View Full Version : 6 Cyl (V6) Applications
  1. cone clutch posi
  2. Cam help
  3. timing and fuel
  4. Help
  5. Please help me
  6. any flowmanster 40's?
  7. Throttle Body Upgrade
  8. where can i find
  9. BIG BIG PROBLEM
  10. Anyone purchase the Airaid intake system?
  11. Power Problem.
  12. Where to get a new reman. engine?
  13. Japanese Power
  14. 98 v6 auto transmission cooler?
  15. Quick question - 4.0L Cast Iron Block
  16. 2.25' or 2.5'???
  17. f-150 swap???
  18. What would you do?
  19. port and polish???
  20. Which would be better
  21. Buying mustang, questions on it
  22. question on fuel management and timing
  23. po340 code and plug wires
  24. LOOKIN TO BUY ANOTHER!!
  25. help
  26. exhuast question!!!
  27. does this make sense?
  28. Wanna make a M112 adaptor
  29. 5mph accident
  30. caster and camber kits
  31. looking to start adding to my stang
  32. about using SEAFOAM
  33. Inertia Fuel Pump Switch
  34. slp catted h pipe from a GT onto a v6?
  35. Drivable FAST V6
  36. HID's
  37. Roush Side Exhaust
  38. whats the best exterior???
  39. power adders?
  40. Painting interior
  41. just crunching the numbers...
  42. will i need it tuned?
  43. Not sure what to say. Exhaust related
  44. Intercoolers
  45. Got my rims w/pics.
  46. replacing rotors RAN INTO PROBLEM...... SH!T
  47. Side exhaust
  48. just bought a Stang, How do find out if my gears have been changed?
  49. Gains?
  50. caliper decals
  51. Coil Spring Tech Info
  52. tree sap on body
  53. passenger side door handel.
  54. taking off the exhaust?
  55. Tuner Question
  56. more power
  57. unlocking tuner
  58. 84-87 Engine Compatibility with 1994 v6
  59. Where to buy flow 40's?
  60. 94 gt coupe springs fit?
  61. How will this exhaust Setup Sound
  62. Cold Air Intake
  63. lowering my car
  64. ne1 have a strut tower bar or rear spoiler for sale?
  65. what would you do with them?
  66. DiabloSport Predator or SCT XCalibrator 3???
  67. diablosport tuner???
  68. Procharger
  69. High Idle -> Vacuum Leak?
  70. Power steering problem on 2000 stang
  71. '98 Wont Start
  72. cars squealin
  73. The problems continue...
  74. V6 bumper covers?
  75. check engine light
  76. over heating
  77. DTC problems and running very lean, need a little help
  78. seafoam stoped misfiring?
  79. Power Locks question
  80. American Muscle Promo Code
  81. Newbie Stang owner - Fighting High Idle (how can i test MAF?
  82. Brakes are sqeeking
  83. aftermarket mirror question
  84. Changing the spark plugs
  85. mount point park
  86. Found a M90, tell me what you think
  87. Mustang Seems to Run Unusually
  88. lean out of 02
  89. Force Pro Size?
  90. bleeding the rad? Helpp!
  91. Chip or tuner?
  92. X-charger or GT
  93. how would it be
  94. Hood scoop
  95. dumped exhaust
  96. Long Tubes
  97. stock numbers
  98. SLP Powerflows
  99. exhaust
  100. x pipe?
  101. dual exhaust
  102. Suspension question
  103. will my aode work with a sc motor
  104. what does a 94 mustang weigh
  105. Side Scoops
  106. Where to get convertible top???
  107. MAF
  108. air silencer location
  109. manual trans swap
  110. TPS P0122 low voltage
  111. 4.2 Crank
  112. 94 headers on 01
  113. headlights
  114. Wheels
  115. how do you clean headers?
  116. I'm a idiot!
  117. Maintenece on a 3.8L V6 1998 Stang
  118. h or x pipe
  119. My new mods!!!
  120. pulleys
  121. Eaton M90
  122. MUFFLER **UPDATE**
  123. 3.8 Modifications step By Step
  124. Exhaust?
  125. supercooler
  126. V6 exhaust
  127. V6 SHAKER SYSTEM
  128. V6 gone.. 351W in!
  129. Painting question!
  130. Need Help On Catalytic Converter!
  131. my build up 5-7 exhaust clip!
