- electrical problems
- Correct Refinishing Steps?
- 68' Coupe
- slip yoke leak
- tranny questions
- Overheating '66 Shelby Clone
- Motor Mount question '67 289
- What trans do I have?
- Noise with new front end
- What size carb jets are you running?
- engine porn
- Oil Leak question..
- Fluids colors
- Advice on Whether or Not Car is Worth the Price
- Performance parts in California
- 1966/67 Mustang Station Wagon?
- HELP! How to adjust valves on a 289....plus more
- kickdown lever leaking?
- well i just bought my new shocks
- 72 mach 1
- Muffler
- Salt air protection
- rocker stud size.
- '68 with PS and long tube headers
- Doctors?....Mechanics!!!
- c4 trans ?
- Large purchase
- Starter keeps spinning...
- brakes and floors ?
- New Intake Question
- Brake Booster extension for 65/66
- MOVED: Have any of you guys raced a supercar?
- c4 to t5
- alternators
- Clutch Pedal Compatibility
- Power booster & MC II
- radiator transfer
- Ignition problems?
- where can
- Project Fastback
- converting to power brakes
- over heating question
- Engine died after 15min drive...
- Spring saddles/perches?
- 65 Mustang 289 Severe Engine Knocking
- T10 or toploader?
- project advise
- timing mark confirmation help
- New carb instillation
- timing fence? question for 6 popper
- Power brake conversion
- How long is a 1962 T-Bird in overall length
- Block Number Help ?
- wheels and tires
- May be driving from San Francisco to central Oregon
- Greetings from Baghdad
- flexplate or flywheel
- Smaller combustion/ flat top pistons
- Tomorrow we dance!
- Gauge the Gage, Your thoughts please
- A couple of questions
- 69 mustang dimmer switch connector
- its not mustang but its a ford
- 1967 GT-350 Clone
- California Pony Cars Anyone?
- Fuel Tank Fuel Line Question...
- COIL SPRING QUESTION
- Mustang Project Advice Please!!
- Body Work
- New engine/trans time Advise?
- '67 coupe project
- Got my car back from the bodyshop
- Starter Run on
- Roller Rocker Arm Question
- Rally Pac
- 66 steering box
- Power steering pump picture needed
- Heater hose routing
- Motor / headers question
- I'll need lot of help
- Side scoopes
- need help!! on a starter motor
- 65 Mustang 1/4 times ...
- Hood To Cowl Seal
- Gone in 60 seconds
- 67 frame question
- '69 Fuses
- Pulled my engine!
- Rookie question about tranny?
- license plate light
- bumper question
- sticking loud pedal
- MIG Welders
- gt40p heads for $200
- photogallery of resto 66 fastback
- 67 A/C
- new brake lines
- what the crap!?
- im getting a new DD
- brake conversion questions
- valve rubbers
- 9 inch rear in 65 stang ?
- stock C4 vs 351W 420hp
- Its not a mustang but is is a ford
- adjusting vacuum advance?
- Blinkers...!!
- Turn Signal Flashes Too Fast?
- Transmission gasket leak, again
- What shocks will give me a more forgiving ride?
- any got 66 layout
- 302 serpentine conversion
- a carb?
- interesting finds in your mustang!
- Radiator advice: Angel or Devils?
- Engine dies at idle and won't resart
- Help Me Decide.
- hiccups at low revs - good at high
- Pics & extra original equipment?
- Radiator fluid level question
- 351
- Best Insurance for a 1966 Mustang?
- engine pull
- anyone need extra advice restoring old cars try this site
- Shelby Drop reconsideration....
- the adventure of the disappearing turn signal
- Need to know a good supplier of sheet metal
- what does the brake light mean? '67
- Safety upgrades
- 67 interior questions help please
- Speedo Cable Too Short?
- Motorcraft 4300 D Carb
- heater blower motor....
- Four Reasons Not to Restore a Vintage Car
- 72 Mach I 351 Q-Code....what do the codes mean?
- roller rocker valve cover clearance
- seatbelts?
- The tear down
- 1966 A-Code casting numbers
- Drip rails
- flowtech didn't work for me!
- Which carb is this ?
- '71 sportsroof seat platform?
- rust and stuff
- Battery Chaged: Car still not starting
- Over heating problem
- Breather hose mystery
- My donor car is in better shape than my restoration project car!
- Engine Question
- Engine Question
- My new 1966 Mustang Coupe (New pictures 7/08/07)
- Car Sale - Transportation???
- Universal Wiring Harness
- D-day! little engine removal advice please
- How Much Is This Engine Worth??? Picture Included!!!!
- brakes question
- Buying a 65 Stang, guy says it's an A code. PICs
- Help question. How do you 'prime' 66 289?
- '67 strt 6 Engine not starting
- *help with a 67 coupe*
- Pulleys not lining up after installing a new Harmonic Balancer...
- 66 motor build
- specific part ? 69 stang
- Suspension specs.?
- Tires and rims (I'm a little slow)
- San Diego Hardcore Mustangs Show & Cruise Aug 26th
- General Terms
- Tuning a Barry Grant carb
- HELP! U JOINT???
- MOVED: Just a Story :)
- who wants a 73 fastback?
- Turn Signals in hood
- wiring help
- Carb Tuning/Hesitation problem, autolite 1100
- 302 to 390
- 67 coupe drip rail
- Wiring question.
- Magnificant Obsession - or is it madness?
- '67 Coupe needing help
- Mustang show & a $400,000 Boss!
- fresh paint on my 67
- so i pulled the heads off the ol 289.
- Great w-e until tonight ... need advice
- wanted 289 block/engine
- why is it always the simplest things...
- Stress Cracks?
- A few pictures from the "Wild West Mustang Nationals", Concord, CA
- Motivation?
- More HP
- Bad News!!!
- new heads and roller rockers
- break in period after overhaul
- 69 suspension
- seriously? another tranny problem
- headers and exhause for a 69 help!!
- '65 Mustang Interior Questions
- 289 Engine Upgrade
- Console Repair
- royal purple
- What is the problem?
- 65 tranny change
- Help me guys, looking for a part
- 1969 351w Valve Cover Problem!!!!!
- 1966 head light problem
- .10" drum brake interchangability
- dumb question time
- My car won't turn off?
- back seat info
- Muffler Change
- instead of back seat...
- important question
- need help with exhaust
- Getting your car ready for a cruise?
- R-e-s-p-e-c-t
- Air Conditioning on a 69
- Shock tower cap!!!
- front suspansion
- I need....
- GM style alternators
- Clearance Problems for High rise intake ?
- 67 door
- 1st time questions on replacing the rear main seal.
- Me and John
- C4 RPMs at 70mph
- T-5 Question
- Ignition lock???
- rotella - engine oil
- valve adjustment question
- Black Sunshine
- greatest car ever?
- Stainless polish
- Another 73 Coupe Value!!!!
- rebuilt tranny recommendations
- FS: 4spd toploader
- Car Show
- Dang Dad Why didnt you?
- Disc Brake Conversion on 66 Coupe
- putting T-10 in '66 200 ci
- Double pump Single Pump \: Vaccum..Carburator Help...
- 2 Speed Automatic Tranny
- Stalling on a 72
- 302's
- 65 Fenders
- Just Got a 66 Coupe and need advice
- School me on a Vortech Supercharger for a 68 coupe!
- How much encapsulator?
- horse power?
- 66 Conv - need advise on radiator & water pump
- 73 Coupe value
- What Transmission does a stock 65 Mustang have ?
