View Full Version : Classic Mustangs
  1. New doors hung
  2. 351c Timing
  3. New 67 Hood
  4. new to old
  5. popular crate engines
  6. Steering Wheel
  7. 4100 carb, spacer and intake?
  8. SHOULD I CHANGE MY GAS TANK
  9. Another Tire Question
  10. Will the 69 C4 trans fit a 66 mustang?
  11. New to the classic car thing, what should i expect for a fastback?
  12. Coolant leaks everywhere
  13. What color?
  14. clutch fan verses stock flex fan
  15. gas tank issues
  16. Fan Shroud issues
  17. 67 fastback 289>300hp
  18. 71 Mustang Instrument panel lights
  19. C4 Shift Kit
  20. Looking for Utah Shops
  21. 13" Wheels
  22. cheap 66 fastback indiana
  23. Car Dolly/Drive shaft
  24. Nice Paintjob....
  25. engine dying on 67 mustang
  26. Cowl - I think I'm in good shape?
  27. Production #'s??
  28. Front running lights
  29. Interior Wood Panels
  30. blinker question
  31. Styled Steel Wheel - what color?
  32. What type of exhaust system!!
  33. Spring perch
  34. MOVED: WTB 4100 Autolite and intake
  35. Door lock issue
  36. Parts on and ready to run!!!
  37. Ralph sold the farm.
  38. Emblem Removal
  39. Guess the name of that car contest.
  40. Parts came from Jim
  41. Almost took my eyebrows clean off!
  42. Wheels?
  43. Jumpy Speedometer
  44. pas window regulator
  45. Prices?
  46. New 68 owner
  47. 70 coupe floor pan
  48. seat belts
  49. A/C Compressor
  50. CABLE CLUTCH
  51. 9" rear end
  52. better cooling fan
  53. Gauge issue clarification
  54. What should I do?
  55. Here is that car with the doors that many thought was fake!!!
  56. What clutch for a '65 stock rebuild?
  57. frame rail extension rust
  58. what kinda tranny to get?
  59. Rear axle leak??? (WITH PICS)
  60. 1967 Valve Body Number
  61. 3-pt. Seat Belt Supplier
  62. Greetings from a new user with questions
  63. instrument bezel replacement
  64. caliper paint for intirior?
  65. Convert 1971 Grande to Mach 1 - Is it possible??
  66. ++++need help++crooked 302!!!!++++
  67. overheating??
  68. turn signal doesn't work all the time
  69. 1969 Roadrunner vs 1968 Fastback
  70. anyone ever use lead to fix bodywork?
  71. OMG, had to share this pic
  72. BEWARE LA MUSTANG
  73. Stupid fender question.
  74. Heartbroken...:(
  75. What does Glen (Soaring) do in retirement
  76. 289 pistons
  77. 65 Mustang project update
  78. 1970 Transmissions
  79. Shelby hood
  80. 1966 2.3 Turbo Mustang
  81. sent out to get media blasted
  82. 69 mustang gauges
  83. WEIRD CLUTCH ISSUES
  84. What color Black?
  85. If i get these heads(link in post), what exhaust?
  86. 1968 Shelby console repos??
  87. 302 Build opinions
  88. 68' coupe rear bumper removal?
  89. PONY MEET 7/22/07 - KENT NARROWS, MD
  90. Drive shaft installation question
  91. Seats aren't the right year?
  92. careful with who does your body work
  93. Appraisal?
  94. where to get good floor pans
  95. 351 and gt40 heads
  96. Adding emergency flasher to '65
  97. Code ?
  98. 70 pics
  99. Cold air intake on 68?
  100. Anyone have a couple of 289 stock pistons?
  101. 1968 mustang motor mounts for 302
  102. Engine Identification Tag (ID) question
  103. 72 convertable.... is there any major things to look for!
  104. Control Valve Question?
  105. 302 or 351
  106. 351W
  107. Need info on buying '65
  108. max temp.
  109. Hood Pins
  110. where would the engine numbers be?
  111. Slower on new server
  112. Inaugural drive...
  113. treatment of bare metal parts
  114. Audio System help
  115. Fox Body?
  116. Grab a Trak susp. questions
  117. Will it fit?
  118. 4100 carb & stock intake?
