View Full Version : Classic Mustangs
  1. A/C not working
  2. Rim Size
  3. Electrical. Year or Engine
  4. 1968 driver side door issues
  5. What is considered being "Hard" on a T-5?
  6. Want To Buy Another Classic Mustang
  7. Spintech mufflers?
  8. Can you simulate my engine?
  9. Ignition Diagnosis, pa-leeeze!
  10. upgrading the T5
  11. Help with a clutch pedal
  12. Street Master Intake?
  13. Mini tub pics (groho)
  14. 65 Mustang Shop Manual?
  15. beginner Restoration question
  16. Looking for help with my 1965 200ci.
  17. Firewall Question
  18. UCA Drop and Negative Wedge????
  19. Timing degree for a 200cid
  20. removing front fenders
  21. 289 to 302
  22. Anyone Looking for a Project?
  23. PCV Crankcase issue
  24. Oil Change
  25. Help.. 1969 Mach 1 needs a little more power
  26. Leaf Springs for a 67.
  27. Very Low or No Oil Pressue.
  28. Pertronix Question
  29. single exhaust tailpipe hanger
  30. ADVICE APPRECIATED!!
  31. 1965 Fastback Project Thread
  32. Engine question
  33. AOD conversion
  34. What size tires
  35. MY turn signal problems
  36. quick q on the studs that hold the carb down
  37. Is this the kind of black paint Ford used in the engine compartment?
  38. MSD 6A Ignition
  39. Could use some advice on upgrades
  40. Side Pipes (carlos) help
  41. it wont fire...it just wont fire
  42. Rim sizing for a 67
  43. Alignment - Take to a Shop or DIY?
  44. Canadian Import
  45. Will a '73 front end fit on a '67?
  46. Ordered new wheels today from Cruizin Concepts!
  47. Attempt at center console
  48. Oil Leak at the Filter.. Need Suggestions
  49. Bar?
  50. 1984 Mustang Foxbody
  51. How can I test turn signal wiring?
  52. Help Decoding
  53. Turn signal help
  54. Then and now...
  55. 8.8 rear end swap in 66
  56. Interior & Switched roof console Map lights - HOWTO
  57. 67 Fastback Frame Dimensions
  58. Hesitation Problem Just Started
  59. Material Purchasing
  60. Good alignment shop in or near Ocala,FL?
  61. Windscreen Trim lugs
  62. Electrical Issues, please help!
  63. Tips on getting engine rebuilt
  64. Installing Tach on dash pad... Pretty scary!
  65. Which suspension for the 67 mustang , rrs, tcp , or Mustang ll
  66. Paint fading to bare metal
  67. Fuel line question
  68. was towed today for 3miles from the front any damage?
  69. The Battle is over with my Grille and YES I LOST.
  70. Gonna let her go after all
  71. Need a GT350 dimension
  72. Gaa! Electrical nightmare.
  73. 70 boss 302 car price
  74. Clean up choke tube sleeve?
  75. Gas Longevity
  76. Starting a frame up restoration, need drawings.
  77. 65 headlight wirung loose?
  78. I need trunk interior ideas.
  79. 390 build for a 69'
  80. c4 trans.. need help
  81. 351w clearance issues, won't fit
  82. C6 3rd gear Woes
  83. '72 351C Heads/Cam/Intake?
  84. Stalling when turning fast
  85. Door window swap?
  86. Spark plugs
  87. restoring painted data/door plate
  88. Heads for 302 Block
  89. What is this? 71 mach electrical
  90. Popping
  91. 67 parking brake, need a picture
  92. vibration at highway speeds
  93. intake installation problems
  94. Question about the cowl
  95. Sequence for removing head bolts same for I6 and V8?
  96. 66 Mustang doesn't want to restart...
  97. 65 Mustang clutch pedal spring keeps braking from the brake pedal
  98. Rehanging an exhaust
  99. MU Sequential tail lights.. help
  100. Dizzy question
  101. the blocked water galley myth
  102. 1967 mustang fastback
  103. ignition curve ....
  104. Turn signal switch
  105. '68 Shelby Progress...
  106. WHY is it Stalling????
  107. boss crate motor
  108. Help with Grill
  109. a little 4 barrel carb help please......
  110. Loosing Water in Radiator
  111. U-Joint Replacement
  112. Turn Signals Broke
  113. Looking for Carb Suggestions
  114. 4 Lug Wheel Help
  115. My radiator quacks like a duck.
  116. Gauges
  117. 302 cam
  118. Rear end Hog Head
  119. 15 inch wheels, how wide can I go?
  120. Anybody tried a Nostalgic Air AC system
  121. is aluminum radiator really any good
  122. Will this fit - 245/40/17 on 17x8 with 4.5" backspace?
  123. 1972 Mustang Interior Question
  124. Rack and Pinion upgrade from RC Motorsports
  125. 69 Headreasts
  126. 68 Coupe - Electrical Questions
  127. Fix a muffler baffel?
  128. 302 Heads?
