View Full Version : Classic Mustangs
  1. Stock head porting
  2. Fuel pump upgrade
  3. C4 Neutral Safety Switch/Reverse Lights
  4. What other cars did you consider when buying a Mustang?
  5. 4 bbl carb question...
  6. Timing
  7. Mustangs
  8. after the stang is there any other car worth bearing the pony car description?
  9. fuel pump
  10. my motor runs great
  11. 8" 3rd member
  12. Late Model Seats into a '65 Mustang
  13. Future plans. Need some help guys
  14. non mach1 shaker to mach 1 with a shaker
  15. PICTURES- FINISHED 69- 2nd TRY
  16. PICTURES OF MY FINISHED 69
  17. How to route this wire
  18. OK, C4 Tranny Experts
  19. mustang ifs or coilover kit
  20. Seat Belt Mating parts
  21. De codeing your stang
  22. Mustang modifications - Any regrets?
  23. Passenger Quarter Panel = Devastated
  24. How do I know?
  25. Holley Application
  26. Removing Tranny Coolant Lines
  27. 289/302 Horse Power Question (by year)
  28. 1968 Cobra jet color question
  29. 289/302 300hp build up for $1500.00
  30. 8" Rear in 66 fastback
  31. Transmission Oil change/check
  32. heater problems, and it's cold outside!
  33. First time at the track not as good as I had hoped
  34. 65 Mustang Coupe Restomod
  35. Throttle Linkage problem
  36. Painless wiring
  37. rear suspension for drag?
  38. heads for a 351w
  39. 64.5 Exhaust?
  40. Overfill Tranny Causes Leaks ???
  41. wiring choices for a 68
  42. shelby drop question
  43. Engine won't run!
  44. Valve covers on a 67' 289?
  45. Soda Balsting?
  46. window problems
  47. cowl question
  48. Where to start?
  49. New Cowl?
  50. How does a guy tighted up that front end?
  51. you fix one thing somethin else breaks
  52. Someone Post A Pic Of Their Air Compressor's "quick drain valve"
  53. 68 quarter glass removal
  54. Apply Brake - Loose Right Turn Signal
  55. What First?
  56. what to do
  57. Tire and wheel size on 1966 GT
  58. Insurance question...
  59. When to paint?
  60. I think I just hosed my 351
  61. sroke existing - or new crate
  62. Weekend Update with Pics
  63. out with the old in with the new---problems
  64. 650dp fluding
  65. HORRIBLE TIMING
  66. lunch break update
  67. What Color?
  68. transmissions
  69. Floors
  70. 308 Engine for sale
  71. northcoast muscle car on ebay
  72. how do you know when to rebuild??
  73. where should?...
  74. coolant leaking inside??
  75. CHEAP ENGINE?
  76. Does anyone live around Owensboro, KY?
  77. What rear end ratio would you run in a 71 Mustang with a 425 horse Cleveland?
  78. 302 turned boss
  79. Gauge Problems
  80. Brake Conversion Question
  81. brake line question
  82. Metal prep for body filler
  83. Where does the dipstick tube bolt on?
  84. firing order
  85. anyone ever notice that something always goes wrong?
  86. Temperature guage calculation
  87. it an exciting time
  88. transmission
  89. Tail lights (can't figure out) issue.
  90. 6 Cyl Conversion
  91. water and fuel pump recommendations
  92. quick radio question
  93. what color paint for 65 mustang grill
  94. Valve chatter
  95. raptors
  96. power steering
  97. ENGINE QUESTION
  98. Intake manifolds
  99. is there a piece that....
  100. Oiling Air Tools
  101. HELP A.S.A.P---->tach installation...
  102. Frame Connector Photos... again
  103. 427 sohc
  104. Frame Connector Photos
  105. 351W roller block
  106. Heater Box Assembly 'thing-y'.
  107. 351 Cleveland
  108. Mach1 Twister
  109. Help!! Oil Dipstick Location Question
  110. Double din in the dash
  111. Do you consider changing the interior Moding?
  112. TO BONDO OR NOT TO BOND.....
  113. Carter AFB ???
  114. Can I drive with the cowl cover on?
  115. any danger
  116. Beware of Indian Steel
  117. Column shifter AOD - Mustang
  118. Forgive me for I have sinned...
  119. Hipo?
  120. what gauges are most important?...
