View Full Version : Classic Mustangs
  1. PCV question
  2. Lightest stock flywheel.
  3. New Member New Project 64 w/picz
  4. Engine Parts
  5. motor craft 1100 carb issues
  6. Wire a PA Alt on a 67
  7. one wire alternator
  8. where to purchase a mini starter
  9. thermo
  10. Rear Window Removal?
  11. mini starter problems
  12. 69 351 Windsor Vaccum diagrams
  13. Removed CA Emmision, Help!
  14. what size tires came on a 66?
  15. Power Steering Vs. Rack and Pinion
  16. Leaf spring question?
  17. Ignition switch
  18. Cobra valve covers
  19. Headlights on '67 convertible
  20. the stang got saved
  21. 289 by chance
  22. T-5 transmission from '95 GT
  23. Pushrods- Help please
  24. 1965 - Good buy?
  25. rear disc questions.
  26. 1966 Mustang Horn
  27. Shelby Drop complete!
  28. Transmission Q's
  29. MSD didn't fix it, I'm barkin' up the wrong tree...
  30. engine rebuildto
  31. T-5 transmission lubricant.
  32. my 65 pics
  33. Drum to Disc - 14" Rims don't fit.
  34. Quick question on front disc brake upgrade....
  35. MOVED: RACE?!?!
  36. my new rear end
  37. Brake System light turned on.....
  38. electrical re-wire question
  39. guage ?'s
  40. New Tranny?
  41. rad is losing water but no visible leak. what's wrong?
  42. help changing 2bbl to 4 bbl carb 73 mustang
  43. two questions??
  44. need help removing the colum
  45. Do I dare tear into the motor deeper???
  46. Rarest Mustang Here
  47. I think I damaged my motor??
  48. 66 mustang
  49. Installing Roller Rockers- Need Some Help
  50. Reliability of your Mustangs
  51. DTC and gear aligmnent
  52. some quick help please
  53. first car show
  54. 67 mustang UPDATED linkage to new edel 600CFM carb needed.
  55. wheel fitment 66 mustang
  56. Fuel Gauge Problems 69 Must
  57. Quarter Window Help
  58. steering box
  59. For the 72-73 guys
  60. names/screen names
  61. Have you seen this stang?
  62. fiber glass hood/gauges
  63. No turning back
  64. 1965 Coupe Question
  65. not a classic but...
  66. Replacing front marker lights on 1970 coupe
  67. How do I tell what gears I have?
  68. Leaking Transmission seal
  69. Single to Dual Master cylinder
  70. Heater core
  71. Need advice info for buying oil cooler for a 200 6 popper
  72. dust cover / inspection plate
  73. Front caliper pistons
  74. Kickdown cable pic's
  75. c4 or c6
  76. Cowl Plug
  77. Carb linkage
  78. Greatest Movie Car Chases
  79. Rack and pinion
  80. Flywheel Dust shield ??
  81. Hoping the classic guys could help
  82. Paint for interior? What to use.
  83. The coolest Mustang ever made
  84. Might need engine rebuilt
  85. my night with a 428 cobra jet
  86. 63 mustang?
  87. Can a 302 hang with a 351?
  88. 65 pics
  89. Just Got Front and Rear Suspension For My New 64 1/2
  90. Roller Cams; what's the deal?
  91. steering wheel issues
  92. I'd like to know what you guys think
  93. A danger near a ford short blocks when armed with a set of spanners!!!
  94. Radio Help
  95. Aftermarket Shaker on a 67 - 68
  96. Always Check your lug nuts after break work(a lesson hard learned)
  97. 4 lugwheels
  98. so i'm replacing the water pump
  99. Putting headers on, Starter is in way!
  100. '67 vs. '68 disc brakes, stopping ability?
  101. 1970 mustang, cassette or 8 track?
  102. Carburetor tag numbers-what do these mean?
  103. Got in a wreck with the stang and it may be Totaled
  104. Anyone need windows? *link*
  105. HP
  106. Ford crate motor question
  107. shock tower repairs help needed!!!
  108. Lean best idle??
  109. Distributor?
  110. Pictures of Dash with AC in 1970
  111. Cam and Stock Carb (is it possible)
  112. priming questions
  113. looking to trade
  114. Interior myself?
  115. Roosters & Wagons
  116. floor panel
  117. new export brace fitting problems
  118. Are these a good buy?
  119. Granada brake users?
  120. 302 question !
  121. Discs for the 67...
  122. 66 Sandblasted
  123. 500 error message
  124. those with Performer RPM heads- HELP
  125. Mustang Fastback Side Vent Drain Hose
  126. Newer custom front end on a 70,, weird
  127. 351c in 66 stang...
