View Full Version : Classic Mustangs
  1. Cheap Paint Job?
  2. 68 Stang good deal?
  3. 351C exhaust manifold bolts
  4. Soarings Slayer Drawing
  5. Signal lights went out i need some help plzz
  6. Whats the trick to removing the headlight switch, wiper switch, ignition switch, etc
  7. Brake light switch replacement
  8. Ok..I am an idiot...thats a given
  9. Member Status
  10. 68 Sketch
  11. Help w/ carb question...
  12. My Engine Set up - Getting new carb
  13. Can You Name This Part Please(s)
  14. 1970 302 engine color, can't find right color to match.
  15. Engine Hesitating a litlle
  16. full quarter.
  17. progress
  18. Quick question and Help please!
  19. Torque converter for AOD swap
  20. how do you post pics?
  21. whoo car show 56k'ers be warned
  22. Looking for used Nugget Gold seat covers (or peices of it) for my 68 Coupe
  23. More questions: Shifter positions
  24. Restomod Question
  25. Problem starting car, please advise*
  26. are these needed?
  27. Hump Hugger ... cruiser or not?
  28. Clev 4v Head Casting Nbrs
  29. What do I have?
  30. Just dies!!
  31. New Carpet
  32. blown head gasket
  33. original radio spacers
  34. almost there
  35. Work YAY
  36. engine rebuild
  37. my carlisle finds( now with pics)
  38. Engine Noise...
  39. Power Steering with Headers
  40. drivetrain behind tranny
  41. Was Bored at work so i picked up a YearOne Cataloge and went to work
  42. Numbers and Symbols
  43. TCP stuff for Classic `67's
  44. Windshield wiper Motor Conversion?
  45. Carlisle
  46. Seem Sealing
  47. Little Old Lady mask
  48. c4 pan fill years
  49. 1973 project
  50. too good to be true?
  51. gas
  52. enamel black.
  53. Newb with 65 mustang Inline Six
  54. Strictly Classic Mustang Magazine(s)?
  55. Fastback trunk filler panel
  56. door frame
  57. sloppy shifter
  58. brake swap help!
  59. Door skins and the infinite sadness
  60. Trunk Weatherstrip
  61. Motor and T5 going in this weekend!! 1 question...
  62. 67 and 68 power brakes
  63. 302 Q
  64. Compressor advise
  65. Help The Mach 1 win! Your votes needed!
  66. chopping gutters
  67. Bad news on my Mustang
  68. Thermostat question...
  69. 351 crank in a 289 block?
  70. Slow to start in the mornings*
  71. "S" Code?...is this rare?
  72. Rear Discs or Bigger drums ??
  73. Where did that wire connect?
  74. Complete List of Parts/Suppliers?
  75. C4 Transmission 65 vs 68
  76. new project worth it?
  77. Valve Clatter question
  78. Speedo calculator
  79. Supercharger / Balancer and tranny question
  80. Please.....Need help with Spark Plugs!
  81. Parts source
  82. Money & Mustangs - the Golden Hobby
  83. Axle length
  84. alternator wiring problems please help!!
  85. Carb!
  86. For Sale - Longtube hooker comp headers
  87. 351C Performance Question
  88. Gt-40P headers
  89. Clutch Pedal Jumps On Hard Acceleration
  90. Please help me with my intake question
  91. block design??
  92. 1967 power steering hoses HELP!!!!
  93. WELL.... *project street beast update*
  94. 3 speed
  95. stalling
  96. Power door locks
  97. 65 Fastback - How much?
  98. axle seal replace = difficult?
  99. Can anyone help me find a AC code power steering pump pulley?
  100. anyone have experience with protrax?
  101. Painting the engine bay
  102. Rust bucket sttrikes again
  103. 351C Adjustable Rocker Kit?
  104. Vinyl Dye
  105. Window crank install
  106. Starting for the first time: prime the fuel pump?
  107. 1973 fender panel questions
  108. 65 289 valves
  109. Drive Shaft Length
  110. aftermarket electrical fuse box location
  111. I want Disk Brakes CHEAP
  112. Rusted Roof
  113. Will I be cast out?
  114. Coil
  115. vin number troubles
  116. spring perches
  117. IT'S FINALLY IN THE DRIVEWAY!
  118. Turn signal Stuck,Only W/ Lights ON
  119. New tranny lines to cooler
  120. reman autolite 4100's
  121. Brake shims?
  122. Best mustang of all time
  123. torque for edelbrock intake bolts
  124. look what i got!
