View Full Version : Classic Mustangs
  1. newest problem dripping carb
  2. Still having brake problems
  3. vynil top pros and cons what are they??
  4. Shift Kit
  5. Soft Brake Pedal
  6. need advice pls
  7. faq section
  8. Ford forums
  9. ebay scammers are getting better!
  10. 641/2$$$
  11. Distributor Help
  12. Help! wiring a 68 302 on engine test stand?
  13. 4 or 8 cylinder
  14. Mustang Fastback 1967 Chassi Meassurements
  15. This might be a dumb question... how do I get into my cowl vent to clean it?
  16. 67 coupe rims??
  17. Big block stroker combos ?
  18. missing data tag
  19. what kind of carb do i have?
  20. My God, what a night. Tornado.
  21. what makes a deluxe coupe 67 ???
  22. 90 degree heater elbow for 200 ci engine
  23. where 2 drill for side views
  24. Dropped off Coupe for paint & bought FB
  25. 8" Rear in 66 fastback
  26. argh...bye bye Juanita
  27. Door Problem
  28. Performer intake vs. Stock
  29. C4 fluid? To much? No 1st Gear?
  30. Weld Dimensions for 69 Engine Bay
  31. Engine sizes
  32. Is Goodyear Air Compressor Hose Any Good?
  33. Ignition Problem, Pertronix=culprit
  34. speedo going crazy
  35. late model roller swap
  36. HELP!! weird problem, any thoughts would be helpful
  37. camshaft
  38. hard core 1970 front sus. options
  39. 1970 engine options, 460?
  40. Best master cylinder for 4 wheel disc?
  41. You guys remember that thread on painting our classics with either Tremclad or Rustoleum?
  42. New Guy, looking to purchase a classic
  43. hood trim above grille?
  44. Steve Mcqueens Exhaust???
  45. Heater Core Reinstallation for a 69 Tips?
  46. 67 mustang suspension
  47. 68' suspension?
  48. shelby drop question
  49. radio repairs
  50. CJ mustang
  51. Good Magazine?
  52. Carb Options
  53. Blinker Trouble
  54. off idle hesitation
  55. insurance
  56. 275's Out Back?
  57. Wide Tire Size for 72 Fastback
  58. Exhaust Sealent?
  59. Abrasive Blaster
  60. Hole in gas tank
  61. Hood Scoop?
  62. Gears
  63. Engine Block
  64. Hello all / 69 8 cyl' coupe
  65. any GUESSES on HP here?
  66. anyone near killeen, TX
  67. Aussie needs assistance buying fastback
  68. 393, 408, OR 427 ?...
  69. cougar
  70. 5.0 HO swap
  71. 347 Stroker
  72. please help with no start
  73. 200 ci 6 cylinder head bolts
  74. Is this structural safe?
  75. Performance Upgrade!
  76. Weatherstripping Adhesive
  77. spray gun
  78. coil springs
  79. Panel Adhesive - Who has Used?
  80. Can anyone recommend a good car transport/shipping company?
  81. inner rockers
  82. GT350H
  83. How Much should i sell my car for??
  84. Aftermarket Rims/Springs Combo
  85. How to do a VIN Search on 1968 Stang
  86. Radio Dash Repair - Pix
  87. What you guys think of these 3 point belts?
  88. Got the Export Brace on
  89. the boss
  90. convertible reservoir
  91. MOVED: mustang fastback
  92. where do i start ?....
  93. Cutting interior panels for Shelby Windows?
  94. Selling my coupe 65
  95. Question on "codes"
  96. Autolite 4100
  97. Good Reading Material?
  98. what to look for when...
  99. is there any good....
  100. Granada disc brake conversion
  101. Ok, which one would you choose?
  102. Frame rust
  103. ENGINE ISSUES
  104. Mach 1 four speed conversion
  105. T-5 rebuild
  106. Someone really hates Mustangs!! Beware
  107. Heaters
  108. Good Find? 1970 mustang
  109. Engine problems
  110. rims from 2007 to a 66?
  111. Play in Output Shaft
  112. MOVED: Airplane passengers
  113. Coupe to Fastback
  114. UCA shims
  115. radio in 66
  116. 71-73 Own section???
  117. Need 8.8 specs
  118. Shelby 10 spoke 17"
  119. Depressing
  120. 67 289 2bl
  121. 351 cleve 73stang vert misfiring
  122. 2 Mustang offers, I can't decide!
