View Full Version : 6 Cyl (V6) Applications
  1. new shifter
  2. stuttering??
  3. Lifters
  4. drive shaft problem
  5. Price??
  6. K&N filter question
  7. How to Replace Alternator?
  8. insurance after modding??
  9. gathering ideas
  10. sugg + questions for my 04 v6 AUTO,coup
  11. Guys please help
  12. performance parts for sale
  13. Step By Step Guide for Replacing Lower Thermostat Housing
  14. how well
  15. Cost estimate
  16. "Strange" shocks/struts
  17. 8.8 rear end install
  18. 2004 mustang v6,mach stereo system diagram?
  19. Pistol grip shifter
  20. Tuner
  21. MAF Sensor
  22. Which hood do you guys think would look best...
  23. 98 Mustang Problem
  24. How Much Should an 8.8" Rearend Swap Cost????
  25. 2000 V6 mustang Fog light HELP?
  26. Bad Squeel
  27. MSD super conductor 8.5mm Wireset problems
  28. Camshaft selection
  29. please help
  30. Used P600 Procharger worth $1300?
  31. How much is an 04 T5 trans worth?
  32. engine light on agian help!!
  33. buzzing at 90mph
  34. couple ?'s
  35. Possible computer problem
  36. directional tires
  37. Tuner Chip
  38. Well Just got the Email...
  39. Oxygen Sensor & Exhaust Question
  40. v6 Gas hog?
  41. Tuning chip
  42. high idle/hard shifting
  43. Give Me ALL Opinions and Suggestions
  44. Website for older V6 Engines
  45. I need some ideas for exterior!!
  46. Overheating...
  47. help finding parts
  48. Which will give more hp
  49. Anyone know what got fried ??
  50. to anyone who has taken out their axles/problem
  51. clutch cable help
  52. TICK TICK TICK TICK.......in engine
  53. next mod
  54. HID
  55. help fast car trouble
  56. question about rims
  57. SCT Tuner (i have no idea what to do with one)
  58. wtf fuse?
  59. Beefing up the rear end suggestionsssss
  60. Just bought my daughter a 2002 with V-6
  61. Rear Brake Problems
  62. P1SC blower leaking oil.
  63. Just got my 99 V6 and have about $600 for mods?
  64. Pick Your Radar Detectors
  65. 99 ford mustang
  66. Help with my clutch.
  67. how can you tell if you have a 3.8 or 3.9l v6
  68. Billet Shift - Small gap?
  69. Need HELP w/ Carb 65 Mustang 200
  70. speedo doesnt work, replacing cluster?
  71. rims, need new center caps
  72. Motor Oils..
  73. tuner question
  74. Mustang A.D.D.- Apperance sugestions
  75. h/c/i project completed!
  76. Is it worth buying a Tuner?
  77. Intake Silencer
  78. Odometer
  79. best place to get under drive pulleys?
  80. 2003 fog light ihinstallation
  81. Repairs Question for a '99 3.8L
  82. Bassani muffler split wtf?
  83. Chip/Tuner question
  84. shift selenoid
  85. changing at stock trans with a v8 trans?
  86. 2002 V6 to Chevy small block?
  87. 3.90 Gears
  88. Chrome lip peeling
  89. Transmission Flush
  90. noise coming from motor
  91. What is the best ebay cai to get?
  92. Question on Tuner as well as 3.73 vs 4.10
  93. Car wants to die when AC is turned on
  94. should i spray my 01 3.8l with a 75 shot..??
  95. new parts
  96. squeaking noise coming from car
  97. Is my sh*t f*cked
  98. Rear end problems
  99. ANNOYING problem
  100. Im thinkin about buying a 2003 mustang and adding in these upgrades are they useless?
  101. First timer need advice
  102. what is a safe rev limit on the 3.8
  103. Wont go into gear....
  104. Need new rear package tray!
  105. Are Cats necessary?
  106. Hurst Shifter Problems
  107. Question About Headers...
  108. Replacing struts?
  109. Stereo problem
  110. broke rear end
  111. WHAT COULD BE CAUSING THIS...???
  112. Nitrous ?'s
  113. engine problems, need help
  114. few minor problems
  115. Help Please...
  116. Spark plugs... Sorry guys :s
  117. Best car cover?
  118. P1443
  119. Wheel Tire Options?
  120. Need Help ... ! Switch
  121. Does rattling inside a cat converter mean its bad?
  122. Pop goes the airbag
  123. 99 Runs Like Crap After Engine Swap
  124. Buy an 04' GT or an 01' V6?
  125. Dry Steering Noise
  126. Need Opinions on Mustang Trade
  127. Help With Exhaust...
  128. help installing rear sway bar
  129. noob driver question
  130. P0455 - Ford's Smoke Test
  131. Exhaust help! Lots of Questions!
  132. cam/exhaust suggestions?
