- 1970 Coupe Availability
- ac activated idle adjustment (solenoid) for 260 V-8?
- Good Year Eagle ST
- Purchase Stock Engine
- E-Brake Problems
- Production number by paint color
- Classic Mustang For Charity
- How old for a classic?
- 1965 and 1966
- carbon fiber or fiberglass?..
- 1969 dash pad removal
- what is this
- What changes are necessary to switch to an 87-93 302 roller block??
- battery still dying!!!!
- Put the Red Stripes on the Mach 1
- my engine is almost done.. possible problems
- 5.0 efi swap question
- 1966 Coupe, is this a factory A/C unit?
- Drum to disk upgrade kit question
- 351 W
- Parts are in!!!!!!
- Lowering
- rotor and cap distributor part number V8 289, 2V 1968
- Hey guys, need to find a good welder
- New heads should I bore them .030?
- Could a guy put together an "Overhaulin'-type" event for a noble cause?
- Speedo is off on 1968
- Parts is parts
- My Ride, New to Forums
- upholstery dye/paint
- fuse box layout
- Water Wetter vs. Purple ice
- Steering And Braking Problems!
- Timing gear question
- 65 engine questions..
- 65' VIN report help and your opinion
- Power Steering Fluid
- pieces of nylon/plastic in pick up screen
- New Vinyl Roof
- OH SNAP! $2500 Vert!
- 5.0/302 vs 5.8/351w
- Input regarding rear main seal replacement
- Horsepower for a 1965 289?
- power steering issues
- 65 console mounting brackets
- Ground Effects
- 1966 Mustang Coupe and a poor college kid...
- FS: 1969 Mustang Coupe
- Smoke coming from one side of 67 Dual Exhaust
- Other forums......Suck!
- Got my DL!!
- Car wont start, something electrical...
- How Old Are You Compared to Your Car? POLL
- Wild stang spotted
- Putting on Holley Heat Shiel with My 4 Hole Spacer
- Chemical Stripping
- New backfire
- wrecked '66 fastback
- found idiot wiring!!!!!
- "self-aligned"
- all lights pulsating
- RACK AND PINION STEERING
- Suggested Shocks
- 1966 Rear Question...?
- shaking comes and goes on my 65
- 66 GUAGES IN A 65
- value for a 65
- what is my 69 fastback????
- Junker Car!
- change oil, no oil pressure
- Increasing compression ratio on the I6
- What would this be worth?
- 289 won't start
- Front Drums
- Lifter Bleed Down???Help me Please!!!
- removing thermostat
- opinion
- Leaf springs
- what color is this?
- HOLLEY 570 CHOKE/TUNING Q.
- Investment in classic mustangs?
- new r&p setup
- Slow-Slow-Slow
- Convince my parents
- i used a " Ridge Reamer " today
- Need some direction-power steering pump
- Dipstick questions
- breaking in my motor ?
- charging trouble?
- Search engine doesn't work for now
- Transmission
- short headers or no??
- Are you guys getting this on here
- Rear belts in a '65 fastback
- kickdown cable
- How old are you compared to your car??
- has anyone heard of?
- Aluminum V-Belt Pulleys for 69 351W
- More horse power 66 289
- Exhaust system anymore and then...
- 67/68 Bullitt Movie Replicas
- Schematics for Seat Belt Installation
- no power in gear
- Modified Exhaust System
- vibration when driven over 30 mph
- 69 AC Control Vacuum Switch - Where?
- Headers on a 66 straight six
- New guy...
- Long trip home ......
- how many amps is my alternator?
- steering wheels
- Power Steering house routing - '67
- new radiator, still hot?
- 17" rimms for a 66 coupe : tires
- Just a reminder.
- Which Spark plugs work well?
- 66 1brll carb part needed!!!!!!
- Interior door light?
- inner door skins
- Where did that wire go?
- Identifing Windsor Engine
- Bad coil?
- Intake manifold question....