  123. Summit Racing 302 HO for $500
  124. 70 coupe radiator question
  125. Is it worth it?
  126. front apron
  127. Dodged a bullet this weekend
  128. Wheel Spacing
  129. please check my research
  130. shelby drop question
  131. 1970 Mach 1
  132. autolite carb CFM question
  133. kelsey hayes conversion
  134. bad experience with cal-mustang
  135. post rear swap noise
  136. Export brace support question
  137. I know you will laugh at me for this question.
  138. 66 Front Frame rails
  139. somebody should have warned me
  140. Ford Toploader Seal replacement
  141. a little OT take a look
  142. When do you know it's time for a rebuild?
  143. bought a 66 fastback project
  144. Strange Noise from Front Suspension
  145. 65 mustang questions
  146. PS control valve rebuild, valve spool direction
  147. 351w cam question
  148. Floorpan progress! pics
  149. Marker Lights & Fuse
  150. 351 w short block for a 69 mach1
  151. low fuel warning
  152. Shock tower cap confusion?
  153. help getting a 351
  154. 351 cj cam question
  155. Fuel Sending Unit Replacement
  156. Adjusting Valves
  157. dang it
  158. wire wheel
  159. Where to mount MSD Coil
  160. new coil
  161. Who makes better cams?
  162. dampness on floor
  163. having problems
  164. ugliest color !
  165. Can I Get A List
  166. Car storage with no supises
  167. Doors
  168. How Much For Spray?
  169. Cheap Spray
  170. How do i adjust timing on 302
  171. I Can Now Die
  172. Lokar, need new peddle
  173. Nice partner for you Pony
  174. california bound - coast to coast- update
  175. which color red?
  176. Original or Not?
  177. 68 Mustang Parts
  178. This guy has a decent colection of original '65 parts he's selling
  179. Drivers side window 1965 convertible
  180. valance recommendations for 65/66
  181. how does this look
  182. Bondo and Rust Bullet
  183. Manifolds vs Headers
  184. i think its time to rebuild the motor!!
  185. 1964-1/2 Transmission Change
  186. Dust Caps for disc brakes
  187. brake shoes
  188. How to paint Chrome
  189. Hello all
  190. need some wheel help
  191. Power Seat Wiring.
  192. 72 MACH 1 body trim?
  193. Pretty nice for 10k...
  194. AWSOME series on DIY Network... '65 fastback restmod
  195. AC Condenser Replacement
  196. Now i am Thinkin gears
  197. Wrong Radiator
  198. remote mirror removal
  199. so cool, tilt wheel
  200. hood alignment
  201. Yet another gear question
  202. Weird, please help
  203. reverb unit
  204. Dash fix
  205. Whats The diffrence?
  206. good source for mach1 parts??????
  207. looking for ideas
  208. 66 flywheel ?
  209. HB Halicki's gone in 60 seconds
  210. Correct Time Setting
  211. Idling Very High when Warm
  212. Power Steering Pump! NOT AGAIN!
  213. Who would win this race?
  214. 1965 INDIGLO INSTRUMENT PANELS
  215. Maybe this is old news but check out this website for old fixer's
  216. What is this guy smoking?
  217. Would this be worthwhile?
  218. my new tail panel
  219. Shim removal from upper control arm
  220. HELP - Mustang died when lights turned on, won't start
  221. Ran out of Toe In adjustment - Suggestions?
  222. Looks like Ford is headed for the outhouse
  223. Headhight switch removal
  224. New Coil
  225. what year of Mustang
  226. engine idea's?
  227. Head to head with 97 Supra with garrett T67
  228. how does this engine combo look????
  229. CANT KEEP THEM ON!!!
  230. Opinions on this engine
  231. Wow... what the hell happened to Mustangs Plus on Ebay?
  232. Help me avoid the pitfalls, stealth swap
  233. 1964 1/2 Convertible -
  234. anyone shipped their pony?
  235. conversion
  236. My newly installed suspension, springs, leafs, Magnaflows...
  237. 65 cowl panel
  238. 351 question
  239. 8.8 inch rear-end
  240. 76 Mustang II
  241. 69 Boss 302
  242. 1967, are new repro headlight buckets REALLY cra$%y?
  243. Intake????
  244. in-line Fuel cutoff ideas
  245. 289 vs 302 what's the diff?
  246. how to identify a tranny...
  247. How do you install a 65 Convertible top?
  248. Floor pan flange
  249. is it real?
  250. Fixing hole in quarterpanel
