- Problems with new clutch
- rmps sticking
- will my warranty fix my head tick noise
- Put some 315s on the Cobra
- hp/tq
- good place to have long tube headers installed
- Quick Tune Up Question
- Looking To Buy SVT Cobra 03/04
- Got some good pics recently.
- 98 cobra for corvette fan
- Looking 2 buy a 98 Cobra, need advise QUICK!
- irs wheel hop on my 1999 cobra
- 4V billet Valve Covers.
- exhaust leak
- Spraying the terminator?
- Clutch info?
- 1998 cobra cams on 1999 cobra
- Help!
- best place to find a car?
- Weird smell, like burning wires, maybe clutch - 99 Cobra, HELP!
- 5.4 build
- 01 cobra to 03-04 cobra supercharge conversion. Want to buy.
- have you seen this 03 cobra with 8.8 swap?
- ...Few Cobra shots!
- Blew out a plug
- Densecharger??
- Looking To Buy Cobra
- New to SVT
- must try this product!!!!!!!
- which longtubes? engines out and ready
- Build engine or drop an 03-04 termi engine?
- site i found
- torque specs for spark plugs?
- recommend dyno shop in central florida
- 2004 cobra factory boost gauge
- Thermostat/Over Heating
- Raising my 97 cobra
- looked at a 97 cobra
- Kim's Cobra on the Dyno
- Skinnies with Cobra brakes?
- sub 2.8 pulley
- My new 04 Comp Orange Cobra
- Engine not running right after rebuild, need help!
- Pinion bearing bad after only 36k miles??
- Ticking sound at idle only--common 4.6 noise?
- 93 Cobra
- supercharger bypass valve
- Changing my diff oil in the AM, tips?
- just got my 2004 cobra
- need help installing fluidyne heat exchanger
- 01 cobra to 03 bumper/hood
- t-3650 in 97 Cobra? or fix t-45
- porting the eaton?
- 99-01 Header Install
- 96 Cobra/Terminator Blower
- 3.4 whipple blowing open resovoir cap pressure??
- Wheel hop
- 04 Cobra bumper fascia seems loose
- CAM ADVICE!!!!!IDK
- Clutch Firewall Adapter
- 03-04 cobra seat covers
- engine knock!!!
- Might sell my 95 cobra for a 97 cobra..
- Custome license plate frame from RPI
- Fuel injectors
- stock rear gear ratio
- pinion bearing/crush sleve preload
- New Cobra pics...
- How long should it take??
- 96 cobra tranny swap
- pulley size?
- 03-04 Cobra Engine Block VIN tag location?
- Thinking of getting 1996 Cobra
- SVT noise chase
- Got the '04 Cobra today...
- Ticking problem by pulleys and fan.Please help!
- basic upgrades for an 03 cobra??
- Pulley's + Squeaking + Surpises (kinda long)
- HELP! Scary sound AND stalling problem
- HOLY CRAP..LISTEN TO THIS! (thought blown gasket)
- Will 99+ Cobra Exhaust manifolds fit a 97 Teksid block?
- 99 cobra cranks but won't start
- Best way to remove dealer decals?
- New SVT Section Moderator
- Picked up a '04 Cobra today....
- Alignment need when replacing front shocks?
- $$$$$$$$ to Burn on my 04 Cobra
- GT to Cobra...ish
- Anyone do their own headporting?
- Clutch replaced in 01 Cobra
- Which exhaust will give my 96 cobra the best gains?
- programming ?
- 96-98, 99-01, 03/04 ?which cobra
- 03 cobra compression test results
- First Dyno....was expecting more
- reverse lockout
- 97 SVT cobra and 97 4.6 MARK VIII 32 VALVE
- Terminator piston to wall clearance
- keep the irs or change to solid
- In need of some pistons
- 99 Cobra Hood Real or Fake?
- 1998 Cobra rearend thud/clunk??
- Flasher and Brake light fuse issues... Help!
- 99 Cobra T-45 tranny or Tremec?
- re-grind cams??
- Sct or Diablo tuner
- buddy's cobra running like ****..help
- 97 cobra bad engine noise???
- What up!!! New guy from Long Island
- Need a new clutch 04 cobra
- Most possible boost out of an eaton?
- Where is the plaque located on the engine?
- DOHC 4.6 Torque
- Chirping sound from 2001 Cobra
- e-brake cables - 99 Cobra
- 97 cobra sc losing oil pressure, help??
- Kenne Bell Supercharger Belt
- 04 Cobra Termi
- 2004 Cobra pricing?
- 13.26 @ 106?????
- Just bought an 03 Cobra......
