View Full Version : Classic Mustangs
  1. wiring problem
  2. shackles?
  3. Auto to Manual flywheel shim?
  4. 4100- check balls
  5. hood and door alignment issues
  6. %%% I need a carb %%%
  7. Starting Out
  8. Warm start problem--need advice
  9. Bigger Radiator?
  10. curb weight
  11. 73 Mustang quarter power windows
  12. a little trunk work today
  13. It's been a while!
  14. Questions on HEADS?
  15. guess waht i just bought for my engine :)
  16. Monte Carlo Bar & Air Conditioner?
  17. progress
  18. Suspension components
  19. Brake question
  20. air filter lingo!
  21. Anyone have.....
  22. 65 fastback "a" motor issues
  23. What could be taken off a 79 Granada and used?
  24. BAd day working on your stang ? MATCH THIS ONE
  25. 70 FB back ...Need body panel source
  26. Crazy ebay find...
  27. 66 quarter window
  28. No brake lights
  29. california anyone?
  30. New Guy Alert
  31. 289 302
  32. So some1 went after me and my car last nite
  33. Rustoleum Progress
  34. Bent Pushrod
  35. help me out wioth this 79 cobra?
  36. 289 or 302 what do i have?
  37. anyone got weatherstrip installation sites for a 65?
  38. FMX tranny??
  39. how do you guys...
  40. good & bad news.
  41. How much horsepower?
  42. tranny problems
  43. Drool on this
  44. MUSTANGS UNLIMITED,, DIDN'T DO IT AGAIN !!!!!!
  45. What is it? I want it!
  46. Borla's Installed
  47. Boiling over
  48. Grenada disc conv. dust cap installation
  49. 70 fender
  50. 68 Coupe Trunk Access through back seat?
  51. torker 289
  52. 66 underdash wiring help
  53. Aftermarket oil pressure guage install questions
  54. '67 Coupe Squatty in the rear
  55. 66 mustang wheels
  56. Odd turn signal problem
  57. more rear end questions! please help!
  58. painting my intake
  59. Going to pull the motor, probably need help..
  60. battery keeps dying
  61. remove and installing intake
  62. Decoding Help!
  63. Anyone Lookin for a Barry Grant 650?
  64. Rear lip?
  65. Look what I found on Craigslist
  66. Gas tank
  67. New carb
  68. 1966 exhaust advice
  69. found C8OF-9510-C carb need info
  70. Rusty Rims
  71. Gas prices
  72. vin code help
  73. where to put them?..
  74. Do you find it a chore to drive your stang?
  75. Could it be the gas tank???
  76. tranny leak?
  77. Need help (formally such is life) new problem
  78. Anyone Looking for N.O.S. BOSS 302 Rods?
  79. Heater box help
  80. How do you know what your car is worth?
  81. Yeller's seals and gaskets aren't leaking.
  82. What's draining my battery?
  83. time 4 an...
  84. GT mustang or not?
  85. Just Browsing on craigslist
  86. Cowl Vent Knob w/ button and toggle
  87. AOD tranny in an I6
  88. Selling my first love
  89. Just found this for sale...'71 Fastback
  90. Cleaning inside the cowl
  91. fuel level sending unit resistances
  92. vacuum booster questions
  93. some newbie questions
  94. Question about brake warning light switch.
  95. on a quest
  96. Shaved antenna
  97. Suggestions on Making the 65 safe and COMFORTABLE
  98. Engine Sex
  99. New Antenna
  100. quad turbos on a stang
  101. after market hoods
  102. Paxton S/C kits for the 69 351
  103. Monte Carlo bar dimensions
  104. fox body wreck at drag track 45 min from me fatal
  105. Cheap but highly visible improvement....
  106. Lights get bright...
  107. Stink-be-gone
  108. 289 ID Help Needed
  109. Hood louvers like on a GT500?? HELP!!!
  110. 2 Q's, One Spoiler and one Shaker Hood scoop
  111. Isn't this Show!
  112. Proportioning valve recommendations
  113. Smoke
  114. Just ordered power window kit
  115. '67 Coupe wheel choices
  116. T-Lock security
  117. Bastard 64 or Bastard 65?
  118. Pics of the newly running engine!
  119. coil spring problems
  120. just some new pics
  121. Anyone install a Vintage AC, How was the install?
  122. Installing Tri Y headers
  123. 9" Carrier Assembly
  124. Stock Intake vs HIPO one
  125. skin or full quarter panel
  126. Preliminary V-8 swap work
  127. Engine In,,,, Sort of,,
  128. Yo
  129. Another, is it worth selling thread. College.
  130. molding hood scoops??