  133. interior upgrade advise
  134. Longtube headers
  135. V-6 Mods
  136. Ball joint questions...
  137. Catalytic converters and exaust 2001
  138. HELP!! Car over heated twice need solution
  139. What fluid goes in a 2001 v6 mustang manual transmission?
  140. Tall guy in a manual seat
  141. I got the squeeks, Bad
  142. (question) How to make an engine last
  143. FRPP T-Lok with NEW 4.10's and Bearing kit
  144. Heater Hoses
  145. Converting a V6 to a full cobra?!
  146. cigarette lighter connection
  147. hesitation and bucking when driving
  148. Differentials
  149. New Brake Pads Screeching
  150. Need a Windshield Wiper Speed Governor
  151. what valve spring and retainer are these?
  152. PLEEEAASSSE HELP .... ! ! ! !!
  153. Head Bolts?!
  154. My 95 mustang runs too hot?
  155. @@@PLEASE HELP@@@ hood cable broke
  156. 94-98 and 99-04 piping difference?
  157. Can a V6 compete with a GT?
  158. Oil dipstick assembly 1996 v6
  159. help! fuel level sensor?
  160. wants to do a tune up, what do i need?
  161. question about the 8.8
  162. PATS & gauge cluster question.
  163. Sensatrak struts
  164. Transmission Ratio
  165. Overheating
  166. problems with startup/takeoff
  167. first mods for my v6
  168. 3.90's for the 7.5" rear end?
  169. THIS IS URGENT GUYS PLEASE HELP
  170. Chip can add 90hp!!!!
  171. head gasket change need serious help
  172. HP/TQ Estimate
  173. What's the stock Pinoin Angle????
  174. Car is acting sluggish? Not sure why
  175. My first jeep build and Wanting to do a second one a lil different needing input
  176. Compatible Engine Blocks
  177. Lowering stang
  178. Just went through Ford's diagnostic test
  179. X or H
  180. Couple wear and tear Concerns
  181. v6 shaker application???
  182. Changed Wire and Distributor Cap..Won't Start
  183. Building up my 97 stang
  184. Overheating
  185. Underdrive pulleys
  186. swap trans.
  187. Going to lower the stang
  188. 2001 fuel line bend/kinks
  189. Is there a T5 write up???
  190. need air compressor help
  191. not happy with window tint, anyone else??
  192. misfire?
  193. Exhaust on the way.
  194. Newbie with a Query (BBK or Acufab TB)
  195. P0401 Exhaust Gas Recirculation Flow Insufficient Detected
  196. Am I missing anything?
  197. window goin bad?
  198. 2000 mustang gas ping or breather tube?
  199. hesitation
  200. high pitch squeal
  201. repairable wheels
  202. break light when accelerating
  203. Which Brakes?
  204. V8 Conversion
  205. starting missfire
  206. squeak
  207. Radiator Leak
  208. HID help
  209. A/C Problems with SES Light
  210. coolant loss in a '96 pony
  211. Air "Cabin" Filter
  212. I Need Dual Exhaust Advice
  213. thinking of udp and driveshaft
  214. Why is car quicker when cold?
  215. change heater core
  216. Best axleback exhaust for a value?
  217. 2004 mustang v6. cant shift to drive
  218. 2004 mustang vl, fuse diagram
  219. Am I forgetting any performance mods???
  220. How to change auto tranny fluid?
  221. anyone have some fr. bumper cover brackets?
  222. When do I upshift on Manual transmission?
  223. Rusty rear axle
  224. 1998 Mustang hood
  225. 2004 mustang, v6, car wont start, loud honk goes off
  226. Thinking of running turn downs...
  227. M-90
  228. Cats on or Off?
  229. 2001 dash issues
  230. "Squeaky Rack"
  231. need turbo
  232. v6 Foglight Install Help
  233. Strange missfire
  234. dual exhaust ?
  235. Rim questions...
  236. 3.8 Losing Power
  237. Cooling Fan Shudder
  238. Help changing stereo
  239. hangers
  240. need a stock CAI (99-04)
  241. Since I dont have a V8...
  242. Hello everyone -- new member here
  243. Gauge Cluster Problem
  244. Emissions test?
  245. Engine Differences and Questions
  246. Top Speed Question
  247. Whats this worth? 98 mustang
  248. 7.5 Torque Arm??
  249. Stock V6 1/4 time
  250. Headgasket leaking......
