PDA
View Full Version : Motor Swap Section
Pages : [1] 2
  1. 4.6 Swap
  2. Engine/motor swap?
  3. 351 C in a 1969 Mach 1
  4. 05-09 GT500 swap in 06 GT
  5. 2001 3.8 swapped to a 89 5.0 motor , tranny, and rearend. Any advice
  6. 67 Mustang Motor swap
  7. engine swap
  8. New addition to my existing swap
  9. Engine
  10. Can anyone identify this motor?
  11. Can I put a 96 GT in my 95 v6
  12. Is there a Ford equivalent of this build?
  13. 1968 Mustang Fastback (X code) 390
  14. 4cyl to 5.0 swap
  15. OMC 5.8 cobra
  16. Trick flow top end kit idle problems after install
  17. newbie with 2002 blownup v6
  18. Need advise please 👍🏻
  19. 96 gt with a 98 motor runs hot!
  20. Engine compabilty
  21. Hi, sorry, newbie here..........
  22. Eng year
  23. Car won't stay running
  24. 5.4 supercharged swap
  25. 2011 5.0 crank relearn issue.
  26. 1985 gt swap. "HELP"
  27. 1990 Thunderbird sc 3.8 into 98 Mustang 3.8
  28. 01-04 engine With t-45?
  29. 3.8 fuel injector question 1994-1998
  30. 2005 v6 and v8 pricing
  31. swap v6 to old school 360
  32. Best option for a 4.6 SOHC replacement?
  33. 4.6 fox swap
  34. 5.0 swap
  35. Has anyone replaced an automatic with a stick?
  36. Anybody bought anything from Automotix?
  37. Need options
  38. no power at WOT
  39. 0 GT Deluxe 4.6 to 5.0
  40. 1995 5.0 bit the dust. What now?
  41. 2009 4V swap considering
  42. 1995 mustang engine swap
  43. swap from 98-4v to 2v reason explained in post
  44. reaching out V6 to 4V swap
  45. 2005 v6 engine swap for 03 cobra terminator engine l
  46. 2011+ Duratec 3.7 V6 in a 66 Mustang?
  47. 351w into fox body, Headers?
  48. 1999 Base Coupe 3.8 -> To 5.0L V8
  49. 5.4 swapped 2000 gt mustang
  50. Lincoln 429?
  51. 2000 gt to 2003 supercharged cobra swap
  52. Help 5.4l 2v Swap Tuning!
  53. 2009 GT/CS coyote swap
  54. Newbie question. A 5.4 liter into a 2000 GT?
  55. need help with swap.
  56. "92" Mustang Engine Swap
  57. Help
  58. Want to swap 65 rear end with 73 comet
  59. 95 v6 to 302 swap- advice?
  60. Supercharger or Turbo?
  61. 66 v6 to v8
  62. will a 97 4.6dohc 4v fit in the 99-04
  63. Need Help please
  64. 2002 gt putting 96 cobra in it? Compatibilities ?
  65. 4.0 To 5.4 (4v) Navi Swap
  66. 1969 mustang
  67. Modified 1992 LX 5.0 Swap SN-95
  68. Ignition wiring issue
  69. 96 v6 351w swap
  70. 2011 5.0 Fuel Requirements to a '98 Cobra System
  71. 94 mustang big block build
  72. 408w Swap
  73. 2002 want crank
  74. 2000 Mustang Motor Swap Possibilities
  75. Engine 92 to 98
  76. Explorer in 94 95 5 speed
  77. Help!!!
  78. 1995 mustang GT engine swap
  79. 98 mustang v6 to 351w
  80. 351w questions
  81. 5.0 swap problems!!
