View Full Version : Classic Mustangs
  1. Exhaust Manifold for 68 Cougar Wanted
  2. Shifting question
  3. what do you say about these wheels??
  4. Steering Issue
  5. Torque Converter Companies
  6. starter relay stuck closed?
  7. I Need Info For 170 CID Generator Heat Shield
  8. Rust on cowl vent
  9. I fixed my dash yay
  10. Brakes
  11. Painted KYB Shocks
  12. Engine Bolts
  13. Subwoofer Installation Pix
  14. Mod the Suspension
  15. New saying hi /w pics
  16. A sub section for buying and selling parts
  17. Brake line flare angle ???
  18. what thread size
  19. Brake Drum Tinnerman Nuts - How many?
  20. So my mustang is leaving today
  21. Mustang Paint ???
  22. rust or no rust
  23. Power Steering
  24. 66 stang brake problem
  25. Shifting Problems
  26. Anyone have a parts car? I ned a brake pedal and other stuff
  27. Hard Top to Fastback
  28. How to install seat foam??
  29. Where can I get some trick brake line mounts for my axle housing?
  30. Tools and parts needed to install a suspension
  31. Stock ride height?
  32. 1964 1/2 Mustang Convertible For Sale
  33. bye bye
  34. Oh no, not ANOTHER classic car insurance thread!
  35. Wiper arm removal
  36. Carb rebuild book/valve cover gaskets
  37. convertible top
  38. New interior for an older stang.
  39. Please help with audio system for 66 stang
  40. interior door color
  41. disassembly help
  42. old car daily driver?
  43. One-wire Alternator conversion
  44. choke plate stuck in open position
  45. What Color?
  46. '71-'73 8-Track Wiring
  47. Where to find an engine lift in az?
  48. 170 to 302 engine swap
  49. Daily driver upgrades
  50. Dallas/Garland Area machine shops?
  51. Timing 289 en 302 the same ?
  52. Exhaust calmps.
  53. here are some pics!!
  54. what does tuning a carb do?
  55. trans q?
  56. Paint is DONE!!!
  57. Progress pictures
  58. SEAT BELT INSTALLATION 1965 FASTBACK
  59. rebuiding carb
  60. global west suspension
  61. which bulb!!!!
  62. tires
  63. 66 Mustang Top Loader
  64. fastbackford351 wayne67vert I_av8_4u
  65. torque convertor (stall selection??)
  66. water pump pulley does not line up with others.
  67. I wanna clean my oil pan.....
  68. pony carb crap rebuild shop in phoenix area
  69. bench bleed master cylinder
  70. vibration Rear axle bearings? diff? *update*
  71. Welding Questions?
  72. Interior Trim Paint
  73. kelsey hayes brakes
  74. Granada swap brake line Q
  75. MOVED: Street Racing II The Dangers
  76. engineswap help
  77. electric choke
  78. MOVED: going to see zz top tuesday night
  79. AOD Yokes. Need quick responses please
  80. Shorty headers wont fit..
  81. 67 and 68?
  82. Windshield and rear window trim
  83. 66 side windows
  84. Looking for parts
  85. So, you want a Nitrous motor, eh?
  86. YEEEEHAAAAAAAAA!!! Scary stuff !!!
  87. Nuts & Bolts - Sweating the Small Stuff
  88. 69-70 coupe
  89. 1973 Rear Seat question?
  90. (Metal) floor pan plugs?
  91. help - midolyne bushings
  92. What shaker base...
  93. what do i need?
  94. s-code mach 1?
  95. Rear end lowering blocks.
  96. Subframe connector PKG
  97. Classic tires vs radials
  98. serpentine vs v-belt
  99. Trohpy Hunting - Showing you Mustang
  100. Steering box adjustment?
  101. where are you?
  102. Auto body shops got you by the gonads?
  103. old fashion cop car noise
  104. Squeak squeak queak!
  105. Monster cable - Building a Mustang Stereo
  106. Year One Special Sales - Save Some Money!
  107. Cell phones and other crap
  108. Ajustment question
  109. 66 Mustang Rally Pac
  110. hood pins
  111. Dash replacement- windshield too?
  112. Oh Mighty Mustang Guru's !
  113. Disc swap complete
  114. Anyone heard of these guys.....
  115. Vin Number
  116. Paint Issues
  117. Compressor for Touch Ups
  118. intake and carb
  119. where to get build sheet?
