View Full Version : Classic Mustangs
  1. i just thought this was cool
  2. are xr7 seats the same as mustang deluxe?
  3. Hard fuel line replacement
  4. Nitrous Oxide
  5. Wiring on a 65 C4 tranny
  6. I need PICTURES.......more info inside
  7. will this work for me?
  8. Police scare me.
  9. Rear Gear Ratio
  10. help with restomod...(hi im new to the group)
  11. 2 Water Gauges
  12. Engine Fan Out?
  13. first time restoration help!
  14. Carb. advice
  15. runs rough at higher speeds
  16. Check this limited edition ROUSH 430HP
  17. Deleted Hemi thread
  18. Electrical issues . . .
  19. Export brace / Monte carlo bar??
  20. a little ot but i think that its cool
  21. 1st-time buyer needs advice
  22. PCV Setup question
  23. Fox body springs on SN95 mustang when lowered?
  24. double pumper carbs
  25. Windshield washer doesn't work
  26. What to do with my I200 ???
  27. wow on craigslist
  28. 73 Fastback to Go
  29. '69 F/B Mustang Project in CO Springs... f/s
  30. New gas Tank... to paint or not to paint.
  31. Flowmasters
  32. starter
  33. What kind of distributor would you recommend?
  34. fuel injection options
  35. NY, Long Island Mustang Meet At Deer Park
  36. Sweet music to my ears!
  37. 06 mustang wheels on a 69????
  38. engine question
  39. So Close!!!
  40. gauges & 6cyl swap to v8
  41. drivetrain questions
  42. motor maitenance
  43. ignition still
  44. swap meets and shows
  45. t-5 swap update....
  46. Starter Grinds
  47. Vent Window Seal
  48. Pictures and info on my '67 Fastback
  49. Engine Mounts
  50. 32 Valve SBF Heads!!!!!!!
  51. Wiring Woes
  52. thermostat question here
  53. Since everyone else is posting their exhaust video clips, here are mine
  54. Trans question.....
  55. things are coming along ...
  56. Questions about Radiator
  57. 1967 engine swap?
  58. Help with Transmission ID
  59. thread sealant on Master cyl. threads?
  60. What kind of mild cam would go with...
  61. What do you think major improvment so far
  62. 1970 302 block seal HEALP!!
  63. ANYONE KNOW WHERE I CAN FIND A QUARTER PANEL FOR A 70 COUPE???
  64. side exhaust clip
  65. Torque Boxes
  66. shelby rear seat delete
  67. '67 Fastback shell
  68. Interior Question
  69. Demon carbs
  70. Rear end gaskets
  71. WOW Expensive Scam on EBAY
  72. headers
  73. Alternators woes(how do they work)
  74. 65 mustang, how big can you go?
  75. choke
  76. You Guys Want a Free Dyno Pull?
  77. Fixing quarter windows on a 66 coupe.
  78. Possible to Convert Coupe to Shelby GT-350?
  79. For those of you who have swapped out a toploader with a t-5...
  80. Barn-Stangs
  81. 68 390 block for a 67 S code?
  82. Air cleaner painting
  83. Timing question
  84. Some questions about the classic Mustangs (1964 - 1973)
  85. where to buy hood/valence/other body parts
  86. Granada disc brake conversion
  87. What is this thing?
  88. Leaving soon
  89. help with ignition
  90. Battery kill switch/disconnect
  91. springs?
  92. 5 gauge cluster on 65?
  93. 289 vs. Hi Po 289
  94. Need some gap info...
  95. Parts
  96. watch the new series bullrun?
  97. i cant believe this!!
  98. 64 1/2 Engine Clean
  99. Question on Replacing 65 Swing gauge with the GT 5 gauge insturment
  100. Quick T5 conversion question for those that have done it...
  101. Entry level N02 system?
  102. Trunk lock cylinder $$$$$ ???
  103. POR 15 paint.....
  104. Define "Numbers Matching"
  105. Jacking points
  106. Fuel hose help
  107. Rear axle question
  108. My lights went out helppp
  109. Got my crank back
  110. The Waiting Game
  111. Transmission Question
  112. Early 67 steering gearbox removal?
  113. Your dream stang?
  114. Help with Brakes
  115. copper v alum radiators
  116. back up lights
  117. Brake booster problem...HELP.
  118. Stupidest thing you have ever done with your Mustang....
  119. Brakes
  120. First Ride
  121. dual master cylinder upgrade on a '65 ?
