View Full Version : 6 Cyl (V6) Applications
  1. Gaskets
  2. tuner and fuel questions
  3. Couple of questions
  4. need some help !!
  5. block questions
  6. Anyone have a part number for GT hood?
  7. Photos.
  8. Mil Eliminators
  9. 2003 Mustang (automatic) question about AC and main fan
  10. Pro Damer Kit?
  11. Airbag light is on won't go off
  12. E Brake Light
  13. Will a 2000 ECU plug into a 96' ECU harness?
  14. Mach 1 Lip.. Have it shipped rolled or open?
  15. Looking for advise before buying
  16. Wrapping Headers?
  17. ENGINE PROBLEMS...PLEASE HELP!!!
  18. What do you guys think of this front lip?
  19. Lowering Springs
  20. Shaker Systerm on V6...
  21. struts
  22. Which should i chose?
  23. Helpp lost wire
  24. Which Hood??
  25. misfire problems
  26. rear end install?
  27. Some Photos
  28. "Lowered look" (pics)
  29. Service Engine Soon light came on...
  30. Headers
  31. g-force anyone?
  32. trouble codes question
  33. Which Throw out Bearing?
  34. help
  35. Want single-port boost? Eaton M90
  36. screamin demon coil with livewires or accel coil?
  37. How much is my car worth?
  38. cams on a v6
  39. Some please help going broke and stang is dead
  40. Where should i put my money?
  41. anyone know where i can get a mandrel exhaust?
  42. Few maintenance questions
  43. Engine Work for Rookie
  44. Not sure if this is where to post but..
  45. 2005 V6 diablosport/failsafe engine mode
  46. Problems shifting auto trans out of park
  47. dumbest move ever
  48. Rear Rotor Replacement
  49. will a
  50. Steering Issues-->Please Help
  51. Loud at highway speeds
  52. Just curious..
  53. power adder question
  54. DriveShaft??
  55. What Size 6 Cyl Do I Have???
  56. ENGINE PROBLEM..HELP!!!
  57. Side Exit Exhaust
  58. egr tube
  59. my u-pull-it scores
  60. Front Control Arm Replacement
  61. Fuel Injectors..
  62. flowmaster muffler question
  63. What dangers w/ Nitrous?
  64. Replace Windsheild with tint?
  65. Cruise Control Servo & Switch
  66. Throttle Body Spacer and/or Intake Spacer
  67. Under Drive Pulley... How much is everything affected?
  68. can sombody help me please.
  69. Bit the Bullet and got a great deal.. What you think...
  70. ABS light is staying on
  71. Sounds like something is making whine noise...
  72. Got the new power steering pump on
  73. need help on power sterring pump remvoal
  74. 75w90 vs. 75w140 for gears
  75. Cabin filter
  76. new to mustang
  77. Best way to tint your window?
  78. Probably a stupid question...
  79. Doing gears.. What do I need..
  80. BBK vs MAC Intake??
  81. UDP w/ Sound System good Idea???
  82. Port and Polished Upper Intake or Windstar Kit??
  83. For the lulz
  84. Mac Headers with Magnaflow Catback?
  85. Is Throttle Body worthe it if....
  86. Engine problems. my car wont turn over. ??
  87. clank noies
  88. '94 v6 for $350, should I do it?
  89. software for sct
  90. Suspension Upgrade...
  91. what would you do with $3,000
  92. Tuner or Shocks/Struts
  93. Dyno Tune
  94. SCT SF3 POWER FLASH Mustang Tuner
  95. New edge seats in an sn95
  96. Good idea?
  97. tune question
  98. Application for a 2004 Rear End
  99. Diablosport problems- not noticing much of a gain
  100. Best Tuner
  101. Rough Ride
  102. window motor replacement advice needed
  103. "high beam indicator" wont light up when bright lights are on
  104. Exhaust Midpipe
  105. PaceSetter Headers?
  106. What mods will be most significant?
  107. source for original exhaust system?
  108. wipers wont work when blinkers are on
  109. high beam indicator possible replacement
  110. need splitport swap installed any takers?
  111. ok guys now i got a problem
  112. MIL Elims, Extenders, and EGR
  113. Shocks
  114. Few questions about V6 stock motor
  115. What gears on V6 Auto?
  116. Programmer or Intake??
  117. tlock/detriot trutrac without gears install?
  118. SHORTY HEADERS
  119. GGGreat Deal
  120. split port swap kit
  121. Blown Shock?
  122. Port and Polished upper and Lower intakes
  123. Thinking about Lt's
  124. Z-Max
  125. Fluid Change
  126. Jumpy Tach, and car
  127. 5th gear grinds...Please help!