- rack & pinion
- Odometer rollback
- Side Marker Question
- Carburator Question
- Power Meet Sweden 2007 - mixed pictures.
- where is the temp sender?
- Be Careful Please
- out for a cruise
- TOOL GUYS?
- Northern GA mustang Meet
- Converting to 9" Rear end. Need Help!
- Source for early 65 289 timing chain cover
- blacked out tail light panel..
- can anyone tell me what model...
- New engine??
- Good Car to buy???
- pony interior help
- door weatherstripping question
- Reputable resto shop in OR/WA
- 1965 Steel wheels 14" factory ?
- Rough Idle and Vibration
- Water Leak Help
- Couple of pics of my cleaned up block,,
- what to do?
- vacuum leak
- Aluminum Block 347?
- pillar pads
- Newbie w/pics
- 67 GTA fog lights
- 351w VS 65 I6 Rear End...
- tach wiring question
- Carb Bowl Deposits What is Causing it?
- need help from the 71-73 stang guys!
- How Much Am I Going To Spend?
- looks like an old but rebuilt 6 and tranny if anyone is looking
- Transmission Castings
- How many Rearends were there?
- 67 A/C Classic Auto Air
- best 4 barrel carb and manifold for a 66 289?
- rear end question
- Electronic Navigation Systems
- timing / idle?
- Fuel pump eccentric problem
- rear seat question
- paint color in trunk compartment
- Safe Rev Point - 289?
- Gauge Replacement
- Shoulder Belts for '65
- Wheel stud size and other problem
- seats out of 70s ranchero?
- ballast resistor
- does this sound familiar to anyone..?
- Top End Cutout Problem
- WHat the heck did I do wrong with my air cleaner????
- 351C Timing Cover Gaskets
- RH headlight Dim
- Taking apart 67 rear quarter louvers
- real cobra gt
- Compression Ratios!!!!!
- 1965 Mustang Smoking!!! ALot!!
- Bizarre door allignment/latching
- RSTMOD INTERIOR PAINT QUESTION
- fuel cells
- My New-to-Me 64 1/2 Mustang
- If you ever needed a reminder to maintain antifreeze
- C4 to AOD
- Battery draing questions
- Gas Mileage for a 1966 289 V8?
- need to find a spring compressor
- Car Stereo
- Honest/good mechanics in Las Vegas to work on 1968 mustang
- Passenger Side Squeak
- Carb dilemma...
- front end springs
- 351 cleveland rebuild??
- In need of some new/used rims badly :(
- MOCA Just a Month Away
- New Problem
- Phenolic spacer (with PICS)
- Wire Terminal Block - '67 Coupe
- Is this to be expected? "Slow start when hot" question...
- 69 AC Blower Problem
- Metal stripping help
- 69 mach1 Air filter fit Question
- Happy Independance Day
- Why did you choose mustang?
- Got the girls out today.
- minilites!!!
- 1966 Marti report?
- 65 stang bogging
- iPhone and Classic Mustangs
- Door Jammed
- Finally a Day off
- fuse block
- VIN on car
- update as of 5am
- Primed
- START COIL GETTEN HOT!!
- Air conditioner compatibility
- 2 part header question
- How to attach 68 Grille Ornaments
- 69 mustang
- WTH!?! Summit 1 wire alternator troubles
- anyone know?
- Trans fluid change at a quick change oil place?
- Worth picking up?
- wheel size question
- 5.0 out of a lincoln?
- EGR?
- exhaust cut outs
- turn signal harness
- Backfiring??
- Hard Starting When Hot
- 8 ' rear end ?????
- what color/kind or paint!!!!
- Radiator Support
- battery keeps dying
- Gas Gauge Problem....
- 351 Engine Wear????
- REAR END
- 289/C4 to rear end match?
- How To Handle This Mess?
- Test Drive video
- Sandblast or Sand?
- Starting a rebuilt 1966 289 with 2-bbl carburetor
- oil pan removal