  132. "SRS"
  133. 02 lowering kit
  134. Best sounding exhaust? yes...yes it is
  135. New Subscriber
  136. hood scoop with stripes?
  137. car having issues with power and running in general.
  138. GEARS...AGAIN??
  139. ANOTHER STARTING PROBLEM??
  140. hood scoop
  141. New England Mustang Meet tonight. (MA area)
  142. 5 speed
  143. Fuel Filter location and Install
  144. Engine upgrades need help!!!
  145. Shift kit help, i need somebody, help!
  146. P&P heads...any gains with stock components?
  147. Spark Plug Suggestions
  148. dual exhaust
  149. Starting Problem Help
  150. Well..I've made some upgrades to the stang..
  151. i need help with exhaust upgrades
  152. CCRM question...
  153. Stripe suggestions
  154. STRANGE PROBLEM?????
  155. 3rd brake light decal install?
  156. Cracked Manifold HP Loss?
  157. Final step in 95 restore
  158. what wrong with my car???
  159. 96 Mustang Problem Question
  160. 3.8L Modifications
  161. spark plugs
  162. grill bolts
  163. Suggestions for upgrades??
  164. Power steering question
  165. running rough, help
  166. Selling my Dual Exhaust Setup $200 obo
  167. Subframe Connectors
  168. how much will all this cost me?
  169. CaM???????/
  170. M90 in a 94
  171. Traction Control????
  172. best exterior , best interior??
  173. Miles per Tank
  174. Replacing Exhaust Rnd 2
  175. anyone know???
  176. Starter Solenoid Location
  177. HELP! i think i have a cracked header? or something
  178. LT headers
  179. ANOTHER ENGINE?????//
  180. Track and Dyno
  181. Custom Supercharger?
  182. f'in scratch
  183. HELP!!!
  184. MOVED: Owned by civic and integra
  185. Starter, Alternator or something else?
  186. Just bought a 95 Mustang! Audio System Help!
  187. true po boy exhaust
  188. supercharger......
  189. ENGINE QUESTION?????
  190. 3rd Brake Light
  191. Engine Ticking
  192. 8.8 rearend
  193. stock 98 rear end to 3.73 posi, help!!
  194. Mach vs. bullit suspension
  195. header gaskets???
  196. 96 3.8 problem, cylinder misfire, rich/lean codes
  197. Intermittent Starting Problems
  198. REAR END
  199. a question
  200. any one have pacesetter lts?
  201. 3.8 to 4.2 block
  202. What Transmission do i have?
  203. gauge pods?
  204. Instrument Cluster lamps
  205. Weird Idle poblem
  206. aim screennames?
  207. does anybody know if a 94 mustang v6 computer would accept a supercoupe supercharger
  208. 3.8 LTR hesitation and lack of power
  209. brakes
  210. Another gears question??
  211. CAM???
  212. 02 senors w/ mac LT headers
  213. 99-04 brake line question
  214. CEL P0340
  215. Rought Idle (can't find issue)
  216. Gear ratios for highway driving?
  217. Opinions
  218. do i need anything else???
  219. Rear wing help?
  220. cheap and easy hp
  221. Nitrous Suggestions
  222. P1633 Code...how to fix???
  223. is a supercoupe 3.8 the same as a mustang 3.8
  224. nitrous systems
  225. Louder.
  226. valve cover
  227. Gears Question???????
  228. Dual or single exhaust
  229. Gears?
  230. Will 5w-30 hurt?
  231. Help detailing motor
  232. does anybody know where i could get a stroker kit for my 3.8
  233. sway bar question
  234. is the wiring harness from an SC the same as a mustang
  235. rim width
  236. Super coupe in a foxbody?
  237. mustang v6 engine swap
  238. 2000 mustang audio system
  239. AM discount code please PM..
  240. Does a Supercoupe 3.8 fit in a 94 mustang
  241. ? for those knowledgable about porting
  242. Jegs offroad X-pipe=junk
  243. Improving for the track
  244. ANYONE???
  245. BBK intake Helppppp
  246. stall converter????
  247. DOES ANYONE KNOW???
  248. Wanting to replace exhaust
  249. where did the headlight how-to thread go? (wet sanding)
  250. decklid blackout write up?
