View Full Version : Classic Mustangs
  1. c4 from a 6 cyl. the same as one from 302?
  2. Fuel line
  3. wheels
  4. Alternator Check
  5. 73 Mustang convertible power windows to crank windows
  6. My 67 Project
  7. Final Head selection
  8. How come i cant post in the for sale section??
  9. Power Brake Booster Push Rod
  10. Backup LIghts
  11. Dyeing/painting bucket seats
  12. a new set of hookers :-)
  13. Tuning
  14. Header bolt will not fit
  15. What do to with my 5.0 engine and AOD?
  16. wont idle
  17. .... unilite distributor ...weird
  18. are 15x8 wheels too wide for the front?
  19. *** NEWBIE NEEDS HELP AGAIN! Price check! ***
  20. 67 Project Thread
  21. Need 1967 accelerator diagram
  22. Can anyone Identify?
  23. Does a carb spacer really help
  24. Restoration Advice
  25. Total Advance ? (5.0 Roller, Duraspark II)
  26. help choosing heads
  27. Headliner insulation?
  28. bucket runs needs carb help
  29. Anybody help me ID this crane cam?
  30. are these '67-only engine mounts?
  31. 85 f150 302/c6 swap into 70 fastback
  32. Motor Mounts
  33. timing mark on 67 289 w/ac
  34. Interesting situation-Engine upgrades
  35. Crank pulley?Rearend?
  36. decisions decisions decisions
  37. Windsor inlet manifold flow figures????
  38. Snapped bolt in bell housing
  39. 2brl Autolite CFM????
  40. Holy ****ake Mushrooms!
  41. Help removing front leaf spring bolt
  42. '68 Heater Box Clips
  43. modify?
  44. i need a good suspension for a 1966 mustang what kind?
  45. Fuel issue?
  46. Real Wood Veneer on console-any every try it ?
  47. gt40 heads
  48. 65-66 carpet in a 64.5?
  49. Will these subframes work?
  50. If I replace my headlight harness
  51. 1969 Mustang Oil Pan
  52. '73 302 mustang......problem or maybe not !!
  53. what would you pay?
  54. GT500 Painted!!!
  55. AOD Neutral Switch... Where To Buy
  56. '66 4V carb secondary opening rpm?
  57. welding in the trunk brace ?
  58. Problems Locking the Doors
  59. Starter or solenoid bad?
  60. Subframe and Torque Boxes Choice
  61. distance between tie rods for a '67?
  62. 1968 Mustang Speed Control
  63. a few more starter Q's
  64. Gasket ?
  65. New Member Hopefully not a stupid?
  66. Wiper delay
  67. Project "Stinger"
  68. Ballast resisitor needed for tach-help
  69. trunk weatherstripping
  70. Transmission question
  71. center steering link
  72. Purchased 65 Mustang. Few questions.
  73. brake conversion questions
  74. Better stopping? 13" 2 piston or 11" 4 piston
  75. Dumb rebuild question
  76. removing cowl
  77. Help with welder wiring!
  78. What are the pros and cons to installing a mustang 2 type suspension
  79. I need healp adjusting valves
  80. Engine has horses running around inside.. Help!
  81. Galvanized metal in car?
  82. Modern Rack and Pinion in 65 Mustang Coupe? Any donor cars work for this?
  83. is a 67 inline 6 car worth putting a 351 in it?
  84. 65 trunk lid inserts?
  85. 1966 roof rail weatherstrip channel
  86. good design idea or no?
  87. night time saftey upgrade you should all do
  88. Rouge Wire on Engine
  89. 66 fastback, built c-4 won't shift right
  90. 200ci starter questions
  91. roll cage for 69
  92. Thanks JamesW on the Magnum 500 advise
  93. universal joint help
  94. Torque Thrust II Questions
  95. Anyone have an electronic shop manual or wiring diagrams for a 66?
  96. Anyone have an electronic ship manual or wiring diagrams for a 66?
  97. 1100 Carb question
  98. Floor pan caulking
  99. SEM Colorcoat for Plastic?
  100. 65 coupe full quarter panel fitting
  101. Window is jammed
  102. window assembly diagram
  103. selecting a OD trans to put in a 67 coupe
  104. Brake Issues, please help...
  105. Redline on a 302 from a 93 fox body?
  106. 65 fastback headliner
  107. thermostat stuck open?
  108. 65 emblem opinion
  109. MSD Questions
  110. flwheel!
  111. Surprise Engine!!!!
  112. Opiniuons on the restomod which way to go (pics)
  113. disc brake swap
  114. 1968 Mustang Option list
  115. transmission help
  116. E-street heads
  117. Fiberglass Vs. Current
  118. is rust meant to flow to the overflow tank?
  119. Shifting
  120. 66 Terlingua Mustang
  121. 1968 Mustang AM/FM Radio Info
  122. Quick question: T5 zspec
  123. Lead for rusted window fame?
  124. voltage regulator
  125. Heater hoses and thermostat HELP.
  126. Cleaning up old nuts and bolts
  127. headlight bucket painting
  128. Intake / Carb suggestions
  129. bolt rotates with nut (?)