  128. got an anooying tick
  129. Squealing Sound on 2000
  130. Pro's and Con's of PCV Deletes
  131. can you stack programmers on a car?
  132. Boss Shinoda V6?
  133. P0156 code
  134. dissapointed with my 96
  135. question about dual exhaust on V6....
  136. Quick question
  137. Need help with sisters lexus, abs and traction light flasing
  138. unlock sct
  139. exhaust re-do (headers)
  140. Mustang V6 Exhaust Adapter Kit
  141. shaker system
  142. SoCal LA Cruise 6/6/09
  143. Fuel filter change
  144. okay just got my aluminum driveshaft need tips and advice on install guys.
  145. Cruise Control
  146. Steering Problem
  147. ABS removal
  148. Black or Anthracite FR500's!? Opinions please!
  149. Fist time at the track with my new car/and old cars mods
  150. tire pressure
  151. looking for an emblem
  152. Noisy belt?
  153. Intake Manifold
  154. Antifreeze leak
  155. 95 3.8 Intake Manifold Issues
  156. Adjustable rear sway bar without a stock bar?
  157. Free Mods?
  158. 100k miles
  159. LOUD TICKING
  160. Have a problem starting
  161. couple exhaust questions
  162. V6 new exhaust question
  163. Blue Hoses
  164. 3.8L swap for a new 4.0L
  165. Anybody Else Have This Problem??
  166. help with gauge cluster
  167. can you change your timing?
  168. what should i buy next?
  169. Clear Corner Headlights ebay?
  170. 05+ Hood scoop on 94-98 hood
  171. Need Opinions
  172. Anyone wanna know what my car sounds like???
  173. Steering Column Shaft
  174. Hose right next to oil cap?
  175. Differential Pressure Sensor
  176. OBDII'S?
  177. Where to get a good Alternator?
  178. car vibrates when in 3rd gear?
  179. CAI Install
  180. Screaming Demon Coil Pack Question
  181. Cruise Control
  182. where is the best place to buy a CAI
  183. tuner vs. tuner + CAI
  184. Alternator Removal
  185. help with problem
  186. What is going on?
  187. Headlight Housing Replacement
  188. good idea bad idea?
  189. 1997 3.8L V6 Coupe
  190. Need some advice...
  191. How does this sound?
  192. Leaking water.. Help!
  193. Just put tokico blues on (review)
  194. 3.8l 5spd Transmission issues
  195. 1996 Mustang 3.8L Alternator
  196. need a good sound
  197. Im new and need help bad miss.
  198. Fuel Pump, or 02 sensors?????
  199. Noise from under the hood
  200. Car and Gear Shift Shake at Higher RPMs
  201. AWESOME!!!!
  202. Adding Exhaust
  203. V6 setup, nothing major... just a quick question.
  204. Need help!
  205. 3.8 Compression
  206. damn car problems again
  207. 66 and 67 v6 mustangs
  208. Torque on the intake manifold
  209. Torque on the intake manifold
  210. Short Shifter
  211. Short Shifter
  212. Any good
  213. wat will happen?
  214. LSD/Gears for modded '01
  215. i dropped the gas tank, couple of questions!
  216. wtf is the airbag module plug?
  217. A/C Compressor Clutch or Bearing?
  218. squeaks and rattles. and leaking radiator coolant.
  219. How does everyone else clean their engines?
  220. 1995 3.8l dipstick tube
  221. tinting
  222. What are some ways to add some quick RWHP?
  223. couple more questions
  224. fuel system questions
  225. Auto Gauges !!
  226. what turbos?
  227. Research on motor work ,need help!!!
  228. upper radiator hose
  229. Gears vs New Rear End
  230. What's that rattle?
  231. mods for looks??
  232. BBK Shorty Headers
  233. lighted visor mirror question
  234. next mod
  235. new mufflers?
  236. Clogged Heater Core
  237. Fix my Suspension please
  238. BBK Catted Midpipe on MAC Longtubes?
  239. eBay hid and smoked headlight combo??
  240. 5 speed swap almost done just a few ?????s
  241. rims rear blackout and lowered
  242. 2003 ford mustang convertible 3.8L V6 ENGINE
  243. Autocross
  244. True Dual Exhaust Help
  245. actual ford fog lights
  246. Roush rear lower CA's
  247. 2000 3.8L fuel pump prob
  248. New Rims/tires and Tailights (pics)
  249. Dragster rims
  250. louder exhaust
