View Full Version : 6 Cyl (V6) Applications
  1. Where to get??
  2. Xhaust Finally!
  3. CRAZY ENGINE SWAP IDEA?!?!?!
  4. 5.0 in a 96
  5. rim sizes need input
  6. Sanding
  7. How 2 Launch in a Race And Short Throw Shifters
  8. I cannot believe it
  9. Ole' Yeller
  10. cobra look for the exhaust
  11. HEADER GASKETS
  12. Mods Needed to Beat a '93 5.0
  13. subwoofers in a convertible??
  14. Replacing Shocks/Struts
  15. 4.2
  16. What can I do now?
  17. whats the difference?
  18. Dual Flowmaster Exhaust and H-pipe???
  19. single 2 dual exhaust
  20. 05 V6 auto, worth modding? or should I just upgrade
  21. tuning chips
  22. odd noise
  23. wiring diagrams
  24. I need some opinions
  25. new some info????
  26. i can hear a clickin noise on my stang
  27. exhaust help?
  28. Duals for the V6
  29. will this exhaust setup work?
  30. tires
  31. Warranty Claim
  32. idk whats wrong wit my car...
  33. windstar update **egr lowered w/ pics pg 4**
  34. MOVED: Local Mustang Club Video, check it out guys!
  35. headers on the six, details inside
  36. I'm missing a few cats...
  37. 97 Mustang Exhaust V6
  38. Ghetto Cats
  39. axle problem!
  40. Supercharger
  41. V6 tune-up: what to get?
  42. P1131 Lack of Upstream Heated Oxygen Sensor Switch
  43. Stalling in neutral...pLz help< its Wierd
  44. dumps?
  45. cruise control
  46. TransGo is in!
  47. Swaping a v6?
  48. n/a horses
  49. subframe connectors
  50. v6 questions...
  51. nankang ns-2 tires?
  52. Summer Plans
  53. 3" dual exhaust or 2.5" dual exhaust
  54. In light of my new found project idea
  55. If the headers are cracked... plus another question
  56. One touch down on power window
  57. Turbo
  58. Bad tire Rubbing
  59. Diablo Tune
  60. is there an actual swappable "chip" available
  61. how do i remove blind rivets holding stock grille?
  62. exhaust help
  63. quick question
  64. Window stuck down...
  65. is it the timing?
  66. possible transmission problems? need help!
  67. do they make this for our car
  68. alternator
  69. 1994 3.8 Brake Rotor Minimum Thickness and Brake Planet
  70. Photoshop Request
  71. misfire help!
  72. Phantom Saleen
  73. spark plug wires and HP?
  74. Car dynoed today
  75. pulley question
  76. TPMS Straps
  77. AC Vent Rattling Problem...How to Take off Vent...
  78. somebody help me out
  79. Screeching noise
  80. cheap performance parts inside!!!!
  81. Small dealer, big problems
  82. I smell gas.....
  83. HELP! - Major misfiring
  84. is this a good deal?
  85. Body kits
  86. Mod question...
  87. Ok . . I'm an idiot
  88. beware of ASP (RANT)
  89. White Bullits
  90. Long Tube headers
  91. IAC GASKET HELP!!!!
  92. IAC mod
  93. Just bought new rims! Help with tires?
  94. Seatbelts
  95. exhaust
  96. YAY THERE HERE
  97. headers problem
  98. 3rd gear
  99. Problem w/ AC Heater Fan Switch...
  100. 3.8L performance?
  101. good free flowing cats
  102. Snag this Cobra?
  103. Non True Dual Exhaust
  104. ticking sound????
  105. Dallas mustang Udp?
  106. erratic idle plz help
  107. ford racing springs are they???
  108. Getting a tune
  109. O2 sensors
  110. Bolt on the exhuast, or weld it on? what should i do
  111. Rattling and Squealing!!
  112. A/C
  113. Tensioner Going Bad??
  114. mac cai help!!!!!!!!!!!!!!!!
  115. WOW
  116. Shift-Kit just arrived.
  117. well i got the SCT and need help tuning
  118. Headers
  119. odometer
  120. New heads after split swap?
  121. MOVED: sirrus in the trunk
  122. clip that hold buckle up on seat belt
  123. called the shop today....
