- Read End Identification Help.
- Which one should i buy?
- is this right?
- crackaling noise from engine?
- rabble rabble
- Turn signal problems
- ANOTHER 4.2 thread....
- M112 vs. Vortech
- 4.2 or 4.3 question
- Auto To Manual
- Questions & Confused.
- 2004 3.9L...Do 3.8L mods work???
- Engine Swap?
- What year 4.2L for my 2001 stang?
- Convertible Top Leak
- Writeup On Replacing Balljoint?
- Issue with a friend's car.
- Side Stripe Removal?
- HELP! Oil Slicked Road Damage
- getting a tuner
- xcal3
- Where to paint louvers?
- Help with a quick question
- SCT Xcal 2 question
- Want to make my 01 v6 mustang louder
- Swapping Fuel Injectors
- CAI PROBLEM!!
- Bad Luck on Christmas....
- What kind of exhaust set-up are some of you 4.2-4.3L guys runnin?
- Window Tint Removal Help
- gears..
- Keys... Again
- Tranny cooler
- Radio Trim Panel
- friction moditfier
- Ba i need New tires want opions
- V6 STUFF, GEARS, INTAKE
- How to prevent rust
- 18X10 Rim tire size
- Hay stack=dangerous
- Good Oil?
- NEED HELP!!!!
- V6 Banger. Literally banger, Having problems, and would like some advice.
- E-Brake Fail....help?
- New Computer-Car won't start
- Port and Polished heads
- First Mod Ever
- Exhaust question...
- My Exhaust
- wondering on how to fix my power of steering
- DPFE Sensor 2000 v6
- Why does my door look jacked up?
- driveshaft
- Transmission!
- MISSING A TUBE??
- Exhaust???
- Seafoam and Fuel Filter
- Help! Serious Knocking
- Loss of power at WOT
- V8 Engine Swap
- Question!!!!
- How much power/abuse will a 7.5" True Trac take???
- windstar intake
- real world hp increase...exhaust, udp, tuner
- venom module
- Windstar & Longtubes
- WTF?? Where are all the SN95 owners???
- taillight dents?
- Paint not matching after Body Shop fixed car
- guess my exhaust
- 232 badges
- CAI problem
- Need help with bride seat rails in an 04... anyone?!
- Should I put my Transgo kit in or not?
- Dome light blinks on and off while driving
- HELP!!!
- hood scoop or cowl hood
- suspension question
- CAI
- Help! I've got a few codes!
- cam?
- locks
- several performance questions...
- I smell coolant burning...
- Trans Question.
- Mods for christmas
- Bumper?
- power steering problem
- Filler Neck replacement in a 2000 Mustang, any advice
- Side scoop
- Cold Air Intake
- Anyone want to do v6 to v8 swap
- need an expert advise
- 65mm Throttle Body
- It only cost 40
- how do i a align a hood?
- Windshield Washer Pump Not working....
- drive shaft safty loop
- billet depot?
- Deer Season!!
- noise from under the hood
- what should i do
- K&N, C&L, or BBK?
- Couple of performace questions.
- Car got hit...
- v6 stock exhaust into dual exhaust
- Diablo predator tuner question
- 2004 3.8, are these aftermarket headers or not!?
- Shifting out of park without key
- FUC%
- P0156 code
- Squeking Crankshaft
- Where is the brake booster thing at?
- Stang Dieing
- Anyone want to m112?
- 94-98 exhaust on 2000?
- DiabloSport Predator in Colorado?
- re; help with my v6
- Rebuild Questions
- debating on exhaust...
- cowl hood
- shifter hard to move when cold
- help with my v6
- mini van to mustang engine swap?
- VAP Windstar intake
- shifter help
- mil eliminators
- MACH Window Speaker removal
- Cam specs?
- hydroboost brakes from gt/cobra fit v6?
- Would this spoiler look gay on my 2000 Mustang?
- How do I make my car run rich?
- strange rattle and funny idle?
- Turbocharger?
- Reverse Hood Scoop on 04
- Would like everyone's opinion..
- How bad does the m112 overheat???
- Supersix motorsports???
- cylinder misfire
- What muffler is best...
- question about rear bumper cover
- Need Pics of LT's & SFC's
- SCT problem
- Fog lights
- hey guys, new here just looking 4 some help
- EVERYONE READ THIS
- Red Foam on power steering cap help?
- Repair Question
- Help Needed Now!!!!!
- Vert top replacement question
- Straight pipes from cats..
- What bulbs?
- O2 Sensors?
- Where to buy ?
- center caps for 95 cobra r style rims
- 'REAL' Tuner gains
- 2nd gear grinds after rebuild
- Brand New 07 Mustang
- V8 Throttle body and Plenium
- tranny ?
- Painted Rims?
- Need Help!!
- Oil Pressure Gauge, reading NO PRESSURE at start up
- powerpack question
- How much HP from a 3.8L?
- HP/TQ
- Bolt On Exhaust
- Who can help me?
- 2000 v6 adding cold air intake without a tune. Is that good?
- Would this fit
- 2001 Convertible Window Sweep weatherstripping?
- Need Help
- Just quits running
- Hesitant Acceleration
- Got a ? about Texas Hot Rods/thr.com
- Drivetrain problems
- How do I advance the timing?
- legit?
- '99-'04 Mustang 5 Spoke Wheels
- 275's and turbo
- HID Foglights? help
- GT takeoff exhaust questions
- Aftermarket pop-up sunroof
- Chirping Belt
- Chirping Belt
- electrical issue
- help replacing pcv valve
- body
- New driveshaft=HP gain?
- Exhaust noise question
- what are hydroboost brakes?
- SLR Motorsport performance chip???(legit)???
- Tlock Install
- Billet Grille Set.
- K&N Filter + Silencer Remove?
- A little help plzzzz...
- Fuel Injectors V6 Mustang
- Spacer to fit with a BBK throttle body?
- final question before i buy
- PICS REQUESTED PLEASE!
- gt hood scoop installation
- CHEAP TIRES! stock wheels w/ michelin destiny tires.
- Where can I find Borla Exhaust?!?!?
- Diablo or SCT X3 programer?
- New Exhaust - Which is best?
- Difference Between GT TAKE OFF and Dual Exhaust System
- New Transmission?
- How do i remove the entire windshield wiper arm?
- ok to remove hoodliner?
- M90 boost leak
- new engine or rebuild?
- Nos install
- Muffler for my 3.8Liter V6
- Killed my baby
- V6 Rear end Gears. 3.73 or 4.10
- hood questions
- 275/40/17
- Targa top?
- 1983 Mustang GL?
- lalala
- Split port swap...Head ache or worth it?
- Best V6 performance upgrades?
- installing a sway bar on a 04 mustang
- Questions About Seafoaming!Help Pls!
- Air conditioner line replacement question
- car problems
- looking for an exhaust
- Engine swap:3.8-5.0
- 1999 Hood Latch Assy.
- 3.8 v6 turbo setup... (Fazm, lilroush, anyone else with an f/i setup...)
- UDP or VAP spacer?
- 3.8L in a Ranger?
- Snow tires
- Rear End and Front End Questions...
- do we still have a write up section?
- acouple of ? on v6 mods
- odometer gear replacement
- Leaking Dif./TruTrac Rebuild
- clock
- header help
- changing the heads and intakes!
- Strut tower brace
- 4.2l internals in a 3.8l
- Dual Halo's are Dim?
- engine swap
- Gear question
- Can I put the progressive blinkers on my car?
- 05+ stock exhaust system
- exhaust question
- My M90 swap- Need opinions
