View Full Version : Classic Mustangs
  1. Confused about this mustang...
  2. 1st time poster here/wheels
  3. 69 C-4 shifts too quickly from 2 to 3 + More pics
  4. Rear main seal leak PT 2! Grrr!
  5. I think I broke my 8"...
  6. Removing dash pad - 66 coupe
  7. Tore my nuts off!
  8. Buzzing transmission
  9. Tranny Conversion
  10. Needed: Ford 9” gurus, I have a bearing question.
  11. 69 OEM Wire Harness
  12. Electrical schematics
  13. Drum or Disk Brake Booster?
  14. Photoshop
  15. Mustang classifieds website.
  16. Kind of a Newb On PCV Vacuum
  17. 73 Restomod exhaust system recommendations
  18. Horn not working
  19. Towing 67
  20. Mini-Tach
  21. ZOMGPWND
  22. Update!
  23. 340-375HP 289/302(Still tryin)
  24. Windshield installation
  25. shift light
  26. Need some help with year
  27. Custom Console for a 68
  28. '68 stangs rare???
  29. Good AOD Kit
  30. Wheels to fit Granada discs
  31. Rear end?
  32. 1967 Blue Bonnet/ Lone Star Edition Mustang Rare?
  33. Emergency Hazards posessed
  34. Throttle response
  35. what am I doing wrong?
  36. doing my cam swap tom
  37. Tranny to Engine Bolts
  38. Update on my stang!!!!
  39. 65 stanger- i need some info. nj.
  40. Pertronix Ignitor II install
  41. RATTLE-1970 FASTBACK
  42. WHAAAA old fashion cop siren sound update in PHX AZ
  43. HEI Distributor/ TACH
  44. need a picture for school
  45. Distributor Rebuilder????
  46. Carb tuning...
  47. 69 Mach 1 Clock Wiring
  48. My New "old" 69.. with pics
  49. My First Mustang
  50. 65 Fastback air intake loovers
  51. MOVED: 1978 King Cobra
  52. 67 manual transmission problem
  53. opinion on mustang GT coupe
  54. fire!
  55. Dynoed the 66...
  56. 05-07 wheels
  57. 67 Alternator Wiring
  58. 66 dies....
  59. 68 w/ AC and oval air clnr - monte carlo bar?
  60. Clock hookup issues **PICS**
  61. added another pony to the stable
  62. stating to get spring fever
  63. spongy brakes
  64. 67 Mustang Spindle
  65. No junk in this trunk
  66. 64.5 Power Steering HELP ME!!!
  67. Project pictures; I'm driving it!!
  68. la carra steering wheel
  69. Floor Sound Deadening
  70. I got $200-$300 to clean the stang up
  71. Transmission leake??
  72. Lower radiator hose
  73. one purrty cat
  74. sources for a good crate motor?
  75. 18 yr old's insurance
  76. What is going on here ? (Engine Compartment Question)
  77. Had a Bad day...
  78. C-4 Leaky Shift Linkage
  79. Bad Vibration
  80. Positioning of Shelby lower scoops.
  81. 17's front 18's rear
  82. What to do?
  83. I think I have the wrong set of poer steering hoses...64 1/2 V8 w/ Eaton pump
  84. 1971 Mach 1 351C 4bbl vacuum problem
  85. carb/intake combos
  86. Project BOSS 408 & Viper T56 (LOTS OF PICS!)
  87. Time to replace water pump?
  88. Insurance, whats it gonna take?
  89. project 1970 update
  90. Pics of power steering hose arrangement, 64 1/2
  91. Backed into a garage door today...
  92. Brake Conversion Kit
  93. 66 coupe parts for sale
  94. California Mod?
  95. Vinyl top
  96. C4 band adjustment- slippage?
  97. Should I spend the time selling my old parts?
  98. thinking about selling...
  99. proportion valve
  100. c-6 to c-4
  101. what is it worth?
  102. funny post I found in the OT section
  103. (Repost?)Guigiaro Mustang Concept
  104. Scat Rally Seats
  105. Vintage tires
  106. Making the most out of a stock 351 Windsor
  107. 67 Conv. Questions
  108. Finally got my mustang today
  109. Never Liked a Mustang II?? Check THIS car out
  110. Belts squealing!?
  111. 69 Mach 1 Alt wiring problems
  112. Distribution block/Proportioning valve
  113. How much is it worth?
  114. Teh Radiator Saga (Rip Off)
  115. '64-'68 Mustang schematics
  116. May have to sell the Stang
  117. bad alternator?
  118. Tranny id??
  119. Petronics / ignition /coil ????
  120. 68 convertible stuff?
