View Full Version : Classic Mustangs
  1. Break My Rear
  2. Whats your Stang worth???
  3. Help Me!
  4. HELP!! What size electric fan for 66 mustang?
  5. Engine stalls - intermittent
  6. CENTER CONSOLE
  7. C4 tranny ?'s
  8. Steering clearance trouble
  9. C6 Pan Torque
  10. Distributor static timing.
  11. 67 power steering bracket
  12. body/paint shops
  13. CArb linkage questions photo please
  14. Checkoff list for engine swap, yes I've done resaearch . .
  15. 66 auto to T5 conv. ?brake pedal?
  16. shock install question
  17. GT 40P's?/ What headers?
  18. seats for 68 coupe.
  19. No Spark
  20. HELP!! Emergency Brake Install
  21. Found some front discs
  22. Help what rear gears do I have?
  23. 66 front fender nuts in rocker panel
  24. new transmission adjustments
  25. Alternator ?'s.
  26. I hate brakework.
  27. Tach
  28. just how fast is a...
  29. Orange peel in paint
  30. 351C 2V to 4V question
  31. Distributors OUT... I own that thing...YES!
  32. OEM grille, worth how much?
  33. Classic car with modern drive train??
  34. lots of play in my steering???
  35. electric fan vs. other one
  36. New owner of a 1966 289 Coupe
  37. I'm Sorry But It Happens To Mustangs Too
  38. granada spindle replacement
  39. '67 Convertible Glass Membrane
  40. where can I get
  41. Bracket/Bucket
  42. 65 in-dash "Type D" speaker
  43. Intake Sugguestions
  44. Staples on the Hood Seal??
  45. WHERE IN THE CAR
  46. New Carb-Great
  47. high back 65 mustang seat interchangeable
  48. exactly what will happen to a 6cyl stang with v8 replacement if no underchassis work is done?
  49. P/S question: pump alignment
  50. Help!!!need parts for a 1 bbl motor craft carb
  51. Is an anti-stall dashpot important in an auto?
  52. power steering pressure line
  53. Surface prep for new primer and filler
  54. Deck lid springs......BOING!!!!!!!!
  55. Know a restorer in DC area?
  56. Pinholes in Floor, Treating the pans
  57. Sand Blasting Small Parts?
  58. shorty headers for a 351C
  59. Best Donor
  60. Ignition Coils
  61. Distributor won round two...
  62. blinkers
  63. Carb rebuild
  64. Anyone in SOCAL want to get together for mustang Play Dates?
  65. 289 POWER
  66. HOOD COWLS
  67. i6Lowering springs?
  68. replacing gas cap
  69. TORQUE / ENGINE SPECS
  70. #1 cylinder?
  71. Young Owning The Old
  72. Toploader - how to evaluate the condition?
  73. 69 GT Coupe Side Scoops
  74. a little help with weatherstripping
  75. Cooling system- what is that replacement for radiator fans?
  76. Restoring a 65...interior rust????
  77. larger radiator for a 65-66
  78. Eleanor Engine??
  79. Anybody ever install the larger 15" styled steel wheels on a 65-66?
  80. my turn for a help question
  81. Archeological Resotrat
  82. Archeological Resotrat
  83. Archeological Resotrat
  84. Gauges broken?
  85. holley carb
  86. The Great Race (its not a race, its a rally!)
  87. What is this?
  88. How to tune your vintage Mustang for improved performance.
  89. Mustang Club of Houston Car Show Pics
  90. 67-68 FB Interior Vent Grills
  91. Clutch pedal question
  92. Valve lash question
  93. Trunk weatherstrip
  94. horn again .. what am I missing (pics)
  95. Eating crow because of bad advice.
  96. brake hose bracket location on a disc brake upgrade
  97. My engine, oil pan troubles
  98. Steering creaking sound
  99. 289 Oil Pressure Sender Orientation?
  100. 1968 mustang...engine vin?
  101. Carb Installation
  102. 67 Mustang Gas tank
  103. Floorpans?
  104. Is it just me . . . .
  105. where to buy carb parts for a motorcraft
  106. 427 medium riser
  107. Motor for my 69
  108. what a car ...
  109. Lincoln Brakes on a Classic??
  110. Glass Refinishing - does it work??
  111. Diffrential code
  112. Starting
  113. Pictures from Mustang Unlimited car show today
  114. Distributor stuck
  115. front tires squealing - alignment? something broke?
  116. Top loader & Bell housing
  117. Engine swap: 200ci I-6 to 429 CJ
  118. What to expect - want to buy a classic Mustang
  119. 79 truck help?
