment
  188. removing rivets
  189. Knock Knock
  190. Need a New Clutch
  191. Will a performer intake clear the hood on a 66?
  192. late 302 heads Vs. Early 302 heads
  193. Help reinstalling rocker panel trim/molding.
  194. what do you call the part...
  195. CjPonyParts
  196. 73 mach1 1st outing
  197. My 67 Resto...is there a "right" place to start
  198. cleaning your engine
  199. disc brake for 67 coupe
  200. 1971 Coupe Questions ...
  201. 620 Spring install vs. new spring perches
  202. Stalling 67 289
  203. Any clearance issues with Magnum 500 wheels and 4 wheel disc?
  204. No where else to turn.
  205. put new leaf springs on, car sits up 5"over tire!
  206. Mustang Featured Marque
  207. Monte Carlo bar installation
  208. Opinions on my engine bay black
  209. Springs (coils) on rear shocks?
  210. finding a 351W
  211. Water Leak
  212. Master Cylinder HElp
  213. rear leaf spring opinions
  214. Shelby conversion, rear window
  215. 66 Leaf Spring Questions
  216. Interesting find
  217. a few pics of my dads cars (IN THE RAIN!!)
  218. DEEP DISH...
  219. MCA Augusta
  220. 1967 question #2
  221. 1967 question
  222. new ring and pinion break in period
  223. 65 Fuel Line/Gauge??
  224. For when I get enough money
  225. Not high rpming?
  226. Air Conditioner?
  227. 69 I6 has five lugs
  228. 66 mustang alternator problem?
  229. Which supplier has the best quality rear louvers for a '69 Mach 1 ?
  230. Restoration Help for a Noob!
  231. Does this look rebuildable ? Should I buy it?
  232. Mobil 1
  233. whats this hole for?
  234. wagon
  235. Rough idle in drive....
  236. So How Many Thousand Miles Is Your Car Reading?
  237. 1970 mustang cleveland 4V what are these hoses.
  238. Who still has theirs?
  239. What size
  240. whats my 70 mach1 clone worth?
  241. BBQ and Poker
  242. Transmission Lines Install
  243. Presentation ... and first problem!
  244. Radiator overflow options
  245. Part info for a '67 Mustang
  246. Beer and Mustangs...
  247. speedometer bounces
  248. 60s stangs good first project?
  249. Running Hot
  250. motor mounts
