- MOVED: Stuck and need some help from my V6 buds
- MOVED: Roush performance
- Direct replacement for plugs and wires
- What gives the 01-04 models 3hp over 99-00?
- IAC Restrictor Gasket Trick Guide
- MOVED: Sorry guys, but this is my Favorite car... She always has been :)
- underdrive pulley question
- aftermarket gauges
- Underdrive pully question: 24 or 42%?
- Roush Springs F/S
- gasket matching upper and lower intake
- drilled holes for hood scoop
- Am I getting screwed???
- can someone run a carfax for me
- Guage Install, HELP
- thinking about buying this GT what do you guys think?
- Need a quick answer!
- Sticker number
- ?Windstar CAI?
- Reverse Glow Guages
- Filler Neck Seal replacement
- !!!!!!!! Exhaust for my 3.9l !!!!!!!
- 66 mustang
- Stock RWHP
- Cig Lighter broken..
- dang
- underdrive pully
- underdrive pulley
- Clutch
- Stock 99 Mustang, What to do with it? help
- helppppp
- Do you think a K&N Air Filter increases MPG?
- One head down One head to go!!! w00t -Take some guesses on fully ported hp gains.
- A few questions
- MOVED: My first..... death
- GT tuner on V6?
- cold air intake problem
- lowering
- pics of my new tinted tail lights
- Exhaust
- Rattles!!!!
- need help asap, car is still jacked up
- Grinding Rattline Noise From Transmission 5spd
- anyone wanna buy a eaton for their v6
- bbk headers not a good idea!!!
- a five.o guy needing help
- What pipe setup? (exhaust)
- Help With Fuel Problem Guys
- magnaflow 16605
- Saleen 1 piece spoiler
- suspension
- MOVED: what an embarrassing night
- changing gear shifter
- anouther x-pipe Q
- MOVED: who here hates running low on money?
- MOVED: DONT BUY GAS THIS TUESDAY 15th GAS BOYCOTT!!!
- hood scoop question...
- EGR WTF?
- Gas mileage is INSANE!
- Installing a super charged thunderbird motor in a 97 mustang
- MOVED: american muscle rip off
- C/B springs and H&R springs
- Fenderwell CAI
- the infamous rattle
- MOVED: Who has.....
- Im a dumb*ss
- A Few pics of my car after a good Bath
- damn i think i might get a GT...
- painting hood scoop with cans
- Exhaust Muffler Question
- need new tires, whats max size?
- Steering Knuckle
- Dyno Database
- Supercharger Question??? Please help
- Eibach Prokit
- "Wild Cam" quesions
- AC problems I need a guru...
- Roller Lifters -What other engines interchange? 302? 351W?
- Axle cover search...
- MOVED: 1st mustang grill emblem
- Anyone ever seen this before?
- exhuast bumper cutouts
- filler neck sealant
- will this sct tuner work?
- 1st car show down
- Roller Rockers?
- Little Help
- exhaust tip
- 97 rear thump noise
- Power steering pump for my Mustang
- Spark plug wire set
- racin a mercury
- Redv6pony's track results inside!!!!!!!!!!!!
- Update: 96' Engine swap and new 00 engine topless!
- Pictures Inside: Intake Height: 94-98 3.8L / 99-04 3.8L / 97-00 4.2L intake
- got a couple questions racing an 86' v6 camaro tommorow
- Need New Pistons/Rods
- Need suspension help
- split port fox?
- engine swap
- Conversion help!!
- No Spark
- 05 16' on a 95??
- code error 0300 0303 0304 0316
- New pics of the stang
- Stock front bumper
- roush subframe connectors
- Intake Manifold spacer??
- Drive then Die?
- Air intake question
- Speedo gear change
- Oil Pressure Problem - HELP?????
- 94 engine swap
- new gears
- anybody have these?
- o2 sensor
- funky shaking when in 2nd?
- Does anyone know the pin size on the 3.8L piston? Im ordering rods.
- FORD badge
- F150 4.2 L
- What's this thing called?
- Tinting..
- cominus
- Need some help
- Ticking under acceleration.
- What year of engines can I directly swap with my 94 V6 mustang?
- MOVED: radio
- where do i get 39# or 42# injectors?
- what can a v6 beat
- trunk vynal?
- MOVED: 97 cobra motor
- wtf????
- intakes ported i love it
- Gas Issue
- mustang vs lumina
- New vids/few snapshots (really dirty). 56k death.
- Can Oxygen sensors be fooled?
- V6 Supercharger Help
- Yellow HID's
- Chin Spoiler------Folded
- new wheels
- Stock injectors 94 3.8l?
- discount code for stangmods.com?
- Bouncing problem
- Attention all New Edge 6ers
- Blue Bulbs and HIDs colors the same?
- need CC plate advice
- ebay smoked clear corner headlights?
- paint
- passenger side exhaust hangers
- BBK Springs + CC Plates??
- Direct Bolt On's?
- Tire pressure?
- Lowering By Cutting Stock Springs on 99-04 V6 STICKY ICKY
- 4.6L Engine Swap
- Plans for this summer..
- what cam
- MOVED: mazda 3
- exhaust pics please
- trouble code P0171
- one more
- quick question
- Notthing ever seems to be a direct bolt on!!!
- X pipe
- I took some pics today
- Looking for hood scoop!
- Intake manifold spacer
- Mustang Upgrade
- Questions about Drilling out cats
- height of 4.2
- HOW TO REPLACE THE STARTER ON A 2000 V6
- This weekend
- removing cats on my V6
- will this fit?
- transmision shifter prob..!!
- uhohh....should i reconsider?
- CAI Whistle
- 95 gt tailpipes
- MOVED: Mustang vs. 07 Altima
- MOVED: fox vs 6
- Long tubes look inside Question
- Catless Pipes
- 3.8 stroker kit and procharger.. need help
- random maybe dumb idea
- Flowmaster Super 44's
- 94 V6 Vert Project car
- K&N CAI PARTS?
- i need some honest opinoins...
- Exhaust, Saleen Body Kit, Lowering Springs Questions
- Serious Transmission Problem?
- subframes again: full length vs non?
- cheapest way to remove speed limiter
- bought gt bumper/hood scoop..help
- Anyone know any good shops in MA?
- 232 emblem from autobadges
- sealing headlights
- PowerPacks?
- concept drawing for 2000 V6 Mustang, check it out... need some help too
- Where do i get a hood scoop?
- got new wheels....
- strut tower brace
- Problem with my Mustang..
- exhaust qs
- dash trim
- Speedometer
- v6 nitrous question
- car question
- Transmission Question
- 84 v6
- which one first?
- I need the P/N for a 180 degree T-Stat on a 2000 3.8L
- Which Headlights??
- Fog light help
- CAM QUESTION
- rear swap
- Side Scoops
- late model 6er in a fox
- t-top?
- Aluminium Drive Shaft
- spoilerless pics
- fuel pump
- Gaskets
- 4.2 crank
- Rear Sway bar
- which ones to buy?
- NEW HEADLIGHTS??
- v6 vs gt exhaust q
- Got the car back/ clutch issues
- cosmetic stuff fix (pics inside)
- How to remove interior peices
- sidestripe? delete it?
- UGM 1994-2004 Saleen Stainless Scuff Door Plates
- To beat a GT...
- Head rest?
- Flex tubing ?
- accident
- clutch?
- eBay HiD's
- new power steering pump, or rebuild?
- windstar intake
- Fuel Consumption
- Where to start on my V6
- Exhaust and OD Question
- cheap gears on ebay
- start up issues
- Saleen rear bumper attachment
- swaybar/subframe connectors?