  120. 65 steering gear box
  121. Oil Pan/Dipstick
  122. New front tires,, and rear air shocks
  123. engine tick
  124. Ignition Issue
  125. the need to feel the power
  126. install time vs mechanic install
  127. Disc brake pressure control valve
  128. body shop price
  129. clutch fork-u
  130. 2004 seats in a '69
  131. Starting the Car Soon
  132. power stering
  133. MOVED: 347 longblock STROKER
  134. Can,t locate my Flasher Assy.
  135. Car stalls when put in gear.
  136. 500 error message
  137. Mods for a I6
  138. Mods?
  139. Dim Headlights?
  140. Gas Line & Gas Filter
  141. Top loader progress
  142. How fast?
  143. pulling a travel trailer with a 68 mustang?
  144. For Soaring
  145. wheel offset question
  146. wipers go too far
  147. Engine Ground Location?
  148. New engine?
  149. 69 mach/428cj/4spd Header fit???
  150. PCV tube
  151. Ignition / startup??
  152. 64 - 70 Spindle Info:
  153. Insurance?
  154. How much is enough?
  155. oilpump info
  156. Mustang Steve Disc Brakes?
  157. what parts can i use?
  158. Thread sealant and my thermostat housing
  159. which way to sell engine
  160. Converting a coupe to a fastback ???
  161. 68 Restoration
  162. Can you help me with this out of order trim tag?
  163. traction issues
  164. i want to modify, not restore, but cant find fitting stuff
  165. frame brackets and 9" rear ends
  166. A little slow the last few days.
  167. Need 65-66 seats
  168. Switching from L6 to V8 questions.
  169. Tranny ??
  170. good news sorta
  171. 1966 Ford Mustang Limousine
  172. Spotted a 289 Vert in the wild today =)
  173. Master Cylinder
  174. Mustang Steve brakes
  175. Body Alignment
  176. 4 speed tranny.. how much?
  177. oil pan for a 347 stroker
  178. C6/C4
  179. HELP! I'm installing Versailles 9" rear
  180. Oil Pan Removal
  181. Windshield leaks
  182. shoot....
  183. Sticky throttle
  184. 17x9 bulletts on 69 coupe?
  185. Is anyone going?
  186. Squeaky Suspension
  187. Anybody ever remove a V8 and install an original I6?
  188. Electric Fan for 66 mustang?
  189. good news!
  190. cool or not
  191. wheels for 69 coupe
  192. oil accumulators
  193. 1973 Mustang 351 2V
  194. 200ci engine problems
  195. Help - Headlight Assembly
  196. Brighter headlight help finding relays
  197. Found a parts car, what should I take
  198. 429 Noob Questions...
  199. adjustable rear sway bars
  200. Help me get started
  201. Welding primer?
  202. 1973 grande
  203. first time driving it
  204. Noise Suppressors
  205. Replacing a Distributor on 200 6 cyl
  206. Torquing Down
  207. ANY recommended fuel pump for a 289?
  208. just when you thought
  209. Oil Pan Depth
  210. gasket eating ethanol
  211. am i in to far over my head?
  212. I could use some help on this
  213. *dead* my car *dead*
  214. frozen bolt
  215. painting for dummies - tips please!
  216. I checked my car out today
  217. Ball Joint?
  218. Decoding for a 68 block.....need help
  219. pics of my project I'm about to start
  220. Engine shake
  221. Laurel Mountain or Mustang Plus Suspension
  222. my car officially...
  223. AOD neutral safety switch
  224. 65 GT
  225. MOVED: 200ci parts for sale!
  226. starter problems
  227. Another battery thread
  228. Weight?
  229. Need Fast Carburetor Answer
  230. Heater Hose-->Intake Manifold Adapter? Help.
  231. what to go with?
  232. power steering pressure hose routing?
  233. A little O/T
  234. Battery Tray removal
  235. Stubborn - DOOR LOCKS for 1966
  236. Opinions on Paint
  237. parking brake setup
  238. Strut rod removal
  239. Ford Hemi thread
  240. drum brake conversion, is this an good deal?
  241. what holley carb would you recommend for a 289?
  242. my floor is wet when it rains in my 66 mustang?
  243. 302
  244. i so want that little mustang
  245. Replaced Alternator and still not charging..
  246. Vibration
  247. my 67 pony
  248. disk brake conversion
  249. Quick Fuel Pump Q
  250. Mustang Buying Hints?