  119. Golden Hack Award Nominee
  120. Ticking Time Bomb???
  121. Wiring
  122. Trunk Lock question
  123. first show
  124. 69 engine bay restore and detail
  125. Total timing on a 302 ?
  126. What temp should i run my mild 302 at?
  127. Looking into a 65-69 Mustang
  128. axle seal leak
  129. Howto buy an old mustang
  130. sticker or no stickers
  131. Corral lights up
  132. best engine/radiator flush
  133. Custom throttle linkage complete
  134. Won't start when hot
  135. Window problems.
  136. Set me straight on H and I beam rods
  137. Figured it out!!
  138. Electric Fuel Pump
  139. MOVED: 1965 Mustang For Sale !!!
  140. Anyone intersted see classic forsale
  141. '67 Coupe Alignment Specs
  142. Vacuum leak?
  143. Car Show
  144. Site Problems
  145. How do I find out what size carb I have?
  146. Brand new '66 mustang owner.
  147. door glass swap
  148. Update to my 65 (alot of pics)
  149. new here (pics)
  150. Final shot
  151. what Holley do I have???
  152. Painting and Patching...
  153. Differential advice?
  154. Juke Box on the Cheap
  155. Rear valance is off
  156. How to get the rocker panel chrome off question.
  157. seat tracks
  158. MIG Welder?
  159. bullit rims on 65' fastback?
  160. Breather smoke
  161. Night driving
  162. Tail panel splash shield?
  163. New shoes for my horse - Pix
  164. Exhaust or Valve cover leak?
  165. E-Brake Handle Retrofit
  166. 289 Head Tightening sequence
  167. M code Coupes
  168. Upgrading drum brakes to disc brakes $?
  169. Engine help please!
  170. Who Needs Door Handles????
  171. -Door Pannel
  172. starter question
  173. any tips on header install?
  174. Question: What do the vacuum ports on my carb. go to?
  175. A/C price
  176. Power steering
  177. shipping companies?
  178. suspension upgrade
  179. 67/68 trunk hinge question
  180. Photo Shop Anyone?
  181. Overfilling an Automatic Transmission - what's the worst that could happen?
  182. Stupid Question....
  183. Ok to mix synthetic brake fluid with regular?
  184. Ford 289 Header Bolt Size?
  185. Engine Question
  186. Distributor, First start question
  187. Gutted
  188. 1966 GT powersteering removal
  189. Mustang Legroom
  190. Engine temp tonight
  191. Gt?
  192. maaaaaaaaan, i want these 2 stangs
  193. camshaft question
  194. inner door
  195. cutting a hole in the hood yes or no?
  196. What can a Carb Spacer do for You?
  197. whats best for my 302
  198. 3 point seatbelts
  199. 289 Crank Specs
  200. 1967 Mustang horns
  201. Alternator belt squeel
  202. One wire alternators?
  203. 68 Tail light issue
  204. Sound System for Convertible
  205. Wat would you do if you had $700?
  206. Which Plug Wires?
  207. Rear Quarter Panel to be repaired
  208. High Beam Light
  209. 1968 mustang tach....
  210. compression ratio's
  211. To clone or not to clone...
  212. Would you fix this or replace this?
  213. AOD Converter diameter and Stall speed
  214. Windshield Removal Process?
  215. Speed demon 750 Carb on a 428 Cobrajet??
  216. reverse light problems
  217. Corral lights up
  218. my new delima
  219. torque converter question
  220. Rotor pics?
  221. PLEASE HELP! ASAP! 1967 Carb question
  222. Shorter Steering Column?
  223. What A Newb - Temp Gauge Install
  224. another stupid question by me
  225. 65vs68 Engine Set ups!!!
  226. 72 302 power recovery
  227. Power Bleeders????
  228. Fastback in popular culture?
  229. Possible
  230. CJ PP
  231. Mighty Demon 750 Carb, Treasure or Trash?
  232. Finally working on the 68 fastback 427 again!
  233. how much could i get
  234. Explain my spring to me....
  235. New distributor any Idea's
  236. fuel pump ?
  237. manual steering conversion
  238. How much to offer?
  239. 69-70 Air Conditioner Question
  240. Value of a 65'
  241. Power steering fluid or f type tranny fluid?
  242. 1970 Coupe Availability
  243. ac activated idle adjustment (solenoid) for 260 V-8?
  244. Good Year Eagle ST
  245. Purchase Stock Engine
  246. E-Brake Problems
  247. Production number by paint color
  248. Classic Mustang For Charity
  249. How old for a classic?
  250. 1965 and 1966