  131. Help needed - 1969 302 2bbl stalls from idle
  132. 71 dome light
  133. semi- restore, need opinion
  134. My new air-cleaner
  135. what are the ideal dimensions and specs for a 289 replacement radiator?
  136. Carb Dilemma
  137. Thank you JamesW
  138. 351w alternator Headache!
  139. white smoke.
  140. 1969 thunderjet mustang
  141. 429 Boss bargain parts
  142. New promblem
  143. Cars working my last nerve.
  144. fuel gauge works but not correct level ?
  145. Hard Times,might sell,is it worth it?
  146. Rear Springs... 4, 4.5, or 5 leaf?
  147. More 9" questions...
  148. gas mileage in your classic mustang
  149. Welding
  150. 72 mach 1
  151. pertronix ignition system
  152. transmission question
  153. carb confusion
  154. Any body heard of Innova Equus timing lights
  155. 67 mustang rear end
  156. Seeling back glass
  157. '67 Drum to Disc Upgrade - 14" Rims
  158. '67 289 C4 Kick Down Cable
  159. exhaust fumes - how to find leak
  160. some help/opinions..
  161. Parts....
  162. 05 mustang seat dye
  163. Need your input
  164. Pics of my 1964 and 1\2 mustang
  165. rebuilt or reman 289?
  166. pics of the new project
  167. Pics of 65 fstbk with a unique set of rims
  168. ebay find
  169. 67 mustang with C6
  170. HOLY CRAP
  171. Need some direction from the Pro's
  172. trans need help badly
  173. cleavor
  174. ::::::::: K CODE 1966 , How many were Built :::::::
  175. Mustang Heaven
  176. need much help with rocker panels
  177. Install Electric Fan
  178. PCV Valve, oil filler cap question
  179. Hard starting when warm
  180. Power Steering Slave Bracket
  181. Hard Brake Decision
  182. Stall
  183. Compression testing..What am I hoping for?
  184. AOD or C4?
  185. edited, craigslist seller not selling now.
  186. Disgrace to this forum.
  187. Interior Vent Panels
  188. speedo cable.
  189. Typical Tune-Up
  190. What is the best way to detail hood hinges without taking them apart?
  191. Autolite 2100 on an L6
  192. HOW COME >......>>>....
  193. New Mustang owner where to get parts.
  194. Opinions for where to buy Aftermarket AC
  195. good place to learn about carbs
  196. 4 years in storage
  197. Insurance
  198. A Good Weekend
  199. Not starting
  200. Light Switch Connector
  201. differential gear question?!
  202. carb question
  203. Radiator Support
  204. Cowl repair
  205. guage pillar pods
  206. How hot is hot?
  207. Mustangs Plus deck lid
  208. Master Cylinder Pushrod
  209. finally won some seats for the stang
  210. Look what I just got.
  211. AUTO TO 4 SPEED CONVERSION
  212. Indulge me - part 2
  213. C4 tranny
  214. Dual Red Line Tires
  215. Ready to sandblast and paint engine bay
  216. POR 15 for interior ONLY??
  217. Symphony of sounds....
  218. Darn California cars ...
  219. what do you guys think?
  220. Refurbish Interior Wood Trim?
  221. 1966 coupe wheel choice?
  222. Parking Brakes
  223. Hipo 289 HELP
  224. video working: the peg legger!!
  225. thank you for help and info
  226. video
  227. Oklahoma City Mustang Show Photos
  228. modifying a 68 coupe?HELP
  229. tires for my son's 2001 GT vert
  230. Monte bar vs none
  231. Alomst restored
  232. Open headers
  233. Anybody know where to get a outer wheelhouse patch for a 71-73?
  234. Its Running!!!!!
  235. Indulge me
  236. Bought a project, where to get a title
  237. 1 thing left to do
  238. Wires smoking... what now?
  239. single to dual exhaust conversion
  240. MOVED: Gas fuel shortage
  241. anyone heard of anything like this 8 inch diff?
  242. Got some New Books today
  243. Engine and Tranny
  244. please help 67 mustant gt 390ci
  245. discbrakeswap.com brake kit
  246. Shocks
  247. does anybody have
  248. Pulls hard thru 6,200rpm
  249. got a new tool
  250. maverick disc brakes