  129. Come See American Powertrain at Midamerica Ford/Shelby Meet
  130. Ignition Switch Replacement.. DONT do this!!
  131. White smoke under hood after few minutes of idle
  132. Convenience System Park
  133. Best California Special Trunk Lid/Extensions?
  134. White Exhaust Smoke
  135. Starter/Alternator
  136. Looking for an interior to match my 1973 ginger and brown inserts
  137. Any decent car covers on the market?
  138. Questions on a 302 and 351W...
  139. Parking Brake hookup - underside
  140. 68 Parts On A 79 Motor And Other
  141. broken header bolts in head [Insert giant swear word in caps lock here]
  142. Transmission leak
  143. Radaitor cap 13 or 16lbs
  144. Leaking rear seal on a t-5
  145. Dart 195cc open em up?
  146. Ford Mustang Straight Six 1965-72 (Mustang owners workshop manual) Autobook
  147. how far should the fan be
  148. 1967 Mustang 289 Stumbling
  149. surface rust, underneath
  150. How to change 65 radio light bulb
  151. will not start
  152. Wiper arms for 68'
  153. Not a Mustang, but help me please?
  154. T-56 transmission + 427 motor?
  155. OMG y am i overheating HELP
  156. windshield question
  157. Just for clarification this is?
  158. Can't find brown connector for efi swap?
  159. vacuume help
  160. 69 Fastback question
  161. Tapping Noise.
  162. snails pace restoration
  163. Oil Dipstick Relocation
  164. How would I go about painting beneath the hood?
  165. Getting my first Mustang, give me pointers
  166. Exercise and the self healing Mustang
  167. Recommended places to start with Shelby
  168. 1973-15" rim backspace ?
  169. Rattling after degreasing engine & new more powerful radiator
  170. Shock Tower
  171. drum brake rebuild nad running front brakes in back(?)
  172. Trans Vacuum modulator
  173. classic guys doing the 2.3t swap
  174. Running 68 6-cylinder Without Thermostat
  175. Frame Rails
  176. AOD header problem.
  177. Why am I losing coolant
  178. Interior Change Finished W/Pics!
  179. coupe fold down seat
  180. quick easy q about 2v to 4v swap
  181. Another new guy from TX
  182. new top convertible
  183. 65 9" Rear 4.56 gearing
  184. Custom Fender Emblem?
  185. 1965 Shelby Dash Pod
  186. Column moves with floor shifter?
  187. Coil Springs
  188. Distribution block for brake swap
  189. GT140T (66 Mustang/SVO 2.3 Turbo) is on the road
  190. Tach instead of dummy lights
  191. new guy from tx
  192. new guy from tx
  193. Sigh...I cant stand electrical!
  194. 1969 Mach I pro-touring
  195. 65 Mustang Tempature Sensor
  196. Anyone in PA going to Lansdale 6/20/09?
  197. Squeek Squeek
  198. cant figure it out...still wreaks..
  199. trying to start my car, cant find TDC
  200. What to do about ethanol and stock carbs?
  201. Engine Question
  202. Need a favor
  203. Monte Carlo
  204. Wilwood brake fluid
  205. New member with a 67 build..resto-mod or not?
  206. Junkyard tranny
  207. Building Dynacorn '67 Fastback
  208. Lower Ball Joint Replacement
  209. need help with rotissere
  210. Carb and starter, big question
  211. Can somebody direct me to a guide to reupholstering?
  212. My supposed "rust free" car
  213. Difference between 68 & 69 seats
  214. Ordered 347 Shortblock - Suggestion on top?
  215. 1967 Mustang headlights
  216. shelby side exhaust
  217. AOD swap question...
  218. 22 gal tank in a '66
  219. 72 floor
  220. Chrome dipstick question... Jimmy
  221. need quick answer,..what trans gear,...C4 with 3.55
  222. Shipping a transmission ?????
  223. How to clean door jams and places I do not want to spray with hose?
  224. power steering? 1969 mustang
  225. Firestone Wide-Ovals
  226. sheet metal
  227. I found the ultimate junkyard seats
  228. Upholstered lower dash
  229. New a part not sure of its name
  230. I can't figure out the master cylinder fittings for my granada conversion
  231. What's the best stuff to clean leather seats?
  232. Any Members going too the 32nd Annual Mustang Show???
  233. B&M Quicksilver shifter
  234. Starting to get frustrated
  235. Shop Manuals
  236. What Octane Gas for '66 Mustang
  237. Back on the Road
  238. Clutch fork anti rattle spring installation
  239. Quoting
  240. Won't turn over
  241. newe model seats question
  242. Portable toilets?
  243. New Shackles, New Problem
  244. Excellent Mig how to welding article
  245. 66 radio problems
  246. Cylinder head swap
  247. C4 - Changing Selector Shaft Seal - good manual?
  248. Blinker Indicator Light
  249. Hooker Headers
  250. How to work this deep dent out?