  120. Electronic Ignition
  121. "Street Racing" what do you think
  122. Bad idle problems, she's too fast... or is she?
  123. AOD Block Plate question
  124. Need help --Camber Caster adjuster kits - do they work?
  125. Bringing Exertior Paint Back to Life
  126. Convertible top
  127. Side drain hose - correct install (pixs)
  128. ride height confusion
  129. Window tint
  130. Supercharger News
  131. Dagenham 4-speed
  132. Diameter of '65 gas cap
  133. upgrade to a Dual exhaust
  134. Paint Protection Film
  135. she's gone
  136. 1990 Mustang Engine
  137. help with fuel sending unit please
  138. Did I just make the problem worst?
  139. So it starts.
  140. New Mustang on the block.
  141. fuel line alternatives
  142. Putting together a parts list
  143. motor buildsystem
  144. Brake Pads
  145. Vin number
  146. PCV plugs?
  147. 1979 mustang (indy pace cars)
  148. Will this fit my 66?
  149. exhuast
  150. 347 Short block assembly w/my heads and cam???
  151. Good Place to Get body parts
  152. Brake booster
  153. Got my mustang!!!!!
  154. 289 rebuild- how difficult?
  155. Flowmaster Delta, Super, or Standard 40's
  156. BODY WORK QUESTON
  157. '69 mustang coupe window trouble
  158. Where to put the JACK??
  159. 64.5 Power Steering
  160. noob to classics
  161. Bench seat foam
  162. Flywheel install question: orientation?
  163. New seat burlaps??
  164. Exhaust Exit Poll HELP!!
  165. C4 High Resolution Breakdown
  166. finally installed my christmas presents
  167. Any good classic Mustang shops in SoCal?
  168. speaking polyurethane bushings
  169. My new mustang and its ugly underbelly.
  170. Patriot Tri Y headers
  171. explorer engine
  172. Door Speaker Grills (new old stock)
  173. getting a welder
  174. clevor thinking 2
  175. Rims for 69 fastback
  176. 17 inch styled steel rims
  177. Vent Window Seals
  178. Carburated vs. Fuel Injected
  179. CD Player in '66 Coupe, basic wiring question
  180. 65/66 Fastbacks - The Hidden Hoses
  181. 289 exhaust is black
  182. Ok, the project begins
  183. Generator to alternator
  184. Will 17's fit
  185. Rear Lowering Kits by TMC
  186. The Day the Music Died
  187. C6 in a 66?
  188. Primer Questions
  189. Shelby Drop?
  190. A True Love Story plz read
  191. Oil Pressure LOW
  192. Quality Body Repair in the DC Area???
  193. GVW
  194. 1966 remote hood latch
  195. brake problems
  196. steering/suspension swap
  197. hey guys....and girls.
  198. ***$10,000 REWARD *** 1965 Mustang Stolen
  199. Work, work, fun, fun!
  200. Bad News and Damage Assesment and Maybe Some Advice
  201. Autozone and advance auto Recon Engines?
  202. Not charged
  203. roller cams
  204. Flywheel/Clutch choice
  205. Seat belts in a 65
  206. 64.5 convertible top adjustment
  207. 68 mustang c-4 questions?
  208. Here's a '65 2+2 for sale if anyone wants one...
  209. Oil coming from exhaust manifold bolt hole
  210. Best place to mount a 3 point seat belt.
  211. Thanks69 Stang Wheels
  212. how difficult is a limited slip upgrade?
  213. wheels for a 1967 4lug
  214. 1969 oem roll bar
  215. Other possible brake donors?
  216. Upper Control Arm
  217. 450hp 351w
  218. Electric Cooling Fan Conversion : Wiring?
  219. 390 exhaust gasket
  220. Magnaflow Question
  221. My first Mustang
  222. BRAKES - need help!
  223. Bought a 04 cobra motor for the Fastback.
  224. how tell if it is a cobra jet engine
  225. 65/66 interior vs. 67 and above
  226. Bullit Proof
  227. Car Show! Mustang Club of Houston April 1st
  228. mod motor
  229. 68 GT500KR
  230. prep for welding?
  231. New Wires
  232. broke something!
  233. Getting original list of options using Vin # on 66 fastback
  234. Stock Wheel Specs
  235. I 6 MPG Question
  236. front end 5 lug conversion
  237. changing a 68 C4 automatic to a T5 standard
  238. Thanks to this forum ..cooling system completed
  239. 65 Fastback restore
  240. best place for stroker kits
  241. instrument panel problems
  242. small vs large distributor cap
  243. looking for a cam...
  244. dieseling
  245. rear end swap
  246. Thorque Thrust II
  247. In Car Fire Extinguisher
  248. lowering ride height
  249. Want to learn manual driving a little better
  250. 302 or 351