  128. maybe..
  129. I found another granada
  130. Accelerator Rod
  131. Headmen headers vs. other brands
  132. Coupe to Convertible
  133. In or around San Diego,, Body/Paint Contact info
  134. freeze plug sealant?
  135. Front disc or power brakes??
  136. HELP with 1st Mustang!!! (WITH PICS)
  137. Neutral Safety Switch
  138. Interior Paint Fiberglass/Plastic/Metal
  139. Brake Booster Suggestion
  140. looking for a pic of shelby accident in CA
  141. rear end power hold
  142. Rust, and lots of it...
  143. 4-Speed Question
  144. How should I do this...
  145. Cold cranking amps?
  146. stroker kit
  147. Subframe connectors and Hey!
  148. 302 for $75
  149. Need help figuring out what to pay for 1st mustang....
  150. 1969 For sale...is it worth it?
  151. new guage cluster
  152. steering wheel issues
  153. Decoding
  154. rebuilt 289
  155. Dropping Car off for Paint tomorrow!!!
  156. Recommended primer for upper cowl?
  157. Need a '67 GT500 for a photoshoot in SoCal
  158. come on ebay pls stop!!!!!
  159. making your own
  160. Billet Lower Grille
  161. Cut Springs to Lower Front End?
  162. 64 1/2 Modified w/Alternator, Need new Wiring Harnessess
  163. 1969 Fastback Interior Panels???? Need Help
  164. Engine Help-many questions
  165. adding AOD to I6 what needs to be done?
  166. dash lights
  167. leaf springs
  168. Axle Spline ?
  169. 351C
  170. Wheel and tires sizes for my 73 cert
  171. Newbie saying hello
  172. faded seat covers
  173. Started the Teardown- Bring on the power!
  174. mini starter on a 67
  175. Bouncy Ride
  176. shoulder belt on a 68 convertible (in the shop manual)
  177. I won't ask for r & p opinions, but...
  178. '67 Mustang, Apraisal advice** good deal?
  179. So, it's raining a bit over here.
  180. some new shoes~!!
  181. Leak??
  182. rust repair
  183. speaker questions.
  184. Help with Interior & Floor Restoration
  185. check this craigslist ad
  186. 66' vent window hardware
  187. Some final questions.
  188. I6-V8 swap pics
  189. v8 spindles
  190. do these actually work better
  191. Edelbrock 500 cfm Performer Series
  192. motor ready for stroker kit
  193. Electrical Question
  194. Wood Carb Spacer (Fabrication)
  195. 200 ci clutch disk thickness?
  196. WTF!!
  197. 67 stereo
  198. PB Blaster in Carb..
  199. Carb for my 67 Notchback...Suggestions?
  200. Autolite NOS Spark Plug Wires $200,100 dollars
  201. Stereo Install
  202. Ok you engine builders, help!
  203. What year and body style is this Mustang?
  204. Found my dataplate!
  205. Din Bezels
  206. 69 mach1 428 surging issue - need help!!!
  207. 66 289
  208. $122k for a custom 1968 Mustang? Wow....
  209. '66 coupe restoration
  210. my 66 coupe engine swap
  211. Really having hard time deciding, Classic air or Vintage
  212. my 65
  213. Reproduction Boss 429 Heads???
  214. 66 radio
  215. 65 Grille
  216. Mustang Twister? Good Buy?
  217. montecarlo bar
  218. Spindles Spindles...what to do...
  219. What year were Mach's made
  220. **LINK** more parts for sale!
  221. tranny oil?
  222. Removing Vent windows/Qtr windows?
  223. FUN FORD THIS WEEKEND-BAYTOWN
  224. YOUR STANCE.
  225. Overheating ?
  226. just got a 66 mustang,no seatbelts, did it come with any?
  227. Exhaust Mystery....
  228. 68 shelby convertible roll bar
  229. Painting my engine firewalls & bay area
  230. I'll go with majority vote on Carb choice.
  231. headers @powersteering
  232. Spark Plug Question
  233. Bay Area
  234. Header tube size
  235. Sentipede - trac-loc feedback
  236. Drove the car last night!!!
  237. AER
  238. one problem fixed now on to another.
  239. Ebay 9" third member
  240. wheel spacing
  241. Emergency Brake Cable Housing Mount
  242. A Question
  243. Looking for lime gold pics for 67/68's and info??
  244. Speedometer not reading correct
  245. wiring diagram
  246. Help
  247. FOMOCO gas sending unit
  248. engine year
  249. Progress today
  250. buck tag help pls!!!!!
