View Full Version : 6 Cyl (V6) Applications
  1. What do I need??
  2. 300hp in a 2000ish mustang
  3. clutch
  4. 98 take off shorty headers.
  5. Is Seafoaming a good idea?
  6. Engine block...
  7. Help Wanted
  8. Wierd Exhaust
  9. Twin Turbo
  10. V6 brake ducts
  11. Governor
  12. Mach1 shocks and springs
  13. Mach1 shocks and springs
  14. LT's?
  15. intake mainfold replacement...
  16. Strange Problem
  17. SSM = ASS
  18. Parting out 96, 5spd.
  19. Performance chips?
  20. SSM Power Pack questions!
  21. transmission swap
  22. Clueless Chick Needs Help!!
  23. Rocker Panel Clips
  24. 95 auto tranny help
  25. O2 sensor MIL eliminators
  26. MAX OFFSET
  27. rear wheel bearing
  28. '97 Grill ( or lack thereof )
  29. 5.0 swap???
  30. car acciedent broken axel
  31. Got a M112 on order
  32. ECU modification
  33. Rear Seat Deletion Kit
  34. lowering my car
  35. My car vs.......PLEASE READ
  36. magnaflow 11225
  37. transmission
  38. Plug Wire Clips
  39. strange smell
  40. S/C question!
  41. speedometer removal
  42. Time for a new exhaust
  43. car heating up??
  44. Ignition
  45. Whistling noise when clutch is engaged?
  46. Short Shifter
  47. car wont start after sitting
  48. boost gauge
  49. windstar intake swap
  50. honeycomb trim panel
  51. CAI?
  52. Port and Polish worth it?
  53. Refilling manuel trans fluid tips
  54. whats it worth
  55. Differential oil?
  56. turbo or supercharger?
  57. OVER DRIVE ON OR OFF??
  58. I need to paint my car but I can only use spray paint
  59. NEW SHOES!!!
  60. Question about the Y-pipe setup on the V6
  61. Help just purchased a 2000 Mustang, Hood will not close!
  62. broke bolt worse spot
  63. Turn Signals
  64. Transmission bobber thingy
  65. Water Pumps..
  66. 39lb injectors
  67. V6 to V8 engine swap?????
  68. Transmission Issue?
  69. Time for a new Clutch?
  70. would these fit????
  71. Allow myself to introduce...uh...myself.
  72. 98 v6 bellhousing removal in car?
  73. rear brake problem 1999 v6
  74. Track Night
  75. car stuttering at 2,000+ rpms
  76. v6 to v8
  77. trans or engine? help please!!
  78. rebuild or replace brake master cylinder?
  79. upper/lower control arms
  80. DEEPEST SOUND
  81. after tlok and gears, good next mod? opinions?
  82. dropping my rear end
  83. SLP or Flowmaster
  84. RedStarBelgrade asked so i did.
  85. How To Prep And Paint Interior Pieces
  86. is this is a sign of a bad transmission?
  87. any mustang slavage near anahiem california?
  88. would springs for a v8 gt, work on a v6?!
  89. new shifter
  90. winshield wiper refils
  91. For those who did 4.2 CRANK swap!
  92. saleen body kit
  93. line lock
  94. Procharged Gt
  95. Exhaust or rims first?
  96. 200000 miles
  97. Seafoam
  98. Need Help
  99. how much should i sell these for, need an answer QUICK
  100. Magnaflow Dual Exhaust???? help plz
  101. hood insulator
  102. What's better?
  103. V10 Mustang pic (not what you think)
  104. Fly wheel
  105. Running a Straight pipe for a 2000 Mustang v6
  106. What do you think???
  107. How to Prep Paint Interior Pieces
  108. New Tires
  109. Stang won't start 1994 V6
  110. seats???
  111. Anybody have the flaming river power steering rack
  112. 3.73 gears
  113. tuner
  114. Bullitt Wheels
  115. what is this grille?
  116. Tail pipe / Muffler / Catalytic Converter Problem
  117. hood pins on GT-S III
  118. Cylinder 2 misfire
  119. 84 rustang eec relay location
  120. steering rack
  121. Leaking brake fluid, help please.
  122. Adjustable Clutch Cable - Help
  123. frustrated
  124. quick TOB ?
