View Full Version : Classic Mustangs
  1. think i blew a head gasket!!!
  2. I Dono About The Rest Of You...
  3. Awesome Ebay Deal!!!!!!!!?
  4. Neighbour has a 71 red convertible should I have a look at it?
  5. Cleaning Nuts and Bolts
  6. Gas odor
  7. How to properly bleed power brakes?EDIT : Power Steering
  8. Stock Paint?
  9. Alt update
  10. Miles per year/ Quality of your Ride/ And... Why?
  11. winter storage 65 mustang
  12. Day 5 - Undercoating done.
  13. Battery level indicator ..... sort of
  14. brake question
  15. Battery tenders
  16. Baby Goes to Shop Tomorrow for Estimate
  17. noticed this today
  18. 2 barrel carb to 4 barrel conversion
  19. 302 carb 2bbl question
  20. Brakes and wheels?
  21. 1966 289 V8 Coupe Engine Rebuild
  22. Clutch?
  23. Wheel Ideas for '65 Inline 6
  24. Steering Gearbox Removal
  25. Good Auto-Body Equipment/Supply Vendor?
  26. choke open?
  27. A New Poll!
  28. 351C Gurus Please Help=(
  29. sweet
  30. Is this a good place for electric choke? **PIC**
  31. Locating Emblems>
  32. V-BELT OR SERPETINE
  33. clutch help
  34. mild cam installation advice needed
  35. Windage Tray
  36. 73 convertible
  37. 69 fastback wiring help
  38. chrome vs. aluminum
  39. Hope that's not serious.Falcon Engine in Mustang - Reading Smoke
  40. Day 4 - Floor pans in.
  41. Another step complete
  42. Re-keying the ignition switch
  43. Re-keying the ignition switch
  44. PIllar Pads
  45. Just blew up a muffler!..need some timing help
  46. 302 Timing questions
  47. Sport grill lights
  48. Brake lines / fuel lines
  49. Inline Six
  50. just for giggles
  51. wheel/tire sizes
  52. Fun with Iron oxide
  53. The 2008 Mustang?
  54. gasket dressing...
  55. Welder
  56. Santa came early
  57. My Stang has always been cold sensitive, but this is ridiculous!!
  58. hello
  59. Transmission Interchangability question
  60. frozen bolt
  61. A Stonger Undercarriage
  62. Power steering or not
  63. WHAT IS A MUSTANG ELANORE ????
  64. 69' Fastback
  65. need help hooking this up
  66. Rebuilding a rear end
  67. bench seats
  68. great deal on ebay
  69. hood with scoop
  70. Rust Converter
  71. Bubbles in Master Cylinder
  72. Sandblaster advice please
  73. Tri-Y Headers
  74. starter
  75. Brake Fluid/Line Question
  76. pulleys, radiator, more dress up
  77. Fuel System 72 Mach 1
  78. Big Block 429
  79. New Suspension for '66
  80. 71-72 .Steering wheels
  81. scat rods and crank
  82. 66 Coupe I built for a friend!
  83. Cowl Damage (minor?) **PICS**
  84. Wheel coating??? To coat or not to coat?
  85. Granada brake swap
  86. Pretty Excited.
  87. Body Style # and Engine Stamp #
  88. Standard Vs. Deluxe interior
  89. 67 or 69 Hood?
  90. So my exhaust fell off today
  91. 65 Coupe
  92. 302 year?
  93. DriveShaft Play??
  94. Heater Box Question
  95. Ebay Scams - 69 Mach1 R code 428 Cobra Jet
  96. 427 SOHC engine
  97. Center Cap for 1967 Hubcap
  98. Rusty Floor Pans
  99. floor pan repair
  100. Vinyl Roof removed,RUST.take alook
  101. '69 vs. '70 Boss 302
  102. How to proceed
  103. counter weight
  104. 351w against a c4?
  105. 69 weight
  106. Percentage of Mustangs with Rust
  107. elec. fuel pump?
  108. 302 v8
  109. World Windsor Sr. 200 Heads
  110. Rebuilt engine starting problem
  111. 66 Fastback
  112. Rust treatment?
  113. glad i waited !