  82. 2006 4.6 motor swap in 69'
  83. 1964 Comet Engine Swap
  84. 5.4 swap questions
  85. 2002 MOTOR SWAP
  86. All Kinds of Messed Up
  87. 351c heads
  88. whats needed to swap a 4.6L into ratrod
  89. Noob needs help! 86 mustang svo motor swapped to 71 5_speed carb 302 v8
  90. boss 351c in 1969 mustang
  91. I just pick up this car today what motor can this be I think it's a 351 windsor
  92. Dead fuel pump, transfer pump and fuel pump modular all at once!
  93. GT to Cobra?
  94. 87 notch 4 cylinder to v8 swap help needed
  95. 1989 5.0 5 speed swap into 1999 v6 auto mustang
  96. 89 5.0 swap into 2002 3.8
  97. 2002 Electric problem
  98. engine swap 69
  99. 4.0 to 5.4 swap questions
  100. Just swapped motor exhaust want fit
  101. Just swapped motors, want start
  102. Throttle linkage help
  103. Ls6/LS3 engine swap into 2002 GT tips
  104. Motor pull help please
  105. 351 into 94 v6 car T5
  106. 94 3.8 to F150 5.4 trition parts list HELP
  107. 351W in 1994 deck to hood space
  108. 1967 swap 289 to 351c 2v
  109. 4.0L V6 to 4.6L V8 swap how-to - 2005-2010
  110. 68 mustang 4.6 swap
  111. Mustang build. Help!
  112. 1980 4cylinder to 351w
  113. 1988 Mustang GT Needs a new engine
  114. 1990 5.0 to a 351W EFI (from a 1996 F-250)
  115. problem with restomod 289 popping through carb
  116. 86 5.0 to an 04
  117. 2008 v8 into a 2001 Gt
  118. 4.6 eng out of e150 to 1973 mustang coupe
  119. cam shaft change vs engine swap
  120. 3.8L V6 to 6.8L 351w in 2000 Mustang
  121. 1967 straight 6 to 289
  122. Please help, need advice
  123. 1965 Ford Mustang V6 Engine Restoration
  124. Longtube Headers
  125. 01 4.6 to 1999 Mustang?
  126. 1994 5.0 into 1967 Mustang
  127. LS SWAP IN 2002 V6 MUSTANG
  128. Edelbrock victor Jr
  129. 2003 GT Lincoln MkVIII Swap - IMRC Functional
  130. 94 Mustang 3.8 v6 swap for a 91 gt 5.0 v8 carbureted motor
  131. break booster clearance
  132. 1995 GT swap to 351w
  133. IT'S ALIVE!!
  134. 1996 4.6 to 359 HO Swap
  135. 1969 Swap
  136. 2000 gt 5.8 swap
  137. 3.8 to 4.6 swap
  138. 94 3.8 to a 01 3.8 swap
  139. 5.8 foxbody swap
  140. '98 4.6L Swap: No Speedo & Runs Rich?
  141. 86 5.0 swap into 93 4cyl car, what do I need?
  142. gt40p heads
  143. Fuel Injector Identification
  144. 5.0 into a 1966
  145. 4.6 into fox
  146. Windsor build
  147. 98 gt auto into 97 manual chassis? Help?
  148. Motor swap
  149. Engine swap & 351/302 intake question
  150. 1966 Mustang engine number query
  151. T5 bolt to carb 302?
  152. 4.0 to 4.6 3v tuning WA State
  153. Help Wanted!
  154. 2000 3.8 to 4.6 swap
  155. 98 mustang 5.0 swap
  156. v6 to v8 conversion wire harness
  157. Most durable of the modular for a performance build?
  158. a 01-05 crown vic fromt supension into a 05-09 mustang
  159. 91 GT Fox Hatchback HO5.0 pushrod into my 02GT engine Bay is it worthy?
  160. 07 motor + tranny into 97
  161. Motor Swap
  162. swap my engine 91 5.0 gt to another mustang 96-99 or another car.
  163. 2007 Mustang GT Coyote Swap?