  125. DiabloSport Tuner
  126. Painting side nonfunctional air vents
  127. SN95 Headlight Aiming
  128. Cobra side skirts
  129. Console suggestions?
  130. Need peoples opinions...
  131. Eaton M90 on 98 3.8L Question
  132. can i put a k&n air filter on americanmuscle am cai?
  133. Suspension Setup
  134. V12 Jag' swap
  135. split port install
  136. Exhaust
  137. Will this hurt anything?
  138. windstar split port intake
  139. engine light
  140. Timing Chain or Timing Belt
  141. i need a rear swaybar
  142. what does this do?
  143. next mods opinion
  144. SVTOA car show yesterday and trunk question
  145. 1999 Body Parts diagram explosion needed
  146. headlights
  147. Does your steering wheel click while you turn with the signal on?
  148. side badges
  149. Exhaust Clip
  150. 83 GLX 3.8L
  151. Just wondering something?
  152. 3.8 or 4.2
  153. Need Pictures
  154. front bumper ???
  155. Quick question from a classics guy.
  156. Need help
  157. Car studdering on acceleration
  158. opinions
  159. need to see
  160. Lowering
  161. electric odometer
  162. RPM's too high?
  163. PATS Key
  164. Am I being jerked around on a T-Lok install quote?
  165. transmission issues
  166. performance rear lower control arms 99-04?
  167. Mods
  168. will the supercharger work?
  169. Richmond Gears ?
  170. automatic tranny ?s
  171. CAI installation help!
  172. couple appearence opinions/questions
  173. Shifter Install
  174. 2006 Mustang
  175. 1996 Head Gasket ??
  176. Rear Shocks
  177. i want more hp for my mustang v6 2001?
  178. Newbie! Mustang vs V8 Chevy ?L Truck
  179. are the springs the same?
  180. spring help
  181. Needin a quick how to
  182. 1996 3.8 oil gauge
  183. THE DINGING!
  184. Remote Starter
  185. brake problem
  186. Low-Beam Headlight delays when comming on???
  187. Engine issue
  188. 2000 Mustang VS. 2001 Mustang
  189. Seafoam?
  190. Just a quicky...Please
  191. Cracking noise when braking or turning
  192. Exhaust Price Question
  193. Cleaning MAF?
  194. Gauge lights?
  195. ABS light on
  196. Noob to 3.8L question
  197. i need some opinions
  198. Might be too extreme Mod.
  199. Exhaust question
  200. brake light
  201. 70mm is back.
  202. 1996 Mustang Questions??
  203. What should come First...
  204. hey i have a 2001 mustang v6 ?
  205. H pipe on v6 Mustang
  206. Where's my horn??
  207. changing my exhaust set up
  208. my brakes
  209. input on future mods
  210. crazy (maybe stupid) pulley question
  211. Help !! Rough Idle
  212. what tuner?
  213. Oiling problem with 3.8L
  214. PCV VALVE CLOGGER
  215. Which first
  216. Fluid Leak Issue
  217. what mod should i get?
  218. Will these work on my V6
  219. Stock Rotor Size on a 2000 V6 Conv
  220. next mod (opinions)
  221. Hood scoop
  222. Seat conversion hepl ASAP!!!!
  223. Door panel questions
  224. Common Q's. Need A's
  225. Finding Vacum Leaks
  226. High Oil pressure
  227. cowl hood
  228. MPG GT and V6
  229. Problems with a 2000 V6 Convertible, help please
  230. new clutch slipping
  231. Bad Torque Converter - Good Replacements???
  232. 4.2L help
  233. Neutral???
  234. Interchangeable 7.5 Question
  235. 4.2 vs SSM Power Pack?!
  236. mac vs pacesetter long tubes
  237. wwhat will dyno tuning do for my car?
  238. starting problems
  239. True Duals with glasspacks and Cat ?
  240. replace suspension parts for 20x10's
  241. V6 mustang vs. Mazda6
  242. 1.5-2k rpms at idle
  243. caster camber plates
  244. Good Price? Is this a Good Deal????
  245. First timer needs help
  246. need help with engine
  247. BEST EXHAUST SIZE?
  248. Look Off The Stang
  249. Clutch Prob?
  250. HELP!!! 96 ford mustang v6 problems