  130. unusual problem
  131. new motor?
  132. Headers vs. Manifolds
  133. A few Hi-po 289 TLC questions.
  134. 4sd shifter knod/reverse/ removal
  135. Buying a blank CA plate for my 67 abroad?
  136. crane back in business :-)
  137. AOD (external) Trans Cooler Install Q?
  138. 1970 convert advice
  139. 1969 Heater Control Knob Removal
  140. Cooling System Question
  141. I6 vs. V8 steering center linkage
  142. crack in alternator bracket
  143. Repro 67 body panels: Who's used them?
  144. Wiring horn to aux swtich?
  145. Engine/Carb HELP!!!
  146. water jackets
  147. looking to buy
  148. anti stall dashpot and idle adjustment
  149. Alternator bolt
  150. Rally Pac wiring question
  151. How tight should I torque my lug nuts?
  152. 65 rear end
  153. 67 coupe water leak help!
  154. quick parts ID plese
  155. rear axle seals
  156. Restoring a 1968 Mustang Convertible: Best place to find parts needed?
  157. sending unit...fast help plz
  158. Connecting Elelbrock 600cfm correctly to 289.
  159. Not enough fuel to engine
  160. Transmission question
  161. Vacuum Line
  162. Rubber "Bumper" in Quarter Extension?
  163. 67 Window wont roll down
  164. 289 in a 69 Coupe...
  165. dies when put into gear!
  166. Coil spring removal (in deep doo doo)
  167. 289 Long Block
  168. 67 manual drums to power discs + new rearend?
  169. aftermarket wheel opening moldings?
  170. dakota dash installed but now wipers.........
  171. how to decipher Holley powervalves ?
  172. HP range
  173. 1995 Mustang Dash Lights and Tail light problem.
  174. mustang wont roll in neutral/engine off
  175. Paint Next Week! gt500
  176. Photoshop help!! i need your skillz
  177. Rolling Chassis Questions???
  178. Stalling my automatic
  179. POR 15: Got a few questions for those that have used it.
  180. Our '65 coupe project, so it begins (Lots of pics)
  181. Fiberglass Quarters
  182. cd player
  183. Black priver on New body parts/panels..to remove or not?
  184. After market seats or modern take off seats... for 65 Mustang Coupe
  185. Borgenson Steering box reviews?
  186. Rack and Pinion vs. Stock steering? Recommendations
  187. Scott Drake Hurricane AC/Heater set up? any good?
  188. Need input on Motor build for 67 restomod
  189. what 351 is better to build or put in a 67
  190. license plate lamps - wiring
  191. 73 engine bay lights
  192. VR1 Oil.. which weight?
  193. Remove old Headliner/Insulation glue?
  194. insurance valuation help on my 69 mustang?
  195. I need some help
  196. Where to find a nice 67 instrument cluster?
  197. How can I Strip Cowel Vent paint?
  198. 170 ponys
  199. 1966 High Beam Issue
  200. Won't start?
  201. Maverick rear end in my 66
  202. QA1 coil over question
  203. Lincoln LSC disc brake rear axle
  204. How to find/choose an appraiser?
  205. Do bump steer tie rod kits work ?
  206. Subframe Connector?
  207. Noisy PCV
  208. mustang line drawings or clip art?
  209. Cobra Brake Conversion Question
  210. '65 woodgrain console
  211. may have to sell
  212. Carb Diagnosis Help Please
  213. Which distributor gear to use? (for Crane 449561)
  214. 68 Transmission Swap for Clifford Build 200ci
  215. 68 mustang powersteering bracket help!!!
  216. windshield gasket for 69 fastback
  217. '67 200ci wont start
  218. Oil smells of gas
  219. 65' Rear Suspension?
  220. 400M engine // what heads to get?
  221. 390 fix up ideas?
  222. Where to get quality window weatherstriping?
  223. Book recomendations
  224. Heat question
  225. home made coil over conversion
  226. roof rail weatherstrip
  227. Anyone try the AJE suspension on a 67 mustang?
  228. Why use phosphoric acid?!
  229. car wont shut off?!?!?!?!?!?!
  230. Doin' a u-turn
  231. Car Not charging correctly & pics from this morning.
  232. Are these 1964/1967 Vintage Mustang Wheel/Rims?
  233. How much can a stock bottom end 390 take?
  234. 65 mustang suspension set up!!!!
  235. Dynomax Mufflers
  236. Clutch
  237. Interior question
  238. 65 Mustang Convertible Pump rubber mounts
  239. Shelby drop??
  240. '64 1/2 Powertrain options
  241. 69 gt scoop on a 66
  242. wuheee! car is moving as it should now :-)
  243. Mustang Mechanic in Charlotte, NC
  244. registration
  245. suspension opinions?
  246. 302 for 1965
  247. Starter smoked
  248. Oil leak and headlight?
  249. Hey guys i need help, 67 gta wiring trouble.
  250. tuff dawg engines?