- T-45 Exploded view
- ready to start my 01
- 99 COBRA TIMING CHAIN COVER
- 03 cobra serv. light on
- Wheel hop on my 2001 SVT Cobra
- Looking at a 99 Cobra, what to keep my eyes open for?
- Check Engine Light on 98 Cobra
- Difference between k-members and driveshafts
- 4.10 Speedometer adjustment?
- 1996 cobra with high RPM miss
- check out what i did last night
- header bolt question?
- '01 Cobra Rear Brake Upgrade???
- New to Cobras, few questions, please help!!!
- Finally blew it up...
- 1996 Cobra Exhaust Opinion
- 4.6 dohc
- 98 cobra, exhaust/headers for road course racing
- NEW DYNO NUMBERS!!!!!
- gonna be sending my cobra overseas
- Dyno Numbers
- radio
- radio
- Bumper question???????
- cobra swap :)
- 4v BBK LT owners - need a favor!
- '99 Cobra - Spoiler? No Spoiler?
- Mystichrome Cobra or not?
- !!!PLEASE HELP!!! no oil on the dipstick
- I found this for you guys. Have fun lol.
- 97 cobra supercharged loss of power need help
- New Terminator Owner
- BATTERY RELOCATION
- pics of valve cover swap...
- black chrome cobras on the sonic blue cobra
- Post Cat o2 Sensor resistor? Help please.
- 96-98 Cobra Engine Specs
- What year Cobra to buy?
- Grill for 2001 Cobra
- What gears for turbo 96-98 cobra
- First time at the track with the Cobra
- KB 50w synthetic oil
- 96-98 GT and Cobra help
- Termie Swap ?'s...
- 96 cobra gearing
- 3:73 or 4:10 gears
- Fitting 05-09 wheels on my 03
- pulley tentioner
- What should i get?
- New cams...
- Im 19 and thinking about getting an 03/04 Cobra..
- BAM! Let's try this again!
- questions on 97 cobra 8.8
- irs brace!
- original 01 bumper or 03-04 bumper
- gt500 & svt raptor
- help with bearings
- Pepe this hard top vert '95 Cobra
- Cobra got a little drop....
- mach 1 for cobra?
- Aluminum Fenders and other lightweight parts...
- New Dyno Numbers for Svt Section
- some 2v's guys?
- Widest tire that will fit on 2001 Cobra Stock Wheels
- looking for a clutch
- 2002 gt running on 6 cylinders..
- N/A with mods vs Vortech
- 97 SVT Cobra?
- 99 cobra oxygen sensor harness
- What do you consider beating a car?
- Brembo rotors
- Car wont start
- Intermittant RPM increase when shifting
- Which CAI?
- 98 cobra pops when idles and car dies when stopping/low rpms. HELP PLEASE!!!
- Spec Clutches
- Bore and stroke questions
- Help with injector size and mass air flow and fuel pump
- A/F ratio
- What do you all think?? need help...
- slugish 2nd and 3rd help
- 3-4 synchros ALREADY?!?!
- which control arms?
- Looking at cobras! What are these worth/good deal?
- lookin to get a cobra
- What plugs do you guys run?
- Which CAI for 04Cobra
- How to cover myself when buying 03/04 Cobra?
- Check out my new triple pump return style system.
- Compound Boost Setup
- Anyone looking for 96/98 Cam Covers
- Torque specs please
- IRS vs SRA
- Procharged cobra.. help??
- HELP plz!
- 97 Cobra engine rattle at mid RPM
- 2003 cobra gauge pod+gauges?
- Soon to be new owner!
- Recommend me a good 700HP clutch
- Began my search Cobra vs. Saleen
- Another New 03 owner
- Which would you rather have???
- Where did my power go
- what do you think its worth?? #2 of 2000 mystic cobra
- Deep Dish Cobra Replica Wheels
- metco 10mm auxiliary idler wont fit?
- Header Install
- New BLING
- Drive belt help
- 1996 mystic cobra for sale #758 out of 2000
- ABS LIGHT
- PA Looking
- Final Dyno Numbers!
- Heads / Tick problem ?
- MODDED 99 COBRA HELP
- Best way to make 100 Octane??
- question on cobra infamous engine tick
- thunk in the trunk
- converting cobra to automatic?
- cobra vs mach 1
- New Owner in VA!
- Some help with cel
- DOESNT MAKE SENSE PLEASE HELP!!!!!!!!
- I need fog light specs on 03 cobra please
- Clutch upgrade time...
- 03/04 cobra bumper on a 99 cobra?
- New to the 03/04 Cobra
- need help diagnosing this problem
- Accufab Single Blade TB vs. BBK Twin 65mm