  121. New calipers?!?!?
  122. 70 302 clanking noice
  123. First Post - First Mustang :) (6 cyl question too)
  124. ERRR timing cover HELP
  125. Source for AM radio knobs?
  126. Frame Connectors
  127. got more work done today
  128. Deleted post
  129. resto mod!
  130. seats...
  131. carb rebuild
  132. Exhaust upgrade....
  133. interior
  134. sand blaster??
  135. Quick help: Part Number
  136. fuses panel
  137. rear suspension
  138. 427 badges
  139. Ghetto Fixing Help...
  140. NOT MY BABY!! **Update**
  141. console bracket
  142. What carb do I have?
  143. Curious of your opinion...
  144. Cowl cleaning tips??
  145. 1969 GT Convertible
  146. Audio and such
  147. Carb problem - sticking throttle
  148. Three pictures, three questions.
  149. new project
  150. Squeaks and Moans
  151. fuse removal
  152. I Wanna Cry
  153. Which carb on a 72' 351C
  154. When life gives you lemons throw them at someone
  155. AutoAuto to 4 speed conversion
  156. 4-speed compatibility for 200 ci?
  157. Whatchmacallit????
  158. COWL
  159. Carb adjustments?
  160. How can I make a 300 hp 302?
  161. HERE ARE SOME EBAY DEALS
  162. front clip question ?
  163. Bad news...
  164. Window Glass Removal
  165. carb w/electric fuel pump -- is a return line needed? recommended?
  166. "Before" photo
  167. Tranny Mount
  168. Engine Art - Black Valve Covers
  169. Dual master cylinder
  170. Autolite Plugs
  171. Air Intake Question
  172. NOT MY BABY!!!
  173. Spring question
  174. Wierd wiper switch part needed
  175. Could it take an STI?
  176. T5 conversion question
  177. Question about value... 1970 BOSS 302
  178. instrument cluster lights not working
  179. Air Conditioner/289 heads Help on both.
  180. What kind of rear end
  181. pulling a 200 I6
  182. New 67 Fastback - $16,000
  183. Winshield Wipers Quit!
  184. point and LOL after you answer please
  185. spark plugs
  186. VALUE
  187. Installing aftermarket radio
  188. Backfiring
  189. Fender Apron top
  190. new project car?
  191. got my interior stripped, cleaning time
  192. Exhaust systmes
  193. Front end work - RUST Found on sway bar link
  194. MOVED: 78 Mustang II
  195. I love CraigsList
  196. Paxton supercharger
  197. Which MSD wire p/n?
  198. Help! Autolite 1100 adjustments
  199. MOVED: Who iss...
  200. There's a 94 Lincoln Mark VII....
  201. Driveshaft Realignment
  202. Best sounding Mustang Muffler
  203. Paxton Supercharger and the Demon
  204. Speedo Gear Replacement procedure!!
  205. Air Compressor Help...
  206. Mirror question
  207. weld wheels?
  208. Remove lower crossmember?
  209. Boredom pays off!
  210. 05-07 wheels on a 67 coupe
  211. Liquid Sound Deadner
  212. need advise on this swap
  213. Where to hook up vacuum
  214. quick question
  215. 331 stoker motor combos
  216. looking for steering wheel lock for '67 mustang coupe
  217. Question on a good V8 donor car
  218. Vacuum advance.
  219. 68 Mustang Interior ?
  220. console trim color
  221. 289 pics
  222. 1966 sprint?
  223. Shaking/Vibration question??
  224. welding/air tool gurus
  225. ANY EXPERTS OUT THERE?
  226. 289 and 302 Oil Filter QUESTION
  227. Rear End Question
  228. 5.0 Heads on my 289, which pushrods?
  229. Route 66 or bust (hopefully not bust)
  230. i cant wait to show you my new horses im getting soon
  231. The Mustang parts guy in Jaxonville Fl
  232. Zerg fittings
  233. OT: OSU vs UF.
  234. How much do you have in your car?
  235. What year is this?
  236. Weird Igniton Problem any ideas would be wonderful
  237. How should I do the Stereo?
  238. Different types on POSI?
  239. Smoking the Tires
  240. Grounding Question
  241. cleveland rebuild 2v
  242. Do I remember this car?
  243. Sirius Power
  244. Coil Spring Covers
  245. which way do rotors face?
  246. 94-03 Cobra Brakes On My 69?
  247. macco paintjob pics
  248. my bell-housing
  249. Shock tower caps?
  250. surface prep for body filer?