  114. arcing
  115. My buddy has a 72 MachI
  116. Giugiaro Mustang Concept pics
  117. 66 4spd converting to 86 5spd
  118. Door Alignment
  119. Tomorrow's the Day
  120. Sand Blaster Help
  121. Legend Reborn?
  122. Rear Frame Rails
  123. Trunk Paint
  124. Ford Racing Parts--need info
  125. 302 / 351 interchangeability
  126. granada swap, quick question
  127. 66 alternator woes
  128. Removing Front 68 Seats
  129. Day 1 done, day 2 starts...
  130. Kinds of Car Paint...Primers...
  131. Ford is.....
  132. overdrive tranny for a small block
  133. 5.0 Engine 41,000 orginal miles
  134. 9" rear end question.
  135. 65,66 steering diagram or pic?
  136. ok ima get new heads(well new to me anyway)
  137. 64-65 mustang
  138. a new build
  139. booster venturi
  140. Cool Idea! Why dont they make this?
  141. Clear coat paint
  142. who sells brake lines for a dual master cylinder conversion?
  143. who makes the best carpet replacement?
  144. helllp 4R70W??? transmission id
  145. 65 convert interior paint
  146. 65 convert engine compart
  147. 68 Pony
  148. MERRY CHRISTMAS TO ME
  149. vin in the engine compartment
  150. 68 Pony V8 Conversion
  151. TV CABLE
  152. Sunday Dec 3rd Cruise. Be there!!
  153. Trap door
  154. Trap door
  155. what would you pay
  156. anyone on this forum in Idaho????
  157. HOW MUCH FOR C4
  158. 67 fuel sending unit
  159. engine redux
  160. Proud Papa
  161. Oil/Alt lights, wipers not working
  162. Engine and Tranny
  163. 289 getting a T5, what flywheel?
  164. Can You Get Spray Nozzle Attachments?
  165. stock CFM for a 2 barrel
  166. Which used engine for a 69 Mach 1?
  167. Just got a Mustang II
  168. 1967 289 convertible or 1967 S Code 390 Coupe?
  169. Console Brackets
  170. found a 66 need help
  171. Float level
  172. thermo choke ?
  173. Raising the rear
  174. Trans to motor problems!!
  175. 1967 Mustang Question
  176. Wiring aftermarket tach (previous owner fiasco)
  177. Mustang musical accompanyment?
  178. Spring side towards engine for thermostat?
  179. 1973 mach
  180. WHAT NAME DID YOU NAME YOUR MUSTANG
  181. my 67 mustang specs
  182. the scarebird disk brake
  183. Releasing Parking Brake
  184. Crate motors
  185. No fear.
  186. Disc brake conversion
  187. Problem w/ start up...
  188. How Do Pop Rivets Work?
  189. Epoxy Primer
  190. Dwell/Tach/Timing Light
  191. want to customize my bumpers
  192. These Will Fit Right?
  193. So I Finally Got An Air Compressor.... :)
  194. photoshop help
  195. Got a new Camera today
  196. FAQ section is getting enormous
  197. Floor Pan
  198. brake up grade
  199. Vintage Mustang Event
  200. All in the steering column.
  201. Gasket for 390
  202. Where to buy sheet metal from?
  203. She'll be great someday I just know it!!
  204. 1965 fastback wiring
  205. GT or not ?
  206. Rust Repair Ideas
  207. How did this hole get there?
  208. 3.55's or 3.73's
  209. MP brakes are OTW
  210. cowl induction.
  211. New to Restoration
  212. need a pic
  213. Update on teardown
  214. Fuse locations
  215. Steering gear box tag
  216. Need a pic
  217. well i think she hates me
  218. Is it ok to drive a classic Mustang hard once in a while?
  219. Cable clutch conversion
  220. 1967 S-code GT fastback
  221. Bumper brace nuts...
  222. looking for a new rear end
  223. mach 1 question
  224. how strong can a t-5 be?
  225. which do you prefer? restomod or restore?
  226. Locked diff(minispool) Drivability??
  227. 1971 Tach cluster switch over
  228. One Extra Light Socket ????????
  229. Bleeding Master Cylinder
  230. heater controls
  231. brake pressure warning light
  232. 1.40 Gears????????
  233. just an update
  234. would you do this with your mustang
  235. I need an intern/apprentice
  236. Best Mustang magazine?
  237. i6 vs 289 or 302
  238. pics of my project
  239. I hate rust with a passion
  240. MOVED: 200x series?
  241. Ideas for a 65 Fastback Restomod
  242. Do These Sockets Look Right?
  243. Wheel Cylinder
  244. The newest 'Steed' for the stable....
  245. problem finding the history of my stang
  246. The time has come
  247. c4 to AOD
  248. possible to put on 5.0 parts onto 66?
  249. New user checking in and have a question
  250. shifter