  121. The grill that nobody likes is done!
  122. Brand new front "everything"
  123. Just for you '68 guys....Project Kiss
  124. Leaf Spring & Rear Shock Removal (1965)
  125. PUERTO RICO M-1964-65-66
  126. Fuel & Brake Lines....What side of car?
  127. Engine Paint and Gaskets
  128. matching numbers
  129. A mechanical question about a 73.
  130. good price for this lift?
  131. Ahoy! 65 Mustang Engine question.
  132. 1967/1968 Mustang Fastback Body Shell
  133. Hood Locks
  134. Transbrake question
  135. WTF ebay??
  136. The stang made it!
  137. Need Help With T-5 Swap
  138. Body Work Question with pics
  139. ebay-good for a laugh
  140. Another shifting question. Second gear is like a kick in the ***
  141. recommended auto shipper?
  142. Fe action in the 67
  143. Tested the mustang project tail lights this weekend
  144. Master cylinder upgrade
  145. What do I need to put an 03' Mach1 front suspension into a 71' Mach1?
  146. 1965 stang, need help
  147. Water gets in when it rains!
  148. Wiring Issue
  149. TMI white interior colors?
  150. Keys
  151. Good weekend in the Garage!! Pictures
  152. Help me identify(block and heads)please
  153. Official FUNFORD notice for Houston TX
  154. grande windshield in fastback?
  155. Mojoe in May Mustang & Fords Mag
  156. Torque Converter
  157. Oil Change
  158. For those of you who painted with rustoleum
  159. LCA washers?
  160. 1970 mustang mach 1
  161. Bay Area CA mechanic needed
  162. Mustang art
  163. Need some space in the garage
  164. vacuum advance?
  165. 1968 seats
  166. 9" rear axle
  167. EFI throttle control
  168. Check out my Cragar SS Wheels!
  169. New Rims and Tires (size) advice.
  170. rack and pinion
  171. Oil leak - rear main or pan?
  172. 1968 Mustang
  173. i got jipped
  174. Yum....
  175. Tune up
  176. factory toqrue specs
  177. Engine for Sale, I-6 rebuilt Will Run
  178. Antenna Delete
  179. Too much detail? Never!
  180. Is your Mustang missing this...
  181. the latest issue of car craft
  182. Mustangs&Fords Pg#27(David Matthews)
  183. Ur thoughts on these rotors?
  184. here is the progress
  185. windshield and back light replacement help
  186. Clutch pack Vs Gear type limited slip
  187. What can I use off of a 68 fairlane
  188. getting close
  189. 4 speed shifter
  190. disconnecting throttle cable
  191. Anyone replaced their own Convertible top?
  192. Lowered Mustang
  193. 6d9 Update
  194. Stereo Amp in Process - PIX
  195. First Ride- Since Upgrades
  196. phx area if you need to get that bolt out
  197. Tranny cooler lines leaking..
  198. Look at this pic.....
  199. New Paint Job
  200. need 71 trunk photos
  201. Need parts magazine to order parts for late 60s mustang
  202. MOVED: toploader in fox
  203. Which leaf spring?
  204. 65 door hinge - NEED PICTURE
  205. What Transmission do i have?
  206. Oil Presure
  207. '69 coupe, falling glass
  208. Temperature Gauge
  209. turn signal switch question
  210. racing stripes/graphics
  211. Exhaust Manifold bolts
  212. Windshield trim tricks?
  213. paint issue
  214. problem, need help!!
  215. Any one running 17 inch Styled Steel Wheels?
  216. front end assembly question - 66'
  217. Latest eBay mailing catalog...classic Stang
  218. 1966 GT - Four Wheel Disc, Dual Master, Power Brakes, Manual Transmission
  219. Interior two tone??
  220. 69 mustang brakes
  221. Is this guy insane or what
  222. body and paint costs
  223. alignment question
  224. anyone have a schematic for tail lights?
  225. Lincoln pro 125 Welder.
  226. Balance issues?
  227. TRUNKS!!
  228. so what can i expect
  229. Carb Spacer
  230. water issue wet floor
  231. is it a good deal........
  232. In need of new wheels..
  233. Shelby Security Systems
  234. How dependable is your ride?
  235. My car is alive, and its not that great.
  236. Pic of the flared rear quarter
  237. Howdy
  238. Proportioning Valve
  239. Exhaust Manifold for 68 Cougar Wanted
  240. Shifting question
  241. what do you say about these wheels??
  242. Steering Issue
  243. Torque Converter Companies
  244. starter relay stuck closed?
  245. I Need Info For 170 CID Generator Heat Shield
  246. Rust on cowl vent
  247. I fixed my dash yay
  248. Brakes
  249. Painted KYB Shocks
  250. Engine Bolts