  125. which cam/intake/carb for stroked 331
  126. Edlebrock Performer v/s RPM Intake and Cam
  127. C4 tranny question...
  128. coolant-drip,drip,drip
  129. This a good deal
  130. Struggling Painting Hood Stripes
  131. 351c cam
  132. battery not holding a charge
  133. dynamat? whose got it?
  134. Look what I'm about to install!!!!
  135. Trunk goes CLUNK!
  136. In your opoin
  137. Throttle Body vs. Carb
  138. headers wont fit
  139. Air/Idle
  140. No Reverse after filter change
  141. Switching 2v Carb to 4v mods!!
  142. Miramar Car Show
  143. 351C Hooker Header Fitment
  144. Any experience buying tire/rims all set up?
  145. Used Block Tests/Machining
  146. take a look at this lol
  147. Hooray another car (maybe)
  148. 3 Angle Valve Job?
  149. 69 Mach 1 Radio
  150. A toast to LCC
  151. AOD swap - need a few parts
  152. New wiring harness is next- awesome kit
  153. 351 W or C Compatibility????
  154. Rear end Swap
  155. Looking for 351 W or C for my 1965 Mustang need help!!
  156. 1965 Engine Swap
  157. my new 65 fastback
  158. jacking locations
  159. E-Cam for a carbed S/C 65?
  160. No Luck Kid!
  161. Looking for some info on an 84
  162. Getting old quarter out of roof
  163. Another Great day of painting
  164. what to do first?
  165. roll cages
  166. Value of a 5 bellhousing bolt 289?
  167. chrome/aluminum dash panels
  168. look at my oil pan!
  169. Leafspring lessons learned...
  170. A Psychological Assessment of Classic Mustang Owners
  171. Who is coming?
  172. Engine Tag Location
  173. Mild cam for 1972
  174. New Member needs help!!
  175. Looking for 351C Cleveland Crate Engine or Short Block
  176. Looky at what was at my house today
  177. T.O.H.S. Car Show
  178. power steering problem ..help!!!
  179. Car show in Moses lake
  180. Transmission Installation.. Tips?
  181. $98 dollar Paint job
  182. Steering wheels
  183. 1967 Mustang Coupe Restoration Project
  184. Hanging 1/4 panels
  185. How to put Spark plug wires in the right place!
  186. domelight wiring
  187. c4 to t5 swap advice
  188. Colors
  189. 2eighty9...
  190. New exhaust system in my future
  191. Painting Progress with more to come...
  192. buffing
  193. Car show today
  194. Two speed Mustang
  195. Is the price right?
  196. ignition bezel
  197. 4 Point harnesses or five point
  198. Outer tie rod
  199. headswap
  200. Restomod information
  201. Air bags
  202. Need help with reversing lights
  203. back lighting issue
  204. Front wheel clearance
  205. Quick Wheel/Tire question
  206. Mustang library
  207. Ain't no sunshine when she's gone.
  208. Oil on plugs
  209. Will this hurt my motor!
  210. Have a Classic Convertible in South Jersey? Please Read
  211. Back from paint, they were nice enough too...
  212. Body filler on decklid?
  213. How do you spot a "K" code engine
  214. Kickdown
  215. Guess what I saw at a car show tonight ? Ranchero
  216. 351C 2V
  217. Image In Signature
  218. Engine Question
  219. 9" is almost done!!
  220. valve covers
  221. Question about wheels
  222. Help!!! Starting problem...
  223. Is this price right???????
  224. flowmaster or magnaflow!
  225. Drivetrain
  226. fuel injection??
  227. My calipers...
  228. Wheels & Tires
  229. 289 STROKER KITZZZ
  230. tranny decode please
  231. Brake Booster Vaccume Plastic thing broken
  232. Clutch Installation
  233. problems
  234. Value of these Wheels & Tires
  235. Brake light
  236. BAD Experience w/ Por 15
  237. Pricing for Engine Rebuild
  238. Introduction
  239. New guy with questions.
  240. Bullitt Rims
  241. Power brakes
  242. how bad are Doug Thorley headers for 351 W with FMX
  243. Doug Thorley headers
  244. Heads for 302
  245. Think it cant be done?
  246. Mustang Phanton Gauges
  247. Claremont HS Auto Shop pics
  248. Engine update W/pics!
  249. '67 Mustang Disc Brake Spindles
  250. Demon vs. Holley Carburetors