  124. Headers. Longs Or Shorts? W or W/O Air Injection
  125. will this fit a 98?
  126. clutch... again
  127. Would this be stupid . . . or even possible??
  128. Dynomax Mufflers Comments Please
  129. exhaust question
  130. Need a little help
  131. replacing brake pads
  132. stupid ses light
  133. Anyone have a problem?
  134. Intake/Throttle Body questions
  135. so do you think i got screwed
  136. confused on what to do next, advice wanted
  137. Weight Saving!
  138. MOVED: QUESTION?
  139. Should I lower....
  140. window mod?
  141. A chance to buy 4.10's & Locker
  142. exhaust?
  143. A question about 4.10 Gears
  144. is there any way to adjust stock shifter to point straight up?
  145. F150 4.2L
  146. UPR Eibach Springs
  147. would that be ok?
  148. new toys installed
  149. How To: get 05+ wheels on your 94-04
  150. How do these seem....?
  151. Air silencer quick question
  152. Loud A/C
  153. MOVED: The mach 460
  154. engine swap thread?
  155. NEED HELP WITH PICKING A SWAYBAR
  156. did this work?
  157. Where does the extra 40 horsepower come from?
  158. supercharge???
  159. MOVED: Sirius Radio
  160. MOVED: Aftermarket Sirius install on Mach 460
  161. hello. newbie question v8 into v6?
  162. engine code P0411
  163. Transmission jerk from park
  164. radiator fluid
  165. V6 Official Time Slip Thread
  166. Screamin' Demon Coil
  167. HELP JUAN fast!!
  168. Changing the shifter on an auto
  169. Intake manifold spacer
  170. front control arms
  171. stock scoop grille
  172. How reliable are the 99-04 sixers?
  173. 4.6 engine, how much would you pay?
  174. Upsizing rims on my 2003 Pony
  175. Stupid Battery Light
  176. i am sooo cheap
  177. Modding Potential
  178. Semi-Manual Transmission Conversion
  179. need some help.....
  180. acceleration
  181. problem in first...
  182. dash lights, running lights dont work
  183. What shop manual is best overall?
  184. Need Some Help PLEASE
  185. fuel pressure
  186. damn engine code too lean
  187. Lookie what I found!
  188. will an aluminum driveshaft be worth it?
  189. Ok Finally. But damnit
  190. low end torque
  191. Dual MAC FlowPaths! (clip)
  192. one last clear up...
  193. Q's on Building a 4.2?
  194. What do you think of these things?
  195. !Hey guys, I urgently need help with my Fuel Pump.
  196. engine code?
  197. supercharger!
  198. MOVED: early 90's f-250?
  199. p&p
  200. MOVED: 98 V6 vs Miata
  201. just picked up my heads
  202. MOVED: Anouther vs race ?
  203. lowering questions???
  204. Need Help with Instrument Cluster prob
  205. help on launching
  206. exhaust help?
  207. Blown head gaskets?
  208. Exhaust Tip size
  209. My stock v6 sound system..
  210. CAI Whistle cured
  211. Breaks Don't work too well
  212. ne check engine light
  213. where can i find this
  214. Wheel TILTING out
  215. These rims??
  216. how many bennies? $$$
  217. It must be a sixer thing
  218. Stock 15s - 17 conversion,
  219. small race story
  220. Custom Exhaust
  221. dude seriously help im pissed
  222. Which exhaust for a 2007 Mustang V6?
  223. what do you guys think about this deal?
  224. bushings
  225. steering pump
  226. speedo gear install
  227. V8 drop questions
  228. 3.8 supercharger question....
  229. anyone know the size for the crank pulley.....
  230. Foglights
  231. water in air filter box
  232. new to stangs
  233. little help?!?!?
  234. Short throw/Short shift Shifters
  235. MOVED: Retarded Race?
  236. 05-07 wheels on a 99?
  237. o2 extenders
  238. Jacking points
  239. Driveshaft or Pulleys
  240. More top end power?
  241. 98' cobra 160mph gauges in my 98' v6?
  242. Changing Clutch Engagement Point
  243. Body Kit
  244. 3rd brake light
  245. Fuel filter removal tool?
  246. Exhaust tips
  247. new exhaust
  248. scoop
  249. Engine swap to v8
  250. Project Car