  122. Front End Upgrade??
  123. sheeeet metal
  124. will 429 fit in 1964-1966 mustang
  125. Threw water pump belt and didn't notice
  126. I moved another thread
  127. License plate ?'s.
  128. I spend about half of my work day on MF!!
  129. Some ?'s.
  130. ~~> Great/Bad News <~~
  131. Radiator Saga Part 3
  132. Paxton Supercharger
  133. oil and filter question
  134. CAS Trapdoor Soundbar
  135. New to the stang world
  136. Transmission Swap
  137. I need help with my 68'
  138. Fastback Roof Replacement
  139. Unisteer rack and pinion install
  140. great deal or not
  141. some tips would be perfect
  142. unkown carb tube...
  143. I Am Super POed
  144. ps control valve/cylinder ram
  145. '68 hi-po 289 upgrades
  146. 2.5 or 3.0 inch exaust?
  147. ssbc rear disc conversion - parking brake???
  148. Temp Cable for a 68 stang
  149. Finally in business- new engine!
  150. Do i need a new solenoid
  151. resistor wire delete...again
  152. 289 cid 1966 upgrade
  153. Boss 429 timing cover/water pump
  154. About How much?
  155. 1967 fast back "s" code
  156. Hub or Lug centric?
  157. Coil over front suspension recommendations
  158. something is killing my battery?
  159. How to get por15 into cowl area?
  160. Converting from 4 lugs to 5.
  161. '66 Mustang C4 Shift Shaft Seal Puller?
  162. MP Brakes upgrade questions
  163. 1966 engine(289) blue paint ?
  164. engine blue paint
  165. Are SS braided brake hoses worth the cost?
  166. It's got to be a fake
  167. half the car is cardboard ... that normal ?
  168. Cam & head work on a '66 rebuilt engine
  169. What's a good oil filter?
  170. cheapest place for wheels?
  171. Radar Detectors
  172. My Old Cam
  173. Backup light switch
  174. a contender to por-15
  175. Angle Eye headlights
  176. Putting a Chevy engine in a 67 Stang.
  177. A questio for the wise and knowledgeable of MF...
  178. New Fat Man suspension
  179. Saw this at the Ford Body shop
  180. a little off topic
  181. Six cylinders engine performance
  182. 67 Coupe with 98 GT Drivetrain?
  183. Who torques their lug nuts
  184. POR 15 goes on the floorboard ! not the hand
  185. MOVED: Selling my '66 Fastback
  186. Lowering Upper control ARMS 1 inch question
  187. quick wheel question!!!
  188. '67 Coupe - Upgrade to power steering
  189. Nice new motor
  190. is this a good suspension setup?
  191. Flatlander Short Blocks
  192. 66gt fastback
  193. I NEED To Pass Inspection
  194. windshield wiper motor
  195. water pump inlet help
  196. C6 Cooling Lines
  197. Re-bleed brakes??
  198. how do the chrome strips below the door connect to body on a 65?
  199. help with back light glass install
  200. Presure Plate for a FMX tranny....
  201. is using original ford parts for restomoding bad?
  202. 66' Parts on my 65' Fastback
  203. 2nd Place In Show- second attempt
  204. Whats the deal with my 302
  205. restoration help!!
  206. OMIGOD
  207. ENGINE SWAP
  208. mounting dashpad harder than it seems ....
  209. Please don't laugh...
  210. Power Steering Control valve leaking
  211. dont kill me for asking
  212. What gear for the stroker?
  213. Test drove a 68 6-banger!! NO umff!!
  214. alignment
  215. 2nd Place In Show!
  216. Hail :(
  217. need help with suspension/steering upgrades
  218. Fuel Injection for Classic Mustangs
  219. Hood Pin installation
  220. Interior Trim Deciphering Help
  221. Convertible well chrome snaps for 68
  222. Temp control cable...Broken Pawl
  223. Help installing a new gear
  224. Engine Number
  225. Whats the quality of this tranny?
  226. Some Body Problems.
  227. tool sale
  228. Missing Dataplate
  229. Serpentine pully system for 69
  230. Floor pan welded in
  231. 3 or 4 speed? / discs brakes?
  232. What gear should I go with? HELP!!
  233. 14x7 Magnum 500
  234. MOVED: fuel injection for a classic
  235. 66 dashpad stud
  236. 2 Different Vacuum Cannister?
  237. Running on corn
  238. AOD Torque Converter
  239. 68 Mustang 289 facory air
  240. Look what I found on the net.
  241. Turn signals and blinkers don't work!
  242. I am confused
  243. Shelby Racing Apron
  244. guys, i dont know if i can do this...
  245. Help with C4 and kick down cable
  246. Brake lines
  247. Front Torque boxes??
  248. Exhaust Manifold choke
  249. Removing engine and Tranny...Worth anything?
  250. 40year old seatbelts .... yuck!