  164. Any good machine/rebuild shops near Atlanta
  165. Certified and proven safety and quality
  166. 1996 Swap- 3.8 to 3.8
  167. 2.3 to 351 swap question
  168. 351w swap
  169. engine swap
  170. Ignition Question
  171. 5.0 H.O. motor swap into Lincoln
  172. 5.0 FI to 302 carb swap
  173. Is a 351c any good?
  174. 1968 Fastback 351w Engine rebuild questions
  175. new member with a 3.8 foxbody
  176. Lincoln 3.9L V8 into a MII?
  177. 1998 V6 to 95 5.0 swap.
  178. Swap 3.8 with 4.6
  179. Fuel injected 5.0 in a 1977 cobra?
  180. 427w into 2012 Mustang
  181. 99 mustang gt rebuild or upgrade heads?
  182. V6 Swap or V8 Supercharged question.
  183. 4.6 L Engine Swap in 1978 Mustang II
  184. 4.6L swap to T5 trans?
  185. Cobra swap.
  186. What i need to put a 2013 shelby motor into a 2003 Expediton xlt ?
  187. 99 cobra engine into a 2000 3.8 mustang
  188. 96 Mustang 351w efi swap
  189. will 97 4.6 from T-bird fit 2001 GT ?
  190. will 97 T-bird 4.6 fit 2001 gt mustang 4.6?
  191. 2001 continental into 87 Gt
  192. 1998 mustang v6 to 302 carb swap need help
  193. Need Help
  194. 02 v6 to terminator swap questions.
  195. im new need help
  196. *New here!* 1999 Mustang police 4.6 swap?
  197. Torn. Advice please.
  198. '87 5.0 from Bronco into a '68 Mustang
  199. Block Code and info on rebuild.
  200. 351w in a Fox
  201. new coyote and trany in my 1997 mustang v6.
  202. 99-04 Gt engine harness in a 96-98 Gt with a 2003 4.6?
  203. mustang with a little lightning
  204. 5.0 stroker/stage 3 heads/ E force SC
  205. How to inspect a used engine? Plan for hi-po rebuild...
  206. 1996 cobra swap into a 96 GT
  207. mustang noob swap questions
  208. Motor Swap Issues - 97 into an 02
  209. 04 4.6 into a 1996 mustang, will it work?
  210. spun a barring, want to get back on the road
  211. 4..6 sohc to dohc in a 99 gt convertible
  212. Carbed 5.0 in 84 AE86 Corolla
  213. 66 6 cylinder to 89 5.0 questions
  214. 95 v6 to 5.0 swap from a moutaineer
  215. Need advice on v8 swap?!?
  216. Almost there....
  217. swap from 2.3 to 5.0?
  218. Questions about swapping an engine and the difference between engines
  219. 5.0 in 95 BMW M3
  220. 2011 v6 engine into a 2010?
  221. engine/Information Conflict
  222. Mustang drivtrain swap
  223. 4.6 in 95gt
  224. I want to go 4v
  225. 98 GT swap 95 Thunderbird Crate Motor?
  226. 2005 V6 Swap to 2011+ V6
  227. very custom sbc in a sn95
  228. going from 4.0 to???
  229. S197 4.6 4V swap!?!
  230. auto to standard
  231. 3.8 to a 4.6
  232. Engine mod or swap?
  233. 98 swap from windsor to romeo
  234. motor swap for 2006 mustang
  235. Shorty Header exhaust
  236. WILL THIS ENGINE SWAP WORK
  237. Edelbrock TOP-END KIT #2091 367HP/340 LB-FT OF TORQUE I
  238. V6 Engine Swap[Question]
  239. coyote engine swap acc brackets
  240. '98 4.6 cobra motor into a '90 GT 5.0 body
  241. Ford 302 casting number help
  242. 86 4 banger to 90 5.0 conversion
  243. Can a 2011 v6 engine/tran fit into a 2007 v6
  244. Serpentine help!!!???
  245. 5.0L Coyote Swap Question
  246. 1996 mustang v6 to carb 351
  247. 88 5.0 gt motor swap to a 97 explorer gt40p engine?
  248. Block comparison Question
  249. Kooks New 1 7/8" & 2" Coyote Swap Headers
  250. Kooks Coyote Swap Headers
